XL2982SL
XL2982SL
    XINLUDA(信路达)
    SOP-18
    集射极饱和压降(VCE(sat)@Ii,Ic):1.8V 输出漏电流(Icex@Vce):20uA 开态输入电流(Ii@Vi):1.25mA@12V 嵌位二极管漏电流(IR@VR):50uA@50V ...
XL2982SL 数据手册
XL2982SL SOP20 Features and Benefits Simplified Block Diagram ▪ TTL, DTL, PMOS, or CMOS compatible inputs ▪ 500 mA output source current capability ▪ Transient-protected outputs ▪ Output breakdown voltage to 50 V Description Recommended for high-side switching applications that benefit from separate logic and load grounds, these devices encompass load supply voltages to 50 V and output currents to -500 mA. These 8-channel source drivers are useful for interfacing between low-level logic and high-current loads. Typical loads include relays, solenoids, lamps, stepper and/or servo motors, print hammers, and LEDs. A L L OWA B L E P A C K A G E P OW E R DIS S IP A T ION (W) All devices may be used with 5 V logic systems — TTL, Schottky TTL, DTL, and 5 V CMOS. The device packages offered are electrically interchangeable, and will withstand a maximum output off voltage of 50 V, and operate to a minimum of 5 V. All devices in this series integrate input current limiting resistors and output transient suppression diodes, and are activated by an active high input. The package is a 20-pin wide-body SOIC with improved thermal characteristics compared to the 18-pin SOIC version it replaces (100% pin-compatible electrically). The package is lead (Pb) free, with 100% matte-tin leadframe plating. 2.5 2.0 20-LE AD S OIC , R JA = 90 C /W 1.5 1.0 0.5 0 25 50 75 100 125 150 Absolute Maximum Ratings Rating Units Output Voltage Range Characteristic VCE 5 to 50 V Input Voltage VIN 20 V Output Current IOUT –500 mA Package Power Dissipation PD See graph – – Operating Ambient Temperature TA Range S –20 to 85 ºC Maximum Junction Temperature TJ(max) 150 ºC Tstg –55 to 150 ºC Storage Temperature Symbol Notes 1 XL2982SL SOP20 One of Eight Drivers Typical electrosensitive printer application R IN1 1 20 IN2 2 19 IN3 3 18 IN4 4 17 IN5 5 16 IN6 6 15 IN7 7 14 IN 8 8 13 VS 9 12 NC 10 11 R R R R R R R L L L L L L L L NC Pins 10 and 11 can float; other pins match discontinued 18-pin SOIC: 1 to 9 same, pins 12 to 20 match pins 10 to 18 2 XL2982SL SOP20 ELECTRICAL CHARACTERISTICS1,2 at TA = +25°C (unless otherwise specified). Characteristic Symbol Test Fig. Min. Typ. Max. Units VIN = 0.4 V, VS = 50 V 1 — — 20 μA IOUT = -45 mA — 35 — — V VIN = 2.4 V, IOUT = -100 mA 2 — 1.6 1.8 V VIN = 2.4 V, IOUT = -225 mA 2 — 1.7 1.9 V VIN = 2.4 V, IOUT = -350 mA 2 — 1.8 2.0 V VIN = 2.4 V 3 — 140 200 μA VIN = 12 V 3 — 1.25 1.93 mA lOUT VIN = 2.4 V, VCE = 2.0 V 2 -350 — — mA Supply Current Leakage Current IS VIN = 2.4 V*, VS = 50 V 4 — — 10 mA Clamp Diode Current IR VR = 50 V, VIN = 0.4 V* 5 — — 50 μA Clamp Diode Forward Voltage VF IF = 350 mA 6 — 1.5 2.0 V Turn-On Delay tON 0.5 EIN to 0.5 EOUT, RL = 100Ω, VS = 35 V — — 0.3 2.0 μs Turn-Off Delay4 tOFF 0.5 EIN to 0.5 EOUT, RL = 100Ω, VS = 35 V, See Note — — 2.0 10 μs Output Leakage Current3 ICEX Output Sustaining Voltage VCE(SUS) Collector-Emitter Saturation Voltage Input Current Output Source Current (Outputs Open) 1Negative VCE(SAT) IIN(ON) Test Conditions current is defined as coming out of (sourcing) the specified device terminal. 2All unused inputs must be connected to ground. Pull-down resistors (approximately 10 kΩ) are recommended for inputs that are allowed to float while power is being applied to VS. 3All inputs simultaneously. 4Turn-off delay is influenced by load conditions. Systems applications well below the specified output loading may require timing considerations for some designs, i.e., multiplexed displays or when used in combination with sink drivers in a totem pole configuration. 3 XL2982SL SOP20 TEST FIGURES Figure 1 Figure 2 VS VS V Figure 3 V V CE I IN mA V mA OPEN I OUT VIN μA IN S V IN I CEX Figure 4 Figure 5 VS VS I S mA OPEN μA OPEN VIN Figure 6 IR OPEN VF VIN 4 V I F XL2982SL SOP20 500 500 450 450 RECOMMENDED MAXIMUM OUTPUT CURRENT 350 3 300 4 5 250 200 NUMBER OF OUTPUTS CONDUCTING SIMULTANEOUSLY 8 7 6 150 100 400 ALLOWABLE PEAK COLLECTOR CURRENT IN mA AT 70°C 400 VS = 15 V RECOMMENDED MAXIMUM OUTPUT CURRENT 350 300 3 4 250 5 200 8 7 6 NUMBER OF OUTPUTS CONDUCTING SIMULTANEOUSLY 150 100 VS = 15 V 50 0 50 0 10 20 30 50 60 40 PER CENT DUTY CYCLE 70 80 90 0 100 10 0 20 30 Input current as a function of input voltage 2.5 2.0 INPUT CURRENT, IIN (mA) ALLOWABLE PEAK COLLECTOR CURRENT IN mA AT 50°C Allowable peak collector current as a function of duty cycle 1.5 UM IM X MA 1.0 AL PIC TY 0.5 2 4 6 8 INPUT VOLTAGE (VOLTS) 5 10 12 50 60 40 PER CENT DUTY CYCLE 70 80 90 100 XL2982SL SOP20 65 6
XL2982SL 价格&库存
很抱歉,暂时无法提供与“XL2982SL”相匹配的价格&库存,您可以联系我们找货
