SR2010KK-0768RL
SR2010KK-0768RL
    YAGEO(国巨)
    贴片电阻 2010 68Ω ±10% 3/4W ±100ppm/℃
SR2010KK-0768RL 数据手册
DATA SHEET SURGE CHIP RESISTORS SR series 20%, 10%, 5% sizes 0402/0603/0805/1206/1210/1218/2010/2512 Product specification – July 22, 2019 V.8 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SR 0402/0603/0805/1206/1210/1218/2010/2512 SERIES SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes SR0402 to SR2512 chip resistors with lead-free terminations made by thick film process. Part number is identified by the series name, size, tolerance, packaging type, temperature coefficient, taping reel and resistance value. APPLICATIONS  Telecommunications  Power supplies  Car electronics FEATURES  AEC-Q200 qualified  Superior to SR series in pulse withstanding voltage and surge withstanding voltage.  MSL class: MSL 1  Halogen free epoxy  RoHS compliant - - Products with lead-free terminations meet RoHS requirements Pb-glass contained in electrodes, resistor element and glass are exempted by RoHS  Reduce environmentally hazardous waste  High component and equipment reliability 2 8 GLOBAL PART NUMBER SR XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512 (2) TOLERANCE J = ± 5% K = ± 10% M = ± 20% (3) PACKAGING TYPE R = Paper taping reel K = Embossed taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Based on spec. (5) TAPING REEL & POWER 07 = 7 inch dia. Reel 7W = 7 inch dia. Reel & 2 x standard power 13 = 13 inch dia. Reel 7T = 7 inch dia. Reel & 3 x standard power 47 = 7 inch dia. Reel & 4xstandard power (6) RESISTANCE VALUE 1 Ω ≤ R ≤ 1M Ω There are 2~4 digits indicated the resistance value. Letter R/K/M is decimal point, no need to mention the last zero after R/K/M, e.g.1K2, not 1K20. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance coding Example rule XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XXKX (10 to 97.6 KΩ) 10K = 10,000 Ω 97K6= 976,000 Ω XXXK (100 KΩ) 100K = 100,000 Ω O RDERING EXAMPLE The ordering code for an SR0805 chip resistor, value 10 KΩ with ± 5% tolerance, supplied in 7-inch tape reel is: SR0805JR-0710KL. www.yageo.com Jul. 22, 2019 V.8 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 3 8 MARKING SR0402 No Marking Fig. 1 SR1218 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 2 Value=10 KΩ SR0603 / SR0805 / SR1206 / SR1210 / SR2010 / SR2512 03 Fig. 3 E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Value=10 KΩ NOTE For further marking information, please refer to data sheet “Chip resistors marking”. TAPING REEL & POWER Table 1 POWER, W (P70) TYPE CODING 07 7W 7T 47 0402 1/16 1/8 1/5 - 0603 1/10 1/5 1/4 - 0805 1/8 1/4 1/3 1/2 1206 1210 1/4 1/2 3/4 1 1/2 1 - - 1218 1 1.5 - - 2010 3/4 1.25 - - 2512 1 2 - - CONSTRUCTION OUTLINES The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added at each end and connected by a resistive glaze. The resistive glaze is covered by a lead-free glass. The composition of the glaze is adjusted to give the approximately required resistance value. The whole element is covered by a protective overcoat. The top of overcoat is marked with the resistance value. Finally, the two external terminations (Ni/matte tin) are added, as shown in Fig.4. Fig. 4 Chip resistor outlines www.yageo.com Jul. 22, 2019 V.8 Product specification Chip Resistor Surface Mount SR SERIES 4 8 0402/0603/0805/1206/1210/1218/2010/2512 DIMENSIONS Table 2 TYPE L (mm) W (mm) H (mm) I1 (mm) I2 (mm) SR0402 1.00± 0.05 0.50± 0.05 0.35± 0.05 0.20± 0.10 0.25± 0.10 SR0603 1.60± 0.10 0.80± 0.10 0.45± 0.10 0.25± 0.15 0.25± 0.15 SR0805 2.00± 0.10 1.25± 0.10 0.50± 0.10 0.35± 0.20 0.35± 0.20 SR1206 3.10± 0.10 1.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 SR1210 3.10± 0.10 2.60± 0.15 0.55± 0.10 0.45± 0.15 0.50± 0.20 SR1218 3.10± 0.10 4.60± 0.10 0.55± 0.10 0.45± 0.20 0.40± 0.20 SR2010 5.00± 0.10 2.50± 0.15 0.55± 0.10 0.55± 0.15 0.50± 0.20 SR2512 6.35± 0.10 3.10± 0.15 0.55± 0.10 0.60± 0.20 0.50± 0.20 For dimension, please refer to Table 1 SR0402 SR0603/0805/1206/ 1210/2010/2512 SR1218 Side view for all type Fig. 5 Chip resistor dimensions ELECTRICAL CHARACTERISTICS Table 3 TYPE SR0402 POWER CHARACTERISTICS Operating Temperature Max. Max. Dielectric RESISTANCE Range Working Overload Withstanding RANGE Voltage Voltage Voltage 1/16W 1/8W 50 V 100 V 100 V 75V 150V 150V 150V 300V 300V Temperature Coefficient of Resistance 1/5W 1/10W SR0603 1/5W 1/4W 1/8 W 1/4W SR0805 1/3W 10Ω < R ≤ 1MΩ 1/2W 1/4 W 1/2W SR1206 3/4W E24 5%, 10%, 20% 1 Ω ≤ R ≤ 1M Ω ± 100 ppm/°C –55 °C to +155 °C 200 V 400 V 500 V 1W 1/2W SR1210 1W 1W SR1218 SR2010 1.5W 3/4W 1.25W SR2512 1W 2W 1Ω ≤ R ≤ 10Ω ± 200 ppm/°C 200 V 400 V 500 V 200 V 400 V 500 V 200 V 400 V 500 V 200 V 400 V 500 V www.yageo.com Jul. 22, 2019 V.8 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 5 8 FOOTPRINT AND SOLDERING PROFILES Recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 4 Packing style and packaging quantity PACKING STYLE Paper taping reel (R) Embossed taping reel (K) REEL DIMENSION SR0402 SR0603/0805/1206 SR1210 SR1218/2010/2512 7" (178 mm) 10,000 5,000 5,000 --- 13" (330 mm) 50,000 20,000 20,000 --- 7" (178 mm) --- --- --- 4,000 NOTE 1. For paper/embossed tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. TEMPERATURE COEFFICIENT OF RESISTANCE RESISTANCE FUNCTIONAL DESCRIPTION RANGE OPERATING TEMPERATURE RANGE PT040–55 °C to +155 °C 100 mΩ to 910 mΩ Range: 2 ± 200 ppm/°C POWER RATING PT060 Each type rated power at 70 ±°C: 200 ppm/°C 3 SR0402: 1/16W, 1/8W, 1/5W SR0603: 1/10W, 1/5W, 1/4W PT080 ± 200 ppm/°C SR0805: 1/8W, 1/4W, 1/3W, 1/2W 5 SR1206: 1/4W, 1/2W, 3/4W, 100 MΩ TO 910 MΩ 1W PT120 1/2W, 1W SR1210: 100 mΩ > 100 mΩ 6 SR1218: 1W, 1.5W SR2010: 3/4W, 1.25W PT201 ± 100 ppm/°C ± 75 ppm/°C SR2512: 1W, 2W 0 Fig. 6 Maximum dissipation (P max ) in percentage of rated power R ATED VOLTAGE as a function of the operating ambient temperature (T amb) PT251 ± 100 ppm/°C ± 75 ppm/°C The 2 DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= (P X R) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) www.yageo.com Jul. 22, 2019 V.8 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 6 8 PULSE LOAD BEHAVIOR Fig. 7 Pulse-Load behavior TESTS AND REQUIREMENTS Table 5 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Temperature Coefficient of Resistance (T.C.R.) MIL-STD-202 Method 304 At +25/–55 °C and +25/+125 °C Refer to table 2 Formula: R2–R1 T.C.R= ------------------------- × 106 (ppm/°C) R1(t2–t1) Where t1= +25 °C or specified room temperature t2= –55 °C or +125 °C test temperature R1=resistance at reference temperature in ohms R2=resistance at test temperature in ohms Short Time Overload IEC60115-1 4.13 2.5 times of rated voltage or maximum overload voltage whichever is less for 5 sec at room temperature ± (2.0%+0.05 Ω) High Temperature Exposure IEC 60068-2-2 1,000 hours at TA = 155 °C ± 5 °C, unpowered ± (3.0%+0.05 Ω) Humidity IEC 60115-1 4.24.2 Steady state for 1,000 hours at 40 °C / 95% R.H. ± (3.0%+0.05 Ω) RCWV applied for 1.5 hours on and 0.5 hour off www.yageo.com Jul. 22, 2019 V.8 Product specification Chip Resistor Surface Mount TEST Life Resistance to Soldering Heat SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 TEST METHOD PROCEDURE REQUIREMENTS IEC 60115-1 4.25.1 1,000 hours at 70± 2 °C, RCWV applied for 1.5 hours on, 0.5 hour off, still-air required ± (3.0%+0.05 Ω) MIL-STD-202 Method 108 IEC 60115-1 4.18 Condition B, no pre-heat of samples ± (1.0%+0.05 Ω) MIL-STD- 202 Method 210 Lead-free solder, 260± 5 °C, 10± 1 seconds immersion time No visible damage 7 8 Procedure 2 for SMD: devices fluxed and cleaned with isopropanol Temperature Cycling JESD22-A104C -55/+125 °C for 1 cycle per hour, with 1,000 cycles. ± (1.0%+0.05 Ω) Devices mounted Solderability - Wetting J-STD-002 Electrical Test not required Magnification 50X Well tinned (≥95% covered) SMD conditions: No visible damage Immerse the specimen into the solder pot at 245± 3°C for 2± 0.5 seconds. Board Flex IEC 60115-1 4.33 Chips mounted on a 90mm glass epoxy resin PCB (FR4) Bending for 0402: 5mm 0603 & 0805: 3mm 1206 and above: 2mm ± (1.0%+0.05 Ω) Holding time: minimum 60 seconds www.yageo.com Jul. 22, 2019 V.8 Product specification Chip Resistor Surface Mount SR SERIES 0402/0603/0805/1206/1210/1218/2010/2512 8 8 REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 8 Jul. 22, 2019 - - Update power rating - Extend resistance range of 0402 ~ 2512 to 1Mohm, Version 7 Sep. 27, 2018 - - Tighten TCR of all sizes for 10Ω < R ≤ 1MΩ from ± 200 ppm/°C to ± 100 ppm/°C - Add SR1210, SR1218, SR2010 7W (double power) Version 6 Oct. 02, 2017 - - Add SR0402 7T (triple power), SR0805 47 (quadruple power), SR2512 7W (double power) Version 5 Nov.11, 2016 - - Update 7T power for 1206 Version 4 Sep. 01, 2015 - Version 3 Jul. 31, 2015 - Version 2 Jan. 06, 2014 - Version 1 Mar 18, 2011 - - Update SR0603 Dielectric Withstanding Voltage to 150V - Update 7T power for 0603/0805 & 7W for 1210 - Comply with AEC-Q200 standard - Add SR0402/0603/1210 - Update electrical characteristic - Change to dual brand datasheet that describes SR0805 to SR2512 with RoHS compliant - Define global part number Version 0 Oct 19, 2004 - - “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products are unchanged. Any product change will be announced by PCN.” "The reimbursement is limited to the value of the products." www.yageo.com Jul. 22, 2019 V.8
SR2010KK-0768RL
1. 物料型号:文档列出了多种尺寸的贴片电阻,如0402、0603、0805、1206、1210、1218、2010和2512。
2. 器件简介:这些电阻采用无铅端子,通过厚膜工艺制造,符合RoHS标准,无卤素。
3. 引脚分配:文档中没有明确提到引脚分配,但通常贴片电阻为两个端子。
4. 参数特性: - 公差等级:±5%、±10%、±20%。 - 包装类型:纸带卷装、压花带卷装。 - 温度系数:基于规格书。 - 电阻值范围:1 Ω至1M Ω。
5. 功能详解: - 符合AEC-Q200标准。 - 具有优越的脉冲电压和浪涌电压承受能力。
6. 应用信息:适用于通信、电源、汽车电子等领域。
7. 封装信息:提供了不同尺寸的详细物理尺寸和电气特性。
8. 订购信息:提供了全球零件编号的编码规则和示例。
9. 标记规则:说明了电阻值的标记方式。
10. 结构:描述了电阻的构造,包括陶瓷基板、内部金属电极、电阻性釉料和保护层。
11. 电气特性:列出了不同尺寸电阻的功率、电阻范围和特性。
12. 测试和要求:包括温度系数、短时间过载、高温暴露、湿度、寿命、耐焊接热、焊锡性和板弯曲等测试条件和要求。
SR2010KK-0768RL 价格&库存
很抱歉,暂时无法提供与“SR2010KK-0768RL”相匹配的价格&库存,您可以联系我们找货
SR2010KK-0768RL
  • 4000+0.735164000+0.09491
