XL1413
XL1413
    XINLUDA(信路达)
    SOP-16
    开态输入电压(VI(on)@Vce,Ic):3V@2V,300mA 集射极饱和压降(VCE(sat)@Ii,Ic):1.1V@500uA,350mA 输出漏电流(Icex@Vce):50uA@50V ...
XL1413 数据手册
XD1413 DIP-16 / XL1413 SOP-16 The seven NPN Darlington connected transistors in these arrays are well suited for driving lamps, relays, or printer hammers in a variety of industrial and consumer applications. Their high breakdown voltage and internal suppression diodes insure freedom from problems associated with inductive loads. Peak inrush currents to 500 mA permit them to drive incandescent lamps. The 1413, B with a 2.7 k W series input resistor is well suited for systems utilizing a 5.0 V TTL or CMOS Logic. 1 16 2 15 3 14 4 13 5 12 6 11 7 10 8 9 Features • Pb−Free Packages are Available* • NCV Prefix for Automotive and Other Applications Requiring Site and Control Changes 1/7 1413, B 2.7 k Pin 9 5.0 k 3.0 k (Top View) 1413 MAXIMUM RATINGS (TA = 25°C, and rating apply to any one device in the package, unless otherwise noted.) Rating Symbol Value Unit Output Voltage VO 50 V Input Voltage VI 30 V Collector Current − Continuous IC 500 mA Base Current − Continuous IB 25 mA Operating Ambient Temperature Range 1413 TA Storage Temperature Range Tstg −55 to +150 °C Junction Temperature TJ 150 °C °C −20 to +85 −40 to +85 −40 to +125 Thermal Resistance, Junction−to−Ambient Case 648, P Suffix Case 751B, D Suffix RqJA Thermal Resistance, Junction−to−Case Case 648, P Suffix Case 751B, D Suffix RqJC Electrostatic Discharge Sensitivity (ESD) Human Body Model (HBM) Machine Model (MM) Charged Device Model (CDM) ESD °C/W 67 100 °C/W 22 20 V 2000 400 1500 1 1413 ELECTRICAL CHARACTERISTICS (TA = 25°C, unless otherwise noted) Characteristic Symbol Min Typ Max − − − − 100 50 − − − 1.1 0.95 0.85 1.6 1.3 1.1 − 0.93 1.35 − − − − − − 2.4 2.7 3.0 II(off) 50 100 − mA hFE 1000 − − − Input Capacitance CI − 15 30 pF Turn−On Delay Time (50% EI to 50% EO) ton − 0.25 1.0 ms Turn−Off Delay Time (50% EI to 50% EO) toff − 0.25 1.0 ms IR − − − − 50 100 mA VF − 1.5 2.0 V Output Leakage Current (VO = 50 V, TA = +85°C) (VO = 50 V, TA = +25°C) All Types All Types Collector−Emitter Saturation Voltage (IC = 350 mA, IB = 500 mA) (IC = 200 mA, IB = 350 mA) (IC = 100 mA, IB = 250 mA) All Types All Types All Types VCE(sat) Input Current − On Condition (VI = 3.85 V) MC1413, B Input Voltage − On Condition (VCE = 2.0 V, IC = 200 mA) (VCE = 2.0 V, IC = 250 mA) (VCE = 2.0 V, IC = 300 mA) MC1413, B MC1413, B MC1413, B mA VI(on) All Types DC Current Gain (VCE = 2.0 V, IC = 350 mA) Clamp Diode Leakage Current (VR = 50 V) V II(on) Input Current − Off Condition (IC = 500 mA, TA = 85°C) TA = +25°C TA = +85°C Clamp Diode Forward Voltage (IF = 350 mA) V NOTE: 1413 low = −40°C, T high= +125°C. Guaranteed by design. NCV prefix is for automotive and other applications requiring site and change control. 2 Unit mA ICEX 1413 TYPICAL PERFORMANCE CURVES − TA = 25°C 400 I O , OUTPUT CURRENT (mA) 300 1413 200 100 0 0 1.0 2.0 3.0 4.0 5.0 8.0 9.0 10 11 300 All Types 200 100 0 12 0 50 100 VI, INPUT VOLTAGE (V) 800 200 250 300 350 400 7.0 8.0 2.5 700 600 I I, INPUT CURRENT (mA) PIN 13 PIN 10 1 Output Conducting at a Time 500 PIN 16 400 300 200 2.0 Maximum 1.5 Typical 1.0 0.5 All Types 100 0 0 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 0 1.0 2.0 VCE(sat), SATURATION VOLTAGE (V) 3.0 4.0 1 700 2 500 3 300 4 5 200 6 7 100 10 5.0 VI, INPUT VOLTAGE (V) 1000 I C, COLLECTOR CURRENT (mA) IC , COLLECTOR CURRENT (mA) 150 II, INPUT CURRENT (mA) 20 30 % DUTY CYCLE 3 50 70 100 NUMBER OF DRIVERS USED I O , OUTPUT CURRENT (mA) 400 6.0 1413 DIP SOP 4
