XH2576-5.0
XH2576-5.0
    XINLUDA(信路达)
    TO263
    功能类型:降压型 同步整流:否 输出通道数:1 拓扑结构:降压式 输入电压:4V~40V 输出电压:5V 输出电流(最大值):3A 开关频率:52kHz SIMPLE SWITCHER? 3A 降压电...
XH2576-5.0 数据手册
XH2576 TO-263 3.3V 5.0V 12V ADJ FEATURES DESCRIPTION 1 • 23 • • • • • • • • • • The XH2576 series of regulators are monolithic integrated circuits that provide all the active functions for a step-down (buck) switching regulator, capable of driving 3A load with excellent line and load regulation. These devices are available in fixed output voltages of 3.3V 5.0V 12V ADJ and an adjustable output version. 3.3V 5.0V 12V ADJ and Adjustable Output Versions Adjustable Version Output Voltage Range,1.23V to 37V (57V for HV Version) ±4% Max Over Line and Load Conditions Specified 3A Output Current Wide Input Voltage Range, 40V Up to 60V for HV Version Requires Only 4 External Components 52 kHz Fixed Frequency Internal Oscillator TTL Shutdown Capability, Low Power Standby Mode High Efficiency Uses Readily Available Standard Inductors Thermal Shutdown and Current Limit Protection P+ Product Enhancement Tested Requiring a minimum number of external components, these regulators are simple to use and include internal frequency compensation and a fixedfrequency oscillator. The XH2576 series offers a high-efficiency replacement for popular three-terminal linear regulators. It substantially reduces the size of the heat sink, and in some cases no heat sink is required. A standard series of inductors optimized for use with the XH2576 are available from several different manufacturers. This feature greatly simplifies the design of switch-mode power supplies. APPLICATIONS • • • • Other features include a specified ±4% tolerance on output voltage within specified input voltages and output load conditions, and ±10% on the oscillator frequency. External shutdown is included, featuring 50 μA (typical) standby current. The output switch includes cycle-by-cycle current limiting, as well as thermal shutdown for full protection under fault conditions. Simple High-Efficiency Step-Down (Buck) Regulator Efficient Pre-Regulator for Linear Regulators On-Card Switching Regulators Positive to Negative Converter (Buck-Boost) TYPICAL APPLICATION (Fixed Output Voltage Versions) XH2576 Figure 1. 1 XH2576 TO-263 3.3V 5.0V 12V ADJ Block Diagram 3.3V R2 = 1.7k 5V, R2 = 3.1k 12V, R2 = 8.84k 15V, R2 = 11.3k For ADJ. Version R1 = Open, R2 = 0Ω Patent Pending 2 XH2576 TO-263 3.3V 5.0V 12V ADJ ABSOLUTE MAXIMUM RATINGS (1) (2) Maximum Supply Voltage XH2576 45V −0.3V ≤ V ≤ +VIN ON /OFF Pin Input Voltage Output Voltage to Ground −1V (Steady State) Power Dissipation Internally Limited Storage Temperature Range −65°C to +150°C Maximum Junction Temperature 150°C Minimum ESD Rating (C = 100 pF, R = 1.5 kΩ) Lead Temperature (Soldering, 10 Seconds) (1) 2 kV 260°C Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is intended to be functional, but do not ensured specific performance limits. For ensured specifications and test conditions, see ELECTRICAL CHARACTERISTICS ALL OUTPUT VOLTAGE VERSIONS. OPERATING RATINGS Temperature Range XH2576 −40°C ≤ TJ ≤ +125°C Supply Voltage XH2576 40V XH2576 60V ELECTRICAL CHARACTERISTICS XH2576-3.3 Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating Temperature Range. Symbol Parameter XH2576-3.3 Conditions Typ Limit (1) Units (Limits) SYSTEM PARAMETERS Test Circuit Figure 21 and Figure 22(2) VOUT VOUT VOUT η (1) (2) Output Voltage VIN = 12V, ILOAD = 0.5A Circuit of Figure 21 and Figure22 3.3 Output Voltage XH2576 6V ≤ VIN ≤ 40V, 0.5A ≤ ILOAD ≤ 3A Circuit of Figure 21 and Figure 22 3.3 Output Voltage 6V ≤ VIN ≤ 60V, 0.5A ≤ ILOAD ≤ 3A Circuit of Figure 21 and Figure 22 3.3 VIN = 12V, ILOAD = 3A 75 Efficiency 3.234 3.366 V V(Min) V(Max) 3.168/3.135 3.432/3.465 V V(Min) V(Max) 3.168/3.135 3.450/3.482 V V(Min) V(Max) % All limits specified at room temperature (standard type face) and at temperature extremes (bold type face). All room temperature limits are 100% production tested. All limits at temperature extremes are specified via correlation using standard Statistical Quality Control (SQC) methods. External components such as the catch diode, inductor, input and output capacitors can affect switching regulator system performance. When the XH2576 is used as shown in Figure 21 and Figure 22, system performance will be as shown in ELECTRICAL CHARACTERISTICS ALL OUTPUT VOLTAGE VERSIONS. 3 XH2576 TO-263 3.3V 5.0V 12V ADJ ELECTRICAL CHARACTERISTICS XH2576-5.0 Specifications with standard type face are for TJ = 25°C, and those with Figure 21 and Figure 22 boldface type apply over full Operating Temperature Range. XH2576-5.0 Symbol Parameter Conditions Typ Limit (1) Units (Limits) SYSTEM PARAMETERS Figure 21 and Figure 22 (2) VOUT VOUT VOUT η (1) (2) Output Voltage VIN = 12V, ILOAD = 0.5A Circuit of Figure 21 and Figure 22 5.0 Output Voltage XH2576 0.5A ≤ ILOAD ≤ 3A, 8V ≤ VIN ≤ 40V Circuit of Figure 21 and Figure 22 5.0 Output Voltage 0.5A ≤ ILOAD ≤ 3A, 8V ≤ VIN ≤ 60V Circuit of Figure 21 and Figure 22 5.0 VIN = 12V, ILOAD = 3A 77 Efficiency 4.900 5.100 V V(Min) V(Max) 4.800/4.750 5.200/5.250 V V(Min) V(Max) 4.800/4.750 5.225/5.275 V V(Min) V(Max) % All limits specified at room temperature (standard type face) and at temperature extremes (bold type face). All room temperature limits are 100% production tested. All limits at temperature extremes are specified via correlation using standard Statistical Quality Control (SQC) methods. External components such as the catch diode, inductor, input and output capacitors can affect switching regulator system performance. When the XH2576 is used as shown in Figure 21 and Figure 22, system performance will be as shown in ELECTRICAL CHARACTERISTICS ALL OUTPUT VOLTAGE VERSIONS. ELECTRICAL CHARACTERISTICS XH2576-12 Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating Temperature Range. XH2576-12 Symbol Parameter Conditions Typ Limit (1) Units (Limits) SYSTEM PARAMETERS Test Circuit Figure 21 and Figure 22 (2) VOUT Output Voltage VIN = 25V, ILOAD = 0.5A Circuit of Figure 21 and Figure 22 12 V 11.76 12.24 VOUT VOUT η (1) (2) Output Voltage XH2576 Output Voltage Efficiency 0.5A ≤ ILOAD ≤ 3A, 15V ≤ VIN ≤ 40V Circuit of Figure 21 and Figure 22 and 0.5A ≤ ILOAD ≤ 3A, 15V ≤ VIN ≤ 60V Circuit of Figure 21 and Figure 22 VIN = 15V, ILOAD = 3A 12 V(Max) V 11.52/11.40 12.48/12.60 12 V(Min) V(Max) V 11.52/11.40 12.54/12.66 88 V(Min) V(Min) V(Max) % All limits specified at room temperature (standard type face) and at temperature extremes (bold type face). All room temperature limits are 100% production tested. All limits at temperature extremes are specified via correlation using standard Statistical Quality Control (SQC) methods. External components such as the catch diode, inductor, input and output capacitors can affect switching regulator system performance. When the XH2576 is used as shown in Figure 21 and Figure 22, system performance will be as shown in ELECTRICAL CHARACTERISTICS ALL OUTPUT VOLTAGE VERSIONS. 4 XH2576 TO-263 3.3V 5.0V 12V ADJ ELECTRICAL CHARACTERISTICS XH2576-ADJ Specifications with standard type face are for TJ = 25°C, and those with boldface type apply over full Operating Temperature Range. Symbol Parameter XH2576-ADJ Conditions Typ Limit (1) Units (Limits) SYSTEM PARAMETERS Test Circuit Figure 21 and Figure 22 (2) VOUT VOUT VOUT η (1) (2) Feedback Voltage VIN = 12V, ILOAD = 0.5A VOUT = 5V, Circuit of Figure 21 and Figure 22 1.230 Feedback Voltage XH2576 0.5A ≤ ILOAD ≤ 3A, 8V ≤ VIN ≤ 40V VOUT = 5V, Circuit of Figure 21 and Figure 22 1.230 Feedback Voltage 0.5A ≤ ILOAD ≤ 3A, 8V ≤ VIN ≤ 60V VOUT = 5V, Circuit of Figure 21 and Figure 22 1.230 Efficiency VIN = 12V, ILOAD = 3A, VOUT = 5V 77 1.217 1.243 V V(Min) V(Max) 1.193/1.180 1.267/1.280 V V(Min) V(Max) 1.193/1.180 1.273/1.286 V V(Min) V(Max) % All limits specified at room temperature (standard type face) and at temperature extremes (bold type face). All room temperature limits are 100% production tested. All limits at temperature extremes are specified via correlation using standard Statistical Quality Control (SQC) methods. External components such as the catch diode, inductor, input and output capacitors can affect switching regulator system performance. When the XH2576 is used as shown in Figure 21 and Figure 22, system performance will be as shown in ELECTRICAL CHARACTERISTICS ALL OUTPUT VOLTAGE VERSIONS. 5 XH2576 TO-263 3.3V 5.0V 12V ADJ TYPICAL PERFORMANCE CHARACTERISTICS (Circuit of Figure 21 and Figure 22) Normalized Output Voltage Line Regulation Figure 2. Figure 3. Dropout Voltage Current Limit Figure 4. Figure 5. Quiescent Current Standby Quiescent Current Figure 6. Figure 7. 6 XH2576 TO-263 3.3V 5.0V 12V ADJ TYPICAL PERFORMANCE CHARACTERISTICS (continued) (Circuit of Figure 21 and Figure 22) Oscillator Frequency Switch Saturation Voltage Figure 8. Figure 9. Efficiency Minimum Operating Voltage Figure 10. Figure 11. Quiescent Current vs Duty Cycle Feedback Voltage vs Duty Cycle Figure 12. Figure 13. 7 XH2576 TO-263 3.3V 5.0V 12V ADJ TYPICAL PERFORMANCE CHARACTERISTICS (continued) (Circuit of Figure 21 and Figure 22) Minimum Operating Voltage Quiescent Current vs Duty Cycle Figure 14. Figure 15. Feedback Voltage vs Duty Cycle Feedback Pin Current Figure 16. Figure 17. 8 XH2576 TO-263 3.3V 5.0V 12V ADJ TYPICAL PERFORMANCE CHARACTERISTICS (continued) (Circuit of Figure 21 and Figure 22) Maximum Power Dissipation (DDPAK/TO-263) Switching Waveforms If the DDPAK/TO-263 package is used, the thermal resistance can be reduced by increasing the PC board copper area thermally connected to the package. Using 0.5 square inches of copper area, θJA is 50°C/W, with 1 square inch of copper area, θJA is 37°C/W, and with 1.6 or more square inches of copper area, θJA is 32°C/W. Figure 18. VOUT = 15V A: Output Pin Voltage, 50V/div B: Output Pin Current, 2A/div C: Inductor Current, 2A/div D: Output Ripple Voltage, 50 mV/div, AC-Coupled Horizontal Time Base: 5 μs/div Figure 19. Load Transient Response Figure 20. 9 XH2576 TO-263 3.3V 5.0V 12V ADJ XH2576 Series Buck Regulator Design Procedure PROCEDURE (Fixed Output Voltage Versions) EXAMPLE (Fixed Output Voltage Versions) Given: VOUT = Regulated Output Voltage (3.3V, 5V, 12V, or 15V) VIN(Max) = Maximum Input Voltage ILOAD(Max) = Maximum Load Current Given: VOUT = 5V VIN(Max) = 15V ILOAD(Max) = 3A 1. Inductor Selection (L1) A. Select the correct Inductor value selection guide from Figure 23, Figure 24, Figure 25, or Figure 26. (Output voltages of 3.3V, 5V, 12V or 15V respectively). For other output voltages, see the design procedure for the adjustable version. B. From the inductor value selection guide, identify the inductance region intersected by VIN(Max) and ILOAD(Max), and note the inductor code for that region. C. Identify the inductor value from the inductor code, and select an appropriate inductor from the table shown in Figure 23. Part numbers are listed for three inductor manufacturers. The inductor chosen must be rated for operation at the XH2576 switching frequency (52 kHz) and for a current rating of 1.15 × ILOAD. For additional inductor information, see INDUCTOR SELECTION. 1. Inductor Selection (L1) A. Use the selection guide shown in Figure 24. B. From the selection guide, the inductance area intersected by the 15V line and 3A line is L100. C. Inductor value required is 100 μH. From the table in Figure 23. Choose AIE 415-0930, Pulse Engineering PE92108, or Renco RL2444. 2. Output Capacitor Selection (COUT) 2. Output Capacitor Selection (COUT) A. The value of the output capacitor together with the inductor A. COUT = 680 μF to 2000 μF standard aluminum electrolytic. defines the dominate pole-pair of the switching regulator loop. For B.Capacitor voltage rating = 20V. stable operation and an acceptable output ripple voltage, (approximately 1% of the output voltage) a value between 100 μF and 470 μF is recommended. B. The capacitor's voltage rating should be at least 1.5 times greater than the output voltage. For a 5V regulator, a rating of at least 8V is appropriate, and a 10V or 15V rating is recommended. Higher voltage electrolytic capacitors generally have lower ESR numbers, and for this reason it may be necessary to select a capacitor rated for a higher voltage than would normally be needed. 3. Catch Diode Selection (D1) A.The catch-diode current rating must be at least 1.2 times greater than the maximum load current. Also, if the power supply design must withstand a continuous output short, the diode should have a current rating equal to the maximum current limit of the XH2576 The most stressful condition for this diode is an overload or shorted output condition. B. The reverse voltage rating of the diode should be at least 1.25 times the maximum input voltage. 3. Catch Diode Selection (D1) A.For this example, a 3A current rating is adequate. B. Use a 20V 1N5823 or SR302 Schottky diode, or any of the suggested fast-recovery diodes shown in Table 1. 4. Input Capacitor (CIN) 4. Input Capacitor (CIN) An aluminum or tantalum electrolytic bypass capacitor located close A 100 μF, 25V aluminum electrolytic capacitor located near the input to the regulator is needed for stable operation. and ground pins provides sufficient bypassing. 10 XH2576 TO-263 3.3V 5.0V 12V ADJ INDUCTOR VALUE SELECTION GUIDES (For Continuous Mode Operation) Figure 23. XH2576-3.3 Figure 24. XH2576-5.0 Figure 25. XH2576-12 11 XH2576 TO-263 3.3V 5.0V 12V ADJ (For Continuous Mode Operation) Figure 26. XH2576-ADJ PROCEDURE (Adjustable Output Voltage Versions) EXAMPLE (Adjustable Output Voltage Versions) Given: VOUT = Regulated Output Voltage VIN(Max) = Maximum Input Voltage ILOAD(Max) = Maximum Load Current F = Switching Frequency (Fixed at 52 kHz) Given: VOUT = 10V VIN(Max) = 25V ILOAD(Max) = 3A F = 52 kHz 1. Programming Output Voltage (Selecting R1 and R2, as shown 1. Programming Output Voltage(Selecting R1 and R2) in Figure 21 and Figure 22) Use the following formula to select the appropriate resistor values. R1 can be between 1k and 5k. (For best temperature coefficient and R2 = 1k (8.13 − 1) = 7.13k, closest 1% value is 7.15k stability with time, use 1% metal film resistors) 12 XH2576 TO-263 3.3V 5.0V 12V ADJ (For Continuous Mode Operation) PROCEDURE (Adjustable Output Voltage Versions) EXAMPLE (Adjustable Output Voltage Versions) 2. Inductor Selection (L1) 2. Inductor Selection (L1) A. Calculate the inductor Volt • microsecond constant, E • T (V • μs), A. Calculate E • T (V • μs) from the following formula: B. Use the E • T value from the previous formula and match it with the E • T number on the vertical axis of the Inductor Value Selection Guide shown in Figure 26. C. On the horizontal axis, select the maximum load current. D. Identify the inductance region intersected by the E • T value and the maximum load current value, and note the inductor code for that region. E. Identify the inductor value from the inductor code, and select an appropriate inductor from the table shown in Table 2. Part numbers are listed for three inductor manufacturers. The inductor chosen must be rated for operation at the XH2576 switching frequency (52 kHz) and for a current rating of 1.15 × ILOAD. For additional inductor information, see INDUCTOR SELECTION. B. E • T = 115 V • μs C. ILOAD(Max) = 3A D. Inductance Region = H150 E. Inductor Value = 150 μH Choose from AIEpart #415-0936Pulse Engineering part #PE-531115, or Renco part #RL2445. 3. Output Capacitor Selection (COUT) 3. Output Capacitor Selection (COUT) A. The value of the output capacitor together with the inductor defines the dominate pole-pair of the switching regulator loop. For stable operation, the capacitor must satisfy the following However, for acceptable output ripple voltage select requirement: COUT ≥ 680 μF COUT = 680 μF electrolytic capacitor The above formula yields capacitor values between 10 μF and 2200 μF that will satisfy the loop requirements for stable operation. But to achieve an acceptable output ripple voltage, (approximately 1% of the output voltage) and transient response, the output capacitor may need to be several times larger than the above formula yields. B. The capacitor's voltage rating should be at last 1.5 times greater than the output voltage. For a 10V regulator, a rating of at least 15V or more is recommended. Higher voltage electrolytic capacitors generally have lower ESR numbers, and for this reason it may be necessary to select a capacitor rate for a higher voltage than would normally be needed. 4. Catch Diode Selection (D1) A. The catch-diode current rating must be at least 1.2 times greater than the maximum load current. Also, if the power supply design must withstand a continuous output short, the diode should have a current rating equal to the maximum current limit of the XH2576 The most stressful condition for this diode is an overload or shorted output. See Table 1. B. The reverse voltage rating of the diode should be at least 1.25 times the maximum input voltage. 4. Catch Diode Selection (D1) A. For this example, a 3.3A current rating is adequate. B. Use a 30V 31DQ03 Schottky diode, or any of the suggested fastrecovery diodes in Table 1. 5. Input Capacitor (CIN) 5. Input Capacitor (CIN) An aluminum or tantalum electrolytic bypass capacitor located close A 100 μF aluminum electrolytic capacitor located near the input and to the regulator is needed for stable operation. ground pins provides sufficient bypassing. 13 XH2576 TO-263 3.3V 5.0V 12V ADJ 14 13
XH2576-5.0 价格&库存
很抱歉,暂时无法提供与“XH2576-5.0”相匹配的价格&库存,您可以联系我们找货
