XD2981 DIP18 / XL2981 SOP18
Features and Benefits
Description
▪ TTL, DTL, PMOS, or CMOS compatible inputs
▪ 500 mA output source current capability
▪ Transient-protected outputs
▪ Output breakdown voltage to 50 V
▪ DIP or SOIC packaging
Recommended for high-side switching applications that benefit
from separate logic and load grounds, these devices encompass
load supply voltages to 50 V and output currents to -500 mA.
These 8-channel source drivers are useful for interfacing
between low-level logic and high-current loads. Typical loads
include relays, solenoids, lamps, stepper and/or servo motors,
print hammers, and LEDs.
All devices may be used with 5 V logic systems — TTL, Schottky
TTL, DTL, and 5 V CMOS. The device packages offered are
electrically interchangeable, and will withstand a maximum
output off voltage of 50 V, and operate to a minimum of 5 V. All
devices in this series integrate input current limiting resistors
and output transient suppression diodes, and are activated by
an active high input.
Simplified Block Diagrams
DIP18 and SOP18
The suffix “A” indicates an 18-lead plastic dual in-line package
with copper lead frame for optimum power dissipation. Under
normal operating conditions, these devices will sustain 120 mA
continuously for each of the eight outputs at an ambient
temperature of +50°C and a supply of 15 V.
Absolute Maximum Ratings
Characteristic
Symbol
Notes
Rating
Units
5 to 50
V
2981
V
XL2982SL,2981
V
–500
mA
Range E
–40 to 85
ºC
Range S
–20 to 85
ºC
Output Voltage Range
VCE
Input Voltage
VIN
Output Current
IOUT
Package Power Dissipation
PD
Operating Ambient Temperature
TA
Maximum Junction Temperature
TJ(max)
150
ºC
Tstg
–55 to 150
ºC
Storage Temperature
See graph
1
A L L OWA B L E P A C K A G E P OW E R DIS S IP A T ION (W)
2.5
2.0
18-P IN DIP , R
JA
= 65 C /W
20-LE AD S OIC , R
JA
= 90 C /W
1.5
1.0
0.5
50
75
100
A MB IE NT T E MP E R A T UR E C
125
One of Eight Drivers
Typical electrosensitive
printer application
2
150
2981 DIP18/SOP18
R
IN1
1
18
IN2
2
17
IN3
3
16
IN4
4
15
IN5
5
14
IN6
6
13
IN7
7
12
IN8
8
11
VS
9
10
R
R
R
R
R
R
R
L
L
L
L
L
L
L
L
2982 SOP20 (LW Package)
R
IN1
1
IN2
2
19
IN3
3
18
IN4
4
17
IN5
5
16
IN6
6
15
IN7
7
14
IN8
8
13
VS
9
12
NC
10
11
R
R
R
R
R
R
R
L
L
L
L
L
L
L
L
NC
Pins 10 and 11 can float; other pins
match discontinued 18-pin SOIC: 1 to 9
same, pins 12 to 20 match pins 10 to 18
3
ELECTRICAL CHARACTERISTICS1,2 at TA = +25°C (unless otherwise specified).
Symbol
Variant
Test Fig.
Min.
Typ.
Max.
Units
Output Leakage Current3
Characteristic
ICEX
All
VIN = 0.4 V, VS = 50 V
1
μA
Output Sustaining Voltage
VCE(SUS)
All
IOUT = -45 mA
35
V
VIN = 2.4 V, IOUT = -100 mA
2
1.6
1.8
V
VIN = 2.4 V, IOUT = -225 mA
2
1.7
1.9
V
VIN = 2.4 V, IOUT = -350 mA
2
1.8
2.0
V
VIN = 2.4 V
3
140
200
μA
VIN = 3.85 V
3
310
450
μA
VIN = 2.4 V
3
140
200
μA
VIN = 12 V
3
1.25
1.93
mA
2981
VIN = 2.4 V, VCE = 2.0 V
2
-350
mA
2982
2
-350
mA
Collector-Emitter
Saturation Voltage
VCE(SAT)
All
2981
Input Current
IIN(ON)
2982
Output Source Current
(Outputs Open)
lOUT
Test Conditions
Supply Current Leakage
Current
IS
All
VIN = 2.4 V*, VS = 50 V
4
10
mA
Clamp Diode Current
IR
All
VR = 50 V, VIN = 0.4 V*
5
50
μA
Clamp Diode Forward
Voltage
VF
All
IF = 350 mA
6
1.5
2.0
V
Turn-On Delay
tON
All
0.5 EIN to 0.5 EOUT, RL = 100Ω, VS = 35 V
0.3
2.0
μs
All
0.5 EIN to 0.5 EOUT, RL = 100Ω, VS = 35 V,
See Note
2.0
10
μs
Turn-Off Delay4
1Negative
tOFF
current is defined as coming out of (sourcing) the specified device terminal.
2All
unused inputs must be connected to ground. Pull-down resistors (approximately 10 kΩ) are recommended for inputs that are allowed to float while power is being applied to VS.
3All
inputs simultaneously.
4Turn-off
delay is influenced by load conditions. Systems applications well below the specified output loading may require timing considerations for some designs, i.e., multiplexed displays or when used in combination with sink drivers in a totem pole configuration.
4
TEST FIGURES
Figure 1
Figure 2
VS
VS
V
Figure 3
V
V CE
I IN
mA
V
mA
OPEN
I OUT
VIN
μA
IN
S
V
IN
I CEX
Figure 4
Figure 5
VS
VS
I S mA
OPEN
μA
OPEN
VIN
Figure 6
IR
OPEN
VF
VIN
5
V
I
F
Allowable peak collector current
as a function of duty cycle
500
500
450
450
RECOMMENDED MAXIMUM OUTPUT CURRENT
350
3
300
4
5
250
200
NUMBER OF OUTPUTS
CONDUCTING
SIMULTANEOUSLY
8
7
6
150
100
400
ALLOWABLE PEAK COLLECTOR CURRENT IN mA AT 70°C
400
VS = 15 V
350
300
3
4
250
5
200
8
7
6
NUMBER OF OUTPUTS
CONDUCTING
SIMULTANEOUSLY
150
100
VS = 15 V
50
50
60
40
PER CENT DUTY CYCLE
70
80
90
10
Input current as a function
of input voltage
2.5
2.0
INPUT CURRENT, IIN (mA)
ALLOWABLE PEAK COLLECTOR CURRENT IN mA AT 50°C
XDXL/2981 and XL2982SL
1.5
UM
IM
X
MA
1.0
AL
PIC
TY
0.5
2
4
6
8
INPUT VOLTAGE (VOLTS)
6
10
12
50
60
40
PER CENT DUTY CYCLE
70
80
90
100
67
很抱歉,暂时无法提供与“XL2981”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.74000
- 100+2.99200
- 1000+2.86000
- 国内价格
- 1+5.67000
- 10+4.60080
- 30+4.06080
- 100+3.53160
- 500+3.15360
- 1000+2.98080
