XD3914
XD3914
    XINLUDA(信路达)
    DIP18_22.86X6.35MM
    LED驱动器模组 DIP-18
XD3914 数据手册
XD3914 DIP-18 FEATURES Versatility was designed into the XD3914 so that controller, visual alarm, and expanded scale functions are easily added on to the display system. The circuit can drive LEDs of many colors, or low-current incandescent lamps. Many XD3914 can be “chained” to form displays of 20 to over 100 segments. Both ends of the voltage divider are externally available so that 2 drivers can be made into a zero-center meter. 1 • • 2 • • • • • • • • • • Drives LEDs, LCDs or Vacuum Fluorescents Bar or Dot Display Mode Externally Selectable by User Expandable to Displays of 100 Steps Internal Voltage Reference from 1.2V to 12V Operates with Single Supply of Less than 3V Inputs Operate Down to Ground Output Current Programmable from 2 mA to 30 mA No Multiplex Switching or Interaction Between Outputs Input Withstands ±35V without Damage or False Outputs LED Driver Outputs are Current Regulated, Open-collectors Outputs can Interface with TTL or CMOS Logic The Internal 10-step Divider is Floating and can be Referenced to a Wide Range of Voltages The XD3914 is very easy to apply as an analog meter circuit. A 1.2V full-scale meter requires only 1 resistor and a single 3V to 15V supply in addition to the 10 display LEDs. If the 1 resistor is a pot, it becomes the LED brightness control. The simplified block diagram illustrates this extremely simple external circuitry. When in the dot mode, there is a small amount of overlap or “fade” (about 1 mV) between segments. This assures that at no time will all LEDs be “OFF”, and thus any ambiguous display is avoided. Various novel displays are possible. Much of the display flexibility derives from the fact that all outputs are individual, DC regulated currents. Various effects can be achieved by modulating these currents. The individual outputs can drive a transistor as well as a LED at the same time, so controller functions including “staging” control can be performed. The XD3914 can also act as a programmer, or sequencer. DESCRIPTION The XD3914 is a monolithic integrated circuit that senses analog voltage levels and drives 10 LEDs, providing a linear analog display. A single pin changes the display from a moving dot to a bar graph. Current drive to the LEDs is regulated and programmable, eliminating the need for resistors. This feature is one that allows operation of the whole system from less than 3V. The XD3914 is rated for operation from 0°C to +70°C. The XD3914 is available in an 18-lead PDIP (NFK) package. The following typical application illustrates adjusting of the reference to a desired value, and proper grounding for accurate operation, and avoiding oscillations. The circuit contains its own adjustable reference and accurate 10-step voltage divider. The low-bias-current input buffer accepts signals down to ground, or V−, yet needs no protection against inputs of 35V above or below ground. The buffer drives 10 individual comparators referenced to the precision divider. Indication non-linearity can thus be held typically to ½%, even over a wide temperature range. 1 XD3914 DIP-18 TYPICAL APPLICATIONS XD3914 Note: Grounding method is typical of all uses. The 2.2μF tantalum or 10 μF aluminum electrolytic capacitor is needed if leads to the LED supply are 6″ or longer. Figure 1. 0V to 5V Bar Graph Meter 2 XD3914 DIP-18 ABSOLUTE MAXIMUM RATINGS (1) (2) Power Dissipation PDIP (NFK) (3) 1365 mW Supply Voltage 25V Voltage on Output Drivers Input Signal Overvoltage 25V (4) ±35V Divider Voltage −100 mV to V+ Reference Load Current 10 mA Storage Temperature Range −55°C to +150°C Soldering Information PDIP Package Soldering (10 seconds) 260°C PLCC Package Vapor Phase (60 seconds) 215°C Infrared (15 seconds) (1) (2) (3) 220°C Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is functional, but do not ensure specific performance limits. Electrical Characteristics state DC and AC electrical specifications under particular test conditions which ensure specific performance limits. This assumes that the device is within the Operating Ratings. Specifications are not specified for parameters where no limit is given, however, the typical value is a good indication of device performance. The maximum junction temperature of the XD3914 is 100°C. Devices must be derated for operation at elevated temperatures. Junction to ambient thermal resistance is 55°C/W for the PDIP (NFK package). Pin 5 input current must be limited to ±3mA. The addition of a 39k resistor in series with pin 5 allows ±100V signals without damage. ELECTRICAL CHARACTERISTICS (1) (2) Parameter Conditions (1) Min Typ Max Units COMPARATOR Offset Voltage, Buffer and First Comparator 0V ≤ VRLO = VRHI ≤ 12V, ILED = 1 mA 3 10 mV Offset Voltage, Buffer and Any Other Comparator 0V ≤ VRLO = VRHI ≤ 12V, ILED = 1 mA 3 15 mV Gain (ΔILED/ΔVIN) IL(REF) = 2 mA, ILED = 10 mA Input Bias Current (at Pin 5) 0V ≤ VIN ≤ V+ − 1.5V Input Signal Overvoltage No Change in Display 3 8 25 mA/mV 100 nA 35 V 12 17 kΩ 0.5 2 % −35 VOLTAGE-DIVIDER Divider Resistance Accuracy (1) (2) (3) Total, Pin 6 to 4 8 (3) Unless otherwise stated, all specifications apply with the following conditions: 3 VDC ≤ V+ ≤ 20 VDC VREF, VRHI, VRLO ≤ (V+ − 1.5V) 3 VDC ≤ VLED ≤ V+ 0V ≤ VIN ≤ V+ − 1.5V −0.015V ≤ VRLO ≤ 12VDC TA = +25°C, IL(REF) = 0.2 mA, VLED = 3.0V, pin 9 connected to pin 3 (Bar Mode). −0.015V ≤ VRHI ≤ 12 VDCFor higher power dissipations, pulse testing is used. Pin 5 input current must be limited to ±3mA. The addition of a 39k resistor in series with pin 5 allows ±100V signals without damage. Accuracy is measured referred to +10.000VDC at pin 6, with 0.000 VDC at pin 4. At lower full-scale voltages, buffer and comparator offset voltage may add significant error. 3 XD3914 DIP-18 ELECTRICAL CHARACTERISTICS(1)(2) (continued) Parameter Conditions (1) Min Typ Max Units 1.2 1.28 1.34 V VOLTAGE REFERENCE Output Voltage 0.1 mA ≤ IL(REF) ≤ 4 mA, V+ = VLED = 5V Line Regulation 3V ≤ V+ ≤ 18V 0.01 0.03 %/V Load Regulation 0.1 mA ≤ IL(REF) ≤ 4 mA, V+ = VLED = 5V 0.4 2 % Output Voltage Change with Temperature 0°C ≤ TA ≤ +70°C, IL(REF) = 1 mA, V+ = 5V 1 Adjust Pin Current 75 % 120 μA mA OUTPUT DRIVERS LED Current V+ = VLED = 5V, IL(REF) = 1 mA LED Current Difference (Between Largest and Smallest LED Currents) VLED = 5V LED Current Regulation 2V ≤ VLED ≤ 17V 10 13 ILED = 2 mA 0.12 0.4 ILED = 20 mA 1.2 3 ILED = 2 mA 0.1 0.25 ILED = 20 mA 1 3 Dropout Voltage ILED(ON) = 20 mA, VLED = 5V, ΔILED = 2 mA Saturation Voltage ILED = 2.0 mA, IL(REF) = 0.4 mA Output Leakage, Each Collector (Bar Mode) (4) Output Leakage (Dot Mode) (4) 7 1.5 mA mA V 0.15 0.4 V 0.1 10 μA 0.1 10 μA 150 450 μA V+ = 5V, IL(REF) = 0.2 mA 2.4 4.2 mA V+ = 20V, IL(REF) = 1.0 mA 6.1 9.2 mA Pins 10–18 Pin 1 60 SUPPLY CURRENT Standby Supply Current (All Outputs Off) (4) Bar mode results when pin 9 is within 20mV of V+. Dot mode results when pin 9 is pulled at least 200mV below V+ or left open circuit. LED No. 10 (pin 10 output current) is disabled if pin 9 is pulled 0.9V or more below VLED. 4 XD3914 DIP-18 TYPICAL PERFORMANCE CHARACTERISTICS Supply Current vs Temperature Operating Input Bias Current vs Temperature Figure 2. Figure 3. Reference Voltage vs Temperature Reference Adjust Pin Current vs Temperature Figure 4. Figure 5. LED Current-Regulation Dropout LED Driver Saturation Voltage Figure 6. Figure 7. 5 XD3914 DIP-18 TYPICAL PERFORMANCE CHARACTERISTICS (continued) Input Current Beyond Signal Range (Pin 5) LED Current vs Reference Loading Figure 8. Figure 9. LED Driver Current Regulation Total Divider Resistance vs Temperature Figure 10. Figure 11. Common-Mode Limits Output Characteristics Figure 12. Figure 13. 6 XD3914 DIP-18 BLOCK DIAGRAM (Showing Simplest Application) 7 XD3914 DIP-18 FUNCTIONAL DESCRIPTION The simplified XD3914 block diagram is to give the general idea of the circuit's operation. A high input impedance buffer operates with signals from ground to 12V, and is protected against reverse and overvoltage signals. The signal is then applied to a series of 10 comparators; each of which is biased to a different comparison level by the resistor string. In the example illustrated, the resistor string is connected to the internal 1.25V reference voltage. In this case, for each 125mV that the input signal increases, a comparator will switch on another indicating LED. This resistor divider can be connected between any 2 voltages, providing that they are 1.5V below V+ and no less than V−. If an expanded scale meter display is desired, the total divider voltage can be as little as 200mV. Expanded-scale meter displays are more accurate and the segments light uniformly only if bar mode is used. At 50mV or more per step, dot mode is usable. INTERNAL VOLTAGE REFERENCE The reference is designed to be adjustable and develops a nominal 1.25V between the REF OUT (pin 7) and REF ADJ (pin 8) terminals. The reference voltage is impressed across program resistor R1 and, since the voltage is constant, a constant current I1 then flows through the output set resistor R2 giving an output voltage of: XD3914 Since the 120μA current (max) from the adjust terminal represents an error term, the reference was designed to minimize changes of this current with V+ and load changes. CURRENT PROGRAMMING A feature not completely illustrated by the block diagram is the LED brightness control. The current drawn out of the reference voltage pin (pin 7) determines LED current. Approximately 10 times this current will be drawn through each lighted LED, and this current will be relatively constant despite supply voltage and temperature changes. Current drawn by the internal 10-resistor divider, as well as by the external current and voltage-setting divider should be included in calculating LED drive current. The ability to modulate LED brightness with time, or in proportion to input voltage and other signals can lead to a number of novel displays or ways of indicating input overvoltages, alarms, etc. MODE PIN USE Pin 9, the Mode Select input controls chaining of multiple XD3914 and controls bar or dot mode operation. The following tabulation shows the basic ways of using this input. Other more complex uses will be illustrated in the applications. Bar Graph Display: Wire Mode Select (pin 9) directly to pin 3 (V+ pin). Dot Display, Single XD3914 Driver: Leave the Mode Select pin open circuit. Dot Display, 20 or More LEDs: Connect pin 9 of the first driver in the series (i.e., the one with the lowest input voltage comparison points) to pin 1 of the next higher XD3914 driver. Continue connecting pin 9 of lower input drivers to pin 1 of higher input drivers for 30, 40, or more LED displays. The last XD3914 driver in the chain will have pin 9 wired to pin 11. All previous drivers should have a 20k resistor in parallel with LED No. 9 (pin 11 to VLED). 8 XD3914 DIP-18 MODE PIN FUNCTIONAL DESCRIPTION This pin actually performs two functions. Refer to the simplified block diagram below. *High for bar Figure 14. Block Diagram of Mode Pin Description DOT OR BAR MODE SELECTION The voltage at pin 9 is sensed by comparator C1, nominally referenced to (V+ − 100mV). The chip is in bar mode when pin 9 is above this level; otherwise it's in dot mode. The comparator is designed so that pin 9 can be left open circuit for dot mode. Taking into account comparator gain and variation in the 100mV reference level, pin 9 should be no more than 20mV below V+ for bar mode and more than 200mV below V+ (or open circuit) for dot mode. In most applications, pin 9 is either open (dot mode) or tied to V+ (bar mode). In bar mode, pin 9 should be connected directly to pin 3. Large currents drawn from the power supply (LED current, for example) should not share this path so that large IR drops are avoided. DOT MODE CARRY In order for the display to make sense when multiple XD3914 are cascaded in dot mode, special circuitry has been included to shut off LED No. 10 of the first device when LED No. 1 of the second device comes on. The connection for cascading in dot mode has already been described and is depicted below. As long as the input signal voltage is below the threshold of the second XD3914 LED No. 11 is off. Pin 9 of XD3914 No. 1 thus sees effectively an open circuit so the chip is in dot mode. As soon as the input voltage reaches the threshold of LED No. 11, pin 9 of XD3914 No. 1 is pulled an LED drop (1.5V or more) below VLED. This condition is sensed by comparator C2, referenced 600mV below VLED. This forces the output of C2 low, which shuts off output transistor Q2, extinguishing LED No. 10. VLED is sensed via the 20k resistor connected to pin 11. The very small current (less than 100μA) that is diverted from LED No. 9 does not noticeably affect its intensity. An auxiliary current source at pin 1 keeps at least 100μA flowing through LED No. 11 even if the input voltage rises high enough to extinguish the LED. This ensures that pin 9 of XD3914 No. 1 is held low enough to force LED No. 10 off when any higher LED is illuminated. While 100μA does not normally produce significant LED illumination, it may be noticeable when using high-efficiency LEDs in a dark environment. If this is bothersome, the simple cure is to shunt LED No. 11 with a 10k resistor. The 1V IR drop is more than the 900mV worst case required to hold off LED No. 10 yet small enough that LED No. 11 does not conduct significantly. 9 XD3914 DIP-18 OTHER DEVICE CHARACTERISTICS The XD3914 is relatively low-powered itself, and since any number of LEDs can be powered from about 3V, it is a very efficient display driver. Typical standby supply current (all LEDs OFF) is 1.6mA (2.5mA max). However, any reference loading adds 4 times that current drain to the V+ (pin 3) supply input. For example, an XD3914 with a 1mA reference pin load (1.3k), would supply almost 10mA to every LED while drawing only 10mA from its V+ pin supply. At full-scale, the IC is typically drawing less than 10% of the current supplied to the display. The display driver does not have built-in hysteresis so that the display does not jump instantly from one LED to the next. Under rapidly changing signal conditions, this cuts down high frequency noise and often an annoying flicker. An “overlap” is built in so that at no time between segments are all LEDs completely OFF in the dot mode. Generally 1 LED fades in while the other fades out over a mV or more of range (1). The change may be much more rapid between LED No. 10 of one device and LED No. 1 of a second device “chained” to the first. The XD3914 features individually current regulated LED driver transistors. Further internal circuitry detects when any driver transistor goes into saturation, and prevents other circuitry from drawing excess current. This results in the ability of the XD3914 to drive and regulate LEDs powered from a pulsating DC power source, i.e., largely unfiltered. (Due to possible oscillations at low voltages a nominal bypass capacitor consisting of a 2.2μF solid tantalum connected from the pulsating LED supply to pin 2 of the XD3914 is recommended.) This ability to operate with low or fluctuating voltages also allows the display driver to interface with logic circuitry, opto-coupled solid-state relays, and low-current incandescent lamps. XD3914 XD3914 Figure 15. Cascading XD3914 in Dot Mode (1) Accuracy is measured referred to +10.000VDC at pin 6, with 0.000 VDC at pin 4. At lower full-scale voltages, buffer and comparator offset voltage may add significant error. 10 XD3914 DIP-18 Typical Applications XD3914 XD3914 Figure 16. Zero-Center Meter, 20-Segment 11 XD3914 DIP-18 XD3914 *This application illustrates that the LED supply needs practically no filtering Calibration: With a precision meter between pins 4 and 6 adjust R1 for voltage VD of 1.20V. Apply 4.94V to pin 5, and adjust R4 until LED No. 5 just lights. The adjustments are non-interacting. Figure 17. Expanded Scale Meter, Dot or Bar Table 1. Application Example: Grading 5V Regulators Highest No. LED on Color VOUT(MIN) 10 Red 5.54 9 Red 5.42 8 Yellow 5.30 7 Green 5.18 6 Green 5.06 5V 5 Green 4.94 4 Green 4.82 3 Yellow 4.7 2 Red 4.58 1 Red 4.46 12 XD3914 DIP-18 XD3914 LEDs light up as illustrated with the upper lit LED indicating the actual input voltage. The display appears to increase resolution and provides an analog indication of overrange. Figure 18. “Exclamation Point” Display XD3914 *The input to the Dot-Bar Switch may be taken from cathodes of other LEDs. Display will change to bar as soon as the LED so selected begins to light. Figure 19. Indicator and Alarm, Full-Scale Changes Display from Dot to Bar 13 XD3914 DIP-18 XD3914 Full-scale causes the full bar display to flash. If the junction of R1 and C1 is connected to a different LED cathode, the display will flash when that LED lights, and at any higher input signal. Figure 20. Bar Display with Alarm Flasher 14 XD3914 DIP-18 XD3914 Hysteresis is 0.5 mV to 1 mV Figure 21. Adding Hysteresis (Single Supply, Bar Mode Only) 15 XD3914 DIP-18 Figure 22. XD3914 The LED currents are approximately 10mA, and the XD3914 outputs operate in saturation for minimum dissipation. *This point is partially regulated and decreases in voltage with temperature. Voltage requirements of the XD3914 also decrease with temperature. Figure 23. Operating with a High Voltage Supply (Dot Mode Only) 16 XD3914 DIP-18 XD3914 XD3914 *The exact wiring arrangement of this schematic shows the need for Mode Select (pin 9) to sense the V+ voltage exactly as it appears on pin 3. Programs LEDs to 10mA Figure 24. 20-Segment Meter with Mode Switch APPLICATION HINTS Three of the most commonly needed precautions for using the XD3914 are shown in the first typical application drawing showing a 0V–5V bar graph meter. The most difficult problem occurs when large LED currents are being drawn, especially in bar graph mode. These currents flowing out of the ground pin cause voltage drops in external wiring, and thus errors and oscillations. Bringing the return wires from signal sources, reference ground and bottom of the resistor string (as illustrated) to a single point very near pin 2 is the best solution. Long wires from VLED to LED anode common can cause oscillations. Depending on the severity of the problem 0.05μF to 2.2μF decoupling capacitors from LED anode common to pin 2 will damp the circuit. If LED anode line wiring is inaccessible, often similar decoupling from pin 1 to pin 2 will be sufficient. 17 XD3914 DIP-18 If LED turn ON seems slow (bar mode) or several LEDs light (dot mode), oscillation or excessive noise is usually the problem. In cases where proper wiring and bypassing fail to stop oscillations, V+ voltage at pin 3 is usually below suggested limits. Expanded scale meter applications may have one or both ends of the internal voltage divider terminated at relatively high value resistors. These high-impedance ends should be bypassed to pin 2 with at least a 0.001μF capacitor, or up to 0.1μF in noisy environments. Power dissipation, especially in bar mode should be given consideration. For example, with a 5V supply and all LEDs programmed to 20mA the driver will dissipate over 600mW. In this case a 7.5Ω resistor in series with the LED supply will cut device heating in half. The negative end of the resistor should be bypassed with a 2.2μF solid tantalum capacitor to pin 2 of the XD3914 Turning OFF of most of the internal current sources is accomplished by pulling positive on the reference with a current source or resistance supplying 100μA or so. Alternately, the input signal can be gated OFF with a transistor switch. Other special features and applications characteristics will be illustrated in the following applications schematics. Notes have been added in many cases, attempting to cover any special procedures or unusual characteristics of these applications. A special section called APPLICATION TIPS FOR THE XD3914 ADJUSTABLE REFERENCE has been included with these schematics. APPLICATION TIPS FOR THE XD3914 ADJUSTABLE REFERENCE Greatly Expanded Scale (Bar Mode Only) Placing the XD3914 internal resistor divider in parallel with a section (≃230Ω) of a stable, low resistance divider greatly reduces voltage changes due to IC resistor value changes with temperature. Voltage V1 should be trimmed to 1.1V first by use of R2. Then the voltage V2 across the IC divider string can be adjusted to 200mV, using R5 without affecting V1. LED current will be approximately 10mA. Non-Interacting Adjustments For Expanded Scale Meter (4.5V to 5V, Bar or Dot Mode) This arrangement allows independent adjustment of LED brightness regardless of meter span and zero adjustments. First, V1 is adjusted to 5V, using R2. Then the span (voltage across R4) can be adjusted to exactly 0.5V using R6 without affecting the previous adjustment. R9 programs LED currents within a range of 2.2mA to 20mA after the above settings are made. XD3914 Figure 25. Greatly Expanded Scale (Bar Mode Only) 18 XD3914 DIP-18 ADJUSTING LINEARITY OF SEVERAL STACKED DIVIDERS Three internal voltage dividers are shown connected in series to provide a 30-step display. If the resulting analog meter is to be accurate and linear the voltage on each divider must be adjusted, preferably without affecting any other adjustments. To do this, adjust R2 first, so that the voltage across R5 is exactly 1V. Then the voltages across R3 and R4 can be independently adjusted by shunting each with selected resistors of 6kΩ or higher resistance. This is possible because the reference of XD3914 No. 3 is acting as a constant current source. The references associated with XD3914 No. 1 and No. 2 should have their Ref Adj pins (pin 8) wired to ground, and their Ref Outputs loaded by a 620Ω resistor to ground. This makes available similar 20mA current outputs to all the LEDs in the system. If an independent LED brightness control is desired (as in the previous application), a unity gain buffer, such as the 310, should be placed between pin 7 and R1, similar to the previous application. (4.5V to 5V, Bar or Dot Mode) Figure 26. Non-Interacting Adjustments for Expanded Scale Meter 19 XD3914 DIP-18 XD3914 XD3914 XD3914 Figure 27. Adjusting Linearity of Several Stacked Dividers OTHER APPLICATIONS • • • • • • • • • • • “Slow”—fade bar or dot display (doubles resolution) 20-step meter with single pot brightness control 10-step (or multiples) programmer Multi-step or “staging” controller Combined controller and process deviation meter Direction and rate indicator (to add to DVMs) Exclamation point display for power saving Graduations can be added to dot displays. Dimly light every other LED using a resistor to ground Electronic “meter-relay”—display could be circle or semi-circle Moving “hole” display—indicator LED is dark, rest of bar lit Drives vacuum-fluorescent and LCDs using added passive parts 20 XD3914 DIP-18 DIP 21 20
XD3914 价格&库存
很抱歉,暂时无法提供与“XD3914”相匹配的价格&库存,您可以联系我们找货
