XD754410
XD754410
    XINLUDA(信路达)
    DIP-16
    半桥驱动器 电源电压:4.5V~36V 输出类型:三态 低电平输出电流(IOL):1A 高电平输出电流(IOH):1A
XD754410 数据手册
XD754410 DIP16 1 Features 3 Description • • The XD754410 is a quadruple high-current half-H driver designed to provide bidirectional drive currents up to 1 A at voltages from 4.5 V to 36 V. The device is designed to drive inductive loads such as relays, solenoids, DC and bipolar stepping motors, as well as other high-current/high-voltage loads in positivesupply applications. 1 • • • • • • • • • • • 1-A Output-Current Capability Per Driver Applications Include Half-H and Full-H Solenoid Drivers and Motor Drivers Designed for Positive-Supply Applications Wide Supply-Voltage Range of 4.5 V to 36 V TTL- and CMOS-Compatible High-Impedance Diode-Clamped Inputs Separate Input-Logic Supply Thermal Shutdown Internal ESD Protection Input Hysteresis Improves Noise Immunity 3-State Outputs Minimized Power Dissipation Sink/Source Interlock Circuitry Prevents Simultaneous Conduction No Output Glitch During Power Up or Power Down All inputs are compatible with TTL-and low-level CMOS logic. Each output (Y) is a complete totempole driver with a Darlington transistor sink and a pseudo-Darlington source. Drivers are enabled in pairs with drivers 1 and 2 enabled by 1,2EN and drivers 3 and 4 enabled by 3,4EN. When an enable input is high, the associated drivers are enabled and their outputs become active and in phase with their inputs. When the enable input is low, those drivers are disabled and their outputs are off and in a highimpedance state. With the proper data inputs, each pair of drivers form a full-H (or bridge) reversible drive suitable for solenoid or motor applications. A separate supply voltage (VCC1) is provided for the logic input circuits to minimize device power dissipation. Supply voltage VCC2 is used for the output circuits. 2 Applications • • • The XD754410 is designed for operation from −40°C to 85°C. Stepper Motor Drivers DC Motor Drivers Latching Relay Drivers 4 Simplified Schematic 1 1 XD754410 DIP16 5 Pin Configuration and Functions 6 Pin Functions PIN NAME NO. 1,2EN 1 A Y GROUND TYPE DESCRIPTION I Enable driver channels 1 and 2 (active high input) 2, 7, 10, 15 I Driver inputs, non-inverting 3, 6, 11, 14 O Driver outputs 4, 5, 12, 13 — Device ground and heat sink pin. Connect to circuit board ground plane with multiple solid vias VCC2 8 — Power VCC for drivers 4.5V to 36V 3,4EN 9 I VCC1 16 — Enable driver channels 3 and 4 (active high input) 5V supply for internal logic translation 2 XD754410 DIP16 7 Specifications 7.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) (2) MIN MAX VCC1 Output supply voltage range –0.5 36 V VCC2 Output supply voltage range –0.5 36 V VI Input voltage –0.5 36 V VO Output voltage range –3 VCC2 + 3 V IP Peak output current ±2 A IO Continuous output current ±1 A PD Continuous total power dissipation at (or below) 25°C free-air temperature (3) TA Operating free-air temperature range –40 85 °C TJ Operating virtual junction temperature range –40 150 °C Tstg Storage temperature range 260 °C (1) (2) (3) UNIT 2075 mW Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. All voltage values are with respect to network GND. For operation above 25°C free-air temperature, derate linearly at the rate of 16.6 mW/°C. To avoid exceeding the design maximum virtual junction temperature, these ratings should not be exceeded. Due to variations in individual device electrical characteristics and thermal resistance, the built-in thermal overload protection can be activated at power levels slightly above or below the rated dissipation. 7.2 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) MIN MAX VCC1 Logic supply voltage 4.5 5.5 V VCC2 Output supply voltage 4.5 36 V VIH High-level input voltage 2 5.5 V VIL Low-level input voltage –0.3 (1) 0.8 V TJ Operating virtual junction temperature –40 125 °C TA Operating free-air temperature –40 85 °C (1) UNIT The algebraic convention, in which the least positive (most negative) limit is designated as minimum, is used in this data sheet for logic voltage levels. 7.3 Thermal Information XD754410 THERMAL METRIC (1) NE UNIT 16 PINS RθJA (1) Junction-to-ambient thermal resistance 60 °C/W For more information about traditional and new thermal metrics, see the IC Package Thermal Metrics application report, SPRA953. 3 XD754410 DIP16 7.4 Electrical Characteristics over operating free-air temperature range (unless otherwise noted) PARAMETER VIK Input clamp voltage TEST CONDITIONS High-level output voltage TYP MAX UNIT –0.9 –1.5 V VCC2 – 1.5 VCC2 – 1.1 II = –12 mA IOH = –0.5 A VOH MIN IOH = –1 A VCC2 – 2 IOH = –1 A, TJ = 25°C VCC2 – 1.8 V VCC2 – 1.4 IOL = 0.5 A VOL Low-level output voltage 1 1.4 1.2 1.8 IOK = –0.5 A VCC2 + 1.4 VCC2 + 2 IOK = 1 A VCC2 + 1.9 VCC2 + 2.5 IOL = 1 A 2 IOL = 1 A, TJ = 25°C VOKH High-level output clamp voltage VOKL Low-level output clamp voltage IOZ(off) Off-state high-impedance-state output current VO = VCC2 IIH High-level input current VI = 5.5 V IIL Low-level input current VI = 0 ICC1 ICC2 Output supply current Output supply current IOK = 0.5 A –1.1 –2 IOK = –1 A –1.3 –2.5 500 VO = 0 IO = 0 IO = 0 –500 V V V µA 10 µA –10 µA All outputs at high level 38 All outputs at low level 70 all outputs at high impedance 25 All outputs at high level 33 All outputs at low level 20 All outputs at high impedance mA nA 5 7.5 Switching Characteristics over operating free-air temperature range (unless otherwise noted), VCC1 = 5 V, VCC2 = 24 V, CL = 30 pF, TA = 25°C PARAMETER td1 Delay time, high-to-low-level output from A input td2 Delay time, low-to-high-level output from A input TEST CONDITIONS MIN TYP MAX UNIT 400 ns 800 ns 300 ns See Figure 3 tTLH Transition time, low-to-high-level output tTHL Transition time, high-to-low-level output 300 ns ten1 Enable time to the high level 700 ns ten2 Enable time to the low level 400 ns tdis1 Disable time from the high level 900 ns tdis2 Disable time from the low level 600 ns See Figure 4 4 XD754410 DIP16 7.6 Typical Characteristics VCC1 = 5 V, VCC2 = 24 V 24.0 2.0 -40C 23.8 25C 23.4 25C 1.6 125C Output Voltage (V) Output Voltage (V) 23.6 -40C 1.8 23.2 23.0 22.8 22.6 1.2 1.0 0.8 0.6 22.4 0.4 22.2 0.2 22.0 125C 1.4 0.0 0.0 0.2 0.4 0.6 Output Current (A) 0.8 1.0 0.0 0.2 0.4 0.6 Output Current (A) C001 Figure 1. VOH vs IOH Figure 2. VOL vs IOL 5 0.8 1.0 C001 XD754410 DIP16 8 Parameter Measurement Information A. The pulse generator has the following characteristics: tr ≤10 ns, tf ≤10 ns, tw = 10 µs, PRR = 5 kHz, ZO = 50 Ω B. CL includes probe and jig capacitance. Figure 3. Test Circuit and Switching Times from Data Inputs A. The pulse generator has the following characteristics: tr ≤10 ns, tf ≤10 ns, tw = 10 µs, PRR = 5 kHz, ZO = 50 Ω B. CL includes probe and jig capacitance. Figure 4. Test Circuit and Switching Times from Enable Inputs 6 XD754410 DIP16 9 Detailed Description 9.1 Overview The XD754410 is a quadruple high-current half-H driver designed to provide bidirectional drive currents up to 1 A at voltages from 4.5 V to 36 V. The device is designed to drive inductive loads such as relays, solenoids, DC and bipolar stepping motors, as well as other high-current/high-voltage loads in positive-supply applications. All inputs are compatible with TTL and low-level CMOS logic. Each output (Y) is a complete totem-pole driver with a Darlington transistor sink and a pseudo-Darlington source. Drivers are enabled in pairs with drivers 1 and 2 enabled by 1,2EN and drivers 3 and 4 enabled by 3,4EN. When an enable input is high, the associated drivers are enabled and their outputs become active and in phase with their inputs. When the enable input is low, those drivers are disabled and their outputs are off and in a high-impedance state. With the proper data inputs, each pair of drivers form a full-H (or bridge) reversible drive suitable for solenoid or motor applications. A separate supply voltage (VCC1) is provided for the logic input circuits to minimize device power dissipation. Supply voltage VCC2 is used for the output circuits. The XD754410 is designed for operation from −40°C to 85°C. 9.2 Functional Block Diagram 9.3 Feature Description 9.3.1 High Current, High Voltage Outputs Four high current and high voltage outputs feature clamp diodes for inductive load driving. Figure 5. Typical of All Outputs 7 XD754410 DIP16 Feature Description (continued) 9.3.2 TTL Compatible Inputs Data inputs and enable inputs are compatible with TTL. 3.3-V CMOS logic is also acceptable, however open or high impedance input voltage can approach VCC1 voltage. Figure 6. Equivalent of Each Input 9.4 Device Functional Modes Table 1. Function Table (1) INPUTS (2) (1) (2) A EN OUTPUTS Y H H H L H L X L Z H = high-level L = low-level X = irrelevant Z = high-impedance (off) In the thermal shutdown mode, the output is in a high-impedance state regardless of the input levels. 8 XD754410 DIP16 10 Application and Implementation 10.1 Application Information Provide a 5-V supply to VCC1 and valid logic input levels to data and enable inputs. VCC2 must be connected to a power supply capable of suppling the needed current and voltage demand for the loads connected to the outputs. 10.2 Typical Application 12 V XD754410 Figure 7. Typical Application Schematic 10.2.1 Design Requirements The design techniques in the following sections may be used for applications which fall within the following requirements. • 4.5-V minimum and 36-V maximum VCC2 voltage • 1000-mA or less output current per channel • 5-V supply with 10% tolerance or less • TTL compatible logic inputs 9 XD754410 DIP16 Typical Application (continued) 10.2.2 Application Curves Driver output voltage waveform with a two phase stepper motor; 12-V 20-Ω coils. 14 12 Voltage (V) 10 8 6 4 2 0 ±2 Output ±4 0 1 2 3 4 5 6 7 8 9 Time (ms) 10 C001 Figure 8. 100 Hz Driver Output Waveform 11 Power Supply Recommendations VCC1 is 5 V ± 0.5 V and VCC2 can be same supply as VCC1 or a higher voltage supply with peak voltage up to 36 V. Bypass capacitors of 0.1 uF or greater should be used at VCC1 and VCC2 pins. There are no power up or power down supply sequence order requirements. 12.2 Layout Example GND 0.1 μF 5V TTL Logic 1 1,2EN TTL Logic 2 1A 4A 15 TTL Logic 1 Ampere 3 1Y 4Y 14 1 Ampere GND VIAS VCC1 16 4 13 5 12 1 Ampere 6 2Y 3Y 11 1 Ampere TTL Logic 7 2A 3A 10 TTL Logic 5V to 36V 8 VCC2 3,4EN 9 1 μF GND Figure 9. Layout Diagram 10 TTL Logic XD754410 DIP16 DIP 11 10
XD754410 价格&库存
很抱歉,暂时无法提供与“XD754410”相匹配的价格&库存,您可以联系我们找货
