RS-06FP7-0R015
RS-06FP7-0R015
    VIKING(光颉)
    贴片电阻 1206 150mΩ ±1% 1/2W ±1500ppm/℃
RS-06FP7-0R015 数据手册
Data Sheet Customer: Product: Current Sensing Thick Film Chip Resistor - RS Series Size: 0402/0603/0805/1206/1210/2010/2512 Issued Date: 10-Mar-21 Edition: REV.B3 VIKING TECH CORPORATION 光頡科技股份有限公司 VIKING TECH CORPORATION KAOHSIUNG BRANCH 光頡科技股份有限公司高雄分公司 VIKING ELECTRONICS (WUXI) CO., LTD. 光頡電子(無錫)有限公司 No.70 Guangfu N. Rd., Hukou Township, Hsinchu County 303, Taiwan No.248-3, Sin-Sheng Rd., Cian-Jhen Dist., Kaohsiung, 806, Taiwan TEL:886-3-5972931 FAX:886-3-5972935•886-3-5973494 E-mail:sales@viking.com.tw TEL:886-7-8217999 FAX:886-7-8228229 E-mail:sales@viking.com.tw No.22 Xixia Road, Machinery & Industry Park, National Hi-Tech Industrial Development Zone of Wuxi, Wuxi, Jiangsu Province, China Zip Code:214028 TEL:86-510-85203339 FAX:86-510-85203667•86-510-85203977 E-mail:china@viking.com.tw Produced by (QC) Checked (QC) Approved by (QC) 10-Mar-21 10-Mar-21 10-Mar-21 Susan Huang J.C. Liu J.C. Liu Prepared by (Sales) Accepted by (Customer) 【RS Series】 Current Sensing Thick Film Chip Resistor Current Sensing Thick Film Chip Resistor ■Scope -This specification applies to all sizes of rectangular-type fixed chip resistors with Ruthenium-base as material. ■Features -Low inductance -Highly reliable multilayer electrode construction -Higher component and equipment reliability -Reduced size of final equipment reliability -RoHS Compliance ■Construction ■Applications -Power Management Applications L -Switching Power Supply D1 -Over Current Protection in Audio Application -Voltage Regulation Module (VRM) W     T -DC-DC Converter, Battery Pack, Charger, Adaptor -Disk Driver      D2  Alumina Substrate  Edge Electrode  Resistor Layer  Bottom Electrode  Barrier Layer  Primary Overcoat  Top Electrode  External Electrode  Secondary Overcoat ■Dimensions L W T D1 D2 (mm) (mm) (mm) (mm) (mm) Weight (g) (1000pcs) 0402 1.00±0.05 0.50±0.05 0.35±0.05 0.20±0.10 0.20±0.10 0.620 RS-03 0603 1.60±0.10 0.80±0.10 0.45±0.10 0.30±0.20 0.30±0.20 2.042 RS-05 0805 2.00±0.10 1.25±0.10 0.50±0.10 0.35±0.20 0.40±0.20 4.368 RS-06 1206 3.10±0.10 1.55±0.10 0.55±0.10 0.50±0.25 0.50±0.20 8.947 RS-10 1210 3.10±0.10 2.60±0.15 0.55±0.10 0.50±0.25 0.50±0.20 15.959 RS-0A 2010 5.00±0.10 2.50±0.15 0.55±0.10 0.60±0.25 0.50±0.20 24.241 RS-12 2512 6.35±0.10 3.10±0.15 0.55±0.10 0.60±0.25 0.50±0.20 39.448 Type Size (Inch) RS-02 www.viking.com.tw For detail questions, contact:sales@viking.com.tw 1 Edition: REV.B3 Revision: 10-Mar-2021 【RS Series】 Current Sensing Thick Film Chip Resistor ■Part Numbering Part Number:RS-03FL7-0R047 RS- 03 F Product Type Dimensions Resistance Tolerance F: ±1% J: ±5% RS 02: 0402 03: 0603 05: 0805 06: 1206 10: 1210 0A: 2010 12: 2512 L ■Recommend Land Pattern 7 Function Code L: Standard P: High Power - Packaging Code 4: 7” Reel 4Kpcs 6: 7” Reel 10Kpcs 7: 7” Reel 5Kpcs 9: 10” Reel 8Kpcs A: 10” Reel 10Kpcs B: 10” Reel 20Kpcs C: 13” Reel 40Kpcs D: 13” Reel 20Kpcs F: Bulk 0 R 0 4 7 Resistance - 0R047: 0.047Ω - - - 0R1: 0.1Ω “-“ to fill up 6 spaces ■Derating Curve Derating Curve 100 Power ratio(%) B . C A Type A (mm) B (mm) C (mm) RS-02 0.50 0.45 0.60 RS-03 0.90 0.60 0.90 RS-05 1.20 0.70 1.30 RS-06 2.00 0.90 1.60 RS-10 2.00 0.90 2.80 RS-0A 3.80 0.90 2.80 RS-12 3.80 1.60 3.50 80 60 40 20 0 0 20 40 60 80 100 120 140 160 180 Ambient Temperature(℃) ■Soldering Condition (IPC/JEDEC J-STD-020) www.viking.com.tw For detail questions, contact:sales@viking.com.tw 2 Edition: REV.B3 Revision: 10-Mar-2021 【RS Series】 Current Sensing Thick Film Chip Resistor ■Standard Electrical Specifications Item Power Rating at 70C Operating Temp. Max. Operating Range Current Type Resistance Range (mΩ) ±1% TCR (PPM/C) ±5% RS-02 (0402) 1/16W -55 ~ +155C 1.11A 50 - 91 100 - 976 800 500 RS-03 (0603) 1/10W -55 ~ +155C 2.23A 20 - 47 50 - 91 100 - 976 1200 800 500 RS-05 (0805) 1/8W -55 ~ +155C 3.53A RS-06 (1206) 1/4W -55 ~ +155C 5.00A 10 - 18 20 - 47 50 - 91 100 - 976 1500 1200 800 500 RS-10 (1210) 1/3W -55 ~ +155C 5.77A RS-0A (2010) 3/4W -55 ~ +155C 8.66A 10 - 18 20 - 91 100 - 976 1500 800 500 RS-12 (2512) 1W -55 ~ +155C 10.0A Operating Voltage=√(P*R) ; Overload Voltage=2.5*√(P*R) ■High Power Electrical Specifications Item Type Power Rating at 70°C Operating Temp. Max. Operating Range Current Resistance Range (mΩ) ±1% TCR (PPM/°C) ±5% RS-02 (0402) 1/10W -55 ~ +155C 1.40A 50 - 91 100 - 976 800 500 RS-03 (0603) 1/8W -55 ~ +155C 2.50A 20 - 47 50 - 91 100 - 976 1200 800 500 RS-05 (0805) 1/4W -55 ~ +155C 5.00A RS-06 (1206) 1/2W -55 ~ +155C 7.07A 10 - 18 20 - 47 50 - 91 100 - 976 1500 1200 800 500 RS-10 (1210) 1/2W -55 ~ +155C 7.07A RS-0A (2010) 1W -55 ~ +155C 10.0A 10 - 18 20 - 91 100 - 976 1500 800 500 RS-12 (2512) 2W -55 ~ +155C 14.1A Operating Voltage=√(P*R) Overload Voltage=2.5*√(P*R) Operating Current=√(P/R) ■ Viking is capable of manufacturing the optional spec based on customer’s requirement. www.viking.com.tw For detail questions, contact:sales@viking.com.tw 3 Edition: REV.B3 Revision: 10-Mar-2021 【RS Series】 Current Sensing Thick Film Chip Resistor ■Environmental Characteristics Requirement Item Temperature Coefficient of Resistance (T.C.R.) JIS-C-5201-1 4.8 IEC-60115-1 4.8 As Spec. Short Time Overload (1.0%+0.05Ω) Insulation Resistance 10G Endurance Test Method 5% 1% (2.0%+0.05Ω) At 25C/-55C and 25C/+125C, 25C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds, 2 seconds for High Power Series JIS-C-5201-1 4.6 IEC-60115-1 4.6 (1.0%+0.10Ω) (2.0%+0.10Ω) Damp Heat with Load (1.0%+0.10Ω) (2.0%+0.10Ω) Dry Heat (1.0%+0.05Ω) (1.5%+0.10Ω) Max. Overload Voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 702C, RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.24 IEC-60115-1 4.24 402C, 90~95% R.H., RCWV for 1000 hrs with 1.5 hrs “ON” and 0.5 hr “OFF” JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +155C for 1000 hrs Bending Strength (1.0%+0.05Ω) Solderability 95% min. coverage Resistance to Soldering Heat (0.5%+0.05Ω) (1.0%+0.05Ω) (1.0%+0.05Ω) JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending once for 60 seconds 2010, 2512 sizes: 2mm Other sizes: 3mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 2455C for 3 seconds JIS-C-5201-1 4.18 IEC-60115-1 4.18 2605C for 10 seconds JIS-C-5201-1 4.7 IEC-60115-1 4.7 Voltage Proof Leaching Rapid Change of Temperature No breakdown or flashover 1.42 times Max. Operating Voltage for 1 minute RS-02:100V; RS-03:150V; RS-05:300V RS-06/10/0A:400V; RS-12:500V Individual leaching area ≦5% JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 Total leaching area ≦ 10% 2605C for 30 seconds JIS-C-5201-1 4.19 IEC-60115-1 4.19 -55C to +155C, 5 cycles (0.5%+0.05Ω) (1.0%+0.05Ω) RCWV(Rated Continuous Working Voltage)=√(P*R) or Max. Operating Voltage whichever is lower. ■ Storage Temperature: 15~28°C; Humidity < 80%RH www.viking.com.tw For detail questions, contact:sales@viking.com.tw 4 Edition: REV.B3 Revision: 10-Mar-2021 【RS Series】 Current Sensing Thick Film Chip Resistor ▓Packaging Reel Specifications & Packaging Quantity Type RS-02 Paper RS-03 RS-05 RS-06 Paper RS-10 RS-0A RS-12 Tape Width Reel Diameter ΦA (mm) 10K 8mm 7 inch 178.5±1.5 20K 8mm 10 inch 254±1.0 40K 8mm 13 inch 330±1.0 5K 8mm 7 inch 178.5±1.5 10K 8mm 10 inch 254±1.0 20K 8mm 13 inch 330±1.0 4K 12mm 7 inch 178.5±1.5 8K 12mm 10 inch 250±1.0 Bottom Tape Top Tape Packaging Quantity ΦB (mm) ΦC (mm) W (mm) T (mm) 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 13.0±0.2 9.0±0.5 12.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 100±0.5 13.0±0.2 9.5±0.5 13.5±0.5 +1/-0 13.0±0.5 13.0±0.5 15.5±0.5 62±0.5 13.0±0.5 12.5±0.5 16.5±0.5 60 60 60 +1/-0 +1/-0 Embossed Paper Tape Specifications ψ D0 E A F W B T Paper Tape Type A (mm) B (mm) W (mm) P1 Resistor E (mm) F (mm) P0 (mm) P2 P0 P1 (mm) Direction of unreeling P2 (mm) ΦD0 (mm) T (mm) RS-02 0.65±0.10 1.15±0.10 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 2.00±0.05 2.00±0.05 1.50+0.1,-0 0.45±0.10 RS-03 1.10±0.10 1.90±0.10 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.70±0.10 RS-05 1.60±0.10 2.40±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RS-06 1.90±0.10 3.50±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 RS-10 2.90±0.10 3.50±0.20 8.00±0.20 1.75±0.10 3.50±0.05 4.00±0.10 4.00±0.05 2.00±0.05 1.50+0.1,-0 0.85±0.10 www.viking.com.tw For detail questions, contact:sales@viking.com.tw 5 Edition: REV.B3 Revision: 10-Mar-2021 【RS Series】 Current Sensing Thick Film Chip Resistor Embossed Plastic Tape Specifications Top Tape ψ D0 E A F W B ψD11.5+0.25,-0 T P1 Resistor P2 P0 Direction of unreeling Embossed Tape P2 (mm) ΦD0 (mm) Type A (mm) B (mm) W (mm) E (mm) F (mm) P0 (mm) P1 (mm) T (mm) RS-0A 2.80±0.10 5.40±0.20 12.0±0.30 1.75±0.10 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 RS-12 3.50±0.10 6.70±0.10 12.0±0.30 1.75±0.10 5.50±0.05 4.00±0.10 4.00±0.10 2.00±0.05 1.50+0.1, -0 1.2 +0 ■Marking No Marking for 0402 1%, 5% for 0805/1206/1210/2010/2512: 4 digits marking Example: Resistance Marking 47mΩ R047 75mΩ R075 15mΩ R015 750mΩ R750 820mΩ R820 5% for 0603: 3 digits marking in E24 1% for 0603: 3 digits marking with under-line in E96 (non-including E24 series) R10 3 digits marking for E24 or R value suffix is zero in E96: R10=100mΩ; R28=280mΩ 243 3 digits marking for E96: 243=243mΩ; 511=511mΩ www.viking.com.tw For detail questions, contact:sales@viking.com.tw 6 Edition: REV.B3 Revision: 10-Mar-2021 【RS Series】 Current Sensing Thick Film Chip Resistor REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version A9 Jun 03, 2014 - - Environmental Characteristics updated Version B - - Remove Material Description - Modify Storage Temperature - - Size 1206 High power product Power rating 1/3W upgrade to 1/2W Jul 15, 2016 Version B1 Mar 06, 2017 Version B2 May 20, 2019 Version B3 Mar 10, 2021 www.viking.com.tw - - Modify TCR Test description - Modify Bending Test description - Modify 2010 Embossed Plastic Tape B Specification - Modify Soldering Condition (IPC/JEDEC J-STD-020) - For detail questions, contact:sales@viking.com.tw 7 Edition: REV.B3 Revision: 10-Mar-2021
RS-06FP7-0R015
物料型号:RS系列电流感应厚膜芯片电阻器
器件简介:这些电阻器采用钌基材料制成,具有低电感、高可靠性的多层电极结构,符合RoHS标准。
引脚分配:文档中没有明确提供引脚分配信息,但通常这类电阻器为端电极设计。
参数特性: - 尺寸范围:0402/0603/0805/1206/1210/2010/2512 - 功率额定值:根据尺寸不同,功率额定值从1/16W至2W不等 - 工作温度范围:-55°C至+155°C - 最大工作电流:根据尺寸不同,最大工作电流从1.11A至14.1A不等 - 电阻范围:50mΩ至10Ω - 温度系数(TCR):+800ppm/°C至+1500ppm/°C
功能详解:适用于电源管理应用、开关电源、音频应用中的过流保护、电压调节模块(VRM)、DC-DC转换器、电池组、充电器、适配器、磁盘驱动器等。
应用信息:RS系列电阻器适用于多种应用,包括但不限于电源管理、开关电源、过流保护、电压调节等。
封装信息:提供多种尺寸的封装选项,每种尺寸都有详细的尺寸参数和重量信息。
RS-06FP7-0R015 价格&库存
很抱歉,暂时无法提供与“RS-06FP7-0R015”相匹配的价格&库存,您可以联系我们找货
