High speed CAN transceiver
XL1040 SOP8
FEATURES
GENERAL DESCRIPTION
• High speed (up to 1 MBaud)
The XL1040 is the interface between the Controller Area
Network (CAN) protocol controller and the physical bus.
It is primarily intended for high speed applications, up to
1 MBaud, in passenger cars. The device provides
differential transmit capability to the bus and differential
receive capability to the CAN controller.
• Very low-current standby mode with remote wake-up
capability via the bus
• Very low ElectroMagnetic Emission (EME)
• Differential receiver with high common-mode range for
ElectroMagnetic Immunity (EMI)
The XL1040 is the next step up from the 1050 high
speed CAN transceiver. Being pin compatible and offering
the same excellent EMC performance, the XL1040 also
features:
• Transceiver in unpowered state disengages from the
bus (zero load)
• Input levels compatible with 3.3 V and 5 V devices
• Voltage source for stabilizing the recessive bus level if
split termination is used (further improvement of EME)
• An ideal passive behaviour when supply voltage is off
• A very low-current standby mode with remote wake-up
capability via the bus.
• At least 110 nodes can be connected
• Transmit Data (TXD) dominant time-out function
This makes the XL1040 an excellent choice in nodes
which can be in power-down or standby mode in partially
powered networks.
• Bus pins protected against transients in automotive
environments
• Bus pins and pin SPLIT short-circuit proof to battery and
ground
• Thermally protected.
QUICK REFERENCE DATA
SYMBOL
PARAMETER
CONDITIONS
VCC
supply voltage
ICC
supply current
standby mode
VCANH
DC voltage on pin CANH
0 < VCC < 5.25 V; no time limit
VCANL
DC voltage on pin CANL
VSPLIT
DC voltage on pin SPLIT
Vesd
electrostatic discharge voltage
Human Body Model (HBM)
tPD(TXD-RXD)
propagation delay TXD to RXD
Tvj
virtual junction temperature
operating range
MIN.
UNIT
5.25
V
5
15
µA
−27
+40
V
−27
+40
V
−27
+40
V
pins CANH, CANL and SPLIT
−6
+6
kV
all other pins
−4
+4
kV
40
255
ns
−40
+150
°C
VSTB = 0 V
1
4.75
MAX.
XL1040
BLOCK DIAGRAM
VCC
handbook, full pagewidth
3
TXD
TIME-OUT &
SLOPE
1
TEMPERATURE
PROTECTION
V SPLIT
VCC
5
7
6
STB
RXD
GND
8
WAKE-UP
MODE CONTROL
4
SPLIT
CANH
CANL
DRIVER
WAKE-UP
FILTER
MUX
XL1040
2
Fig.1 Block diagram.
PINNING
SYMBOL
PIN
DESCRIPTION
TXD
1
transmit data input
GND
2
ground supply
TXD 1
VCC
3
supply voltage
GND 2
RXD
4
receive data output; reads out data
from the bus lines
SPLIT
5
common-mode stabilization output
CANL
6
LOW-level CAN bus line
CANH
7
HIGH-level CAN bus line
STB
8
standby mode control input
handbook, halfpage
8
STB
7
CANH
VCC 3
6
CANL
RXD 4
5
SPLIT
XL1040
Fig.2 Pin configuration.
2
XL1040
FUNCTIONAL DESCRIPTION
to the centre tap of the split termination (see Fig.4). In case
of a recessive bus voltage
很抱歉,暂时无法提供与“XL1040”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.02468
- 50+1.56492
- 150+1.36793
- 500+1.07892
- 2500+0.96952
