XL386 SOP8/XD386-1 DIP8/XL386-MS MSOP-8
1 Features
3 Description
The 386 are power amplifiers
designed for use in low voltage consumer
applications. The gain is internally set to 20 to keep
external part count low, but the addition of an external
resistor and capacitor between pins 1 and 8 will
increase the gain to any value from 20 to 200.
1
Battery Operation
Minimum External Parts
Wide Supply Voltage Range: 4 V–12 V or
5 V–18 V
Low Quiescent Current Drain: 4 mA
Voltage Gains from 20 to 200
Ground-Referenced Input
Self-Centering Output Quiescent Voltage
Low Distortion: 0.2% (AV = 20, VS = 6 V, RL = 8 Ω,
PO = 125 mW, f = 1 kHz)
Available in 8-Pin MSOP Package
The inputs are ground referenced while the output
automatically biases to one-half the supply voltage.
The quiescent power drain is only 24 mW when
operating from a 6-V supply, making the 386 ideal
for battery operation.
2 Applications
AM-FM Radio Amplifiers
Portable Tape Player Amplifiers
Intercoms
TV Sound Systems
Line Drivers
Ultrasonic Drivers
Small Servo Drivers
Power Converters
4 Schematic
6
VS
15 k
7
BYPASS
15 k
GAIN
8
GAIN
1
15 k
5
VOUT
150
2
1.35 k
3
- INPUT
+ INPUT
50 k
50 k
4
GND
1
1
5 Pin Configuration and Functions
D Package
8-Pin MSOP
Top View
GAIN
- INPUT
+ INPUT
GND
1
8
2
7
3
6
4
5
GAIN
BYPASS
VS
VOUT
Pin Functions
PIN
TYPE
DESCRIPTION
NAME
NO.
GAIN
1
Gain setting pin
–INPUT
2
I
Inverting input
+INPUT
3
I
Noninverting input
GND
4
P
Ground reference
VOUT
5
O
Output
VS
6
P
Power supply voltage
BYPASS
7
O
Bypass decoupling path
GAIN
8
Gain setting pin
6 Specifications
6.1 Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted) (1)
MIN
Supply Voltage, VCC
XD386-1.XL386
15
22
XD386
Package Dissipation
MAX
UNIT
V
1.25
XL386
0.73
XL386-MS
0.595
W
Input Voltage, VI
–0.4
0.4
V
Storage temperature, Tstg
–65
150
°C
(1)
Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings
only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended
Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
6.2 ESD Ratings
VALUE
V(ESD)
Electrostatic discharge
Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001 (1)
±1000
Charged-device model (CDM), per JEDEC specification JESD22C101 (2)
±1000
2
UNIT
V
6.3 Recommended Operating Conditions
MIN
NOM
MAX
UNIT
Supply Voltage
4
12
386
5
18
Speaker Impedance
4
VI
Analog input voltage
–0.4
0.4
V
TA
Operating free-air temperature
°C
VCC
V
V
Ω
6.4 Thermal Information
XL386
THERMAL METRIC (1)
XL386
XD386
D (MSOP)
DGK (SOP)
P (DIP)
8
8
8
UNIT
RθJA
Junction-to-ambient thermal resistance
115.7
169.3
53.4
°C/W
RθJC(top)
Junction-to-case (top) thermal resistance
59.7
73.1
42.1
°C/W
RθJB
Junction-to-board thermal resistance
56.2
100.2
30.6
°C/W
ψJT
Junction-to-top characterization parameter
12.4
9.2
19.0
°C/W
ψJB
Junction-to-board characterization parameter
55.6
99.1
50.5
°C/W
6.5 Electrical Characteristics
PARAMETER
VS
Operating Supply Voltage
IQ
Quiescent Current
TEST CONDITIONS
Output Power
TYP
MAX
4
12
XD386
5
18
VS = 6 V, VIN = 0
4
VS = 6 V, RL = 8 Ω, THD = 10%
XD386 XL386 XL386-MS
POUT
MIN
250
325
VS = 9 V, RL = 8 Ω, THD = 10%
500
700
VS = 16 V, RL = 32 Ω, THD = 10%
700
100
VS = 6 V, f = 1 kHz
26
10 µF from Pin 1 to 8
46
AV
Voltage Gain
BW
Bandwidth
VS = 6 V, Pins 1 and 8 Open
THD
Total Harmonic Distortion
VS = 6 V, RL = 8 Ω, POUT = 125 mW
f = 1 kHz, Pins 1 and 8 Open
PSRR
Power Supply Rejection Ratio
VS = 6 V, f = 1 kHz, CBYPASS = 10 μF
Pins 1 and 8 Open, Referred to Output
RIN
Input Resistance
IBIAS
Input Bias Current
VS = 6 V, Pins 2 and 3 Open
3
300
8
UNIT
V
mA
mW
dB
kHz
0.2%
50
dB
50
kΩ
250
nA
6.6 Typical Characteristics
Supply Current vs Supply Voltage
Power Supply Rejection vs Frequency
Output Voltage vs Supply Voltage
Voltage Gain vs Frequency
Total Harmonic Distortion vs Frequency
Total Harmonic Distortion vs Power Out
4
Typical Characteristics (continued)
Device Dissipation vs Output Power
5
7 Detailed Description
7.1 Overview
The 386 is a mono low voltage amplifier that can be used in a variety of applications. It can drive loads from 4
Ω to 32 Ω. The gain is internally set to 20 but it can be modified from 20 to 200 by placing a resistor and
capacitor between pins 1 and 8. This device comes in three different 8-pin packages as PDIP, SOIC and VSSOP
to fit in different applications.
7.2 Functional Block Diagram
Gain
Circuitry
Bias
Circuitry
Bypass
7.3 Feature Description
There is an internal 1.35-KΩ resistor that sets the gain of this device to 20. The gain can be modified from 20 to
200. Detailed information about gain setting can be found in the Detailed Design Procedure section.
7.4 Device Functional Modes
As this is an Op Amp it can be used in different configurations to fit in several applications. The internal gain
setting resistor allows the 386 to be used in a very low part count system. In addition a series resistor can be
placed between pins 1 and 5 to modify the gain and frequency response for specific applications.
6
8 Application and Implementation
8.1 Application Information
Below are shown different setups that show how the 386 can be implemented in a variety of applications.
8.2 Typical Application
8.2.1 386 with Gain = 20
Figure 10 shows the minimum part count application that can be implemented using 386. Its gain is internally
set to 20.
2
6
1
250 µF
8
386
VIN
3
10 k
5
7
0.05 µF
4
10
386 with Gain = 20
8.2.1.1 Design Requirements
Table 1. Design Parameters
DESIGN PARAMETER
EXAMPLE VALUE
Load Impedance
4 Ω to 32 Ω
Supply Voltage
5 V to 12 V
8.2.1.2 Detailed Design Procedure
8.2.1.2.1 Gain Control
To make the 386 a more versatile amplifier, two pins (1 and 8) are provided for gain control. With pins 1 and 8
open the 1.35-kΩ resistor sets the gain at 20 (26 dB). If a capacitor is put from pin 1 to 8, bypassing the 1.35-kΩ
resistor, the gain will go up to 200 (46 dB). If a resistor is placed in series with the capacitor, the gain can be set
to any value from 20 to 200. Gain control can also be done by capacitively coupling a resistor (or FET) from pin 1
to ground.
Additional external components can be placed in parallel with the internal feedback resistors to tailor the gain and
frequency response for individual applications. For example, we can compensate poor speaker bass response by
frequency shaping the feedback path. This is done with a series RC from pin 1 to 5 (paralleling the internal
15-kΩ resistor). For 6 dB effective bass boost: R ~= 15 kΩ, the lowest value for good stable operation is R = 10
kΩ if pin 8 is open. If pins 1 and 8 are bypassed then R as low as 2 kΩ can be used. This restriction is because
the amplifier is only compensated for closed-loop gains greater than 9.
7
8.2.1.2.2 Input Biasing
The schematic shows that both inputs are biased to ground with a 50 kΩ resistor. The base current of the input
transistors is about 250 nA, so the inputs are at about 12.5 mV when left open. If the dc source resistance driving
the 386 is higher than 250 kΩ it will contribute very little additional offset (about 2.5 mV at the input, 50 mV at
the output). If the dc source resistance is less than 10 kΩ, then shorting the unused input to ground will keep the
offset low (about 2.5 mV at the input, 50 mV at the output). For dc source resistances between these values we
can eliminate excess offset by putting a resistor from the unused input to ground, equal in value to the dc source
resistance. Of course all offset problems are eliminated if the input is capacitively coupled.
When using the 386 with higher gains (bypassing the 1.35 kΩ resistor between pins 1 and 8) it is necessary
to bypass the unused input, preventing degradation of gain and possible instabilities. This is done with a 0.1 μF
capacitor or a short to ground depending on the dc source resistance on the driven input.
8.2.1.3 Application Curve
8
DIP
89
SOP
10
8
MSOP-8
811
很抱歉,暂时无法提供与“XL386-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.83160
- 50+0.65308
- 150+0.56387
- 500+0.49691
