XD3915
XD3915
    XINLUDA(信路达)
    DIP-18
XD3915 数据手册
XD3915 DIP-18 FEATURES DESCRIPTION • • • The XD3915 is a monolithic integrated circuit that senses analog voltage levels and drives ten LEDs, LCDs or vacuum fluorescent displays, providing a logarithmic 3 dB/step analog display. One pin changes the display from a bar graph to a moving dot display. LED current drive is regulated and programmable, eliminating the need for current limiting resistors. The whole display system can operate from a single supply as low as 3V or as high as 25V. 1 2 • • • • • • • • • 3 dB/step, 30 dB Range Drives LEDs, LCDs, or Vacuum Fluorescents Bar or Dot Display Mode Externally Selectable by User Expandable to Displays of 90 dB Internal Voltage Reference from 1.2V to 12V Operates with Single Supply of 3V to 25V Inputs Operate Down to Ground Output Current Programmable from 1 mA to 30 mA Input Withstands ±35V without Damage or False Outputs Outputs are Current Regulated, Open Collectors Directly Drives TTL or CMOS The Internal 10-step Divider is Floating and can be Referenced to a Wide Range of Voltages The XD3915 is Rated for Operation from 0°C to +70°C. The IC contains an adjustable voltage reference and an accurate ten-step voltage divider. The highimpedance input buffer accepts signals down to ground and up to within 1.5V of the positive supply. Further, it needs no protection against inputs of ±35V. The input buffer drives 10 individual comparators referenced to the precision divider. Accuracy is typically better than 1 dB. The XD3915 dB/step display is suited for signals with wide dynamic range, such as audio level, power, light intensity or vibration. Audio applications include average or peak level indicators, power meters and RF signal strength meters. Replacing conventional meters with an LED bar graph results in a faster responding, more rugged display with high visibility that retains the ease of interpretation of an analog display. The XD3915 is extremely easy to apply. A 1.2V fullscale meter requires only one resistor in addition to the ten LEDs. One more resistor programs the fullscale anywhere from 1.2V to 12V independent of supply voltage. LED brightness is easily controlled with a single pot. The XD3915 is very versatile. The outputs can drive LCDs, vacuum fluorescents and incandescent bulbs as well as LEDs of any color. Multiple devices can be cascaded for a dot or bar mode display with a range of 60 or 90 dB. XD3915 can also be cascaded with XD3914 for a linear/log display or with XD3916 for an extended-range VU meter. 1 XD3915 DIP-18 Typical Applications XD3915 Notes: Capacitor C1 is required if leads to the LED supply are 6″ or longer. Circuit as shown is wired for dot mode. For bar mode, connect pin 9 to pin 3. VLED must be kept below 7V or dropping resistor should be used to limit IC power dissipation. Figure 1. 0V to 10V Log Display 2 XD3915 DIP-18 ABSOLUTE MAXIMUM RATINGS (1) (2) Power Dissipation PDIP (NFK) (3) 1365 mW Supply Voltage 25V Voltage on Output Drivers Input Signal Overvoltage 25V (4) ±35V −100 mV to V+ Divider Voltage Reference Load Current 10 mA −55°C to +150°C Storage Temperature Range Lead Temperature (Soldering, 10 sec.) 260°C (1) Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is functional, but do not ensure specific performance limits. Electrical Characteristics state DC and AC electrical specifications under particular test conditions which ensure specific performance limits. This assumes that the device is within the Operating Ratings. Specifications are not ensured for parameters where no limit is given, however, the typical value is a good indication of device performance. (2) The maximum junction temperature of the XD3915 is 100°C. Devices must be derated for operation at elevated temperatures. Junction to ambient thermal resistance is 55°C/W for the PDIP (NFK package). Pin 5 input current must be limited to ±3 mA. The addition of a 39k resistor in series with pin 5 allows ±100V signals without damage. (3) ELECTRICAL CHARACTERISTICS (1) (2) Conditions (1) Parameter Min Typ Max Units COMPARATOR Offset Voltage, Buffer and First Comparator 0V ≤ VRLO = VRHI ≤ 12V, ILED = 1 mA 3 10 mV Offset Voltage, Buffer and Any Other Comparator 0V ≤ VRLO = VRHI ≤ 12V, ILED = 1 mA 3 15 mV Gain (ΔILED/ΔVIN) IL(REF) = 2 mA, ILED = 10 mA Input Bias Current (at Pin 5) 0V ≤ VIN ≤ (V+ − 1.5V) Input Signal Overvoltage No Change in Display 3 8 25 −35 mA/mV 100 nA 35 V VOLTAGE-DIVIDER Divider Resistance Total, Pin 6 to 4 Relative Accuracy (Input Change Between Any Two Threshold Points) (3) Absolute Accuracy at Each Threshold Point (3) (1) (2) (3) 16 28 36 kΩ 2.0 3.0 4.0 dB VIN = −3, −6 dB −0.5 +0.5 dB VIN = −9 dB −0.5 +0.65 dB VIN = −12, −15, −18 dB −0.5 +1.0 dB VIH = −21, −24, −27 dB −0.5 +1.5 dB Unless otherwise stated, all specifications apply with the following conditions: 3 VDC ≤ V+ ≤ 20 VDC −0.015V ≤ VRLO ≤ 12 VDC TA = 25°C, IL(REF) = 0.2 mA, pin 9 connected to pin 3 (bar mode). 3 VDC ≤ VLED ≤ V+ VREF, VRHI, VRLO ≤ (V+ − 1.5V) For higher power dissipations, pulse testing is used.−0.015V ≤ VRHI ≤ 12 VDC 0V ≤ VIN ≤ V+ − 1.5V Pin 5 input current must be limited to ±3 mA. The addition of a 39k resistor in series with pin 5 allows ±100V signals without damage. Accuracy is measured referred to 0 dB = + 10.000 VDC at pin 5, with + 10.000 VDC at pin 6, and 0.000 VDC at pin 4. At lower full scale voltages, buffer and comparator offset voltage may add significant error. See Threshold Voltage. 3 XD3915 DIP-18 ELECTRICAL CHARACTERISTICS(1)(2) (continued) Conditions (1) Parameter Min Typ Max Units 1.2 1.28 1.34 V VOLTAGE REFERENCE Output Voltage 0.1 mA ≤ IL(REF) ≤ 4 mA, V+ = VLED = 5V Line Regulation 3V ≤ V+ ≤ 18V 0.01 0.03 %/V Load Regulation 0.1 mA ≤ IL(REF) ≤ 4 mA, V+ = VLED = 5V 0.4 2 % Output Voltage Change with Temperature 0°C ≤ TA ≤ +70°C, IL(REF) = 1 mA, V + = VLED = 5V 1 Adjust Pin Current % 75 120 μA mA OUTPUT DRIVERS LED Current V + = VLED = 5V, IL(REF) = 1 mA 10 13 LED Current Difference (Between Largest and Smallest LED Currents) VLED = 5V, ILED = 2 mA VLED = 5V, ILED 20 mA 0.12 0.4 1.2 3 LED Current Regulation 2V ≤ VLED ≤ 17V, ILED = 2 mA ILED = 20 mA 0.1 0.25 1 3 Dropout Voltage ILED(ON) = 20 mA, @ VLED = 5V, ΔILED = 2 mA Saturation Voltage ILED = 2.0 mA, IL(REF) = 0.4 mA Output Leakage, Each Collector (Bar Mode) (4) Output Leakage Pins 10–18 (Dot Mode) (4) 7 1.5 Pin 1 60 mA mA V 0.15 0.4 V 0.1 10 μA 0.1 10 μA 150 450 μA 2.4 4.2 mA 6.1 9.2 mA SUPPLY CURRENT V+ = +5V, IL(REF) = 0.2 mA V+ = +20V, IL(REF) = 1.0 mA Standby Supply Current (All Outputs Off) (4) + + Bar mode results when pin 9 is within 20 mV of V . Dot mode results when pin 9 is pulled at least 200 mV below V . LED #10 (pin 10 output current) is disabled if pin 9 is pulled 0.9V or more below VLED. THRESHOLD VOLTAGE (1) (1) Output dB Min Typ Max Output dB Min Typ Max 1 −27 0.422 0.447 0.531 6 −12 2.372 2.512 2.819 2 −24 0.596 0.631 0.750 7 −9 3.350 3.548 3.825 3 −21 0.841 0.891 1.059 8 −6 4.732 5.012 5.309 4 −18 1.189 1.259 1.413 9 −3 6.683 7.079 7.498 5 −15 1.679 1.778 1.995 10 0 9.985 10 10.015 Accuracy is measured referred to 0 dB = + 10.000 VDC at pin 5, with + 10.000 VDC at pin 6, and 0.000 VDC at pin 4. At lower full scale voltages, buffer and comparator offset voltage may add significant error. See Threshold Voltage. 4 XD3915 DIP-18 TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Temperature Operating Input Bias Current vs Temperature Figure 2. Figure 3. Reference Voltage vs Temperature Reference Adjust Pin Current vs Temperature Figure 4. Figure 5. LED Current-Regulation Dropout LED Driver Saturation Voltage Figure 6. Figure 7. 5 XD3915 DIP-18 TYPICAL PERFORMANCE CHARACTERISTICS (continued) Input Current Beyond Signal Range (Pin 5) LED Current vs Reference Loading Figure 8. Figure 9. LED Driver Current Regulation Total Divider Resistance vs Temperature Figure 10. Figure 11. Common-Mode Limits Output Characteristics Figure 12. Figure 13. 6 XD3915 DIP-18 BLOCK DIAGRAM (Showing Simplest Application) XD3915 7 XD3915 DIP-18 FUNCTIONAL DESCRIPTION The simplified XD3915 block diagram is included to give the general idea of the circuit's operation. A high input impedance buffer operates with signals from ground to 12V, and is protected against reverse and overvoltage signals. The signal is then applied to a series of 10 comparators; each of which is biased to a different comparison level by the resistor string. In the example illustrated, the resistor string is connected to the internal 1.25V reference voltage. In this case, for each 3 dB that the input signal increases, a comparator will switch on another indicating LED. This resistor divider can be connected between any 2 voltages, providing that they are at least 1.5V below V+ and no lower than V−. INTERNAL VOLTAGE REFERENCE The reference is designed to be adjustable and develops a nominal 1.25V between the REF OUT (pin 7) and REF ADJ (pin 8) terminals. The reference voltage is impressed across program resistor R1 and, since the voltage is constant, a constant current I1 then flows through the output set resistor R2 giving an output voltage of: (1) XD3915 Since the 120 μA current (max) from the adjust terminal represents an error term, the reference was designed to minimize changes of this current with V+ and load changes. For correct operation, reference load current should be between 80 μA and 5 mA. Load capacitance should be less than 0.05 μF. CURRENT PROGRAMMING A feature not completely illustrated by the block diagram is the LED brightness control. The current drawn out of the reference voltage pin (pin 7) determines LED current. Approximately 10 times this current will be drawn through each lighted LED, and this current will be relatively constant despite supply voltage and temperature changes. Current drawn by the internal 10-resistor divider, as well as by the external current and voltage-setting divider should be included in calculating LED drive current. The ability to modulate LED brightness with time, or in proportion to input voltage and other signals can lead to a number of novel displays or ways of indicating input overvoltages, alarms, etc. The XD3915 outputs are current-limited NPN transistors as shown below. An internal feedback loop regulates the transistor drive. Output current is held at about 10 times the reference load current, independent of output voltage and processing variables, as long as the transistor is not saturated. 8 XD3915 DIP-18 Figure 14. XD3915 Output Circuit Outputs may be run in saturation with no adverse effects, making it possible to directly drive logic. The effective saturation resistance of the output transistors, equal to RE plus the transistors' collector resistance, is about 50Ω. It's also possible to drive LEDs from rectified AC with no filtering. To avoid oscillations, the LED supply should be bypassed with a 2.2 μF tantalum or 10 μF aluminum electrolytic capacitor. MODE PIN USE Pin 9, the Mode Select input, permits chaining of multiple XD3915, and controls bar or dot mode operation. The following tabulation shows the basic ways of using this input. Other more complex uses will be illustrated in the applications. Bar Graph Display: Wire Mode Select (pin 9) directly to pin 3 (V+ pin). Dot Display, Single XD3915 Driver: Leave the Mode Select pin open circuit. Dot Display, 20 or More LEDs: Connect pin 9 of the first driver in the series (i.e., the one with the lowest input voltage comparison points) to pin 1 of the next higher XD3915 driver. Continue connecting pin 9 of lower input drivers to pin 1 of higher input drivers for 30 or more LED displays. The last XD3915 driver in the chain will have pin 9 left open. All previous drivers should have a 20k resistor in parallel with LED #9 (pin 11 to VLED). Mode Pin Functional Description This pin actually performs two functions. Refer to the simplified block diagram below. *High for bar Figure 15. Block Diagram of Mode Pin Function 9 XD3915 DIP-18 XD3915 XD3915 Figure 16. Cascading XD3915 in Dot Mode Power dissipation, especially in bar mode should be given consideration. For example, with a 5V supply and all LEDs programmed to 20 mA the driver will dissipate over 600 mW. In this case a 7.5Ω resistor in series with the LED supply will cut device heating in half. The negative end of the resistor should be bypassed with a 2.2 μF solid tantalum capacitor to pin 2. TIPS ON RECTIFIER CIRCUITS The simplest way to display an AC signal using the XD3915 is to apply it right to pin 5 unrectified. Since the LED illuminated represents the instantaneous value of the AC waveform, one can readily discern both peak and average values of audio signals in this manner. The XD3915 will respond to positive half-cycles only but will not be damaged by signals up to ±35V (or up to ±100V if a 39k resistor is in series with the input). It's recommended to use dot mode and to run the LEDs at 30 mA for high enough average intensity. True average or peak detection requires rectification. If an XD3915 is set up with 10V full scale across its voltage divider, the turn-on point for the first LED is only 450 mV. A simple silicon diode rectifier won't work well at the low end due to the 600 mV diode threshold. The half-wave peak detector in Figure 17 uses a PNP emitterfollower in front of the diode. Now, the transistor's base-emitter voltage cancels out the diode offset, within about 100 mV. This approach is usually satisfactory when a single XD3915 is used for a 30 dB display. Display circuits using two or more XD3915 for a dynamic range of 60 dB or greater require more accurate detection. In the precision half-wave rectifier of Figure 18 the effective diode offset is reduced by a factor equal to the open-loop gain of the op amp. Filter capacitor C2 charges through R3 and discharges through R2 and R3, so that appropriate selection of these values results in either a peak or an average detector. The circuit has a gain equal to R2/R1. It's best to capacitively couple the input. Audio sources frequently have a small DC offset that can cause significant error at the low end of the log display. Op amps that slew quickly, such as the LF351, LF353, or LF356, are needed to faithfully respond to sudden transients. It may be necessary to trim out the op amp DC offset voltage to accurately cover a 60 dB range. Best results are obtained if the circuit is adjusted for the correct output when a low-level AC signal (10 mV to 20 mV) is applied, rather than adjusting for zero output with zero input. For precision full-wave averaging use the circuit in Figure 19. Using 1% resistors for R1 through R4, gain for positive and negative signal differs by only 0.5 dB worst case. Substituting 5% resistors increases this to 2 dB worst case. (A 2 dB gain difference means that the display may have a ±1 dB error when the input is a nonsymmetrical transient). The averaging time constant is R5–C2. A simple modification results in the precision full-wave detector of Figure 20. Since the filter capacitor is not buffered, this circuit can drive only high impedance loads such as the input of an XD3915. 10 XD3915 DIP-18 *DC Couple Figure 17. Half-Wave Peak Detector D1, D2: 1N914 or 1N4148 See Precision Half-Wave Rectifier Table R1 = R2 for AV = 1 R1 = R2/R10 for AV = 10 C1 = 10/R1 Figure 18. Precision Half-Wave Rectifier Precision Half-Wave Rectifier Average Peak R2 1k 100k R3 100k 1k 11 XD3915 DIP-18 D1, D2: 1N914 or 1N4148 Figure 19. Precision Full-Wave Average Detector D1, D2, D3, D4: 1N914 or 1N4148 Figure 20. Precision Full-Wave Peak Detector CASCADING THE XD3915 To display signals of 60 dB or 90 dB dynamic range, multiple XD3915 can be easily cascaded. Alternatively, it is possible to cascade an XD3915 with XD3914 for a log/linear display or with an XD3916 to get an extended range VU meter. A simple, low cost approach to cascading two XD3915 is to set the reference voltages of the two chips 30 dB apart as in Figure 21. Potentiometer R1 is used to adjust the full scale voltage of XD3915 #1 to 316 mV nominally while the second IC's reference is set at 10V by R4. The drawback of this method is that the threshold of LED #1 is only 14 mV and, since the XD3915 can have an offset voltage as high as 10 mV, large errors can occur. This technique is not recommended for 60 dB displays requiring good accuracy at the first few display thresholds. 12 XD3915 DIP-18 A better approach shown in Figure 22 is to keep the reference at 10V for both XD3915 and amplify the input signal to the lower XD3915 by 30 dB. Since two 1% resistors can set the amplifier gain within ±0.2 dB, a gain trim is unnecessary. However, an op amp offset voltage of 5 mV will shift the first LED threshold as much as 4 dB, so that an offset trim may be required. Note that a single adjustment can null out offset in both the precision rectifier and the 30 dB gain stage. Alternatively, instead of amplifying, input signals of sufficient amplitude can be fed directly to the lower XD3915 and attenuated by 30 dB to drive the second XD3915. XD3915 XD3915 Figure 21. Low Cost Circuit for 60 dB Display XD3915 XD3915 Figure 22. Improved Circuit for 60 dB Display To extend this approach to get a 90 dB display, another 30 dB of amplification must be placed in the signal path ahead of the lowest XD3915. Extreme care is required as the lowest XD3915 displays input signals down to 0.5 mV! Several offset nulls may be required. High currents should not share the same path as the low level signal. Also power line wiring should be kept away from signal lines. TIPS ON REFERENCE VOLTAGE AND LED CURRENT PROGRAMMING Single XD3915 The equations in Figure 23 illustrate how to choose resistor values to set reference voltage for the simple case where no LED intensity adjustment is required. A LED current of 10 mA to 20 mA generally produces adequate illumination. Having 10V full-scale across the internal voltage divider gives best accuracy by keeping signal level high relative to the offset voltage of the internal comparators. However, this causes 450 μA to flow from pin 7 into the divider which means that the LED current will be at least 5 mA. R1 will typically be between 1 kΩ and 2 kΩ. To trim the reference voltage, vary R2. 13 XD3915 DIP-18 The circuit in Figure 24 shows how to add a LED intensity control which can vary LED current from 9 mA to 28 mA. The reference adjustment has some effect on LED intensity but the reverse is not true. Multiple XD3915 Figure 25 shows how to obtain a common reference trim and intensity control for two XD3915. The two ICs may be connected in cascade for a 60 dB display or may be handling separate channels for stereo. This technique can be extended for larger numbers of XD3915 by varying the values of R1, R2 and R3 in inverse proportion to the number of devices tied in. The ICs' internal references track within 100 mV so that worst case error from chip to chip is only 0.1 dB for VREF = 10V. XD3915 Figure 23. Design Equations for Fixed LED Intensity XD3915 *9 mA < ILED < 28 mA @ VREF = 10V Figure 24. Varying LED Intensity 14 XD3915 DIP-18 XD3915 XD3915 Figure 25. Independent Adjustment of Reference Voltage and LED Intensity for Multiple XD3915 The scheme in Figure 26 is useful when the reference and LED intensity must be adjusted independently over a wide range. The RHI voltage can be adjusted from 1.2V to 10V with no effect on LED current. Since the internal divider here does not load down the reference, minimum LED current is much lower. At the minimum recommended reference load of 80 μA, LED current is about 0.8 mA. The resistor values shown give a LED current range from 1.5 mA to 20 mA. At the low end of the intensity adjustment, the voltage drop across the 510Ω current-sharing resistors is so small that chip to chip variation in reference voltage may yield a visible variation in LED intensity. The optional approach shown of connecting the bottom end of the intensity control pot to a negative supply overcomes this problem by allowing a larger voltage drop across the (larger) current-sharing resistors. Other Applications For increased resolution, it's possible to obtain a display with a smooth transition between LEDs. This is accomplished by varying the reference level at pin 6 by 3 dBp-p as shown in Figure 27. The signal can be a triangle, sawtooth or sine wave from 60 Hz to 1 kHz. The display can be run in either dot or bar mode. When an exponentially decaying RC discharge waveform is applied to pin 5, the XD3915 outputs will switch at equal intervals. This makes a simple timer or sequencer. Each time interval is equal to RC/3. The output may be used to drive logic, opto-couplers, relays or PNP transistors, for example. 15 XD3915 DIP-18 Typical Applications XD3915 XD3915 XD3915 *Optional circuit for improved intensity matching at low currents. See text. Figure 26. Wide-Range Adjustment of Reference Voltage and LED Intensity for Multiple XD3915 XD3915 Figure 27. 0V to 10V Log Display with Smooth Transitions 16 XD3915 DIP-18 XD3915 XD3915 This application shows that the LED supply requires minimal filtering. *See Application Hints for optional Peak or Average Detector. †Adjust R3 for 3 dB difference between LED #11 and LED #12. Figure 28. Extended Range VU Meter XD3915 Figure 29. Vibration Meter LED Threshold 1 60 mV 2 80 mV 3 110 mV 17 XD3915 DIP-18 LED Threshold 4 160 mV 5 220 mV 6 320 mV 7 440 mV 8 630 mV 9 890 mV 10 1.25V XD3915 *The input to the dot bar switch may be taken from cathodes of other LEDs. Display will change to bar as soon as the LED so selected begins to light. **Optional. Shunts 100 μA auxiliary sink current away from LED #1. Figure 30. Indicator and Alarm, Full-Scale Changes Display from Dot to Bar 18 XD3915 DIP-18 XD3915 XD3915 **Optional. Shunts 100 μA auxiliary sink current away from LED #11. Figure 31. 60 dB Dot Mode Display 19 XD3915 DIP-18 XD3915 R7 thru R15: 10k ±10% D1, D2: 1N914 or 1N4148 *Half-wave peak detector. See Application Hints. Figure 32. Driving Vacuum Fluorescent Display 20 XD3915 DIP-18 XD3915 Supply current drain is only 15 mA with ten LEDs illuminated. Figure 33. Low Current Bar Mode Display XD3915 Figure 34. Driving Liquid Crystal Display 21 XD3915 DIP-18 XD3915 Full-scale causes the full bar display to flash. If the junction of R1 and C1 is connected to a different LED cathode, the display will flash when that LED lights, and at any higher input signal. Figure 35. Bar Display with Alarm Flasher XD3915 XD3915 Logarithmic response allows coarse and fine adjustments without changing scale. Resolution ranges from 10 mV at VIN = 0 mV to 500 mV at VIN = ±1.25V. Figure 36. Precision Null Meter 22 XD3915 DIP-18 XD3915 The LED currents are approximately 10 mA, and the XD3915 outputs operate in saturation for minimum dissipation. *This point is partially regulated and decreases in voltage with temperature. Voltage requirements of the XD3915 also decrease with temperature. Figure 37. Operating with a High Voltage Supply (Dot Mode Only) 23 XD3915 DIP-18 XD3915 XD3915 *Resistor value selects exposure 1/2 f/stop resolution Ten f/stop range (1000:1) Typical supply current is 8 mA. Figure 38. Light Meter 24 XD3915 DIP-18 XD3915 Figure 39. Audio Power Meter Load Impedance R1 4Ω 10k 8Ω 18k 16Ω 30k 25 XD3915 DIP-18 Connection Diagram *Discontinued, Life Time Buy date 12/20/99 Figure 40. PDIP Package Top View See Package Number NFK0018A Definition of Terms Absolute Accuracy: The difference between the observed threshold voltage and the ideal threshold voltage for each comparator. Specified and tested with 10V across the internal voltage divider so that resistor ratio matching error predominates over comparator offset voltage. Adjust Pin Current: Current flowing out of the reference adjust pin when the reference amplifier is in the linear region. Comparator Gain: The ratio of the change in output current (ILED) to the change in input voltage (VIN) required to produce it for a comparator in the linear region. Dropout Voltage: The voltage measured at the current source outputs required to make the output current fall by 10%. Input Bias Current: Current flowing out of the signal input when the input buffer is in the linear region. LED Current Regulation: The change in output current over the specified range of LED supply voltage (VLED) as measured at the current source outputs. As the forward voltage of an LED does not change significantly with a small change in forward current, this is equivalent to changing the voltage at the LED anodes by the same amount. Line Regulation: The average change in reference output voltage (VREF) over the specified range of supply voltage (V+). Load Regulation: The change in reference output voltage over the specified range of load current (IL(REF)). Offset Voltage: The differential input voltage which must be applied to each comparator to bias the output in the linear region. Most significant error when the voltage across the internal voltage divider is small. Specified and tested with pin 6 voltage (VRHI) equal to pin 4 voltage (VRLO). Relative Accuracy: The difference between any two adjacent threshold points. Specified and tested with 10V across the internal voltage divider so that resistor ratio matching error predominates over comparator offset voltage. 26 XD3915 DIP-18 DIP 27 26
XD3915 价格&库存
很抱歉,暂时无法提供与“XD3915”相匹配的价格&库存,您可以联系我们找货
