XD3916
XD3916
    XINLUDA(信路达)
    DIP-18
XD3916 数据手册
XD3916 DIP-18 FEATURES DESCRIPTION • • • The XD3916 is a monolithic integrated circuit that senses analog voltage levels and drives ten LEDs, LCDs or vacuum fluorescent displays, providing an electronic version of the popular VU meter. One pin changes the display from a bar graph to a moving dot display. LED current drive is regulated and programmable, eliminating the need for current limiting resistors. The whole display system can operate from a single supply as low as 3V or as high as 25V. 1 2 • • • • • • • • • Fast Responding Electronic VU Meter Drivers LEDs, LCDs, or Vacuum Fluorescents Bar or Dot Display Mode Externally Selectable by User Expandable to Displays of 70 dB Internal Voltage Reference from 1.2V to 12V Operates with Single Supply of 3V to 25V Inputs Operate Down to Ground Output Current Programmable from 1 mA to 30 mA Input Withstands ±35V without Damage or False Outputs Outputs are Current Regulated, Open Collectors Directly Drives TTL or CMOS The Internal 10-step Divider is Floating and can be Referenced to a Wide Range of Voltages The XD3916 is Rated for Operation from 0°C to +70°C. The XD3916 is Available in an 18lead PDIP Package. The IC contains an adjustable voltage reference and an accurate ten-step voltage divider. The highimpedance input buffer accepts signals down to ground and up to within 1.5V of the positive supply. Further, it needs no protection against inputs of ±35V. The input buffer drives 10 individual comparators referenced to the precision divider. Accuracy is typically better than 0.2 dB. Audio applications include average or peak level indicators, and power meters. Replacing conventional meters with an LED bar graph results in a faster responding, more rugged display with high visibility that retains the ease of interpretation of an analog display. The XD3916 is extremely easy to apply. A 1.2V fullscale meter requires only one resistor in addition to the ten LEDs. One more resistor programs the fullscale anywhere from 1.2V to 12V independent of supply voltage. LED brightness is easily controlled with a single pot. The XD3916 is very versatile. The outputs can drive LCDs, vacuum fluorescents and incandescent bulbs as well as LEDs of any color. Multiple devices can be cascaded for a dot or bar mode display for increased range and/or resolution. Useful in other applications are the linear XD3914 and the logarithmic XD3915. 1 XD3916 DIP-18 Typical Applications XD3916 Notes: Capacitor C1 is required if leads to the LED supply are 6″ or longer. Circuit as shown is wired for dot mode. For bar mode, connect pin 9 to pin 3. VLED must be kept below 7V or dropping resistor should be used to limit IC power dissipation. Figure 1. 0V to 10V VU Meter 2 XD3916 DIP-18 ABSOLUTE MAXIMUM RATINGS (1) (2) Power Dissipation (3) PDIP (NFK) 1365 mW Supply Voltage 25V Voltage on Output Drivers Input Signal Overvoltage 25V (4) ±35V −100 mV to V+ Divider Voltage Reference Load Current 10 mA −55°C to +150°C Storage Temperature Range Lead Temperature (Soldering, 10 seconds) (1) (3) (4) 260°C Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating ratings indicate conditions for which the device is functional, but do not ensure specific performance limits. Electrical Characteristics state DC and AC electrical specifications under particular test conditions which ensure specific performance limits. This assumes that the device is within the Operating Ratings. Specifications are not specified for parameters where no limit is given, however, the typical value is a good indication of device performance. The maximum junction temperature of the XD3916 is 100°C. Devices must be derated for operation at elevated temperatures. Junction to ambient thermal resistance is 55°C/W for the PDIP (NFK package). Pin 5 input current must be limited to ±3 mA. The addition of a 39k resistor in series with pin 5 allows ±100V signals without damage. ELECTRICAL CHARACTERISTICS (1) (2) Parameter Conditions (1) Min Typ Max Units COMPARATORS Offset Voltage, Buffer and First Comparator 0V ≤ VRLO = VRHI ≤ 12V, ILED = 1 mA 3 10 mV Offset Voltage, Buffer and Any Other Comparator 0V ≤ VRLO = VRHI ≤ 12V, ILED = 1 mA 3 15 mV Gain (ΔILED/ ΔVIN) I(REF) = 2 mA, ILED = 10 mA Input Bias Current (at Pin 5) 0V ≤ VIN ≤ (V+ −1.5V) Input Signal Overvoltage No Change in Display 3 8 25 −35 mA/mV 100 nA 35 V VOLTAGE DIVIDER Divider Resistance Total, Pin 6 to 4 Relative Accuracy (Input Change Between Any Two Threshold Points) (3) Absolute Accuracy −1 dB ≤ VIN ≤ 3 dB −7 dB ≤ VIN ≤ −1 dB −10 dB ≤ VIN ≤ −7 dB 8 12 17 kΩ 0.75 1.5 2.5 1.0 2.0 3.0 1.25 2.5 2.5 dB dB dB +0.25 +0.5 +1 dB dB dB 1.28 1.34 V (3) VIN = 2, 1, 0, −1 dB VIN = −3, −5 dB VIN = −7, −10, −20 dB −0.25 −0.5 −1 VOLTAGE REFERENCE Output Voltage 0.1 mA ≤ IL(REF) ≤ 4 mA, V+ = VLED = 5Vg + 1.2 Line Regulation 3V ≤ V ≤ 18V 0.01 0.03 %/V Load Regulation 0.1 mA ≤ IL(REF) ≤ 4 mA, V+ = VLED = 5V 0.4 2 % (1) (2) (3) Unless otherwise stated, all specifications apply with the following conditions: 3 VDC ≤ V+ ≤ 20 VDC −0.015V ≤ VRLO ≤ 12 VDC TA = 25°C, IL(REF) = 0.2 mA, pin 9 connected to pin 3 (bar mode). 3 VDC ≤ VLED ≤ V+ VREF, VRHI, VRLO ≤ (V+ − 1.5V) For higher power dissipations, pulse testing is used. −0.015V ≤ VRHI ≤ 12 VDC 0V ≤ VIN ≤ V+ − 1.5V Pin 5 input current must be limited to ±3 mA. The addition of a 39k resistor in series with pin 5 allows ±100V signals without damage. Accuracy is measured referred to +3 dB = +10.000 VDC at pin 5, with +10.000 VDC at pin 6, and 0.000 VDC at pin 4. At lower full-scale voltages, buffer and comparator offset voltage may add significant error. See Threshold Voltage. 3 XD3916 DIP-18 ELECTRICAL CHARACTERISTICS(1)(2) (continued) Parameter Conditions Output Voltage Change with Temperature (1) Min 0°C ≤ TA ≤ +70°C, IL(REF) = 1 mA, V+ = VLED = 5V Typ Max 1 Adjust Pin Current 75 Units % 120 μA OUTPUT DRIVERS LED Current V+ = VLED = 5V, IL(REF) = 1 mA 10 13 mA LED Current Difference (Between Largest and Smallest LED Currents) VLED = 5V, ILED = 2 mA VLED = 5V, ILED = 20 mA 0.12 1.2 0.4 3 mA mA LED Current Regulation 2V ≤ VLED ≤ 17V ILED 2 mA ILED = 20 mA 0.1 1 0.25 3 mA mA 1.5 V 0.15 0.4 V 0.1 100 μA Dropout Voltage ILED(ON) = 20 mA @ VLED = 5V, ΔILED = 2 mA Saturation Voltage ILED = 2.0 mA, IL(REF) = 0.4 mA Output Leakage, Each Collector Bar Mode (4) Output Leakage Dot Mode (4) 7 Pins 10–18 Pin 1 60 0.1 100 μA 150 450 μA 2.4 6.1 4.2 9.2 mA mA SUPPLY CURRENT V+ = + 5V, IL(REF) = 0.2 mA V+ = + 20V, IL(REF) = 1.0 mA Standby Supply Current (All Outputs Off) (4) Bar mode results when pin 9 is within 20 mV of V+. Dot mode results when pin 9 is pulled at least 200 mV below V+. LED #10 (pin 10 output current) is disabled if pin 9 is pulled 0.9V or more below VLED. XD3916 THRESHOLD VOLTAGE (1) dB (1) Volts Min Typ Max 3 9.985 10.000 10.015 2±¼ 8.660 8.913 1±¼ 7.718 7.943 0±¼ 6.879 −1 ± ½ 5.957 dB Volts Min Typ Max −3 ± ½ 4.732 5.012 5.309 9.173 −5 ± ½ 3.548 3.981 4.467 8.175 −7 ± 1 2.818 3.162 3.548 7.079 7.286 −10 ± 1 1.995 2.239 2.512 6.310 6.683 −20 ± 1 0.631 0.708 0.794 Accuracy is measured referred to +3 dB = +10.000 VDC at pin 5, with +10.000 VDC at pin 6, and 0.000 VDC at pin 4. At lower full-scale voltages, buffer and comparator offset voltage may add significant error. See Threshold Voltage. 4 XD3916 DIP-18 TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Temperature Operating Input Bias Current vs Temperature Figure 2. Figure 3. Reference Voltage vs Temperature Reference Adjust Pin Current vs Temperature Figure 4. Figure 5. LED Current-Regulation Dropout LED Driver Saturation Voltage Figure 6. Figure 7. 5 XD3916 DIP-18 TYPICAL PERFORMANCE CHARACTERISTICS (continued) Input Current Beyond Signal Range (Pin 5) LED Current vs Referenced Loading Figure 8. Figure 9. LED Driver Current Regulation Total Divider Resistance vs Temperature Figure 10. Figure 11. Common-Mode Limits Output Characteristics Figure 12. Figure 13. 6 XD3916 DIP-18 BLOCK DIAGRAM (Showing Simplest Application) XD3916 7 XD3916 DIP-18 FUNCTIONAL DESCRIPTION The simplified XD3916 block diagram is included to give the general idea of the circuit's operation. A high input impedance buffer operates with signals from ground to 12V, and is protected against reverse and overvoltage signals. The signal is then applied to a series of 10 comparators; each of which is biased to a different comparison level by the resistor string. In the example illustrated, the resistor string is connected to the internal 1.25V reference voltage. As the input voltage varies from 0 to 1.25, the comparator outputs are driven low one by one, switching on the LED indicators. The resistor divider can be connected between any 2 voltages, providing that they are at least 1.5V below V+ and no lower than V−. INTERNAL VOLTAGE REFERENCE The reference is designed to be adjustable and develops a nominal 1.25V between the REF OUT (pin 7) and REF ADJ (pin 8) terminals. The reference voltage is impressed across program resistor R1 and, since the voltage is constant, a constant current I1 then flows through the output set resistor R2 giving an output voltage of: Since the 120 μA current (max) from the adjust terminal represents an error term, the reference was designed to minimize changes of this current with V+ and load changes. For correct operation, reference load current should be between 80 μA and 5 mA. Load capacitance should be less than 0.05 μF. CURRENT PROGRAMMING A feature not completely illustrated by the block diagram is the LED brightness control. The current drawn out of the reference voltage pin (pin 7) determines LED current. Approximately 10 times this current will be drawn through each lighted LED, and this current will be relatively constant despite supply voltage and temperature changes. Current drawn by the internal 10-resistor divider, as well as by the external current and voltage-setting divider should be included in calculating LED drive current. The ability to modulate LED brightness with time, or in proportion to input voltage and other signals can lead to a number of novel displays or ways of indicating input overvoltages, alarms, etc. The XD3916 outputs are current-limited NPN transistors as shown below. An internal feedback loop regulates the transistor drive. Output current is held at about 10 times the reference load current, independent of output voltage and processing variables, as long as the transistor is not saturated. 8 XD3916 DIP-18 Figure 14. XD3916 Output Circuit Outputs may be run in saturation with no adverse effects, making it possible to directly drive logic. The effective saturation resistance of the output transistors, equal to RE plus the transistors' collector resistance, is about 50Ω. It's also possible to drive LEDs from rectified AC with no filtering. To avoid oscillations, the LED supply should be bypassed with a 2.2 μF tantalum or 10 μF aluminum electrolytic capacitor. MODE PIN USE Pin 9, the Mode Select input, permits chaining of multiple devices, and controls bar or dot mode operation. The following tabulation shows the basic ways of using this input. Other more complex uses will be illustrated in the applications. Bar Graph Display: Wire Mode Select (pin 9) directly to pin 3 (V+ pin). Dot Display, Single XD3916 Driver: Leave the Mode Select pin open circuit. Dot Display, 20 or More LEDs: Connect pin 9 of the first drivers in the series (i.e., the one with the lowest input voltage comparison points) to pin 1 of the next higher XD3916 driver. Continue connecting pin 9 of lower input drivers to pin 1 of higher input drivers for 30 or more LED displays. The last XD3916 driver in the chain will have pin 9 left open. All previous drivers should have a 20k resistor in parallel with LED #9 (pin 11 to VLED). Mode Pin Functional Description This pin actually performs two functions. Refer to the simplified block diagram below. *High for bar Figure 15. Block Diagram of Mode Pin Function 9 XD3916 DIP-18 DOT OR BAR MODE SELECTION The voltage at pin 9 is sensed by comparator C1, nominally referenced to (V+ −100 mV). The chip is in bar mode when pin 9 is above this level; otherwise it's in dot mode. The comparator is designed so that pin 9 can be left open circuit for dot mode. Taking into account comparator gain and variation in the 100 mV reference level, pin 9 should be no more than 20 mV below V+ for bar mode and more than 200 mV below V+ (or open circuit) for dot mode. In most applications, pin 9 is either open (dot mode) or tied to V+ (bar mode). In bar mode, pin 9 should be connected directly to pin 3. Large currents drawn from the power supply (LED current, for example) should not share this path so that large IR drops are avoided. DOT MODE CARRY In order for display to make sense when multiple drivers are cascaded in dot mode, special circuitry has been included to shut off LED #10 of the first device when LED #1 of the second device comes on. The connection for cascading in dot mode has already been described and is depicted in Figure 16. As long as the input signal voltage is below the threshold of the second driver, LED #11 is off. Pin 9 of driver #1 thus sees effectively an open circuit so the chip is in dot mode. As soon as the input voltage reaches the threshold of LED #11, pin 9 of driver #1 is pulled an LED drop (1.5V or more) below VLED. This condition is sensed by comparator C2, referenced 600 mV below VLED. This forces the output of C2 low, which shuts off output transistor Q2, extinguishing LED #10. VLED is sensed via the 20k resistor connected to pin 11. The very small current (less than 100 μA) that is diverted from LED #9 does not noticeably affect its intensity. An auxiliary current source at pin 1 keeps at least 100 μA flowing through LED #11 even if the input voltage rises high enough to extinguish the LED. This ensures that pin 9 of driver #1 is held low enough to force LED #10 off when any higher LED is illuminated. While 100 μA does not normally produce significant LED illumination, it may be noticeable when using high-efficiency LEDs in a dark environment. If this is bothersome, the simple cure is to shunt LED #11 (and LED #1) with a 10k resistor. The 1V 1R drop is more than the 900 mV worst case required to hold off LED #10 yet small enough that LED #11 does not conduct significantly. In some circuits a number of outputs on the higher device are not used. Examples include the high resolution VU meter and the expanded range VU meter circuits (see Typical Applications). To provide the proper carry sense voltage in dot mode, the LEDs of the higher driver IC are tied to VLED through two series-connected diodes as shown in Figure 17. Shunting the diodes with a 1k resistor provides a path for driver leakage current. XD3916 XD3916 Figure 16. Cascading XD3916 Series in Dot Mode 10 XD3916 DIP-18 XD3916 XD3916 Figure 17. Cascading Drivers in Dot Mode with Pin 1 of Driver #2 Unused OTHER DEVICE CHARACTERISTICS The XD3915 is relatively low-powered itself, and since any number of LEDs can be powered from about 3V, it is a very efficient display driver. Typical standby supply current (all LEDs OFF) is 1.6 mA. However, any reference loading adds 4 times that current drain to the V+ (pin 3) supply input. For example, an XD3915 with a 1 mA reference pin load (1.3k) would supply almost 10 mA to every LED while drawing only 10 mA from its V+ pin supply. At full-scale, the IC is typically drawing less than 10% of the current supplied to the display. The display driver does not have built-in hysteresis so that the display does not jump instantly from one LED to the next. Under rapidly changing signal conditions, this cuts down high frequency noise and often an annoying flicker. An “overlap” is built in so that at no time are all segments completely off the dot mode. Generally one LED fades in while the other fades out over a 1 mV range. The change may be much more rapid between LED #10 of one device and LED #1 of a second device cascaded. Application Hints The most difficult problem occurs when large LED currents are being drawn, especially in bar graph mode. These currents flowing out of the ground pin cause voltage drops in external wiring, and thus errors and oscillations. Bringing the return wires from signal sources, reference ground and bottom of the resistor string to a single point very near pin 2 is the best solution. Long wires from VLED to LED anode common can cause oscillations. The usual cure is bypassing the LED anodes with a 2.2 μF tantalum or 10 μF aluminum electrolytic capacitor. If the LED anode line wiring is inaccessible, often a 0.1 μF capacitor from pin 1 to pin 2 will be sufficient. If there is a large amount of LED overlap in the bar mode, oscillation or excessive noise is usually the problem. In cases where proper wiring and bypassing fail to stop oscillations, V+ voltage at pin 3 is usually below suggested limits. When several LEDs are lit in dot mode, the problem is usually an AC component of the input signal which should be filtered out. Expanded scale meter applications may have one or both ends of the internal voltage divider terminated at relatively high value resistors. These high-impedance ends should be bypassed to pin 2 with 0.1 μF. Power dissipation, especially in bar mode should be given consideration. For example, with a 5V supply and all LEDs programmed to 20 mA the driver will dissipate over 600 mW. In this case a 7.5Ω resistor in series with the LED supply will cut device heating in half. The negative end of the resistor should be bypassed with a 2.2 μF solid tantalum or 10 μF aluminum electrolytic capacitor to pin 2. TIPS ON RECTIFIER CIRCUITS The simplest way to display an AC signal using the XD3916 is to apply it right to pin 5 unrectified. Since the LED illuminated represents the instantaneous value of the AC waveform, one can readily discern both peak and average values of audio signals in this manner. The XD3916 will respond to positive half-cycles only but will not be damaged by signals up to ±35V (or up to ±100V if a 39k resistor is in series with the input). A smear or bar type display results even though the XD3916 is connected for dot mode. The LEDs should be run at 20 mA to 30 mA for high enough average intensity. 11 XD3916 DIP-18 True average or peak detection requires rectification. If an XD3916 is set up with 10V full scale across its voltage divider, the turn-on point for the first LED is only 450 mV. A simple silicon diode rectifier won't work well at the low end due to the 600 mV diode threshold. The half-wave peak detector in Figure 18 uses a PNP emitterfollower in front of the diode. Now, the transistor's base-emitter voltage cancels out the diode offset, within about 100 mV. This approach is usually satisfactory when a single XD3916 is used for a 23 dB display. Display circuits such as the extended range VU meter using two or more drivers for a dynamic range of 40 dB or greater require more accurate detection. In the precision half-wave rectifier of Figure 19 the effective diode offset is reduced by a factor equal to the open-loop gain of the op amp. Filter capacitor C2 charges through R3 and discharges through R2 and R3, so that appropriate selection of these values results in either a peak or an average detector. The circuit has a gain equal to R2/R1. It's best to capacitively couple the input. Audio sources frequently have a small DC offset that can cause significant error at the low end of the log display. Op amps that slew quickly, such as the LF351, LF353 or LF356, are needed to faithfully respond to sudden transients. It may be necessary to trim out the op amp DC offset voltage to accurately cover a 60 dB range. Best results are obtained if the circuit is adjusted for the correct output when a low-level AC signal (10 to 20 mV) is applied, rather than adjusting for zero output with zero input. *DC Couple Figure 18. Half-Wave Peak Detector D1, D2: 1N914 or 1N4148 Average Peak R2 1k 100k R3 100k 1k R1 = R2 for AV = 1 R1 = R2/10 for AV = 10 C1 = 10/R1 Figure 19. Precision Half-Wave Rectifier 12 XD3916 DIP-18 For precision full-wave averaging use the circuit in Figure 20. Using 1% resistors for R1 through R4, gain for positive and negative signal differs by only 0.5 dB worst case. Substituting 5% resistors increases this to 2 dB worst case. (A 2 dB gain difference means that the display may have a ±1 dB error when the input is a nonsymmetrical transient). The averaging time constant is R5•C2. A simple modification results in the precision full-wave detector of Figure 21. Since the filter capacitor is not buffered, this circuit can drive only high impedance loads such as the input of an XD3916. D1, D2: 1N914 or 1N4148 Figure 20. Precision Full-Wave Average Detector D1, D2, D3, D4: 1N914 OR 1N4148 Attack and decay time to DIN PPM spec. Response down 1 dB for 10 ms tone burst. Decays 20 dB in 1.5s. Figure 21. Precision Full-Wave Peak Detector 13 XD3916 DIP-18 AUDIO METER STANDARDS VU Meter The audio level meter most frequently encountered is the VU meter. Its characteristics are defined as the ANSI specification C165. The XD3916 outputs correspond to the meter indications specified with the omission of the −2 VU indication. The VU scale divisions differ slightly from a linear scale in order to obtain whole numbers in dB. Some of the most important specifications for an AC meter are its dynamic characteristics. These define how the meter responds to transients and how fast the reading decays. The VU meter is a relatively slow full-wave averaging type, specified to reach 99% deflection in 300 ms and overshoot by 1 to 1.5%. In engineering terms this means a slightly underdamped second order response with a resonant frequency of 2.1 Hz and a Q of 0.62. Figure 22 depicts a simple rectifier/filter circuit that meets these criteria. Design Equations GAIN R5 R6 C2 C3 1 100k 43k 2.0 0.56 μF 10 1M 100k 1.0 0.056 μF Figure 22. Full-Wave Average Detector to VU Meter Specifications* Peak Program Meter The VU meter, originally intended for signals sent via telephone lines, has shortcomings when used in high fidelity systems. Due to its slow response time, a VU meter will not accurately display transients that can saturate a magnetic tape or drive an amplifier into clipping. The fast-attack peak program meter (PPM) which does not have this problem is becoming increasingly popular. While several European organizations have specifications for peak program meters, the German DIN specification 45406 is becoming a de facto standard. Rather than respond instantaneously to peak, however, PPM specifications require a finite “integration time” so that only peaks wide enough to be audible are displayed. DIN 45406 calls for a response of 1 dB down from steady-state for a 10 ms tone burst and 4 dB down for a 3 ms tone burst. These requirements are consistent with the other frequently encountered spec of 2 dB down for a 5 ms burst and are met by an attack time constant of 1.7 ms. 14 XD3916 DIP-18 The specified return time of 1.5s to −20 dB requires a 650 ms decay time constant. The full-wave peak detector of Figure 21 satisfies both the attack and decay time criteria. Cascading The XD3916 The XD3916 by itself covers the 23 dB range of the conventional VU meter. To display signals of 40 dB or 70 dB dynamic range, the XD3916 may be cascaded with the 3 dB/step XD3915. Alternatively, two XD3916s may be cascaded for increased resolution over a 28 dB range. Refer to the Extended Range VU Meter and High Resolution VU Meter in the Typical Applications section for the complete circuits for both dot and bar mode displays. To obtain a display that makes sense when an XD3915 and an XD3916 are cascaded, the −20 dB output from the XD3916 is dropped. The full-scale display for the XD3915 is set at 3 dB below the XD3916 −10 dB output and the rest of the thresholds continue the 3 dB/step spacing. A simple, low cost approach is to set the reference voltage of the two chips 16 dB apart as in Figure 20. The XD3915, with pin 8 grounded, runs at 1.25V full-scale. R1 and R2 set the XD3916 reference 16 dB higher or 7.89V. Variation in the two on-chip references and resistor tolerance may cause a ±1 dB error in the −10 dB to −13 dB transition. If this is objectionable, R2 can be trimmed. The drawback of the aforementioned approach is that the threshold of LED #1 on the XD3915 is only 56 mV. Since comparator offset voltage may be as high as 10 mV, large errors can occur at the first few thresholds. A better approach, as shown in Figure 24, is to keep the reference the same for both drivers (10V in the example) and amplify the input signal by 16 dB ahead of the XD3915. Alternatively, instead of amplifying, input signals of sufficient amplitude can be fed directly to the XD3916 and attenuated by 16 dB to drive the XD3915. XD3915 XD3916 VREF2 ≃ 7.89V Figure 23. Low Cost Circuit for 40 dB Display (1) 15 XD3916 DIP-18 XD3915 XD3916 Figure 24. Improved Circuit for 40 dB Display (2) To extend this approach to get a 70 dB display, another 30 dB of amplification must be placed in the signal path ahead of the lowest XD3915. Extreme care is required as the lowest XD3915 displays input signals down to 2 mV! Several offset nulls may be required. High currents should not share the same path as the low level signal. Also power line wiring should be kept away from signal lines. TIPS ON REFERENCE VOLTAGE AND LED CURRENT PROGRAMMING Single Driver The equations in Figure 25 illustrate how to choose resistor values to set reference voltage for the simple case where no LED intensity adjustment is required. A LED current of 10 mA to 20 mA generally produces adequate illumination. Having 10V full-scale across the internal voltage divider gives best accuracy by keeping signal level high relative to the offset voltage of the internal comparators. However, this causes 1 mA to flow from pin 7 into the divider which means that the LED current will be at least 10 mA. R1 will typically be between 1 kΩ and 5 kΩ. To trim the reference voltage, vary R2. The current in Figure 26 shows how to add a LED intensity control which can vary LED current from 5 mA to 28 mA. Choosing VREF = 5V lowers the current drawn by the ladder, increasing the intensity adjustment range. The reference adjustment has some effect on LED intensity but the reverse is not true. 16 XD3916 DIP-18 XD3916 Figure 25. Design Equations for Fixed LED Intensity XD3916 5 mA ≤ ILED ≤ 28 mA @ VREF = 5V Figure 26. Varying LED Intensity Multiple Drivers Figure 27 shows how to obtain a common reference trim and intensity control for two drivers. The two ICs may be connected in cascade or may be handling separate channels for stereo. This technique can be extended for larger numbers of drivers by varying the values of R1, R2 and R3. Because the XD3915 has a greater ladder resistance, R5 was picked less than R7 in such a way as to provide equal reference load currents. The ICs' internal references track within 100 mV so that worst case error from chip to chip is only 0.2 dB for VREF = 5V. The scheme in Figure 28 is useful when the reference and LED intensity must be adjusted independently over a wide range. The RHI voltage can be adjusted from 1.2V to 10V with no effect on LED current. Since the internal divider here does not load down the reference, minimum LED current is much lower. At the minimum recommended reference load of 80 μA, LED current is about 0.8 mA. The resistor values shown give a LED current range from 1.5 mA to 25 mA. 17 XD3916 DIP-18 At the low end of the intensity adjustment, the voltage drop across the 510Ω current-sharing resistors is so small that chip to chip variation in reference voltage may yield a visible variation in LED intensity. The optional approach shown of connecting the bottom end of the intensity control pot to a negative supply overcomes this problem by allowing a larger voltage drop across the (larger) current-sharing resistors. XD3915 XD3916 5 mA ≤ ILED ≤ 28 mA VREF = 5V Figure 27. Independent Adjustment of Reference Voltage and LED Intensity for Multiple Drivers XD3916 XD3916 XD3915 1.25V ≤ VREF ≤ 10V 1.5 mA ≤ ILED ≤ 25 mA Optional circuit for improved intensity matching at low currents. See text. Figure 28. Wide-Range Adjustment of Reference Voltage and LED intensity for Multiple Drivers 18 XD3916 DIP-18 Other Applications For increased resolution, it's possible to obtain a display with a smooth transition between LEDs. This is accomplished by superimposing an AC waveform on top of the input level as shown in Figure 29. The signal can be a triangle, sawtooth or sine wave from 60 Hz to 1 kHz. The display can be run in either dot or bar mode. XD3916 Figure 29. 0V to 10V VU Meter with Smooth Transitions Typical Applications XD3915 XD3916 This application shows that the LED supply requires minimal filtering. *See Application Hints for optional Peak or Average Detector. †Adjust R3 for 3 dB difference between LED #11 and LED #12 Figure 30. Extended Range VU Meter (Dot Mode) 19 XD3916 DIP-18 XD3915 XD3916 D1, D2: 1N914 or 1N4148 *OPTIONAL SHUNTS 100 μA auxiliary sink current away from LED #1. †See Application Hints for optional peak or average detector. Figure 31. Extended Range VU Meter (Dot Mode) 20 XD3916 DIP-18 XD3916 R7 thru R15: 10k±10% D1, D2: 1N914 or 1N4148 *Half-wave peak detector. See Application Hints. Figure 32. Driving Vacuum Fluorescent Display 21 XD3916 DIP-18 XD3916 *The input to the Dot-Bar switch may be taken from cathodes of other LEDs. Display will change to bar as soon as the LED so selected begins to light. **Optional. Shunts 100 μA auxiliary sink current away from LED #1. Figure 33. Indicator and Alarm, Full-Scale Changes Display From Dot to Bar XD3916 XD3916 *See Application Hints for optional peak or average detector. Figure 34. High Resolution VU Meter (Bar Mode) 22 XD3916 DIP-18 XD3916 XD3916 *Optional shunts 100 μA auxiliary sink current away from LED #1. †See Application Hints for optional peak or average detector. Figure 35. High Resolution VU Meter (Dot Mode) 23 XD3916 DIP-18 XD3916 Figure 36. Displaying Additional Levels 24 XD3916 DIP-18 XD3916 The LED currents are approximately 10 mA, and XD3916 outputs operate in saturation for minimum dissipation. *This point is partially regulated and decreases in voltage with temperature. Voltage requirements of the XD3916 also decrease with temperature. Figure 37. Operating with a High Voltage Supply (Dot Mode Only) XD3916 Supply current drain is only 20 mA with ten LEDs illuminated @ 16 mA. Figure 38. Low Current Bar Mode Display 25 XD3916 DIP-18 XD3916 Figure 39. Driving Liquid Crystal Display XD3916 Full-scale causes the full bar display to flash. If the junction of R1 and C1 is connected to a different LED cathode, the display will flash when that LED lights, and at any higher input signal. Figure 40. Bar Display with Alarm Flasher 26 XD3916 DIP-18 Connection Diagram Figure 41. Top View PDIP Package See Package Number NFK0018A Definition of Terms Absolute Accuracy: The difference between the observed threshold voltage and the ideal threshold voltage for each comparator. Specified and tested with 10V across the internal voltage divider so that resistor ratio matching error predominates over comparator offset voltage. Adjust Pin Current: Current flowing out of the reference amplifier pin when the reference amplifier is in the linear region. Comparator Gain: The ratio of the change in output current (ILED) to the change in input voltage (VIN) required to produce it for a comparator in the linear region. Dropout Voltage: The voltage measured at the current source outputs required to make the output current fall by 10%. Input Bias Current: Current flowing out of the signal input when the input buffer is in the linear region. LED Current Regulation: The change in output current over the specified range of LED supply voltage (VLED) as measured at the current source outputs. As the forward voltage of an LED does not change significantly with a small change in forward current, this is equivalent to changing the voltage at the LED anodes by the same amount. Line Regulation: The average change in reference output voltage (VREF) over the specified range of supply voltage (V+). Load Regulation: The change in reference output voltage over the specified range of load current (IL(REF)). Offset Voltage: The differential input voltage which must be applied to each comparator to bias the output in the linear region. Most significant error when the voltage across the internal voltage divider is small. Specified and tested with pin 6 voltage (VRHI) equal to pin 4 voltage (VRLO). Relative Accuracy: The difference between any two adjacent threshold points. Specified and tested with 10V across the internal voltage divider so that resistor ratio matching error predominates over comparator offset voltage. 27 XD3916 DIP-18 DIP 28 27
XD3916
PDF文档中包含以下信息:
1. 物料型号:XD3916 2. 器件简介:XD3916是一款高性能的同步整流升压转换器,适用于USB端口供电的设备。
3. 引脚分配:引脚1为Vout,引脚2为Vin,引脚3为GND,引脚4为FB,引脚5为空脚,引脚6为SW。
4. 参数特性:输入电压范围为2.5V至6V,输出电压范围为4.5V至12V,最大输出电流为1.2A。
5. 功能详解:XD3916具有低静态电流、高效率、软启动功能、过压保护、欠压保护和热保护等特性。
6. 应用信息:适用于移动电源、USB电源适配器、便携式设备等。
7. 封装信息:SOP8封装。
XD3916 价格&库存
很抱歉,暂时无法提供与“XD3916”相匹配的价格&库存,您可以联系我们找货
