XD2543N
XD2543N
    XINLUDA(信路达)
    SOP-16
    XD2543N
XD2543N 数据手册
XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 D D D D D D D D D D D D D 12-Bit-Resolution A/D Converter 10-µs Conversion Time Over Operating Temperature 11 Analog Input Channels 3 Built-In Self-Test Modes Inherent Sample-and-Hold Function Linearity Error . . . ± 1 LSB Max On-Chip System Clock End-of-Conversion Output Unipolar or Bipolar Output Operation (Signed Binary With Respect to 1/2 the Applied Voltage Reference) Programmable MSB or LSB First Programmable Power Down Programmable Output Data Length CMOS Technology DIP/SOP/SSOP (TOP VIEW) AIN0 AIN1 AIN2 AIN3 AIN4 AIN5 AIN6 AIN7 AIN8 GND description 1 20 2 19 3 18 4 17 5 16 6 15 7 14 8 13 9 12 10 11 VCC EOC I/O CLOCK DATA INPUT DATA OUT CS REF + REF – AIN10 AIN9 The 2543 are 12-bit, switched- capacitor, successive-approximation, analog-todigital converters. Each device, with three control inputs [chip select (CS), the input-output clock, and the address input (DATA INPUT)], is designed for communication with the serial port of a host processor or peripheral through a serial 3-state output. The device allows high-speed data transfers from the host. In addition to the high-speed converter and versatile control capability, the device has an on-chip 14-channel multiplexer that can select any one of 11 inputs or any one of three internal self-test voltages. The sample-and-hold function is automatic. At the end of conversion, the end-of-conversion (EOC) output goes high to indicate that conversion is complete. The converter incorporated in the device features differential high-impedance reference inputs that facilitate ratiometric conversion, scaling, and isolation of analog circuitry from logic and supply noise. A switched-capacitor design allows low-error conversion over the full operating temperature range. 1 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 AVAILABLE OPTIONS PACKAGE TA DIP – 40°C to 85°C SOP SSOP XL2543 XD2543N XL2543-SS functional block diagram AIN0 AIN1 AIN2 AIN3 AIN4 AIN5 AIN6 AIN7 AIN8 AIN9 AIN10 1 2 3 4 5 6 7 8 9 11 12 REF + REF – 14 13 12-Bit Analog-to-Digital Converter (Switched Capacitors) Sample-andHold Function 14-Channel Analog Multiplexer 12 4 Output Data Register Input Address Register 12 12-to-1 Data Selector and Driver 16 DATA OUT 4 3 Control Logic and I/O Counters Self-Test Reference 19 DATA INPUT I/O CLOCK CS 17 18 15 2 EOC XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 Terminal Functions TERMINAL I/O DESCRIPTION 1 – 9, 11, 12 I Analog input. These 11 analog-signal inputs are internally multiplexed. The driving source impedance should be less than or equal to 50 Ω for 4.1-MHz I/O CLOCK operation and be capable of slewing the analog input voltage into a capacitance of 60 pF. CS 15 I Chip select. A high-to-low transition on CS resets the internal counters and controls and enables DATA OUT, DATA INPUT, and I/O CLOCK. A low-to-high transition disables DATA INPUT and I/O CLOCK within a setup time. DATA INPUT 17 I Serial-data input. A 4-bit serial address selects the desired analog input or test voltage to be converted next. The serial data is presented with the MSB first and is shifted in on the first four rising edges of I/O CLOCK. After the four address bits are read into the address register, I/O CLOCK clocks the remaining bits in order. DATA OUT 16 O The 3-state serial output for the A/D conversion result. DATA OUT is in the high-impedance state when CS is high and active when CS is low. With a valid CS, DATA OUT is removed from the high-impedance state and is driven to the logic level corresponding to the MSB/LSB† value of the previous conversion result. The next falling edge of I/O CLOCK drives DATA OUT to the logic level corresponding to the next MSB / LSB, and the remaining bits are shifted out in order. EOC 19 O End of conversion. EOC goes from a high to a low logic level after the falling edge of the last I/O CLOCK and remains low until the conversion is complete and the data is ready for transfer. GND 10 I/O CLOCK 18 I Input /output clock. I/O CLOCK receives the serial input and performs the following four functions: 1. It clocks the eight input data bits into the input data register on the first eight rising edges of I/O CLOCK with the multiplexer address available after the fourth rising edge. 2. On the fourth falling edge of I/O CLOCK, the analog input voltage on the selected multiplexer input begins charging the capacitor array and continues to do so until the last falling edge of the I/O CLOCK. 3. It shifts the 11 remaining bits of the previous conversion data out on DATA OUT. Data changes on the falling edge of I/O CLOCK. 4. It transfers control of the conversion to the internal state controller on the falling edge of the last I/O CLOCK. REF + 14 I Positive reference voltage The upper reference voltage value (nominally VCC) is applied to REF+. The maximum input voltage range is determined by the difference between the voltage applied to this terminal and the voltage applied to the REF – terminal. REF – 13 I Negative reference voltage. The lower reference voltage value (nominally ground) is applied to REF –. NAME NO. AIN0 – AIN10 Ground. GND is the ground return terminal for the internal circuitry. Unless otherwise noted, all voltage measurements are with respect to GND. VCC 20 Positive supply voltage † MSB/LSB = Most significant bit / least significant bit 3 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage range, VCC (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . – 0.5 V to 6.5 V Input voltage range, VI (any input) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . – 0.3 V to VCC + 0.3 V Output voltage range, VO . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . – 0.3 V to VCC + 0.3 V Positive reference voltage, Vref + . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . VCC + 0.1 V Negative reference voltage, Vref – . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . – 0.1 V Peak input current, II (any input) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ± 20 mA Peak total input current, II (all inputs) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ± 30 mA Operating free-air temperature range, TA: 2543 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0 °C to 70°C 2543 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . – 40°C to 85°C Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . – 65°C to 150°C Lead temperature 1,6 mm (1/16 inch) from the case for 10 seconds . . . . . . . . . . . . . . . . . . . . . . . . . . . . 260°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTE 1: All voltage values are with respect to the GND terminal with REF – and GND wired together (unless otherwise noted). recommended operating conditions Supply voltage, VCC MIN NOM MAX 4.5 5 5.5 Positive reference voltage, Vref + (see Note 2) VCC 0 Negative reference voltage, Vref – (see Note 2) Differential reference voltage, Vref + – Vref – (see Note 2) 2.5 Analog input voltage (see Note 2) 0 High-level control input voltage, VIH VCC = 4.5 V to 5.5 V VCC = 4.5 V to 5.5 V Low-level control input voltage, VIL Clock frequency at I/O CLOCK Hold time, address bits after I/O CLOCK↑, th(A) (see Figure 4) Hold time, CS low after last I/O CLOCK↓, th(CS) (see Figure 5) V V V VCC + 0.1 VCC 2 0 Setup time, address bits at DATA INPUT before I/O CLOCK↑, tsu(A) (see Figure 4) VCC UNIT V V V 0.8 V 4.1 MHz 100 ns 0 ns 0 ns 1.425 µs Pulse duration, I/O CLOCK high, twH(I/O) 120 ns Pulse duration, I/O CLOCK low, twL(I/O) 120 Setup time, CS low before clocking in first address bit, tsu(CS) (see Note 3 and Figure 5) Transition time, I/O CLOCK high to low, tt(I/O) (see Note 4 and Figure 6) Transition time, DATA INPUT and CS, tt(CS) Operating free-air temperature, TA ns 1 µs 10 µs 2543 0 70 2543 – 40 85 °C NOTES: 2. Analog input voltages greater than that applied to REF+ convert as all ones (111111111111), while input voltages less than that applied to REF– convert as all zeros (000000000000). 3. To minimize errors caused by noise at the CS input, the internal circuitry waits for a setup time after CS↓ before responding to control input signals. No attempt should be made to clock in an address until the minimum CS setup time has elapsed. 4. This is the time required for the clock input signal to fall from VIHmin to VILmax or to rise from VILmax to VIHmin. In the vicinity of normal room temperature, the devices function with input clock transition time as slow as 1 µs for remote data acquisition applications where the sensor and the A/D converter are placed several feet away from the controlling microprocessor. 4 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 electrical characteristics over recommended operating free-air temperature range, VCC = Vref+ = 4.5 V to 5.5 V, f(I/O CLOCK) = 4.1 MHz (unless otherwise noted) PARAMETER TEST CONDITIONS MIN 2543 TYP† MAX VOH High level output voltage High-level VCC = 4.5 V, VCC = 4.5 V to 5.5 V, IOH = –1.6 mA IOH = –20 µA VOL Low level output voltage Low-level VCC = 4.5 V, VCC = 4.5 V to 5.5 V, IOL = 1.6 mA IOL = 20 µA IOZ High-impedance g off-state output current VO = VCC, VO = 0, CS at VCC 1 2.5 CS at VCC 1 – 2.5 IIH IIL High-level input current 1 2.5 Low-level input current VI = VCC VI = 0 1 – 2.5 µA ICC Operating supply current CS at 0 V 1 2.5 mA ICC(PD) Power-down current For all digital inputs, 0 ≤ VI ≤ 0.5 V or VI ≥ VCC – 0.5 V 4 25 µA Selected channel leakage current Maximum static analog reference current into REF + Ci Input capacitance Selected channel at VCC, 2.4 UNIT V VCC – 0.1 0.4 0.1 Unselected channel at 0 V –1 Vref – = GND 1 2.5 Analog inputs 30 60 Control inputs 5 15 † All typical values are at VCC = 5 V, TA = 25°C. 5 µA µA 1 Selected channel at 0 V, Unselected channel at VCC Vref + = VCC, V µA µA pF XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 operating characteristics over recommended operating free-air temperature range, VCC = Vref+ = 4.5 V to 5.5 V, f(I/O CLOCK) = 4.1 MHz PARAMETER TEST CONDITIONS MIN TYP† MAX UNIT Linearity error (see Note 5) See Figure 2 ±1 LSB Differential linearity error See Figure 2 ±1 LSB EO Offset error (see Note 6) See Note 2 and Figure 2 ± 1.5 LSB EG Gain error (see Note 6) See Note 2 and Figure 2 ±1 LSB ET Total unadjusted error (see Note 7) ± 1.75 LSB EL ED Self-test output code (see Table 3 and Note 8) t(conv) Conversion time DATA INPUT = 1011 2048 DATA INPUT = 1100 0 DATA INPUT = 1101 4095 See Figures 9 – 14 8 10 10 + total I/O CLOCK periods + td(I/O-EOC) µs tc Total cycle time (access, sample, and conversion) See Figures 9 – 14 and Note 9 tacq Channel acquisition time (sample) See Figures 9 – 14 and Note 9 tv td(I/O-DATA) Valid time, DATA OUT remains valid after I/O CLOCK↓ See Figure 6 Delay time, I/O CLOCK↓ to DATA OUT valid See Figure 6 td(I/O-EOC) td(EOC-DATA) Delay time, last I/O CLOCK↓ to EOC↓ See Figure 7 Delay time, EOC↑ to DATA OUT (MSB / LSB) See Figure 8 100 ns tPZH, tPZL tPHZ, tPLZ Enable time, CS↓ to DATA OUT (MSB / LSB driven) See Figure 3 0.7 1.3 µs Disable time, CS↑ to DATA OUT (high impedance) See Figure 3 70 150 ns tr(EOC) tf(EOC) Rise time, EOC See Figure 8 15 50 ns Fall time, EOC See Figure 7 15 50 ns tr(bus) tf(bus) Rise time, data bus See Figure 6 15 50 ns Fall time, data bus See Figure 6 15 50 ns 5 µs td(I/O-CS) Delay time, last I/O CLOCK↓ to CS↓ to abort conversion (see Note 10) 4 12 10 µs I/O CLOCK periods ns 1.5 150 ns 2.2 µs † All typical values are at TA = 25°C. NOTES: 2. Analog input voltages greater than that applied to REF + convert as all ones (111111111111), while input voltages less than that applied to REF – convert as all zeros (000000000000). 5. Linearity error is the maximum deviation from the best straight line through the A/D transfer characteristics. 6. Gain error is the difference between the actual midstep value and the nominal midstep value in the transfer diagram at the specified gain point after the offset error has been adjusted to zero. Offset error is the difference between the actual midstep value and the nominal midstep value at the offset point. 7. Total unadjusted error comprises linearity, zero-scale, and full-scale errors. 8. Both the input address and the output codes are expressed in positive logic. 9. I/O CLOCK period = 1 /(I/O CLOCK frequency) (see Figure 7). 10. Any transitions of CS are recognized as valid only when the level is maintained for a setup time. CS must be taken low at ≤ 5 µs of the tenth I/O CLOCK falling edge to ensure a conversion is aborted. Between 5 µs and 10 µs, the result is uncertain as to whether the conversion is aborted or the conversion results are valid. 6 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PARAMETER MEASUREMENT INFORMATION 15 V 50 Ω C1 10 µF C2 0.1 µF C3 470 pF 10 Ω _ U1 + VI C1 10 µF 2543 AIN0 – AIN10 C3 470 pF C2 0.1 µF 50 Ω – 15 V LOCATION DESCRIPTION U1 C1 C2 C3 PART NUMBER OP27 10-µF 35-V tantalum capacitor 0.1-µF ceramic NPO SMD capacitor 470-pF porcelain Hi-Q SMD capacitor — — AVX 12105C104KA105 or equivalent Johanson 201S420471JG4L or equivalent Figure 1. Analog Input Buffer to Analog Inputs AIN0 – AIN10 VCC Test Point VCC Test Point RL = 2.18 kΩ RL = 2.18 kΩ EOC DATA OUT CL = 50 pF 12 kΩ 12 kΩ CL = 100 pF Figure 2. Load Circuits Data Valid 2V CS tPZH, tPZL DATA OUT 2V 0.8 V DATA INPUT 0.8 V tPHZ, tPLZ 2.4 V 90% 0.4 V 10% th(A) tsu(A) I/O CLOCK 0.8 V Figure 4. DATA INPUT and I/O CLOCK Voltage Waveforms Figure 3. DATA OUT to Hi-Z Voltage Waveforms 7 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PARAMETER MEASUREMENT INFORMATION 2V CS 0.8 V tsu(CS) I/O CLOCK th(CS) Last Clock 0.8 V 0.8 V NOTE A: To ensure full conversion accuracy, it is recommended that no input signal change occurs while a conversion is ongoing. Figure 5. CS and I/O CLOCK Voltage Waveforms tt(I/O) tt(I/O) I/O CLOCK 2V 2V 0.8 V 0.8 V 0.8 V I/O CLOCK Period td(I/O-DATA) tv DATA OUT 2.4 V 0.4 V 2.4 V 0.4 V tr(bus), tf(bus) Figure 6. I/O CLOCK and DATA OUT Voltage Waveforms I/O CLOCK Last Clock 0.8 V td(I/O-EOC) 2.4 V EOC 0.4 V tf(EOC) Figure 7. I/O CLOCK and EOC Voltage Waveforms tr(EOC) EOC 2.4 V 0.4 V td(EOC-DATA) 2.4 V 0.4 V DATA OUT Valid MSB Figure 8. EOC and DATA OUT Voltage Waveforms 8 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PARAMETER MEASUREMENT INFORMATION CS (see Note A) I/O CLOCK 1 2 3 4 5 6 Access Cycle B 8 11 12 Sample Cycle B ÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ 1 Hi-Z State DATA OUT A11 A10 A9 A8 A7 A6 A5 A4 A1 A0 Previous Conversion Data ÎÎÎ ÎÎ ÎÎ Î Î Î ÎÎ ÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎ Î ÎÎÎÎÎÎÎÎ MSB DATA INPUT 7 B7 B6 B5 B4 MSB B3 B2 B1 B11 ÎÎ ÎÎ ÎÎÎÎ LSB C7 B0 LSB EOC t(conv) Shift in New Multiplexer Address, Simultaneously Shift Out Previous Conversion Value A/D Conversion Interval Initialize Initialize NOTE A: To minimize errors caused by noise at CS, the internal circuitry waits for a setup time after CS↓ before responding to control input signals. Therefore, no attempt should be made to clock in an address until the minimum CS setup time has elapsed. Figure 9. Timing for 12-Clock Transfer Using CS With MSB First CS (see Note A) I/O CLOCK 1 2 3 4 5 6 Access Cycle B DATA OUT A11 A10 A9 8 11 A8 A7 A6 A5 A4 A1 ÎÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ B7 B6 MSB B5 12 1 Sample Cycle B Previous Conversion Data MSB DATA INPUT 7 B4 B3 B2 B1 A0 B11 Low Level ÎÎÎ ÎÎ ÎÎÎ ÎÎ ÎÎÎÎÎ LSB C7 B0 LSB EOC Shift in New Multiplexer Address, Simultaneously Shift Out Previous Conversion Value Initialize t(conv) A/D Conversion Interval Initialize NOTE A: To minimize errors caused by noise at CS, the internal circuitry waits for a setup time after CS↓ before responding to control input signals. Therefore, no attempt should be made to clock in an address until the minimum CS setup time has elapsed. Figure 10. Timing for 12-Clock Transfer Not Using CS With MSB First 9 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PARAMETER MEASUREMENT INFORMATION CS (see Note A) 1 I/O CLOCK 2 3 4 5 Access Cycle B A7 DATA OUT A6 A5 7 ÎÎÎÎÎÎ ÎÎÎÎÎÎ 8 Sample Cycle B A4 A3 A2 A1 Previous Conversion Data Hi-Z A0 1 B7 ÎÎÎ ÎÎ ÎÎ Î Î Î ÎÎ ÎÎ ÎÎÎÎÎ ÎÎÎ ÎÎ ÎÎÎÎÎÎÎÎ Î ÎÎÎÎÎÎÎÎÎÎ ÎÎÎÎÎ MSB DATA INPUT 6 B7 B6 B5 B4 MSB B3 LSB B2 B1 B0 C7 LSB EOC Shift in New Multiplexer Address, Simultaneously Shift Out Previous Conversion Value t(conv) A/D Conversion Interval Initialize Initialize NOTE A: To minimize errors caused by noise at CS, the internal circuitry waits for a setup time after CS↓ before responding to control input signals. Therefore, no attempt should be made to clock in an address until the minimum CS setup time has elapsed. Figure 11. Timing for 8-Clock Transfer Using CS With MSB First CS (see Note A) 1 I/O CLOCK 2 3 4 5 Access Cycle B DATA OUT A7 A6 A5 7 8 1 Sample Cycle B A4 A3 A2 A1 Previous Conversion Data A0 Low Level ÎÎÎ ÎÎ Î Î ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎÎÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎ MSB DATA INPUT 6 B7 MSB B6 B5 B4 B3 B2 ÎÎ ÎÎ ÎÎÎÎ LSB B1 B7 C7 B0 LSB EOC Shift in New Multiplexer Address, Simultaneously Shift Out Previous Conversion Value Initialize t(conv) A/D Conversion Interval Initialize NOTE A: To minimize errors caused by noise at CS, the internal circuitry waits for a setup time after CS↓ before responding to control input signals. Therefore, no attempt should be made to clock in an address until the minimum CS setup time has elapsed. Figure 12. Timing for 8-Clock Transfer Not Using CS With MSB First 10 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PARAMETER MEASUREMENT INFORMATION CS (see Note A) I/O CLOCK 1 2 3 4 5 6 Access Cycle B 7 8 15 16 Sample Cycle B ÎÎÎÎÎÎÎ ÎÎÎÎÎÎÎ 1 Hi-Z State DATA OUT A15 A14 A13 A12 A11 A10 A9 A8 A1 A0 ÎÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ Previous Conversion Data MSB B15 ÎÎ ÎÎÎ LSB DATA INPUT B7 B6 B5 B3 B4 MSB B2 B1 B0 C7 LSB EOC t(conv) Shift in New Multiplexer Address, Simultaneously Shift Out Previous Conversion Value A/D Conversion Interval Initialize Initialize NOTE A: To minimize errors caused by noise at CS, the internal circuitry waits for a setup time after CS↓ before responding to control input signals. Therefore, no attempt should be made to clock in an address until the minimum CS setup time has elapsed. Figure 13. Timing for 16-Clock Transfer Using CS With MSB First CS (see Note A) I/O CLOCK 1 2 3 4 5 6 Access Cycle B DATA OUT A15 A14 A13 7 8 15 1 Sample Cycle B A12 A11 A10 A9 A8 A1 ÎÎ Î ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎ ÎÎÎÎÎÎÎÎÎÎÎÎÎÎÎ Previous Conversion Data MSB 16 A0 Low Level ÎÎÎÎ Î ÎÎÎÎÎ LSB DATA INPUT B7 MSB B6 B5 B4 B3 B2 B1 B15 B0 C7 LSB EOC Shift in New Multiplexer Address, Simultaneously Shift Out Previous Conversion Value Initialize t(conv) A/D Conversion Interval NOTE A: To minimize errors caused by noise at CS, the internal circuitry waits for a setup time after CS↓ before responding to control input signals. Therefore, no attempt should be made to clock in an address until the minimum CS setup time has elapsed. Figure 14. Timing for 16-Clock Transfer Not Using CS With MSB First 11 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PRINCIPLES OF OPERATION Initially, with chip select (CS) high, I/O CLOCK and DATA INPUT are disabled and DATA OUT is in the high-impedance state. CS going low begins the conversion sequence by enabling I/O CLOCK and DATA INPUT and removes DATA OUT from the high-impedance state. The input data is an 8-bit data stream consisting of a 4-bit analog channel address (D7 – D4), a 2-bit data length select (D3 – D2), an output MSB or LSB first bit (D1), and a unipolar or bipolar output select bit (D0) that are applied to DATA INPUT. The I/O CLOCK sequence applied to the I/O CLOCK terminal transfers this data to the input data register. During this transfer, the I/O CLOCK sequence also shifts the previous conversion result from the output data register to DATA OUT. I/O CLOCK receives the input sequence of 8, 12, or 16 clock cycles long depending on the data-length selection in the input data register. Sampling of the analog input begins on the fourth falling edge of the input I/O CLOCK sequence and is held after the last falling edge of the I/O CLOCK sequence. The last falling edge of the I/O CLOCK sequence also takes EOC low and begins the conversion. converter operation The operation of the converter is organized as a succession of two distinct cycles: 1) the I/O cycle and 2) the actual conversion cycle. I/O cycle The I/O cycle is defined by the externally provided I/O CLOCK and lasts 8, 12, or 16 clock periods, depending on the selected output data length. During the I/O cycle, the following two operations take place simultaneously. An 8-bit data stream consisting of address and control information is provided to DATA INPUT. This data is shifted into the device on the rising edge of the first eight I/O CLOCKs. DATA INPUT is ignored after the first eight clocks during 12- or 16-clock I/O transfers. The data output, with a length of 8, 12, or 16 bits, is provided serially on DATA OUT. When CS is held low, the first output data bit occurs on the rising edge of EOC. When CS is negated between conversions, the first output data bit occurs on the falling edge of CS. This data is the result of the previous conversion period, and after the first output data bit, each succeeding bit is clocked out on the falling edge of each succeeding I/O CLOCK. conversion cycle The conversion cycle is transparent to the user, and it is controlled by an internal clock synchronized to I/O CLOCK. During the conversion period, the device performs a successive-approximation conversion on the analog input voltage. The EOC output goes low at the start of the conversion cycle and goes high when conversion is complete and the output data register is latched. A conversion cycle is started only after the I/O cycle is completed, which minimizes the influence of external digital noise on the accuracy of the conversion. 12 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PRINCIPLES OF OPERATION power up and initialization After power up, CS must be taken from high to low to begin an I/O cycle. EOC is initially high, and the input data register is set to all zeroes. The contents of the output data register are random, and the first conversion result should be ignored. To initialize during operation, CS is taken high and is then returned low to begin the next I/O cycle. The first conversion after the device has returned from the power-down state may not read accurately due to internal device settling. Table 1. Operational Terminology Current (N) I/O cycle The entire I/O CLOCK sequence that transfers address and control data into the data register and clocks the digital result from the previous conversion from DATA OUT Current (N) conversion cycle The conversion cycle starts immediately after the current I/O cycle. The end of the current I/O cycle is the last clock falling edge in the I/O CLOCK sequence. The current conversion result is loaded into the output register when conversion is complete. Current (N) conversion result The current conversion result is serially shifted out on the next I/O cycle. Previous (N – 1) conversion cycle The conversion cycle just prior to the current I/O cycle Next (N + 1) I/O cycle The I/O period that follows the current conversion cycle Example: In the 12-bit mode, the result of the current conversion cycle is a 12-bit serial-data stream clocked out during the next I/O cycle. The current I/O cycle must be exactly 12 bits long to maintain synchronization, even when this corrupts the output data from the previous conversion. The current conversion is begun immediately after the twelfth falling edge of the current I/O cycle. 13 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PRINCIPLES OF OPERATION data input The data input is internally connected to an 8-bit serial-input address and control register. The register defines the operation of the converter and the output data length. The host provides the data word with the MSB first. Each data bit is clocked in on the rising edge of the I/O CLOCK sequence (see Table 2 for the data input-register format). Table 2. Input-Register Format INPUT DATA BYTE ADDRESS BITS FUNCTION SELECT Select input channel AIN0 AIN1 AIN2 AIN3 AIN4 AIN5 AIN6 AIN7 AIN8 AIN9 AIN10 Select test voltage (Vref + – Vref –)/2 Vref – Vref + Software power down D7 (MSB) D6 D5 D4 0 0 0 0 0 0 0 0 1 1 1 0 0 0 0 1 1 1 1 0 0 0 0 0 1 1 0 0 1 1 0 0 1 0 1 0 1 0 1 0 1 0 1 0 1 1 1 0 1 1 1 0 0 1 0 1 1 1 1 0 Output data length 8 bits 12 bits 16 bits Output data format MSB first LSB first (LSBF) L1 L0 LSBF BIP D3 D2 D1 D0 (LSB) 0 X† 1 1 0 1 0 1 Unipolar (binary) 0 Bipolar (BIP) 2s complement 1 † X represents a do not care condition. data input address bits The four MSBs (D7 – D4) of the data register address one of the 11 input channels, a reference-test voltage, or the power-down mode. The address bits affect the current conversion, which is the conversion that immediately follows the current I/O cycle. The reference voltage is nominally equal to Vref+ – Vref –. 14 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PRINCIPLES OF OPERATION analog input, test, and power-down mode The 11 analog inputs, three internal voltages, and power-down mode are selected by the input multiplexer according to the input addresses shown in Tables 2, 3, and 4. The input multiplexer is a break-before-make type to reduce input-to-input noise rejection resulting from channel switching. Sampling of the analog input starts on the falling edge of the fourth I/O CLOCK and continues for the remaining I/O CLOCK pulses. The sample is held on the falling edge of the last I/O CLOCK pulse. The three internal test inputs are applied to the multiplexer, then sampled and converted in the same manner as the external analog inputs. The first conversion after the device has returned from the power-down state may not read accurately due to internal device settling. Table 3. Analog-Channel-Select Address VALUE SHIFTED INTO DATA INPUT ANALOG INPUT SELECTED BINARY HEX AIN0 0000 0 AIN1 0001 1 AIN2 0010 2 AIN3 0011 3 AIN4 0100 4 AIN5 0101 5 AIN6 0110 6 AIN7 0111 7 AIN8 1000 8 AIN9 1001 9 AIN10 1010 A Table 4. Test-Mode-Select Address INTERNAL SELF-TEST VOLTAGE SELECTED† VALUE SHIFTED INTO DATA INPUT BINARY HEX 1011 B Vref + – Vref – 2 UNIPOLAR OUTPUT RESULT (HEX)‡ 800 Vref – 1100 C 000 Vref + 1101 D FFF † Vref + is the voltage applied to REF +, and Vref – is the voltage applied to REF –. ‡ The output results shown are the ideal values and may vary with the reference stability and with internal offsets. Table 5. Power-Down-Select Address INPUT COMMAND Power down VALUE SHIFTED INTO DATA INPUT BINARY HEX 1110 E 15 RESULT ICC ≤ 25 µA XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 PRINCIPLES OF OPERATION converter and analog input The CMOS threshold detector in the successive-approximation conversion system determines each bit by examining the charge on a series of binary-weighted capacitors (see Figure 1). In the first phase of the conversion process, the analog input is sampled by closing the SC switch and all ST switches simultaneously. This action charges all the capacitors to the input voltage. In the next phase of the conversion process, all ST and SC switches are opened and the threshold detector begins identifying bits by identifying the charge (voltage) on each capacitor relative to the reference (REF –) voltage. In the switching sequence, 12 capacitors are examined separately until all 12 bits are identified and the charge-convert sequence is repeated. In the first step of the conversion phase, the threshold detector looks at the first capacitor (weight = 4096). Node 4096 of this capacitor is switched to the REF+ voltage, and the equivalent nodes of all the other capacitors on the ladder are switched to REF–. When the voltage at the summing node is greater than the trip point of the threshold detector (approximately 1/2 VCC ), a bit 0 is placed in the output register and the 4096-weight capacitor is switched to REF–. When the voltage at the summing node is less than the trip point of the threshold detector, a bit 1 is placed in the register and this 4096-weight capacitor remains connected to REF + through the remainder of the successive-approximation process. The process is repeated for the 2048-weight capacitor, the 1024-weight capacitor, and so forth down the line until all bits are determined. With each step of the successive-approximation process, the initial charge is redistributed among the capacitors. The conversion process relies on charge redistribution to determine the bits from MSB to LSB. reference voltage inputs The two reference inputs used with the device are the voltages applied to the REF+ and REF– terminals. These voltage values establish the upper and lower limits of the analog input to produce a full-scale and zero-scale reading respectively. These voltages and the analog input should not exceed the positive supply or be lower than ground consistent with the specified absolute maximum ratings. The digital output is at full scale when the input signal is equal to or higher than REF+ terminal voltage and at zero when the input signal is equal to or lower than REF– terminal voltage. SC Threshold Detector 4096 2048 Node 4096 REF – 1024 REF+ REF – ST 16 REF+ REF – ST 8 REF+ REF – ST 4 REF+ REF – ST REF+ REF – ST 2 1 REF+ REF+ REF – ST REF – ST To Output Latches 1 REF – ST ST VI Figure 15. Simplified Model of the Successive-Approximation System 16 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 APPLICATION INFORMATION 4095 111111111111 VFS See Notes A and B 4094 111111111110 VFSnom 4093 VFT = VFS – 1/2 LSB 2049 100000000001 2048 100000000000 VZT = VZS + 1/2 LSB Step Digital Output Code 111111111101 2047 011111111111 VZS 000000000001 1 000000000000 0 0.0012 0.0024 2.4564 2.4576 2.4588 4.9128 4.9134 2 0.0006 000000000010 4.9140 0 4.9152 VI – Analog Input Voltage – V NOTES: A. This curve is based on the assumption that Vref+ and Vref – have been adjusted so that the voltage at the transition from digital 0 to 1 (VZT) is 0.0006 V and the transition to full scale (VFT) is 4.9134 V. 1 LSB = 1.2 mV. B. The full-scale value (VFS) is the step whose nominal midstep value has the highest absolute value. The zero-scale value (VZS) is the step whose nominal midstep value equals zero. Figure 16. Ideal Conversion Characteristics 2543 1 2 3 4 5 Analog Inputs 6 7 8 9 11 12 15 AIN0 CS AIN1 I/O CLOCK AIN2 DATA INPUT 18 17 Processor AIN3 AIN4 DATA OUT AIN5 EOC 16 19 AIN6 AIN7 AIN8 REF+ AIN9 AIN10 REF– 14 5-V DC Regulated 13 GND 10 To Source Ground Figure 17. Serial Interface 17 Control Circuit XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 APPLICATION INFORMATION simplified analog input analysis Using the equivalent circuit in Figure 18, the time required to charge the analog input capacitance from 0 V to VS within 1/2 LSB can be derived as follows: ǒ Ǔ The capacitance charging voltage is given by V C + VS 1–e–tcńRtCi Where: (1) Rt = Rs + ri The final voltage to 1/2 LSB is given by VC (1/2 LSB) = VS – (VS /8192) (2) ǒ Ǔ Equating equation 1 to equation 2 and solving for time tc gives V and S * ǒ V Ǔ ń8192 + VS 1–e–tcńRtCi S (3) tc (1/2 LSB) = Rt × Ci × ln(8192) (4) Therefore, with the values given, the time for the analog input signal to settle is tc (1/2 LSB) = (Rs + 1 kΩ) × 60 pF × ln(8192) (5) This time must be less than the converter sample time shown in the timing diagrams. Driving Source† 2543 Rs VS VI ri VC 1 kΩ Max Ci 60 pF Max VI = Input Voltage at AIN VS = External Driving Source Voltage Rs = Source Resistance ri = Input Resistance Ci = Input Capacitance VC = Capacitance Charging Voltage † Driving source requirements: • Noise and distortion for the source must be equivalent to the resolution of the converter. • Rs must be real at the input frequency. Figure 18. Equivalent Input Circuit Including the Driving Source 18 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 SSOP 19 18 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 SOP 20 18 XD2543N DIP-20 XL2543 SOP20 XL2543-SS SSOP20 21 20
XD2543N 价格&库存
很抱歉,暂时无法提供与“XD2543N”相匹配的价格&库存,您可以联系我们找货
