XL555
XL555
    XINLUDA(信路达)
    SOP-8
    定时器芯片 2V~15V 360uA 2.1MHz
XL555 数据手册
XD555 DIP8 / XL555 SOP8 D Very Low Power Consumption D D D D D D D D D description − 1 mW Typ at VDD = 5 V Capable of Operation in Astable Mode CMOS Output Capable of Swinging Rail to Rail High Output-Current Capability − Sink 100 mA Typ − Source 10 mA Typ Output Fully Compatible With CMOS, TTL, and MOS Low Supply Current Reduces Spikes During Output Transitions Single-Supply Operation From 2 V to 15 V Functionally Interchangeable With the 555NE; Has Same Pinout ESD Protection Exceeds 2000 V Per MIL-STD-883C, Method 3015.2 Available in Q-Temp Automotive High Reliability Automotive Applications Configuration Control/Print Support Qualification to Automotive Standards The XD/XL555 is a monolithic timing circuit fabricated using the TI LinCMOS process. The timer is fully compatible with CMOS, TTL, and MOS logic and operates at frequencies up to 2 MHz. Because of its high input impedance, this device uses smaller timing capacitors than those used by the 555NE. As a result, more accurate time delays and oscillations are possible. Power consumption is low across the full range of power supply voltage. D, DB, JG, OR P PACKAGE (TOP VIEW) GND TRIG OUT RESET 1 8 2 7 3 6 4 5 VDD DISCH THRES CONT Like the 555NE, the XD/XL555 has a trigger level equal to approximately one-third of the supply voltage and a threshold level equal to approximately two-thirds of the supply voltage. These levels can be altered by use of the control voltage terminal (CONT). When the trigger input (TRIG) falls below the trigger level, the flip-flop is set and the output goes high. If TRIG is above the trigger level and the threshold input (THRES) is above the threshold level, the flip-flop is reset and the output is low. The reset input (RESET) can override all other inputs and can be used to initiate a new timing cycle. If RESET is low, the flip-flop is reset and the output is low. Whenever the output is low, a low-impedance path is provided between the discharge terminal (DISCH) and GND. All unused inputs should be tied to an appropriate logic level to prevent false triggering. While the CMOS output is capable of sinking over 100 mA and sourcing over 10 mA, the XD/XL555 exhibits greatly reduced supply-current spikes during output transitions. This minimizes the need for the large decoupling capacitors required by the 555NE. 1 XD555 DIP8 / XL555 SOP8 description (continued) The XD/XL555 is characterized for operation from 0 °C to 70°C. The XD/XL555 is characterized for operation from −40°C to 85°C. The XD/XL555 is characterized for operation over the automotive temperature range of −40°C to 125°C. The XD/XL555 is characterized for operation over the full military temperature range of −55°C to 125°C. AVAILABLE OPTIONS† PACKAGED DEVICES TA VDD RANGE 0°C to 70°C 2 V to 15 V −40°C to 85°C 3 V to 15 V −40°C to 125°C 5 V to 15 V −55°C to 125°C 5 V to 15 V SMALL OUTLINE (D)‡ SSOP (DB)‡ CHIP CARRIER (FK) CERAMIC DIP (JG) PLASTIC DIP (P) TSSOP (PW)‡ — — — XD555 — — — — XD555 — — — — — — — — — XD555 — XL555 FUNCTION TABLE RESET VOLTAGE‡ TRIGGER VOLTAGE‡ THRESHOLD VOLTAGE‡ OUTPUT DISCHARGE SWITCH On MAX MAX >MAX >MAX L On >MAX >MAX
XL555
1. 物料型号:XD555 DIP8 和 XL555 SOP8 是超低功耗的单片定时电路,兼容CMOS、TTL和MOS逻辑,工作频率高达2MHz。
2. 器件简介:XD/XL555以其高输入阻抗,可以使用比555NE更小的定时电容,实现更精确的时间延迟和振荡。整个电源电压范围内功耗低,具有可摆动至轨的CMOS输出,并且具有高达100mA的典型下拉电流和10mA的典型上拉电流。
3. 引脚分配:8脚为VDD,6脚为THRES(阈值),5脚为CONT(控制),3脚为OUT(输出),2脚为TRIG(触发),7脚为DISCH(放电),4脚为GND。
4. 参数特性:具有超低功耗(在5V供电时典型值为1mW),可单电源操作(2V至15V),并且具有ESD保护超过2000V。具有温度特性,适用于汽车标准,有多种封装选项。
5. 功能详解:XD/XL555具有稳定的触发和阈值电压水平,可以通过控制电压端进行调节。具有复位输入,可以覆盖所有其他输入并启动新的计时周期。
6. 应用信息:提供了应用电路图,包括稳定操作的触发和阈值电压波形图。
7. 封装信息:提供了多种封装选项,包括DIP8、SOP8等,以及它们的工作温度范围和电源电压范围。
XL555 价格&库存
很抱歉,暂时无法提供与“XL555”相匹配的价格&库存,您可以联系我们找货
XL555
    • 5+0.76842
    • 50+0.59907
    • 150+0.51430
    库存:351
