RJ0805FRE073R9L
RJ0805FRE073R9L
    YAGEO(国巨)
    贴片电阻 0805 3.9Ω ±1% 1/10W ±50ppm/℃
RJ0805FRE073R9L 数据手册
DATA SHEET THIN FILM CHIP RESISTORS General purpose RJ series 1%, TC50 sizes 0402/0603/0805/1206/ 1210/2010/2512 Product specification – Jul 11, 2008 V.2 RoHS compliant Product specification Chip Resistor Surface Mount RJ SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes RJ0402 to RJ2512 general purpose chip resistors with leadfree terminations made by thin film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. APPLICATIONS Converters Printer equipment Server board Telecom Consumer 2 9 0402 to 2512 (RoHS Compliant) SERIES YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) RJ XXXX F X E XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0402 / 0603 / 0805 / 1206 / 1210 / 2010 / 2512 (2) TOLERANCE F = ±1% (3) PACKAGING TYPE FEATURES RoHS compliant - Products with lead free terminations meet RoHS requirements - Pb-glass contained in electrodes - Resistor element and glass are exempted by RoHS Reducing environmentally hazardous wastes High component and equipment reliability Saving of PCB space None forbidden-materials used in products/production Halogen Free Epoxy R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE E = ±50 ppm/°C (5) TAPING REEL 07 = 7 inch dia. Reel 10 = 10 inch dia. Reel 13 = 13 inch dia. Reel (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed resistance rules show in table of “Resistance rule of global part number”. (7) OPTIONAL CODE L = optional symbol (Note) Resistance rule of global part number Resistance code rule Example XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XMXX (1 to 9.76 MΩ) 1M = 1,000,000 Ω 9M76= 9,760,000 Ω ORDERING EXAMPLE The ordering code of a RJ0603 chip resistor, TC50 value 56 X with ±1% tolerance, supplied in 7-inch tape reel is: RJ0603FRE0756R(L). NOTE 1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Jul 11, 2008 V.2 Product specification Chip Resistor Surface Mount RJ SERIES 3 9 0402 to 2512 (RoHS Compliant) PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER ( PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. 12NC CODE 2390 XXX XXXXX L (1) (2) (3) (4) RJ START TOL. RESISTANCE SIZE IN (1) (%) RANGE EMBOSSED TAPE ON REEL(2) PAPER TAPE ON REEL (units) (2) 4,000 5,000 10,000 20,000 0402 2390 ±1% 10 Ω to 121 kΩ - - 407 8xxxx 427 8xxxx 447 8xxxx 0603 2390 ±1% 5.1 Ω to 681 kΩ - 404 8xxxx 424 8xxxx 444 8xxxx - 0805 2390 ±1% 5.1 Ω to 1.5 MΩ - 401 8xxxx 421 8xxxx 441 8xxxx - 1206 2390 ±1% 5.1 Ω to 1.5 MΩ - 411 8xxxx 431 8xxxx 451 8xxxx - 1210 2390 ±1% 5.1 Ω to 1 MΩ - 412 0xxxx 432 8xxxx 412 8xxxx - 2010 2390 ±1% 10 Ω to 1 MΩ 415 8xxxx - - - - 2512 2390 ±1% 10 Ω to 1 MΩ 418 8xxxx - - - - (1) The resistors have a 12-digit ordering code starting with 2390. (2) The subsequent 4 digits indicate the resistor tolerance and packaging. 50,000 Last digit of 12NC Resistance decade (3) Last digit 0.01 to 0.0976 X 0.1 to 0.976 X 0 1 to 9.76 X 8 10 to 97.6 X 9 100 to 976 X 1 ORDERING EXAMPLE 1 to 9.76 kX 2 The ordering code of a RJ0603 resistor, TC50 value 56 X, with ±1% tolerance, supplied in tape of 5,000 units per reel is: 239040485609(L) or RJ0603FRE0756R(L). 10 to 97.6 kX 3 100 to 976 kX 4 1 to 9.76 MX 5 10 to 97.6 MX 6 (3) The remaining 4 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. (4) “L” is optional symbol (Note) NOTE 1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) Example: 7 0.02 X = 0200 or 200 0.3 X = 3007 or 307 1X = 1008 or 108 33 kX = 3303 or 333 10 MX = 1006 or 106 www.yageo.com Jul 11, 2008 V.2 Product specification Chip Resistor Surface Mount RJ SERIES 4 9 0402 to 2512 (RoHS Compliant) MARKING RJ0805 / RJ1206 / RJ1210 / RJ2010 / RJ2512 Either resistance in E-24 or E-96: 4 digits 00 YNSC004 Fig. 1 Value = 10 kΩ First three digits for significant figure and 4th digit for number of zeros RJ0603 E-24 series: 3 digits ynsc015 Fig. 2 Value = 12 kΩ First two digits for significant figure and 3rd digit for number of zeros E-96 series: 3 digits for 0603±1% EIA-96 marking method Fig. 3 Value = 12.4 kΩ RJ0402 ynsc007 No marking Fig. 4 For further marking information, please see special data sheet “Chip resistors marking”. www.yageo.com Jul 11, 2008 V.2 Product specification Chip Resistor Surface Mount RJ 5 9 0402 to 2512 (RoHS Compliant) SERIES CONSTRUCTION A metal film layer is deposited on a high-grade ceramic body (aluminium oxide). It is given the approximate resistance required and the value is trimmed to within tolerance by laser cutting of this resistive layer. OUTLINES For dimension see Table 1 marking layer Internal metal electrodes are formed into several layers at each end as a contact. To guarantee optimum solderability, the outer layer consists of matte tin. The resistive layer is covered with a protective coat and printed with the resistance value. See fig. 5. protective coat resistive layer inner electrode H termination (Ni / matte tin) ceramic substrate I2 Table 1 For outlines see fig. 5 TYPE L (mm) W (mm) H (mm) I1 (mm) I1 I2 (mm) RJ0402 1.00 ±0.10 0.50 ±0.05 0.30 ±0.05 0.20 ±0.10 0.25 ±0.10 RJ0603 1.60 ±0.10 0.80 ±0.10 0.45 ±0.10 0.25 ±0.15 0.25 ±0.15 W RJ0805 2.00 ±0.10 1.25 ±0.10 0.50 ±0.10 0.35 ±0.20 0.35 ±0.20 RJ1206 3.10 ±0.10 1.60 ±0.10 0.55 ±0.10 0.45 ±0.20 0.40 ±0.20 YNSC064 RJ1210 3.10 ±0.10 2.60 ±0.15 0.55 ±0.10 0.50 ±0.20 0.50 ±0.20 RJ2010 5.00 ±0.10 2.50 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20 RJ2512 6.35 ±0.10 3.20 ±0.15 0.55 ±0.10 0.60 ±0.20 0.50 ±0.20 L Fig. 5 Chip resistor outlines ELECTRICAL CHARACTERISTICS Table 2 RATING MAXIMUM WORKING VOLTAGE DIELECTRIC WITHSTAND VOLTAGE MAXIMUM OVERLOAD VOLTAGE TEMPERATURE COEFFICIENT OF RESISTANCE –55 °C to +125 °C 1/16 W 25 V 100 V 100 V ±50 ppm/°C 5.1 Ω to 681 KΩ –55 °C to +125 °C 1/16 W 50 V 100 V 100 V ±50 ppm/°C 5.1 Ω to 1.5 MΩ –55 °C to +125 °C 1/10 W 100 V 250 V 200 V ±50 ppm/°C 5.1 Ω to 1.5 MΩ –55 °C to +125 °C 1/8 W 150 V 250 V 250 V ±50 ppm/°C 5.1 Ω to 1 MΩ –55 °C to +125 °C 1/4 W 150 V 400 V 300 V ±50 ppm/°C 10 Ω to 1 MΩ –55 °C to +125 °C 1/2 W 150 V 400 V 300 V ±50 ppm/°C 10 Ω to 1 MΩ –55 °C to +125 °C 3/4 W 150 V 400 V 300 V ±50 ppm/°C RESISTANCE RANGE OPERATING TEMPERATURE RANGE RJ0402 10 Ω to 121 KΩ RJ0603 RJ0805 RJ1206 RJ1210 RJ2010 RJ2512 TYPE POWER www.yageo.com Jul 11, 2008 V.2 Product specification Chip Resistor Surface Mount RJ 6 9 0402 to 2512 (RoHS Compliant) SERIES FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL DIMENSION RJ0402 RJ0603 RJ0805 RJ1206 RJ1210 RJ2010 RJ2512 7" (178 mm) 10,000 5,000 5,000 5,000 5,000 --- --- 10" (254 mm) 20,000 10,000 10,000 10,000 10,000 --- --- 13" (330 mm) 50,000 20,000 20,000 20,000 20,000 --- --- 7" (178 mm) --- --- --- --- --- 4,000 4,000 Paper taping reel (R) Embossed taping reel (K) NOTE 1. For Paper/Embossed tape and reel specification/dimensions, please see the special data sheet “Packing” document. FUNCTIONAL DESCRIPTION OPERATINGTEMPERATURE RANGE Range: –55°C to +125°C handbook, P halfpage POWER RATING Each type rated power at 70°C: RJ0402=1/16 W, RJ0603=1/16 W, RJ0805=1/10 W, RJ1206=1/8 W, RJ1210=1/4 W, RJ2010=1/2 W, RJ2512=3/4 W. 50 RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V = √(P X R) MLB206 max (%Prated ) 100 0 55 0 50 70 100 125 o Tamb ( C) Fig. 6 Maximum dissipation (Pmax) in percentage of rated power as a function of the operating ambient temperature (Tamb ) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (X) www.yageo.com Jul 11, 2008 V.2 Product specification Chip Resistor Surface Mount RJ SERIES 7 9 0402 to 2512 (RoHS Compliant) TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Life/ Operational Life/ Endurance MIL-STD-202F-method 108A 1,000 hours at 70°C ±5°C applied RCWV 1.5h on, 0.5h off, still air required ±(1%+0.05 Ω) High Temperature Exposure/ Endurance at upper category temperature MIL-STD-202F-method 108A 1,000 hours at maximum operating temperature depending on specification, unpowered ±(0.5%+0.05 Ω) IEC 60115- 4.25.3 JIS C 5202-7.11 No direct impingement of forced air to the parts Moisture Resistance MIL-STD-202F-method 106F IEC 60115- 4.25.1 JIS C 5202-7.10 Tolerances: 125±3 °C IEC 60115- 4.24.2 Each temperature / humidity cycle is defined at 8 hours (method 106F), 3 cycles / 24 hours for 10d with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered ±(0.5%+0.05 Ω) Parts mounted on test-boards, without condensation on parts Measurement at 24±2 hours after test conclusion Thermal Shock MIL-STD-202 Method 107 -55/+125 °C Note: Number of cycles required is 300. Devices unmounted ±(0.5%+0.05 Ω) Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air Short time overload MIL-R-55342D-para 4.7.5 Board Flex/ Bending IEC60115-1 4.33 IEC60155-1 4.6.1.1 IEC60068-2-21 Ue1 2.5 times RCWV or maximum overload voltage whichever is less for 5 sec at room temperature ±(1%+0.05 Ω) Device mounted on PC board as described, only 1 board bending required ±(1%+0.05 Ω) Bending : sizes ≤ 1206 : 3mm sizes > 1206 : 2mm Bending time: 60±5 seconds Ohmic value checked during bending www.yageo.com Jul 11, 2008 V.2 Product specification Chip Resistor Surface Mount RJ SERIES TEST TEST METHOD PROCEDURE REQUIREMENTS Solderability - Wetting J-STD-002 Electrical Test not required. Magnification 50X. Well tinned (≥95% covered) No visible damage SMD conditions: 1st step: method B, aging 4 hours at 155°C dry heat 8 9 0402 to 2512 (RoHS Compliant) 2nd step: leadfree solder bath at 245±3°C Dipping time: 3±0.5 seconds - Leaching EIA/IS 4.13B Leadfree solder, 260 °C, 30 seconds immersion time No visible damage Condition B, no pre-heat of samples ±(0.5%+0.05 Ω) IEC 60115-8 4.18 - Resistance to Soldering Heat MIL-STD-202 Method 210 Leadfree solder, 270 °C, 10 seconds immersion time Procedure 2 for SMD: devices fluxed and cleaned with isopropanol www.yageo.com Jul 11, 2008 V.2 Product specification Chip Resistor Surface Mount RJ SERIES 9 9 0402 to 2512 (RoHS Compliant) REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 2 - - Change to dual brand datasheet that describe RJ0402 to RJ2512 with RoHS compliant Jul 11, 2008 - Modify ordering information - global part number & 12NC - Modify electrical characteristic - Tests and requirements update Version 1 May 30, 2005 - - New datasheet for thin film general purpose chip resistors sizes of 0201/0402/0603/0805/1206/1210/2010/2512 1%, TC50 with lead-free terminations www.yageo.com Jul 11, 2008 V.2
RJ0805FRE073R9L 价格&库存
很抱歉,暂时无法提供与“RJ0805FRE073R9L”相匹配的价格&库存,您可以联系我们找货
