XP8255
XP8255
    XINLUDA(信路达)
    PLCC44
    XP8255 是一个高性能CMOS版本的行业标准8255,具有24个可编程I/O引脚,可在三种主要模式下操作。
XP8255 数据手册
XP8255 PLCC44 XD8255-2 DIP-40 The 8255 is a high performance CMOS version of the industry standard 8255 and is manufactured using a self-aligned silicon gate CMOS process (Scaled SAJI IV). It is a general purpose programmable I/O device which may be used with many different microprocessors. There are 24 I/O pins which may be individually programmed in 2 groups of 12 and used in 3 major modes of operation. The high performance and industry standard configuration of the 8255 make it compatible with the 8086, 8088 and other microprocessors. Features Static CMOS circuit design insures low operating power. TTL compatibility over the full military temperature range and bus hold circuitry eliminate the need for pull-up resistors. The Intersil advanced SAJI process results in performance equal to or greater than existing functionally equivalent products at a fraction of the power. • Direct Bit Set/Reset Capability • Pb-Free Plus Anneal Available (RoHS Compliant) (See Ordering Info) • Pin Compatible with NMOS 8255 • 24 Programmable I/O Pins • Fully TTL Compatible • High Speed, No “Wait State” Operation with 5MHz and 8MHz 8086 and 8088 • Enhanced Control Word Read Capability • L7 Process • 2.5mA Drive Capability on All I/O Ports • Low Standby Power (ICCSB) . . . . . . . . . . . . . . . . . . .10µA Ordering Information PART NUMBERS PART MARKING 5MHz XD8255-2 XD8255-2 8MHz XD8255-2 PART MARKING XD8255-2 XP8255 TEMP. RANGE (°C) 0 to +70 PACKAGE PKG. DWG. # 40 Ld PDIP (Pb-free) 0 to +70 44 Ld PLCC (Pb-free) -40 to +85 44 Ld PLCC (Pb-free) E40.6 N44.65 Pinouts 8255 (PDIP, CERDIP) A0 PC7 PC6 PC5 PC4 PC0 PC1 PC2 PC3 PB0 PB1 PB2 9 10 11 12 32 D2 31 D3 30 D4 29 D5 28 D6 27 D7 26 VCC 25 PB7 24 PB6 23 PB5 22 PB4 21 PB3 13 14 15 16 17 18 19 20 8255 (PLCC) TOP VIEW PA4 PA5 PA6 PA7 WR RESET D0 D1 6 5 4 3 2 1 44 43 42 41 40 CS GND A1 A0 PC7 NC PC6 PC5 PC4 PC0 PC1 7 8 9 10 11 12 13 14 15 16 17 39 38 37 36 35 34 33 32 31 30 29 18 1920 21 22 23 24 25 26 27 28 1 PB2 NC PB3 PB4 PB5 PB6 PB7 40 39 38 37 36 35 34 33 RD PA0 PA1 PA2 PA3 NC PA4 PA5 PA6 PA7 WR 1 2 3 4 5 6 7 8 PC2 PC3 PB0 PB1 PA3 PA2 PA1 PA0 RD CS GND A1 RESET D0 D1 D2 D3 NC D4 D5 D6 D7 VCC XP8255 PLCC44 XD8255-2 DIP-40 Pin Description SYMBOL TYPE DESCRIPTION VCC VCC: The +5V power supply pin. A 0.1F capacitor between VCC and GND is recommended for decoupling. GND GROUND D0-D7 I/O DATA BUS: The Data Bus lines are bidirectional three-state pins connected to the system data bus. RESET I RESET: A high on this input clears the control register and all ports (A, B, C) are set to the input mode with the “Bus Hold” circuitry turned on. CS I CHIP SELECT: Chip select is an active low input used to enable the 8255 onto the Data Bus for CPU communications. RD I READ: Read is an active low input control signal used by the CPU to read status information or data via the data bus. WR I WRITE: Write is an active low input control signal used by the CPU to load control words and data into the 8255. A0-A1 I ADDRESS: These input signals, in conjunction with the RD and WR inputs, control the selection of one of the three ports or the control word register. A0 and A1 are normally connected to the least significant bits of the Address Bus A0, A1. PA0-PA7 I/O PORT A: 8-bit input and output port. Both bus hold high and bus hold low circuitry are present on this port. PB0-PB7 I/O PORT B: 8-bit input and output port. Bus hold high circuitry is present on this port. PC0-PC7 I/O PORT C: 8-bit input and output port. Bus hold circuitry is present on this port. Functional Diagram POWER SUPPLIES +5V GND GROUP A PORT A (8) GROUP A CONTROL GROUP A PORT C UPPER (4) BIDIRECTIONAL DATA BUS D7-D0 DATA BUS BUFFER 8-BIT INTERNAL DATA BUS RD WR A1 READ WRITE CONTROL LOGIC GROUP B CONTROL GROUP B PORT C LOWER (4) GROUP B PORT B (8) A0 RESET CS 2 I/O PA7-PA0 I/O PC7-PC4 I/O PC3-PC0 I/O PB7-PB0 XP8255 PLCC44 XD8255-2 DIP-40 Functional Description Data Bus Buffer POWER SUPPLIES This three-state bidirectional 8-bit buffer is used to interface the 8255 to the system data bus. Data is transmitted or received by the buffer upon execution of input or output instructions by the CPU. Control words and status information are also transferred through the data bus buffer. BIDIRECTIONAL DATA BUS DATA BUS D7-D0 BUFFER Read/Write and Control Logic The function of this block is to manage all of the internal and external transfers of both Data and Control or Status words. It accepts inputs from the CPU Address and Control busses and in turn, issues commands to both of the Control Groups. RD WR A1 A0 RESET (CS) Chip Select. A “low” on this input pin enables the communication between the 8255 and the CPU. 0 0 0 1 0 Port A Data Bus 0 1 0 1 0 Port B Data Bus 1 0 0 1 0 Port C Data Bus 1 1 0 1 0 Control Word Data Bus GROUP B CONTROL GROUP B PORT B (8) I/O PC3PC0 I/O PB7PB0 Each of the Control blocks (Group A and Group B) accepts “commands” from the Read/Write Control logic, receives “control words” from the internal data bus and issues the proper commands to its associated ports. INPUT OPERATION (READ) CS 8-BIT INTERNAL DATA BUS GROUP B PORT C LOWER (4) I/O PC7PC4 Group A and Group B Controls 8255 BASIC OPERATION WR GROUP A PORT C UPPER (4) The functional configuration of each port is programmed by the systems software. In essence, the CPU “outputs” a control word to the 8255. The control word contains information such as “mode”, “bit set”, “bit reset”, etc., that initializes the functional configuration of the 8255. (A0 and A1) Port Select 0 and Port Select 1. These input signals, in conjunction with the RD and WR inputs, control the selection of one of the three ports or the control word register. They are normally connected to the least significant bits of the address bus (A0 and A1). RD GROUP A PORT A (8) FIGURE 1. 8255 BLOCK DIAGRAM. DATA BUS BUFFER, READ/WRITE, GROUP A & B CONTROL LOGIC FUNCTIONS (WR) Write. A “low” on this input pin enables the CPU to write data or control words into the 8255. A0 READ WRITE CONTROL LOGIC GROUP A CONTROL CS (RD) Read. A “low” on this input pin enables 8255 to send the data or status information to the CPU on the data bus. In essence, it allows the CPU to “read from” the 8255. A1 +5V GND I/O PA7PA0 Control Group A - Port A and Port C upper (C7 - C4) Control Group B - Port B and Port C lower (C3 - C0) The control word register can be both written and read as shown in the “Basic Operation” table. Figure 4 shows the control word format for both Read and Write operations. When the control word is read, bit D7 will always be a logic “1”, as this implies control word mode information. OUTPUT OPERATION (WRITE) 0 0 1 0 0 Data Bus Port A 0 1 1 0 0 Data Bus Port B Ports A, B, and C 1 0 1 0 0 Data Bus Port C 1 1 1 0 0 Data Bus Control The 8255 contains three 8-bit ports (A, B, and C). All can be configured to a wide variety of functional characteristics by the system software but each has its own special features or “personality” to further enhance the power and flexibility of the 8255. DISABLE FUNCTION X X X X 1 Data Bus Three-State X X 1 1 0 Data Bus Three-State Port A One 8-bit data output latch/buffer and one 8-bit data input latch. Both “pull-up” and “pull-down” bus-hold devices are present on Port A. See Figure 2A. (RESET) Reset. A “high” on this input initializes the control register to 9Bh and all ports (A, B, C) are set to the input mode. “Bus hold” devices internal to the 8255 will hold the I/O port inputs to a logic “1” state with a maximum hold current of 400A. Port B One 8-bit data input/output latch/buffer and one 8-bit data input buffer. See Figure 2B. Port C One 8-bit data output latch/buffer and one 8-bit data input buffer (no latch for input). This port can be divided into 3 XP8255 PLCC44 XD8255-2 DIP-40 two 4-bit ports under the mode control. Each 4-bit port contains a 4-bit latch and it can be used for the control signal output and status signal inputs in conjunction with ports A and B. See Figure 2B. ADDRESS BUS CONTROL BUS DATA BUS INPUT MODE MASTER RESET OR MODE CHANGE RD, WR INTERNAL DATA IN EXTERNAL PORT A PIN MODE 0 INTERNAL DATA OUT (LATCHED) OUTPUT MODE I/O PB7-PB0 FIGURE 2A. PORT A BUS-HOLD CONFIGURATION MODE 1 VCC EXTERNAL PORT B, C PIN INTERNAL DATA OUT (LATCHED) 4 I/O PC7-PC4 I/O 8 CONTROL CONTROL OR I/O OR I/O C I/O PA7-PA0 A 8 I/O PA7-PA0 A BIDIRECTIONAL I/O PB7-PB0 OUTPUT MODE I/O PC3-PC0 B 8 A C PB7-PB0 MODE 2 4 B 8 P INTERNAL DATA IN A0-A1 CS C B 8 RESET OR MODE CHANGE D7-D0 8255 CONTROL PA7-PA0 FIGURE 3. BASIC MODE DEFINITIONS AND BUS INTERFACE FIGURE 2B. PORT B AND C BUS-HOLD CONFIGURATION FIGURE 2. BUS-HOLD CONFIGURATION CONTROL WORD Operational Description D7 D6 D5 D4 D3 D2 D1 D0 GROUP B Mode Selection PORT C (LOWER) 1 = INPUT 0 = OUTPUT There are three basic modes of operation than can be selected by the system software: Mode 0 - Basic Input/Output Mode 1 - Strobed Input/Output Mode 2 - Bidirectional Bus PORT B 1 = INPUT 0 = OUTPUT MODE SELECTION 0 = MODE 0 1 = MODE 1 When the reset input goes “high”, all ports will be set to the input mode with all 24 port lines held at a logic “one” level by internal bus hold devices. After the reset is removed, the 8255 can remain in the input mode with no additional initialization required. This eliminates the need to pull-up or pull-down resistors in all-CMOS designs. The control word register will contain 9Bh. During the execution of the system program, any of the other modes may be selected using a single output instruction. This allows a single 8255 to service a variety of peripheral devices with a simple software maintenance routine. Any port programmed as an output port is initialized to all zeros when the control word is written. GROUP A PORT C (UPPER) 1 = INPUT 0 = OUTPUT PORT A 1 = INPUT 0 = OUTPUT MODE SELECTION 00 = MODE 0 01 = MODE 1 1X = MODE 2 MODE SET FLAG 1 = ACTIVE FIGURE 4. MODE DEFINITION FORMAT 4 XP8255 PLCC44 XD8255-2 DIP-40 INTE Flip-Flop Definition The modes for Port A and Port B can be separately defined, while Port C is divided into two portions as required by the Port A and Port B definitions. All of the output registers, including the status flip-flops, will be reset whenever the mode is changed. Modes may be combined so that their functional definition can be “tailored” to almost any I/O structure. For instance: Group B can be programmed in Mode 0 to monitor simple switch closings or display computational results, Group A could be programmed in Mode 1 to monitor a keyboard or tape reader on an interrupt-driven basis. (BIT-SET)-INTE is SET - Interrupt Enable (BIT-RESET)-INTE is Reset - Interrupt Disable NOTE: All Mask flip-flops are automatically reset during mode selection and device Reset. Operating Modes Mode 0 (Basic Input/Output). This functional configuration provides simple input and output operations for each of the three ports. No handshaking is required, data is simply written to or read from a specific port. The mode definitions and possible mode combinations may seem confusing at first, but after a cursory review of the complete device operation a simple, logical I/O approach will surface. The design of the 8255 has taken into account things such as efficient PC board layout, control signal definition vs. PC layout and complete functional flexibility to support almost any peripheral device with no external logic. Such design represents the maximum use of the available pins. Mode 0 Basic Functional Definitions: • Two 8-bit ports and two 4-bit ports • Any Port can be input or output • Outputs are latched • Inputs are not latched • 16 different Input/Output configurations possible Single Bit Set/Reset Feature (Figure 5) Any of the eight bits of Port C can be Set or Reset using a single Output instruction. This feature reduces software requirements in control-based applications. MODE 0 PORT DEFINITION A When Port C is being used as status/control for Port A or B, these bits can be set or reset by using the Bit Set/Reset operation just as if they were output ports. B GROUP A PORT C PORT A (Upper) GROUP B D3 D1 D0 0 0 0 0 Output Output 0 Output Output 0 0 0 1 Output Output 1 Output Input 0 0 1 0 Output Output 2 Input Output 0 0 1 1 Output Output 3 Input Input 0 1 0 0 Output Input 4 Output Output 0 1 0 1 Output Input 5 Output Input 0 1 1 0 Output Input 6 Input Output 0 1 1 1 Output Input 7 Input Input 1 0 0 0 Input Output 8 Output Output 1 0 0 1 Input Output 9 Output Input 1 0 1 0 Input Output 10 Input Output 1 0 1 1 Input Output 11 Input Input 1 1 0 0 Input Input 12 Output Output Interrupt Control Functions 1 1 0 1 Input Input 13 Output Input When the 8255 is programmed to operate in mode 1 or mode 2, control signals are provided that can be used as interrupt request inputs to the CPU. The interrupt request signals, generated from port C, can be inhibited or enabled by setting or resetting the associated INTE flip-flop, using the bit set/reset function of port C. 1 1 1 0 Input Input 14 Input Output 1 1 1 1 Input Input 15 Input Input CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 X X X DON’T CARE BIT SET/RESET 1 = SET 0 = RESET BIT SELECT 0 1 2 3 4 0 1 0 1 0 0 0 1 1 0 0 0 0 0 1 5 1 0 1 6 0 1 1 7 1 B0 1 B1 1 B2 BIT SET/RESET FLAG 0 = ACTIVE FIGURE 5. BIT SET/RESET FORMAT This function allows the programmer to enable or disable a CPU interrupt by a specific I/O device without affecting any other device in the interrupt structure. 5 # PORT C PORT B (Lower) D4 XP8255 PLCC44 XD8255-2 DIP-40 Mode 0 (Basic Input) tRR RD tIR tHR INPUT tAR tRA CS, A1, A0 D7-D0 tRD tDF Mode 0 (Basic Output) tWW WR tWD tDW D7-D0 tAW tWA CS, A1, A0 OUTPUT tWB Mode 0 Configurations CONTROL WORD #0 CONTROL WORD #2 D7 D6 D5 D4 D3 D2 D1 D0 1 0 0 0 0 0 0 0 A 8255 1 8 4 C D7 - D0 D7 D6 D5 D4 D3 D2 D1 D0 4 B 8 0 0 0 0 1 0 8255 4 PC7 - PC4 C D7 - D0 8 4 PC3 - PC0 PB7 - PB0 B 8 PA7 - PA0 PC7 - PC4 PC3 - PC0 PB7 - PB0 CONTROL WORD #3 0 0 0 D7 D6 D5 D4 D3 D2 D1 D0 1 A 8255 D7 - D0 0 A D7 D6 D5 D4 D3 D2 D1 D0 0 0 PA7 - PA0 CONTROL WORD #1 1 0 1 8 4 C 4 B 8 0 0 0 0 0 1 1 PA7 - PA0 A 8255 4 PC7 - PC4 D7 - D0 C 4 PC3 - PC0 PB7 - PB0 B 6 8 8 PA7 - PA0 PC7 - PC4 PC3 - PC0 PB7 - PB0 XP8255 PLCC44 XD8255-2 DIP-40 Mode 0 Configurations (Continued) CONTROL WORD #4 CONTROL WORD #8 D7 D6 D5 D4 D3 D2 D1 D0 1 0 0 0 1 0 0 A 8255 1 8 4 C D7 - D0 D7 D6 D5 D4 D3 D2 D1 D0 0 4 B 8 0 0 1 0 0 D7 - D0 PB7 - PB0 1 0 1 8 8 PC7 - PC4 PC3 - PC0 PB7 - PB0 0 1 0 0 0 1 A 8255 4 PC7 - PC4 C D7 - D0 8 4 PC3 - PC0 PB7 - PB0 B 8 PA7 - PA0 PC7 - PC4 PC3 - PC0 PB7 - PB0 D7 D6 D5 D4 D3 D2 D1 D0 1 8 4 C D7 - D0 4 B 8 0 0 1 0 0 1 0 PA7 - PA0 A 8255 C D7 - D0 8 4 PC7 - PC4 4 PC3 - PC0 PB7 - PB0 B CONTROL WORD #7 8 PA7 - PA0 PC7 - PC4 PC3 - PC0 PB7 - PB0 CONTROL WORD #11 D7 D6 D5 D4 D3 D2 D1 D0 1 0 1 D7 D6 D5 D4 D3 D2 D1 D0 1 A 8255 D7 - D0 0 PA7 - PA0 0 8255 0 8 PA7 - PA0 CONTROL WORD #10 A 0 4 B D7 D6 D5 D4 D3 D2 D1 D0 0 C D7 - D0 8 4 PC3 - PC0 CONTROL WORD #6 1 0 PC7 - PC4 1 4 B 0 0 D7 D6 D5 D4 D3 D2 D1 D0 4 C 0 0 8255 1 8255 0 0 CONTROL WORD #9 A 1 1 A D7 D6 D5 D4 D3 D2 D1 D0 0 0 PA7 - PA0 CONTROL WORD #5 1 0 1 8 4 C 4 B 8 0 0 1 0 0 1 1 PA7 - PA0 A 8255 4 PC7 - PC4 D7 - D0 C 4 PC3 - PC0 PB7 - PB0 B 7 8 8 PA7 - PA0 PC7 - PC4 PC3 - PC0 PB7 - PB0 XP8255 PLCC44 XD8255-2 DIP-40 Mode 0 Configurations (Continued) CONTROL WORD #12 CONTROL WORD #14 D7 D6 D5 D4 D3 D2 D1 D0 1 0 0 1 1 0 0 A 8255 1 8 4 C D7 - D0 D7 D6 D5 D4 D3 D2 D1 D0 0 4 B 8 0 1 1 1 0 1 0 8 A 8255 4 PC7 - PC4 C D7 - D0 4 PC3 - PC0 PB7 - PB0 8 B PA7 - PA0 PC7 - PC4 PC3 - PC0 PB7 - PB0 CONTROL WORD #15 D7 D6 D5 D4 D3 D2 D1 D0 0 0 PA7 - PA0 CONTROL WORD #13 1 0 1 0 0 A 8255 D7 - D0 D7 D6 D5 D4 D3 D2 D1 D0 1 1 8 4 C 4 B 8 0 0 1 1 0 1 1 PA7 - PA0 8 A 8255 4 PC7 - PC4 C D7 - D0 4 PC3 - PC0 PB7 - PB0 8 B Operating Modes PA7 - PA0 PC7 - PC4 PC3 - PC0 PB7 - PB0 MODE 1 (PORT A) Mode 1 - (Strobed Input/Output). This functional configuration provides a means for transferring I/O data to or from a specified port in conjunction with strobes or “hand shaking” signals. In mode 1, port A and port B use the lines on port C to generate or accept these “hand shaking” signals. CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 1 0 1 1 1/0 INTE A PC6, PC7 1 = INPUT 0 = OUTPUT Mode 1 Basic Function Definitions: 8 PA7-PA0 PC4 STBA PC5 IBFA INTRA PC3 • Two Groups (Group A and Group B) RD • Each group contains one 8-bit port and one 4-bit control/data port • The 8-bit data port can be either input or output. Both inputs and outputs are latched. PC6, PC7 2 I/O MODE 1 (PORT B) • The 4-bit port is used for control and status of the 8-bit port. CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 Input Control Signal Definition 1 (Figures 6 and 7) 1 1 PB7-PB0 INTE B PC2 8 STBB PC1 IBFB PC0 INTRB STB (Strobe Input) A “low” on this input loads data into the input latch. RD IBF (Input Buffer Full F/F) A “high” on this output indicates that the data has been loaded into the input latch: in essence, an acknowledgment. IBF is set by STB input being low and is reset by the rising edge of the RD input. FIGURE 6. MODE 1 INPUT 8 XP8255 PLCC44 XD8255-2 DIP-40 tST STB tSIB IBF tSIT tRIB INTR tRIT RD tPH INPUT FROM PERIPHERAL tPS FIGURE 7. MODE 1 (STROBED INPUT) INTR (Interrupt Request) INTE A A “high” on this output can be used to interrupt the CPU when an input device is requesting service. INTR is set by the condition: STB is a “one”, IBF is a “one” and INTE is a “one”. It is reset by the falling edge of RD. This procedure allows an input device to request service from the CPU by simply strobing its data into the port. Controlled by Bit Set/Reset of PC6. INTE B Controlled by Bit Set/Reset of PC2. NOTE: 1. To strobe data into the peripheral device, the user must operate the strobe line in a hand shaking mode. The user needs to send OBF to the peripheral device, generates an ACK from the peripheral device and then latch data into the peripheral device on the rising edge of OBF. INTE A Controlled by bit set/reset of PC4. INTE B Controlled by bit set/reset of PC2. MODE 1 (PORT A) Output Control Signal Definition PA7-PA0 CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 (Figure 8 and 9) 1 OBF - (Output Buffer Full F/F). The OBF output will go “low” to indicate that the CPU has written data out to the specified port. This does not mean valid data is sent out of the port at this time since OBF can go true before data is available. Data is guaranteed valid at the rising edge of OBF, (See Note 1). The OBF F/F will be set by the rising edge of the WR input and reset by ACK input being low. 0 1 1 1/0 PC4, PC5 1 = INPUT 0 = OUTPUT INTE A 8 PC7 OBFA PC6 ACKA INTRA PC3 WR ACK - (Acknowledge Input). A “low” on this input informs the 8255 that the data from Port A or Port B is ready to be accepted. In essence, a response from the peripheral device indicating that it is ready to accept data, (See Note 1). PC4, PC5 2 MODE 1 (PORT B) PB7-PB0 CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 INTR - (Interrupt Request). A “high” on this output can be used to interrupt the CPU when an output device has accepted data transmitted by the CPU. INTR is set when ACK is a “one”, OBF is a “one” and INTE is a “one”. It is reset by the falling edge of WR. 1 1 0 INTE B WR FIGURE 8. MODE 1 OUTPUT 9 8 PC1 OBFB PC2 ACKB PC0 INTRB XP8255 PLCC44 XD8255-2 DIP-40 tWOB WR tAOB OBF INTR tWIT ACK tAK tAIT OUTPUT tWB FIGURE 9. MODE 1 (STROBED OUTPUT) 8 PA7-PA0 RD CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 1 0 1 1 1/0 1 PC4 STBA PC5 IIBFA PC6, PC7 1 = INPUT 0 = OUTPUT PC6, PC7 2 PB7, PB0 WR WR CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 INTRA PC3 0 PA7-PA0 1 0 1 0 1/0 I/O OBFB PC2 PC0 PC7 OBFA PC6 ACKA INTRA PC3 1 PC4, PC5 1 = INPUT 0 = OUTPUT 8 PC1 1 8 PC4, PC5 PB7, PB0 2 I/O 8 PC2 STBB ACKB PC1 IBFB INTRB PC0 INTRB RD PORT A - (STROBED INPUT) PORT B - (STROBED OUTPUT) PORT A - (STROBED OUTPUT) PORT B - (STROBED INPUT) Combinations of Mode 1: Port A and Port B can be individually defined as input or output in Mode 1 to support a wide variety of strobed I/O applications. FIGURE 10. COMBINATIONS OF MODE 1 Operating Modes Output Operations Mode 2 (Strobed Bidirectional Bus I/O) OBF - (Output Buffer Full). The OBF output will go “low” to indicate that the CPU has written data out to port A. This functional configuration provides a means for communicating with a peripheral device or structure on a single 8-bit bus for both transmitting and receiving data (bidirectional bus I/O). “Hand shaking” signals are provided to maintain proper bus flow discipline similar to Mode 1. Interrupt generation and enable/disable functions are also available. ACK - (Acknowledge). A “low” on this input enables the threestate output buffer of port A to send out the data. Otherwise, the output buffer will be in the high impedance state. INTE 1 - (The INTE flip-flop associated with OBF). Controlled by bit set/reset of PC4. Mode 2 Basic Functional Definitions: Input Operations • Used in Group A only STB - (Strobe Input). A “low” on this input loads data into the input latch. • One 8-bit, bidirectional bus Port (Port A) and a 5-bit control Port (Port C) IBF - (Input Buffer Full F/F). A “high” on this output indicates that data has been loaded into the input latch. • Both inputs and outputs are latched • The 5-bit control port (Port C) is used for control and status for the 8-bit, bidirectional bus port (Port A) INTE 2 - (The INTE flip-flop associated with IBF). Controlled by bit set/reset of PC4. Bidirectional Bus I/O Control Signal Definition (Figures 11, 12, 13, 14) INTR - (Interrupt Request). A high on this output can be used to interrupt the CPU for both input or output operations. 10 XP8255 PLCC44 XD8255-2 DIP-40 CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 1 1 INTRA PC3 1/0 1/0 1/0 PA7-PA0 PC2-PC0 1 = INPUT 0 = OUTPUT PORT B 1 = INPUT 0 = OUTPUT 8 PC7 OBFA INTE 1 PC6 ACKA INTE 2 PC4 STBA PC5 IBFA WR GROUP B MODE 0 = MODE 0 1 = MODE 1 PC2-PC0 RD FIGURE 11. MODE CONTROL WORD 3 I/O FIGURE 12. MODE 2 DATA FROM CPU TO 8255 WR tAOB OBF tWOB INTR tAK ACK tST STB tSIB IBF tAD tPS tKD PERIPHERAL BUS tRIB tPH RD DATA FROM PERIPHERAL TO 8255 DATA FROM 8255 TO PERIPHERAL DATA FROM 8255 TO CPU NOTE: Any sequence where WR occurs before ACK and STB occurs before RD is permissible. (INTR = IBF  MASK  STB  RD + OBF  MASK  ACK  WR) FIGURE 13. MODE 2 (BIDIRECTIONAL) 11 XP8255 PLCC44 XD8255-2 DIP-40 MODE 2 AND MODE 0 (INPUT) MODE 2 AND MODE 0 (OUTPUT) PC3 PA7-PA0 1 1 0 1 1/0 PC2-PC0 1 = INPUT 0 = OUTPUT PA7-PA0 8 OBFA PC7 CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 PC6 ACKA PC4 STBA PC5 IBFA PC2-PC0 PC3 INTRA 3 CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 1 1 I/O PB7-PB0 PC6 ACKA PC4 STBA PC5 IBFA PC2-PC0 3 I/O 8 MODE 2 AND MODE 1 (INPUT) PA7-PA0 CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 0 PC3 INTRA PA7-PA0 8 PC7 OBFA PC6 ACKA PC4 STBA PC5 IBFA PB7-PB0 WR OBFA WR PC3 RD PC7 PB7, PB0 8 MODE 2 AND MODE 1 (OUTPUT) 1 1/0 8 RD WR 1 0 PC2-PC0 1 = INPUT 0 = OUTPUT RD 1 0 INTRA CONTROL WORD D7 D6 D5 D4 D3 D2 D1 D0 1 1 1 1 PC1 OBFB PC2 ACKB PC0 INTRB RD WR FIGURE 14. MODE 2 COMBINATIONS 12 8 PC7 OBFA PC6 ACKA PC4 STBA PC5 IBFA PB7-PB0 8 INTRA 8 PC2 STBB PC1 IBFB PC0 INTRB XP8255 PLCC44 XD8255-2 DIP-40 MODE DEFINITION SUMMARY MODE 0 MODE 1 MODE 2 IN OUT IN OUT PA0 PA1 PA2 PA3 PA4 PA5 PA6 PA7 In In In In In In In In Out Out Out Out Out Out Out Out In In In In In In In In Out Out Out Out Out Out Out Out PB0 PB1 PB2 PB3 PB4 PB5 PB6 PB7 In In In In In In In In Out Out Out Out Out Out Out Out In In In In In In In In Out Out Out Out Out Out Out Out PC0 PC1 PC2 PC3 PC4 PC5 PC6 PC7 In In In In In In In In Out Out Out Out Out Out Out Out INTRB IBFB STBB INTRA STBA IBFA I/O I/O INTRB OBFB ACKB INTRA I/O I/O ACKA OBFA Special Mode Combination Considerations GROUP A ONLY Mode 0 or Mode 1 Only I/O I/O I/O INTRA STBA IBFA ACKA OBFA INPUT CONFIGURATION There are several combinations of modes possible. For any combination, some or all of Port C lines are used for control or status. The remaining bits are either inputs or outputs as defined by a “Set Mode” command. D7 D6 D5 I/O I/O IBFA D4 D3 D2 INTEA INTRA INTEB GROUP A During a read of Port C, the state of all the Port C lines, except the ACK and STB lines, will be placed on the data bus. In place of the ACK and STB line states, flag status will appear on the data bus in the PC2, PC4, and PC6 bit positions as illustrated by Figure 17. D1 D0 IBFB INTRB GROUP B OUTPUT CONFIGURATION D7 D6 OBFA INTEA D5 D4 I/O I/O D3 D2 D0 INTRA INTEB OBFB INTRB GROUP A Through a “Write Port C” command, only the Port C pins programmed as outputs in a Mode 0 group can be written. No other pins can be affected by a “Write Port C” command, nor can the interrupt enable flags be accessed. To write to any Port C output programmed as an output in Mode 1 group or to change an interrupt enable flag, the “Set/Reset Port C Bit” command must be used. D1 GROUP B FIGURE 15. MODE 1 STATUS WORD FORMAT D7 D6 OBFA INTE1 D5 IBFA D4 D3 INTE2 INTRA D2 D1 D0 X X X GROUP A GROUP B (Defined by Mode 0 or Mode 1 Selection) With a “Set/Reset Port C Bit” command, any Port C line programmed as an output (including IBF and OBF) can be written, or an interrupt enable flag can be either set or reset. Port C lines programmed as inputs, including ACK and STB lines, associated with Port C are not affected by a “Set/Reset Port C Bit” command. Writing to the corresponding Port C bit positions of the ACK and STB lines with the “Set Reset Port C Bit” command will affect the Group A and Group B interrupt enable flags, as illustrated in Figure 17. FIGURE 16. MODE 2 STATUS WORD FORMAT Current Drive Capability Any output on Port A, B or C can sink or source 2.5mA. This feature allows the 8255 to directly drive Darlington type drivers and high-voltage displays that require such sink or source current. Reading Port C Status (Figures 15 and 16) In Mode 0, Port C transfers data to or from the peripheral device. When the 8255 is programmed to function in Modes 13 XP8255 PLCC44 XD8255-2 DIP-40 Applications of the 8255 1 or 2, Port C generates or accepts “hand shaking” signals with the peripheral device. Reading the contents of Port C allows the programmer to test or verify the “status” of each peripheral device and change the program flow accordingly. The 8255 is a very powerful tool for interfacing peripheral equipment to the microcomputer system. It represents the optimum use of available pins and is flexible enough to interface almost any I/O device without the need for additional external logic. There is not a special instruction to read the status information from Port C. A normal read operation of Port C is executed to perform this function. INTERRUPT ENABLE FLAG POSITION INTE B PC2 ACKB (Output Mode 1) or STBB (Input Mode 1) INTE A2 PC4 STBA (Input Mode 1 or Mode 2) INTE A1 PC6 ACKA (Output Mode 1 or Mode 2) Each peripheral device in a microcomputer system usually has a “service routine” associated with it. The routine manages the software interface between the device and the CPU. The functional definition of the 8255 is programmed by the I/O service routine and becomes an extension of the system software. By examining the I/O devices interface characteristics for both data transfer and timing, and matching this information to the examples and tables in the detailed operational description, a control word can easily be developed to initialize the 8255 to exactl y “fit” the application. Figures 18 through 24 present a few examples of typical applications of the 8255. ALTERNATE PORT C PIN SIGNAL (MODE) FIGURE 17. INTERRUPT ENABLE FLAGS IN MODES 1 AND 2 INTERRUPT REQUEST PC3 MODE 1 (OUTPUT) PA0 PA1 PA2 PA3 PA4 PA5 PA6 PA7 PC7 PC6 PC5 PC4 8255 HIGH SPEED PRINTER HAMMER RELAYS DATA READY ACK PAPER FEED FORWARD/REV. PB0 PB1 PB2 PB3 PB4 MODE 1 PB5 (OUTPUT) PB6 PB7 PC1 PC2 PAPER FEED FORWARD/REV. RIBBON CARRIAGE SEN. DATA READY ACK PC0 INTERRUPT REQUEST CONTROL LOGIC AND DRIVERS FIGURE 18. PRINTER INTERFACE 14 XP8255 PLCC44 XD8255-2 DIP-40 INTERRUPT REQUEST PC3 MODE 1 (INPUT) PA0 PA1 PA2 PA3 PA4 PA5 PA6 PA7 R0 R1 R2 FULLY R3 DECODED R4 KEYBOARD R5 SHIFT CONTROL PC4 PC5 STROBE ACK INTERRUPT REQUEST PC3 MODE 1 (INPUT) 8255 PB0 PB1 PB2 PB3 PB4 MODE 1 PB5 (OUTPUT) PB6 PB7 B0 B1 B2 BURROUGHS SELF-SCAN B3 DISPLAY B4 B5 BACKSPACE CLEAR 8255 MODE 0 (INPUT) DATA READY ACK BLANKING CANCEL WORD PC1 PC2 PC6 PC7 PA0 PA1 PA2 PA3 PA4 PA5 PA6 PA7 R0 R1 R2 FULLY R3 DECODED R4 KEYBOARD R5 SHIFT CONTROL PC4 PC5 PC6 PC7 STROBE ACK BUST LT TEST LT TERMINAL ADDRESS PB0 PB1 PB2 PB3 PB4 PB5 PB6 PB7 INTERRUPT REQUEST FIGURE 20. KEYBOARD AND TERMINAL ADDRESS INTERFACE FIGURE 19. KEYBOARD AND DISPLAY INTERFACE INTERRUPT REQUEST PA0 PA1 PA2 PA3 PA4 MODE 0 PA5 (OUTPUT) PA6 PA7 PC4 PC5 PC6 PC7 8255 PC0 PC1 BIT SET/RESET PC2 PC3 LSB PB0 PB1 PB2 LSB MODE 0 (INPUT) PB3 PB4 PB5 PB6 PB7 PC3 12-BIT D/A CONVERTER (DAC) PA0 PA1 PA2 PA3 PA4 PA5 MODE 1 (OUTPUT) PA6 PA7 ANALOG OUTPUT MSB 8255 STB DATA SAMPLE EN STB 8-BIT A/D CONVERTER (ADC) PC7 PC6 PC5 PC4 DATA READY ACK BLANKED BLACK/WHITE PC2 PC1 PC0 ROW STB COLUMN STB CURSOR H/V STB PB0 MODE 0 PB1 (OUTPUT) PB2 PB3 PB4 PB5 PB6 PB7 ANALOG INPUT MSB FIGURE 21. DIGITAL TO ANALOG, ANALOG TO DIGITAL R0 R1 R2 CRT CONTROLLER R3 ² CHARACTER GEN. ² REFRESH BUFFER R4 ² CURSOR CONTROL R5 SHIFT CONTROL CURSOR/ROW/COLUMN ADDRESS H&V FIGURE 22. BASIC CRT CONTROLLER INTERFACE 15 XP8255 PLCC44 XD8255-2 DIP-40 INTERRUPT REQUEST INTERRUPT REQUEST PC3 MODE 2 8255 PC3 PA0 PA1 PA2 PA3 PA4 PA5 PA6 PA7 D0 D1 D2 D3 D4 D5 D6 D7 PC4 PC5 PC7 PC6 DATA STB ACK (IN) DATA READY ACK (OUT) PC2 PC1 PC0 TRACK “0” SENSOR SYNC READY INDEX PB0 PB1 PB2 MODE 0 PB3 (OUTPUT) PB4 PB5 PB6 PB7 FLOPPY DISK CONTROLLER AND DRIVE MODE 1 (INPUT) PA0 PA1 PA2 PA3 PA4 PA5 PA6 PA7 R0 R1 R2 R3 R4 R5 R6 R7 PC4 PC5 PC6 STB ACK STOP/GO MACHINE TOOL 8255 MODE 0 (INPUT) ENGAGE HEAD FORWARD/REV. READ ENABLE WRITE ENABLE DISC SELECT ENABLE CRC TEST BUSY LT PC0 PC1 PC2 PB0 PB1 PB2 MODE 0 PB3 (OUTPUT) PB4 PB5 PB6 PB7 FIGURE 23. BASIC FLOPPY DISC INTERFACE B LEVEL PAPER TAPE READER START/STOP LIMIT SENSOR (H/V) OUT OF FLUID CHANGE TOOL LEFT/RIGHT UP/DOWN HOR. STEP STROBE VERT. STEP STROBE SLEW/STEP FLUID ENABLE EMERGENCY STOP FIGURE 24. MACHINE TOOL CONTROLLER INTERFACE 16 XP8255 PLCC44 XD8255-2 DIP-40 Absolute Maximum Ratings TA = +25°C Thermal Information Supply Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +8.0V Input, Output or I/O Voltage . . . . . . . . . . . . . GND-0.5V to VCC+0.5V ESD Classification . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Class 1 Thermal Resistance (Typical, Note 1) JA (°C/W) JC(°C/W) CERDIP Package. . . . . . . . . . . . . . . . . 50 10 CLCC Package . . . . . . . . . . . . . . . . . . 65 14 PDIP Package . . . . . . . . . . . . . . . . . . . 50 N/A PLCC Package. . . . . . . . . . . . . . . . . . . 55 N/A MQFP Package . . . . . . . . . . . . . . . . . . 62 N/A Maximum Storage Temperature Range. . . . . . . . . .-65°C to +150°C Maximum Junction Temperature CDIP Packages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +175°C PDIP Packages . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +150°C Maximum Lead Temperature (Soldering 10s) . . . . . . . . . . . . +300°C (PLCC and MQFP Lead Tips Only) Operating Conditions Voltage Range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +4.5V to 5.5V Operating Temperature Range 8255 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to 70°C 8255 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-40°C to 85°C 8255 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .-55°C to 125°C Die Characteristics Gate Count. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1000 Gates CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. JA is measured with the component mounted on an evaluation PC board in free air. Electrical Specifications SYMBOL VCC = 5.0V ±10%; TA = Operating Temperature Range PARAMETER TEST CONDITIONS MIN MAX UNITS VIH Logical One Input Voltage 2.0 2.2 - V VIL Logical Zero Input Voltage - 0.8 V 3.0 VCC -0.4 - V - 0.4 V VOH Logical One Output Voltage IOH = -2.5mA, IOH = -100A VOL Logical Zero Output Voltage IOL +2.5mA II Input Leakage Current VIN = VCC or GND, RD, CS, A1, A0, RESET, WR -1.0 +1.0 A IO I/O Pin Leakage Current VO = VCC or GND, D0 - D7 -10 +10 A Bus Hold High Current VO = 3.0V. Ports A, B, C TA = -55°C -50 -450 A TA = +128°C -50 -400 A TA = -55°C 50 450 A TA = +128°C 50 400 A -2.5 Note 2, 4 mA IBHH IBHL IDAR Bus Hold Low Current VO = 1.0V. Port A ONLY Darlington Drive Current Ports A, B, C. Test Condition 3 ICCSB Standby Power Supply Current VCC = 5.5V, VIN = VCC or GND. Output Open - 10 A ICCOP Operating Power Supply Current TA = +25°C, VCC = 5.0V, Typical (See Note 3) - 1 mA/MHz NOTES: 2. No internal current limiting exists on Port Outputs. A resistor must be added externally to limit the current. 3. ICCOP = 1mA/MHz of Peripheral Read/Write cycle time. (Example: 1.0s I/O Read/Write cycle time = 1mA). 4. Tested as VOH at -2.5mA. Capacitance TA = +25°C SYMBOL PARAMETER TYPICAL UNITS CIN Input Capacitance 10 pF CI/O I/O Capacitance 20 pF 17 TEST CONDITIONS FREQ = 1MHz, All Measurements are referenced to device GND XP8255 PLCC44 XD8255-2 DIP-40 AC Electrical Specifications VCC = +5V 10%, GND = 0V; TA = Operating Temperature Range 8255-5 SYMBOL PARAMETER 8255 MIN MAX MIN MAX UNITS TEST CONDITIONS READ TIMING (1) tAR Address Stable Before RD 0 - 0 - ns (2) tRA Address Stable After RD 0 - 0 - ns (3) tRR RD Pulse Width 250 - 150 - ns (4) tRD Data Valid From RD - 200 - 120 ns 1 (5) tDF Data Float After RD 10 75 10 75 ns 2 (6) tRV Time Between RDs and/or WRs 300 - 300 - ns WRITE TIMING (7) tAW Address Stable Before WR 0 - 0 - ns (8) tWA Address Stable After WR 20 - 20 - ns (9) tWW WR Pulse Width 100 - 100 - ns (10) tDW Data Valid to WR High 100 - 100 - ns (11) tWD Data Valid After WR High 30 - 30 - ns OTHER TIMING (12) tWB WR = 1 to Output - 350 - 350 ns (13) tIR Peripheral Data Before RD 0 - 0 - ns (14) tHR Peripheral Data After RD 0 - 0 - ns (15) tAK ACK Pulse Width 200 - 200 - ns (16) tST STB Pulse Width 100 - 100 - ns (17) tPS Peripheral Data Before STB High 20 - 20 - ns (18) tPH Peripheral Data After STB High 50 - 50 - ns (19) tAD ACK = 0 to Output - 175 - 175 ns 1 (20) tKD ACK = 1 to Output Float 20 250 20 250 ns 2 (21) tWOB WR = 1 to OBF = 0 - 150 - 150 ns 1 (22) tAOB ACK = 0 to OBF = 1 - 150 - 150 ns 1 (23) tSIB STB = 0 to IBF = 1 - 150 - 150 ns 1 (24) tRIB RD = 1 to IBF = 0 - 150 - 150 ns 1 (25) tRIT RD = 0 to INTR = 0 - 200 - 200 ns 1 (26) tSIT STB = 1 to INTR = 1 - 150 - 150 ns 1 (27) tAIT ACK = 1 to INTR = 1 - 150 - 150 ns 1 (28) tWIT WR = 0 to INTR = 0 - 200 - 200 ns 1 (29) tRES Reset Pulse Width 500 - 500 - ns 1, (Note) NOTE: Period of initial Reset pulse after power-on must be at least 50sec. Subsequent Reset pulses may be 500ns minimum. 18 1 XP8255 PLCC44 XD8255-2 DIP-40 Timing Waveforms tRR (3) RD tIR (13) tHR (14) INPUT tAR (1) tRA (2) CS, A1, A0 D7-D0 tRD (4) tDF (5) FIGURE 25. MODE 0 (BASIC INPUT) tWW (9) WR tDW (10) tWD (11) D7-D0 tAW (7) tWA (8) CS, A1, A0 OUTPUT tWS (12) FIGURE 26. MODE 0 (BASIC OUTPUT) tST (16) STB IBF tSIB (23) tSIT (26) tRIB (24) tRIT (25) INTR RD tPH (18) INPUT FROM PERIPHERAL tPS (17) FIGURE 27. MODE 1 (STROBED INPUT) 19 XP8255 PLCC44 XD8255-2 DIP-40 Timing Waveforms (Continued) tWOB (21) WR tAOB (22) OBF tWIT (28) INTR ACK tAK (15) tAIT (27) OUTPUT tWB (12) FIGURE 28. MODE 1 (STROBED OUTPUT) DATA FROM CPU TO 8255 WR (NOTE) tAOB (22) OBF tWOB (21) INTR tAK (15) ACK tST (16) STB (NOTE) IBF tSIB (23) tAD (19) tPS (17) tKD (20) PERIPHERAL BUS tRIB (24) tPH (18) RD DATA FROM PERIPHERAL TO 8255 DATA FROM 8255 TO PERIPHERAL DATA FROM 8255 TO CPU FIGURE 29. MODE 2 (BIDIRECTIONAL) NOTE: Any sequence where WR occurs before ACK and STB occurs before RD is permissible. (INTR = IBF  MASK  STB  RD  OBF  MASK  ACK  WR) 20 XP8255 PLCC44 XD8255-2 DIP-40 Timing Waveforms (Continued) A0-A1, CS A0-A1, CS tWA (8) tAW (7) tDW (10) tRA (2) tAR (1) DATA BUS tRR (3) RD tWD (11) (4) tRD WR tDF (5) DATA BUS VALID tWW (9) HIGH IMPEDANCE FIGURE 30. WRITE TIMING FIGURE 31. READ TIMING AC Test Circuit AC Testing Input, Output Waveforms V1 INPUT OUTPUT VIH + 0.4V VOH 1.5V R1 OUTPUT FROM DEVICE UNDER TEST VIL - 0.4V TEST POINT R2 1.5V VOL AC Testing: All AC Parameters tested as per test circuits. Input RISE and FALL times are driven at 1ns/V. C1 (SEE NOTE) TEST CONDITION DEFINITION TABLE NOTE: Includes STRAY and JIG Capacitance 21 TEST CONDITION V1 R1 R2 C1 1 1.7V 523 Open 150pF 2 VCC 2k 1.7k 50pF 3 1.5V 750 Open 50pF XP8255 PLCC44 XD8255-2 DIP-40 Burn-In Circuits F14 F4 5 36 F2 F3 6 35 F5 F5 F11 9 37 F15 F12 F1 10 36 F11 F13 F10 11 35 F12 F14 F6 12 34 F13 F15 F7 13 33 F14 F8 14 32 F15 F9 15 31 F11 F10 16 30 F12 F6 17 29 13 F9 14 27 F10 15 26 F6 16 25 F13 F7 17 24 F14 F8 18 23 F15 19 22 F11 20 21 F12 F9 F10 F11 F12 VCC C1 18 19 20 21 22 23 24 25 26 27 28 C1 NOTES: NOTES: 1. VCC = 5.5V  0.5V 1. C1 = 0.01F minimum 2. VIH = 4.5V  10% 2. All resistors are 47k  5% 3. VIL = -0.2V to 0.4V 3. f0 = 100kHz  10% 4. GND = 0V 4. f1 = f0  2; f2 = f1  2; . . . ; f15 = f14  2 22 F13 F8 VCC 28 38 F0 F15 F14 29 39 8 F15 12 30 1 44 43 42 41 40 F11 F7 11 31 2 F12 F6 10 32 3 F10 F10 9 33 4 F9 F1 8 34 5 F8 F0 7 6 7 F7 GND GND F2 37 F14 4 F13 F13 F9 F11 38 F12 3 F7 F12 F8 F8 F11 39 F9 40 2 F4 1 F7 F3 F6 F6 PLCC CERDIP XP8255 PLCC44 XD8255-2 DIP-40 23 22
XP8255 价格&库存
很抱歉,暂时无法提供与“XP8255”相匹配的价格&库存,您可以联系我们找货
