XD4066 DIP-14
1. General description
TheXD4066 provides four single-pole, si ngle-throw analog switch functions. Each
switch has two input/output terminals (nY and nZ) and an active HIGH enable input (nE).
When nE is LOW, the analog switch is turned off.
The XD4066 is pin compatible with the XD4016 but exhibits a much lower ON
resistance. In addition the ON resistance is relatively constant over the full input signal
range.
2. Features and benefits
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Inputs and outputs are protected against electrostatic effects
Specified from 40 C to +85 C and 40 C to +125 C
3. Applications
Analog multiplexing and demultiplexing
Digital multiplexing and demultiplexing
Signal gating
4 Functional diagram
Fig 1.
Q<
Q(
9''
9''
966
Functional diagram
Fig 2.
1
Logic diagram (one switch)
Q=
XD4066 DIP-14
Quad single-pole single-throw analog switch
5 Pinning information
Fig 3.
Pin configuration
Table 2.
Pin description
Symbol
9''
966
XD4066
Pin
Description
1Y, 2Y, 3Y, 4Y
1, 4, 8, 11
independent input or output
1Z, 2Z, 3Z, 4Z
2, 3, 9, 10
1E, 2E, 3E, 4E
13, 5, 6, 12
enable input (active HIGH)
VSS
7
ground (0 V)
VDD
14
supply voltage
2
XD4066 DIP-14
6 Functional description
Table 3.
Function table[1]
Input nE
Switch
H
ON
L
OFF
[1]
H = HIGH voltage level; L = LOW voltage level.
7 Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
Conditions
VI < 0.5 V or VI > VDD + 0.5 V
Min
Max
Unit
0.5
+18
V
10
mA
0.5
VDD + 0.5 V
II/O
input/output current
10
mA
Tstg
storage temperature
65
+150
C
Tamb
ambient temperature
40
+125
C
Ptot
total power dissipation
500
mW
100
mW
[1]
Tamb = 40 C to +125 C
[2]
SO14
P
power dissipation
per switch
[1]
To avoid drawing VDD current out of terminal nZ, when switch current flows into terminals nY, the voltage drop across the bidirectional
switch must not exceed 0.4 V. If the switch current flows into terminal nZ, no VDD current will flow out of terminals nY, in this case there
is no limit for the voltage drop across the switch, but the voltages at nY and nZ may not exceed VDD or VSS.
[2]
For SO14 packages: above Tamb = 70 C, Ptot derates linearly with 8 mW/K.
8 Recommended operating conditions
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDD
supply voltage
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
40
+125
C
t/V
input transition rise and fall
rate
VDD = 5 V
3.75
s/V
VDD = 10 V
0.5
s/V
VDD = 15 V
0.08
s/V
3
XD4066 DIP-14
9 Static characteristics
Table 6.
VSS = 0 V; VI = VSS or VDD unless otherwise specified.
Symbol Parameter
Conditions
VDD
Tamb = 40 C Tamb = 25 C
Min
VIH
VIL
HIGH-level
input voltage
LOW-level
input voltage
IO < 1 A
IO < 1 A
II
input leakage
current
IS(OFF)
OFF-state
leakage
current
IDD
supply current all valid input
combinations
CI
input
capacitance
per channel;
see Figure 4
nE input
Max
Min
Max
Min
Max
Min
Max
5V
3.5
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
4.0
V
15 V
0.1
0.1
1.0
1.0
A
15 V
200
nA
5V
1.0
1.0
7.5
7.5
A
10 V
2.0
2.0
15.0
15.0
A
15 V
4.0
4.0
30.0
30.0
A
7.5
pF
9''
Q(
9,/
Q=
9,
Fig 4.
Tamb = 85 C Tamb = 125 C Unit
Q<
966
Test circuit for measuring OFF-state leakage current
4
,6
92
XD4066 DIP-14
Table 7.
ON resistance
Tamb = 25 C; ISW = 200 A; VSS = 0 V.
Symbol
Parameter
Conditions
VDD
Typ
Max
Unit
RON(peak)
ON resistance (peak)
VI = 0 V to VDD; see Figure 5 and
Figure 6
5V
350
2500
10 V
80
245
15 V
60
175
5V
115
340
10 V
50
160
RON(rail)
ON resistance (rail)
VI = 0 V; see Figure 5 and Figure 6
VI = VDD; see Figure 5 and Figure 6
RON
ON resistance mismatch
between channels
15 V
40
115
5V
120
365
10 V
65
200
15 V
50
155
5V
25
10 V
10
15 V
5
521
ȍ
96:
9''
Q(
9,+
Q<
9,
Q=
966
,6:
9,9
ISW = 200 A.
RON = VSW / ISW.
(1) VDD = 5 V
(2) VDD = 10 V
(3) VDD = 15 V
Fig 5.
Test circuit for measuring RON
Fig 6.
5
Typical RON as a function of input voltage
XD4066 DIP-14
10. Dynamic characteristics
Table 8.
Tamb = 25 C; VSS = 0 V; for test circuit see Figure 9.
Symbol
Parameter
Conditions
tPHL
HIGH to LOW propagation delay nY, nZ to nZ, nY; see Figure 7
tPHZ
tPZH
tPLZ
tPZL
HIGH to OFF-state
propagation delay
nE to nY, nZ; see Figure 8
OFF-state to HIGH
propagation delay
LOW to OFF-state
propagation delay
OFF-state to LOW
propagation delay
VDD
Typ
Max
Unit
5V
10
ns
10 V
5
10
ns
15 V
5
10
ns
5V
10
ns
10 V
5
10
ns
15 V
5
10
ns
5V
80
160
ns
10 V
65
130
ns
15 V
60
120
ns
5V
40
80
ns
10 V
ns
15 V
15
30
ns
5V
80
160
ns
10 V
70
140
ns
15 V
70
140
ns
5V
45
90
ns
10 V
ns
15 V
15
30
ns
Table 9.
Dynamic power dissipation PD
PD can be calculated from the formulas shown; VSS = 0 V; tr = tf 20 ns; Tamb = 25 C.
Symbol
PD
Parameter
dynamic power
dissipation
VDD
Typical formula for PD (W)
where:
5V
PD = 2500 fi + (fo CL) VDD
10 V
PD = 11500 fi + (fo CL) VDD2
fo = output frequency in MHz;
15 V
PD = 29000 fi + (fo CL)
CL = output load capacitance in pF;
2
VDD2
fi = input frequency in MHz;
VDD = supply voltage in V;
(CL fo) = sum of the outputs.
6
XD4066 DIP-14
10.1 Waveforms and test circuit
9,
90
90
W3/+
W3+/
LQSXWQ
很抱歉,暂时无法提供与“XD4066”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.17267
- 50+0.89716
- 150+0.79197
