XL336-5.0 SOP-8/XT336-5.0 TO-92
FEATURES
DESCRIPTION
The XL336-5.0 and XT336-5.0 integrated
circuits are precision 5.0V shunt regulator diodes.
These monolithic IC voltage references operate as a
low temperature coefficient 5.0V zener with 0.6Ω
dynamic impedance. A third terminal on the XL3365.0 allows the reference voltage and temperature
coefficient to be trimmed easily.
1
2
Adjustable 4V to 6V
Low Temperature Coefficient
Wide Operating Current of 600 μA to 10 mA
0.6Ω Dynamic Impedance
± 1% Initial Tolerance Available
Specified Temperature Stability
Easily Trimmed for Minimum Temperature Drift
Fast Turn-on
Three Lead Transistor Package
The XL336-5.0 series is useful as a precision 5.0V
low voltage reference for digital voltmeters, power
supplies or op amp circuitry. The 5.0V makes it
convenient to obtain a stable reference from low
voltage supplies. Further, since the XL336-5.0
operates as a shunt regulator, it can be used as
either a positive or negative voltage reference.
The XL336-5.0 is rated for operation over −55°C to
+125°C while the XT336-5.0 is rated over a −25°C to
+85°C temperature range. The XT336-5.0 is rated for
operation over a 0°C to +70°C temperature range.
See the Connection Diagrams for available packages.
For applications requiring 2.5V see XL336-5.0.
Connection Diagrams
Figure 1. TO-92 Plastic Package
(Bottom View)
Figure 2. SOIC Package
1
XL336-5.0 SOP-8 XT336-5.0 TO-92
Typical Applications
XL336-5.0
Figure 4. 5.0V Reference
XL336-5.0
XT336-5.0
† Adjust to 5.00V
* Any silicon signal diode
Figure 5. 5.0V Reference with Minimum
XT336-5.0
* Does not affect temperature coefficient
Figure 6. Trimmed 4V to 6V Reference
with Temperature Coefficient
Independent of Breakdown Voltage
2
ABSOLUTE MAXIMUM RATINGS
(1)
Reverse Current
15
mA
Forward Current
10
mA
−60 to +150
°C
−55 to +150
°C
−25 to +85
°C
0 to +70
°C
TO-92 Package (10 sec.)
260
°C
TO Package (10 sec.)
300
°C
Vapor Phase (60 sec.)
215
°C
Infrared (15 sec.)
220
°C
Storage Temperature
Operating Temperature Range
(2)
XL336-5.0 / XT336-5.0
Soldering Information
SOIC Package
(1)
(2)
Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Electrical specifications do not apply when
operating the device beyond its specified operating conditions.
For elevated temperature operation, Tj max see THERMAL CHARACTERISTICS
over operating free-air temperature range (unless otherwise noted)
150°C
125°C
100°C
Thermal Resistance
θja (Junction to Ambient)
TO-92
180°C/W (0.4″ Leads)
TO
SOIC-8
440°C/W
165°C/W
80°C/W
N/A
170°C/W (0.125″ Leads)
θja (Junction to Case)
N/A
ELECTRICAL CHARACTERISTICS
Parameter
Reverse Breakdown
Voltage
XL336-5.0
Conditions
Min
Typ
4.9
5.00
4.95
5.00
6
0.6
XT336-5.0
Max
Units
Min
Typ
Max
5.1
4.8
5.00
5.2
5.05
4.90
5.00
5.1
V
12
6
mV
1.2
0.6
2
Ω
4
12
mV
TA=25°C, IR=1 mA
Reverse Breakdown
Change
TA=25°C,
With Current
600 μA≤IR≤10 mA
Reverse Dynamic
Impedance
TA=25°C, IR=1 mA, f = 100 Hz
V
Temperature Stability VR Adjusted 5.00V
(2)
IR=1 mA, (Figure 15)
0°C≤TA≤70°C XL336-5.0)
(1)
(2)
Unless otherwise specified, the XL336-5.0 is specified from −55°C≤TA≤+125°C, the XT336-5.0 from −25°C≤TA≤+85°C and the XL3365.0 from 0°C≤TA≤+70°C.
Temperature stability for the XL336 and XT336 family is specified by design. Design limits are specified (but not 100% percent
production tested) over the indicated temperature and supply voltage ranges. These limits are not used to calculate outgoing quality
levels. Stability is defined as the maximum charge in VREF from 25°C to TA(min) or TA(max).
3
ELECTRICAL CHARACTERISTICS (continued)
(1)
Parameter
Min
Reverse Breakdown
Change
XT336-5.0
XL336-5.0
Conditions
Min
Typ
Units
Typ
Max
Max
−25°C≤TA≤+85°C (XL336-5.0)
7
18
mV
−55°C≤TA≤+125°C (XT336-5.0)
mV
600 μA≤IR≤10 mA
6
17
6
1.6
0.8
24
mV
2.5
Ω
With Current
Adjustment Range
Circuit of Figure 14
±1
Reverse Dynamic
Impedance
IR = 1 mA
0.8
Long Term Stability
TA=25°C±0.1°C, IR=1 mA, t = 1000 hrs
±1
V
ppm
TYPICAL PERFORMANCE CHARACTERISTICS
Reverse Voltage Change
Zener Noise Voltage
Figure 7.
Figure 8.
Dynamic Impedance
Response Time
Figure 9.
Figure 10.
Reverse Characteristics
Temperature Drift
Figure 11.
Figure 12.
5
TYPICAL PERFORMANCE CHARACTERISTICS (continued)
Forward Characteristics
Figure 13.
6
APPLICATION HINTS
The XL336-5.0 series voltage references are much easier to use than ordinary zener diodes. Their low
impedance and wide operating current range simplify biasing in almost any circuit. Further, either the breakdown
voltage or the temperature coefficient can be adjusted to optimize circuit performance.
Figure 14 shows an XL336-5.0 with a 10k potentiometer for adjusting the reverse breakdown voltage. With the
addition of R1 the breakdown voltage can be adjusted without affecting the temperature coefficient of the device.
The adjustment range is usually sufficient to adjust for both the initial device tolerance and inaccuracies in buffer
circuitry.
If minimum temperature coefficient is desired, four diodes can be added in series with the adjustment
potentiometer as shown in Figure 15. When the device is adjusted to 5.00V the temperature coefficient is
minimized. Almost any silicon signal diode can be used for this purpose such as a 1N914, 1N4148 or a 1N457.
For proper temperature compensation the diodes should be in the same thermal environment as the XL336-5.0.
It is usually sufficient to mount the diodes near the XL336-5.0 on the printed circuit board. The absolute
resistance of the network is not critical and any value from 2k to 20k will work. Because of the wide adjustment
range, fixed resistors should be connected in series with the pot to make pot setting less critical.
XL336-5.0
XT336-5.0
Figure 14. XL336-5.0 with Pot for Adjustment of
Breakdown Voltage (Trim Range = ±1.0V Typical)
Figure 15. Temperature Coefficient Adjustment
(Trim Range = ±0.5V Typical)
336-5.0
* Adjust for 6.25V across R1
Figure 16. Precision Power Regulator with Low Temperature Coefficient
7
XL336-5.0
Figure 17. 5V Crowbar
Figure 18. Adjustable Shunt Regulator
336-5.0
336-5.0
336-5.0
Figure 19. Linear Ohmmeter
Figure 20. Op Amp with Output Clamped
336-5.0
336-5.0
Figure 21. Bipolar Output Reference
Figure 22. 5.0V Square Wave Calibrator
8
336-5.0
336-5.0
Figure 23. 10V Buffered Reference
Figure 24. Low Noise Buffered Reference
336-5.0
Figure 25. Wide Input Range Reference
Schematic Diagram
9
910
911
912
很抱歉,暂时无法提供与“XT336-5.0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.81832
- 50+0.65114
- 150+0.56754
