XD339 DIP14 XD239 DIP14 XD2901 DIP14
XL339 SOP14 XL239 SOP14 XL2901 SOP14
FEATURES
1
Wide Supply Ranges
– Single Supply: 2 V to 36 V
(Tested to 30 V for Non-V Devices and 32 V
for V-Suffix Devices)
– Dual Supplies: ±1 V to ±18 V
(Tested to ±15 V for Non-V Devices and
±16 V for V-Suffix Devices)
Low Supply-Current Drain Independent of
Supply Voltage: 0.8 mA (Typ)
Low Input Bias Current: 25 nA (Typ)
Low Input Offset Current: 3 nA (Typ) (139)
Low Input Offset Voltage: 2 mV (Typ)
Common-Mode Input Voltage Range Includes
Ground
Differential Input Voltage Range Equal to
Maximum-Rated Supply Voltage: ±36 V
Low Output Saturation Voltage
Output Compatible With TTL, MOS, and CMOS
DESCRIPTION/ORDERING INFORMATION
These devices consist of four independent voltage comparators that are designed to operate from a single power
supply over a wide range of voltages. Operation from dual supplies also is possible, as long as the difference
between the two supplies is 2 V to 36 V, and VCC is at least 1.5 V more positive than the input common-mode
voltage. Current drain is independent of the supply voltage. The outputs can be connected to other opencollector outputs to achieve wired-AND relationships.
The XD239 and XL239 are characterized for operation from –25°C to 125°C. The XD339 and XL339
are characterized for operation from 0°C to 70°C. The 2901 are characterized for
operation from –40°C to 125°C.
1OUT
2OUT
VCC
2IN2IN+
1IN1IN+
1
1
14
2
13
3
12
4
11
5
10
6
9
7
8
OUT3
OUT4
GND
4IN+
4IN3IN+
3IN-
SYMBOL (EACH COMPARATOR)
IN+
OUT
IN−
SCHEMATIC (EACH COMPARATOR)
VCC
80-µA
Current
Regulator
10 µA
60 µA
10 µA
80 µA
IN+
OUT
IN−
GND
All current values shown are nominal.
2
ABSOLUTE MAXIMUM RATINGS (1)
over operating free-air temperature range (unless otherwise noted)
MIN
(2)
VCC
Supply voltage
VID
Differential input voltage (3)
VI
Input voltage range (either input)
VO
Output voltage
IO
Output current
–0.3
Duration of output short circuit to ground (4)
θJA
θJC
TJ
Tstg
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
UNIT
36
V
±36
V
36
V
36
V
mA
Unlimited
Package thermal impedance, junction to free air (5)
Package thermal impedance, junction to case (7)
MAX
(6)
(8)
D package
86
DB package
96
N package
80
NS package
76
PW package
113
FK package
5.61
J package
15.05
W package
14.65
Operating virtual-junction temperature
°C/W
°C/W
150
°C
Case temperature for 60 s
FK package
260
°C
Lead temperature 1,6 mm (1/16 in) from case for 60 s
J package
300
°C
150
°C
Storage temperature range
–65
Stresses beyond those listed under "absolute maximum ratings" may cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any other conditions beyond those indicated under "recommended operating
conditions" is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
All voltage values, except differential voltages, are with respect to network ground.
Differential voltages are at IN+ with respect to IN–.
Short circuits from outputs to VCC can cause excessive heating and eventual destruction.
Maximum power dissipation is a function of TJ (max), θJA, and TA. The maximum allowable power dissipation at any allowable ambient
temperature is PD = (TJ (max) – TA)/θJA. Operating at the absolute maximum TJ of 150°C can affect reliability.
The package thermal impedance is calculated in accordance with JESD 51-7.
Maximum power dissipation is a function of TJ (max), θJC, and TC. The maximum allowable power dissipation at any allowable case
temperature is PD = (TJ (max) – TC)/θJC. Operating at the absolute maximum TJ of 150°C can affect reliability.
The package thermal impedance is calculated in accordance with MIL-STD-883.
3
ELECTRICAL CHARACTERISTICS
at specified free-air temperature, VCC = 5 V (unless otherwise noted)
TEST CONDITIONS (1)
PARAMETER
TA
XD239
XD339
(2)
MIN
VIO
Input offset voltage
VCC = 5 V to 30 V,
VIC = VICR min,
VO = 1.4 V
IIO
Input offset current
VO = 1.4 V
IIB
Input bias current
VO = 1.4 V
VICR
Common-mode inputvoltage range (3)
2
Full range
25°C
5
25°C
IOH
High-level output current
VID = 1 V
VOL
Low-level output voltage
VID = –1 V,
IOL = 4 mA
IOL
Low-level output current
VID = –1 V,
VOL = 1.5 V
25°C
ICC
Supply current
(four comparators)
VO = 2.5 V,
No load
25°C
25°C
VOH = 30 V
Full range
50
5
–25 –250
–25 –250
–400
–400
0 to
–2
50
VCC
200
0.1
50
50
150
Full range
200
0.1
400
150
700
6
16
0.8
2
nA
nA
V/mV
50
nA
1
μA
400
700
6
mV
V
1
25°C
50
150
0 to
–2
VCC
3
4
0 to
VCC – 1.5
25°C
VOH = 5 V
1
0 to
VCC – 1.5
Full range
Large-signal differentialvoltage amplification
5
UNIT
TYP MAX
150
Full range
25°C
MIN
9
Full range
AVD
(3)
TYP MAX
25°C
VCC = 15 V,
VO = 1.4 V to 11.4 V,
RL ≥ 15 kΩ to VCC
(1)
(2)
XL239
XL339
16
0.8
mV
mA
2
mA
All characteristics are measured with zero common-mode input voltage, unless otherwise specified.
Full range (MIN to MAX) for XD239/XL239 is –25°C to 85°C, and for XD339/XL339 is 0°C to 70°C. All characteristics are measured
The voltage at either input or common-mode should not be allowed to go negative by more than 0.3 V. The upper end of the commonmode voltage range is VCC+ – 1.5 V; however, one input can exceed VCC, and the comparator will provide a proper output state as long
as the other input remains in the common-mode range. Either or both inputs can go to 30 V without damage.
SWITCHING CHARACTERISTICS
VCC = 5 V, TA = 25°C
PARAMETER
TEST CONDITIONS
XD239
XL239
XD339
XL339
UNIT
TYP
Response time
(1)
(2)
RL connected to 5 V through 5.1 kΩ,
CL = 15 pF (1) (2)
100-mV input step with 5-mV overdrive
1.3
TTL-level input step
0.3
CL includes probe and jig capacitance.
The response time specified is the interval between the input step function and the instant when the output crosses 1.4 V.
4
μs
TEST CONDITIONS (1)
PARAMETER
VIO
Non-A devices
VIC = VICR min,
VO = 1.4 V,
VCC = 5 V to MAX (3)
IIO
VO = 1.4 V
IIB
Input bias current
VO = 1.4 V
VICR
Common-mode inputvoltage range (4)
TA
A-suffix devices
MAX
2
15
25°C
1
2
5
50
Full range
Full range
IOH
VID = 1 V
VID = –1 V,
IOL = 4 mA
25°C
VOH = 5 V
VOH = VCC MAX (3)
Non-V devices
V-suffix devices
200
–25
VID = –1 V,
VOL = 1.5 V
ICC
Supply current
(four comparators)
VO = 2.5 V,
No load
VCC = 5 V
VCC = MAX (3)
0 to
VCC – 1.5
VCC
25
nA
nA
V
0 to
–2
100
V/mV
0.1
25°C
25°C
–500
25°C
Full range
IOL
–250
Full range
All devices
mV
4
25°C
25°C
UNIT
7
Full range
Full range
AVD
(3)
(4)
25°C
TYP
Full range
VCC = 15 V, VO = 1.4 V to 11.4 V,
RL ≥ 15 kΩ to VCC
(1)
(2)
MIN
25°C
VOL
2901
(2)
50
nA
1
μA
150
500
150
400
mV
700
6
25°C
16
mA
0.8
2
1
2.5
mA
Full range (MIN to MAX) for 2901 is –40°C to 125°C. All characteristics are measured with zero common-mode input voltage, unless
VCC MAX = 30 V for non-V devices, and 32 V for V-suffix devices
as the other input remains in the common-mode range. Either or both inputs can go to VCC MAX without damage.
PARAMETER
Response time
(1)
(2)
TEST CONDITIONS
CL = 15 pF (1) (2)
2901
TYP
1.3
0.3
5
UNIT
μs
TYPICAL CHARACTERISTICS
SUPPLY CURRENT
vs
SUPPLY VOLTAGE
INPUT BIAS CURRENT
vs
SUPPLY VOLTAGE
80
1.8
1.6
IIN – Input Bias Current – nA
1.4
TA = 25°C
TA = 0°C
1.2
1
TA = 70°C
0.8
TA = 125°C
0.6
0.4
TA = –55°C
60
TA = 0°C
50
TA = 25°C
40
TA = 70°C
30
TA = 125°C
0.2
10
15
30
35
VCC – Supply Voltage – V
10
15
OUTPUT SATURATION VOLTAGE
10
VO – Saturation Voltage – V
ICC – Supply Current – mA
70
TA = –55°C
1
TA = 125°C
TA = 25°C
0.1
TA = –55°C
0.01
0.001
0.01
0.1
1
10
IO – Output Sink Current – mA
6
100
30
35
TYPICAL CHARACTERISTICS (continued)
RESPONSE TIME FOR VARIOUS OVERDRIVES
NEGATIVE TRANSITION
POSITIVE TRANSITION
6
6
5
5
VO – Output Voltage – V
Overdrive = 5 mV
4
Overdrive = 20 mV
3
Overdrive = 100 mV
2
1
-0.3
Overdrive = 5 mV
4
Overdrive = 20 mV
3
Overdrive = 100 mV
2
1
1
1.25 1.5 1.75
2
-1
-0.3
2.25
t – Time – µs
1
1.25 1.5 1.75
t – Time – µs
7
2
2.25
78
很抱歉,暂时无法提供与“XD2901”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.90083
- 50+0.69023
- 150+0.59800
- 500+0.52877
