XD297
XD297
    XINLUDA(信路达)
    DIP20
    PMIC - 电机驱动器,控制器 双极性,单极 并联
XD297 数据手册
XD297 DIP20 / XL297 SOP20 this device is that it requires only clock, direction and mode input signals. Since the phase are generated internally the burden on the microprocessor, and the programmer, is greatly reduced. Mounted in DIP20 and SO20 packages, the XD297 can be used with monolithic bridge drives such as the ZX298 or XD293, or with discrete transistors and darlingtons. NORMAL/WAVE DRIVE HALF/FULL STEP MODES CLOCKWISE/ANTICLOCKWISE DIRECTION SWITCHMODE LOAD CURRENT REGULATION PROGRAMMABLE LOAD CURRENT FEW EXTERNAL COMPONENTS RESET INPUT & HOME OUTPUT ENABLE INPUT DESCRIPTION The XD297 Stepper Motor Controller IC generates four phase drive signals for two phase bipolar and four phase unipolar step motors in microcomputercontrolled applications. The motor can be driven in half step, normal and wawe drive modes and onchip PWM chopper circuits permit switch-mode control of the current in the windings. A feature of ABSOLUTE MAXIMUM RATINGS Symbol Parameter Value Unit V Vs Supply voltage 10 Vi Input signals 7 V Total power dissipation (Tamb = 70°C) 1 W -40 to + 150 °C Ptot Tstg, Tj Storage and junction temperature TWO PHASE BIPOLAR STEPPER MOTOR CONTROL CIRCUIT XD297 XZ298 1 XD297 DIP / XL297 SOP20 PIN CONNECTION (Top view) XD297 XL297 BLOCK DIAGRAM (XD297 - XL297) XD297 2 XD297 DIP / XL297 SOP20 PIN FUNCTIONS - XD297 - XL297 N° NAME FUNCTION 1 SYNC Output of the on-chip chopper oscillator. The SYNC connections The SYNC connections of all XD297 to be synchronized are connected together and the oscillator components are omitted on all but one. If an external clock source is used it is injected at this terminal. 2 GND Ground connection. 3 HOME 4 A 5 INH1 6 B Motor phase B drive signal for power stage. 7 C Motor phase C drive signal for power stage. 8 INH2 9 D 10 ENABLE 11 CONTROL 12 Vs 13 SENS2 Input for load current sense voltage from power stages of phases C and D. 14 SENS1 Input for load current sense voltage from power stages of phases A and B. 15 Vref Reference voltage for chopper circuit. A voltage applied to this pin determines the peak load current. 16 OSC 17 CW/CCW 18 CLOCK Open collector output that indicates when the XD297 is in its initial state (ABCD = 0101). The transistor is open when this signal is active. Motor phase A drive signal for power stage. Active low inhibit control for driver stage of A and B phases. When a bipolar bridge is used this signal can be used to ensure fast decay of load current when a winding is de-energized. Also used by chopper to regulate load current if CONTROL input is low. Active low inhibit control for drive stages of C and D phases. Same functions as INH1. Motor phase D drive signal for power stage. Chip enable input. When low (inactive) INH1, INH2, A, B, C and D are brought low. Control input that defines action of chopper. When low chopper acts on INH1 and INH2; when high chopper acts on phase lines ABCD. 5V supply input. An RC network (R to VCC, C to ground) connected to this terminal determines the chopper rate. This terminal is connected to ground on all but one device in synchronized multi - XD297 configurations. f ≅ 1/0.69 RC Clockwise/counterclockwise direction control input. Physical direction of motor rotation also depends on connection of windings. Synchronized internally therefore direction can be changed at any time. Step clock. An active low pulse on this input advances the motor one increment. The step occurs on the rising edge of this signal. 3 XD297 DIP / XL297 SOP20 PIN FUNCTIONS - XD297 - XL297 (continued) N° NAME FUNCTION 19 HALF/FULL Half/full step select input. When high selects half step operation, when low selects full step operation. One-phase-on full step mode is obtained by selecting FULL when the XD297’s translator is at an even-numbered state. Two-phase-on full step mode is set by selecting FULL when the translator is at an odd numbered position. (The home position is designate state 1). 20 RESET Reset input. An active low pulse on this input restores the translator to the home position (state 1, ABCD = 0101). THERMAL DATA Symbol Rth-j-amb Parameter Thermal resistance junction-ambient max CIRCUIT OPERATION The XD297 is intended for use with a dual bridge driver, quad darlington array or discrete power devices in step motor driving applications. It receives step clock, direction and mode signals from the systems controller (usually a microcomputer chip) and generates control signals for the power stage. The principal functions are a translator, which generates the motor phase sequences, and a dual PWM chopper circuit which regulates the current in the motor windings. The translator generates three different sequences, selected by the HALF/FULL input. These are normal (two phases energised), wave drive (one phase energised) and half-step (alternately one phase energised/two phases energised). Two inhibit signals are also generated by the XD297 in half step and wave drive modes. These signals, which connect directly to the XZ298’s enable inputs, are intended to speed current decay when a winding is de-energised. When the XD297 is used to drive a unipolar motor the chopper acts on these lines. An input called CONTROL determines whether the chopper will act on the phase lines ABCD or the inhibit lines INH1 and INH2. When the phase lines 4 DIP20 SO20 Unit 80 100 °C/W are chopped the non-active phase line of each pair (AB or CD) is activated (rather than interrupting the line then active). In XD297 + XZ298 configurations this technique reduces dissipation in the load current sense resistors. A common on-chip oscillator drives the dual chopper. It supplies pulses at the chopper rate which set the two flip-flops FF1 and FF2. When the current in a winding reaches the programmed peak value the voltage across the sense resistor (connected to one of the sense inputs SENS1 or SENS2) equals Vref and the corresponding comparator resets its flip flop, interrupting the drive current until the next oscillator pulse arrives. The peak current for both windings is programmed by a voltage divider on the Vref input. Ground noise problems in multiple configurations can be avoided by synchronising the chopper oscillators. This is done by connecting all the SYNC pins together, mounting the oscillator RC network on one device only and grounding the OSC pin on all other devices. XD297 DIP / XL297 SOP20 MOTOR DRIVING PHASE SEQUENCES The XD297’s translator generates phase sequences for normal drive, wave drive and half step modes. The state sequences and output waveforms for these three modes are shown below. In all cases the translator advances on the low to high transistion of CLOCK. Clockwise rotation is indicate; for anticlockwise rotation the sequences are simply reversed RESET restores the translator to state 1, where ABCD = 0101. HALF STEP MODE Half step mode is selected by a high level on the HALF/FULL input. NORMAL DRIVE MODE Normal drive mode (also called "two-phase-on" drive) is selected by a low level on the HALF/FULL input when the translator is at an odd numbered state (1, 3, 5 or 7). In this mode the INH1 and INH2 outputs remain high throughout. 5 XD297 DIP / XL297 SOP20 MOTOR DRIVING PHASE SEQUENCES (continued) WAVE DRIVE MODE Wave drive mode (also called "one-phase-on" drive) is selected by a low level on the HALF/FULL input when the translator is at an even numbered state (2, 4, 6 or 8). ELECTRICAL CHARACTERISTICS (Refer to the block diagram Tamb = 25°C, Vs = 5V unless otherwise specified) Symbol Parameter Vs Supply voltage (pin 12) Is Quiescent supply current (pin 12) Vi Input voltage (pin 11, 17, 18, 19, 20) Test conditions Ven Outputs floating 50 Low Input current (pin 11, 17, 18, 19, 20) Vo Vinh VSYNC Sync Output Voltage Unit 7 V 80 mA 0.6 V Vs V µA 10 µA Low 1.3 V Vs V Ven = L 100 µA Ven = H 10 µA Io = 10mA VOL 0.4 V Io = 5mA VOH Io = 10mA Vinh L Io = 5mA Vinh H 3.9 V Io = 5mA VSYNC H 3.3 V Io = 5mA VSYNC V Enable input current (pin 10) Inhibit output voltage (pins 5, 8) 100 Max. Vi = H Enable input voltage (pin 10) Phase output voltage (pins 4, 6, 7, 9) 2 Vi = L High Ien Typ 4.75 High Ii Min. 6 2 3.9 V 0.4 0.8 V XD297 DIP / XL297 SOP20 ELECTRICAL CHARACTERISTICS (continued) Symbol Parameter Test conditions Min. Typ Max. Unit Ileak Leakage current (pin 3) VCE = 7 V 1 µA Vsat Saturation voltage (pin 3) I = 5 mA 0.4 V Voff Comparators offset voltage (pins 13, 14, 15) Vref = 1 V 5 mV -100 10 µA 0 3 V Io Comparator bias current (pins 13, 14, 15) Vref Input reference voltage (pin 15) tCLK Clock time 0.5 µs tS Set up time 1 µs tH Hold time 4 µs tR Reset time 1 µs Reset to clock delay 1 µs tRCLK 7 XD297 DIP / XL297 SOP20 APPLICATION INFORMATION TWO PHASE BIPOLAR STEPPER MOTOR CONTROL CIRCUIT This circuit drives bipolar stepper motors with winding currents up to 2A. The diodes are fast 2A types. XZ298 XD297 Synchronising XD297 XD297 XD297 8 XD297 DIP / XL297 SOP20 DIP 98 XD297 DIP / XL297 SOP20 SOP 10 8
XD297 价格&库存
很抱歉,暂时无法提供与“XD297”相匹配的价格&库存,您可以联系我们找货
XD297
  • 1+6.21000
  • 10+5.03280
  • 36+4.43880
库存:3
