RR1220P-304-B-T5
RR1220P-304-B-T5
    SUSUMU
    贴片电阻 0805 300KΩ ±0.1% 1/10W ±25ppm/℃
RR1220P-304-B-T5 数据手册
RR series, ultra-precision metal film chip resistors Available for resistance tolerance of +/-0.1%, thermal coefficient of resistance of +/-5ppm/degree C Our SMD components contribute to lead-free composition of electronic products. SPECIFICATIONS Dimension (mm) L W P T Mechanical W P RR1220 (RN73) (0805) 2.000.20 1.250.20 0.400.20 0.400.10 RR0816 (0603) 1.600.20 0.800.20 0.300.20 0.400.10 RR1632 (1206) RR2632 (1210) 3.200.20 1.600.20 0.500.20 0.400.10 3.200.20 2.600.20 0.500.20 0.400.10 L T Equivalent circuit Electrical Type Power Resistance Tolerance (code) Resistance Range(ohm) Temperature Coefficient of Resistance ppm /C(code) RR0816 1/16W RN73 1/10W 0.1% (B) 0.1% 0.5% (B) (D) RR1632 1/8W RR2632 1/4W 0.1% (B) 0.1% (B) 100332K 511100K 100100K 1001M 100200K 100200K 511M 100330K 100330K 512M 25 (P) E24/E96 75V Maximum Operating Voltage Resistance Value Package RR1220 1,000• 5,000pcs/reel 5 (V) 25 (P) 10 (N) 5 (V) E24/E96 100V 1,000•5,000• 10,000pcs/reel 1,000•5,000 pcs/reel 10 (N) 25 (P) 5 (V) 10 (N) 25 (P) E24/E96 150V E24/E96 200V 1,000•5,000pcs/reel 1,000•5,000pcs/reel •RR1632 and RR2632 with resistance value less than 50 ohm are also available. •RR0510 type with resistance tolerance +/-0.1% is also available. PART NUMBER RR 0816 P - 102 - B (-T1) Quantity in a tape:T1(1000pcs),T5(5000pcs),T10(10000pcs) Resistance Tolerance Resistance (The resistance values of RR1632 and RR2632 are expressed in four-digit figures.) Power Rating Temperature Coefficient of Resistance Dimensions Part Code RN73 N 2X 1001 B (-T1) susumu group catalog 7
RR1220P-304-B-T5
1. 物料型号:文档中列出了几种型号,包括RR0816、RR1220、RR1632和RR2632。
2. 器件简介:这些是超精密金属膜芯片电阻器,具有±0.1%的电阻公差和±5ppm/°C的电阻温度系数。这些SMD组件有助于电子产品的无铅组成。
3. 引脚分配:文档中没有明确提到引脚分配,但提供了不同型号的尺寸信息,包括长度(L)、宽度(W)、引脚间距(P)和厚度(T)。
4. 参数特性: - 电阻公差:±0.1%(B)、±0.5%(D) - 电阻范围:100Ω至332KΩ,具体范围根据型号而异 - 温度系数:±25ppm/°C(P)、±10ppm/°C(N)、±5ppm/°C(V) - 最大工作电压:75V至200V,取决于型号 - 包装:1,000至10,000件/卷
5. 功能详解:文档中没有提供功能详解,但可以推断这些电阻器因其高精度和温度稳定性而适用于精密电子设备。
6. 应用信息:文档中没有直接提供应用信息,但考虑到它们的高精度特性,它们可能用于需要精确电阻值的电路。
7. 封装信息:提供了不同型号的封装尺寸和包装数量。
RR1220P-304-B-T5 价格&库存
很抱歉,暂时无法提供与“RR1220P-304-B-T5”相匹配的价格&库存,您可以联系我们找货
