XL2902
XL2902
    XINLUDA(信路达)
    SOP-14
    General Purpose 低功耗四路运算放大器
XL2902 数据手册
XD124/XD224/XD324/XD2902N DIP14 XL124/XL224/XL324/XL2902 SOP14 FEATURES DESCRIPTION • These devices consist of four independent high-gain frequency-compensated operational amplifiers that are designed specifically to operate from a single supply over a wide range of voltages. Operation from split supplies also is possible if the difference between the two supplies is 3 V to 32 V (3 V to 26 V for the XD2902 device), and VCC is at least 1.5 V more positive than the input common-mode voltage. The low supply-current drain is independent of the magnitude of the supply voltage. 1 • • • • • • • • 2-kV ESD Protection for: – XD224, XL224 – XD324, XL324 – XD2902, XL2902 Wide Supply Ranges – Single Supply: 3 V to 32 V (26 V for XD2902) – Dual Supplies: ±1.5 V to ±16 V (±13 V for XL2902) Low Supply-Current Drain Independent of Supply Voltage: 0.8 mA Typ Common-Mode Input Voltage Range Includes Ground, Allowing Direct Sensing Near Ground Low Input Bias and Offset Parameters – Input Offset Voltage: 3 mV Typ MM A Versions: 2 mV Typ – Input Offset Current: 2 nA Typ – Input Bias Curren: 20 nA Typ MMA Versions: 15 nA Typ Differential Input Voltage Range Equal to Maximum-Rated Supply Voltage: 32 V (26 V for XD2902) Open-Loop Differential Voltage Amplification: 100 V/mV Typ Internal Frequency Compensation On Products Compliant to MIL-PRF-38535, All Parameters Are Tested Unless Otherwise Noted. On All Other Products, Production Processing Does Not Necessarily Include Testing of All Parameters. Applications include transducer amplifiers, dc amplification blocks, and all the conventional operational-amplifier circuits that now can be more easily implemented in single-supply-voltage systems. For example, the XD124 device can be operated directly from the standard 5-V supply that is used in digital systems and provides the required interface electronics, without requiring additional ±15-V supplies. XD124/XD224/XD324/XD2902N XL124/XL224/XL324/XL2902 (TOP VIEW) 1OUT 1IN− 1IN+ VCC 2IN+ 2IN− 2OUT 1 1 14 2 13 3 12 4 11 5 10 6 9 7 8 4OUT 4IN− 4IN+ GND 3IN+ 3IN− 3OUT XD124/XD224/XD324/XD2902N DIP14 XL124/XL224/XL324/XL2902 SOP14 Symbol (Each Amplifier) 1IN− 1OUT NC 4OUT 4IN− IN− 3 2 1 20 19 18 5 17 6 16 7 15 8 14 9 10 11 12 13 4IN+ NC GND NC 3IN+ 2IN− 2OUT NC 3OUT 3IN− 4 OUT IN+ + 1IN+ NC VCC NC 2IN+ − XD124/XL124A (TOP VIEW) NC − No internal connection Schematic (Each Amplifier) VCC ≈6-µA Current Regulator ≈6-µA Current Regulator ≈100-µA Current Regulator OUT IN− † ≈50-µA Current Regulator IN+ † GND To Other Amplifiers COMPONENT COUNT (total device) Epi-FET Transistors Diodes Resistors Capacitors † XD324 and only only ESD protection cells - available on LM324K andXL324 LM324KA 2 1 95 4 11 4 XD124/XD224/XD324/XD2902N DIP14 XL124/XL224/XL324/XL2902 SOP14 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) Supply voltage, VCC (2) Differential input voltage, VID (3) Input voltage, VI (either input) Duration of output short circuit (one amplifier) to ground at (or below) TA = 25°C, VCC ≤ 15 V Package thermal impedance, θJA (4) (5) Package thermal impedance, θJC (6) (7) ±16 or 32 V ±26 ±32 V –0.3 to 26 –0.3 to 32 V Unlimited 86 DB package 96 96 N package 80 80 NS package 76 76 PW package 113 5.61 J package 15.05 W package 14.65 150 J or W package Storage temperature range, Tstg °C/W 113 FK package FK package (7) ±13 or 26 86 Lead temperature 1,6 mm (1/16 inch) from case for 60 seconds (6) UNIT Unlimited Case temperature for 60 seconds (2) (3) (4) (5) ALL OTHER DEVICES D package Operating virtual junction temperature, TJ (1) (4) XD2902 °C/W 150 °C 260 °C 300 300 °C –65 to 150 –65 to 150 °C Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. All voltage values (except differential voltages and VCC specified for the measurement of IOS) are with respect to the network GND. Differential voltages are at IN+, with respect to IN−. Short circuits from outputs to VCC can cause excessive heating and eventual destruction. Maximum power dissipation is a function of TJ(max), θJA, and TA. The maximum allowable power dissipation at any allowable ambient temperature is PD = (TJ(max) – TA)/θJA. Operating at the absolute maximum TJ of 150°C can affect reliability. Maximum power dissipation is a function of TJ(max), θJA, and TC. The maximum allowable power dissipation at any allowable case temperature is PD = (TJ(max) – TC)/θJC. Operating at the absolute maximum TJ of 150°C can affect reliability. The package thermal impedance is calculated in accordance with MIL-STD-883 ESD Protection TEST CONDITIONS Human-Body Model XD224, XL224, XD324, XL324, XD2902, XL2902, 3 TYP ±2 UNIT kV XD124/XD224/XD324/XD2902N DIP14 XL124/XL224/XL324/XL2902 SOP14 Electrical Characteristics at specified free-air temperature, VCC = 5 V (unless otherwise noted) PARAMETER VIO Input offset voltage IIO Input offset current IIB Input bias current TEST CONDITIONS (1) VCC = 5 V to MAX, VIC = VICRmin, VO = 1.4 V TA (2) XD124, XD224 MIN 25°C 2 High-level output voltage VO = 1.4 V RL = 2 kΩ 25°C RL = 10 kΩ 25°C –20 –250 –500 0 to VCC – 2 VCC – 1.5 VCC – 1.5 26 27 Common-mode rejection ratio VIC = VICRmin kSVR Supply-voltage rejection ratio (ΔVCC /ΔVIO) VO1/ VO2 Crosstalk attenuation (2) (3) –150 0 to VCC – 2 Full range CMRR (1) 50 150 0 to VCC – 1.5 RL ≥ 10 kΩ AVD Supply current (four amplifiers) 2 V V VCC = 15 V, VO = 1 V to 11 V, RL ≥ 2 kΩ ICC 30 0 to VCC – 1.5 26 Large-signal differential voltage amplification Short-circuit output current 9 –300 Full range RL ≤ 10 kΩ IOS –20 RL = 2 kΩ Low-level output voltage Output current 7 nA VOL IO 3 100 Full range VCC = 5 V to MAX VCC = MAX MAX nA Full range Full range VOH 5 UNIT TYP (3) mV 25°C Common-mode input voltage range 3 MIN 7 25°C VICR MAX Full range 25°C VO = 1.4 V XD324 XL324 TYP (3) Full range 28 5 27 28 25 100 20 100 5 20 50 Full range 25 25°C 70 80 65 80 dB 25°C 65 100 65 100 dB V/mV 15 f = 1 kHz to 20 kHz 25°C VCC = 15 V, VID = 1 V, VO = 0 25°C –20 Full range –10 25°C 10 Full range 5 VID = –1 V, VO = 200 mV 25°C 12 VCC at 5 V, VO = 0, GND at –5 V 25°C ±40 ±60 ±40 ±60 VO = 2.5 V, No load Full range 0.7 1.2 0.7 1.2 VCC = MAX, VO = 0.5 VCC, No load Full range 1.4 3 1.4 3 VCC = 15 V, VID = –1 V, VO = 15 V mV 25°C 120 –30 120 –60 –20 –30 dB –60 Source –10 mA 20 10 20 Sink 5 30 12 μA 30 mA mA All characteristics are measured under open-loop conditions, with zero common-mode input voltage, unless otherwise specified. MAX VCC for testing purposes is 26 V for XD2902 and 30 V for the others. Full range is –55°C to 125°C for LM124, –25°C to 85°C for LM224, and 0°C to 70°C for XD324. All typical values are at TA = 25°C 4 XD124/XD224/XD324/XD2902N DIP14 XL124/XL224/XL324/XL2902 SOP14 Electrical Characteristics at specified free-air temperature, VCC = 5 V (unless otherwise noted) PARAMETER VIO Input offset voltage ΔVIO/ΔT Input offset voltage temperature drift TEST CONDITIONS (1) VCC = 5 V to MAX, VIC = VICRmin, VO = 1.4 V Non-A-suffix devices TA (2) XD2902 MIN 25°C 3 Full range Input offset current ΔIIO/ΔT Input offset voltage temperature drift Input bias current Common-mode input voltage range RS = 0 Ω VO = 1.4 V 1 4 2 AVD Large-signal differential voltage amplification CMRR Common-mode rejection ratio VIC = VICRmin kSVR Supply-voltage rejection ratio (ΔVCC /ΔVIO) VO1/ VO2 Crosstalk attenuation IO Output current IOS Short-circuit output current ICC Supply current (four amplifiers) (1) (2) (3) 50 2 300 150 –250 –20 pA/°C –250 nA –500 –500 0 to VCC – 1.5 0 to VCC – 1.5 0 to VCC – 2 0 to VCC – 2 V 25°C VCC – 1.5 VCC – 1.5 RL = 2 kΩ Full range 25°C 22 26 RL ≥ 10 kΩ Full range 23 Full range 24 5 V 27 20 100 5 25 20 mV 25°C 25 Full range 15 100 25°C 50 80 60 80 dB 25°C 50 100 60 100 dB V/mV f = 1 kHz to 20 kHz 25°C VCC = 15 V, VID = 1 V, VO = 0 25°C –20 Full range –10 25°C 10 Full range 5 VCC = 15 V, VID = –1 V, VO = 15 V μV/°C 50 10 –20 Full range RL = 10 kΩ VCC = 15 V, VO = 1 V to 11 V, RL ≥ 2 kΩ 2 nA VCC = 5 V to MAX RL ≤ 10 kΩ 7 7 Full range VO = 1.4 V Low-level output voltage UNIT MAX 10 Ful range VCC = MAX VOL 3 Ful range RL = 2 kΩ High-level output voltage TYP (3) Full range Full range VOH 7 25°C 25°C VICR MIN mV A-suffix devices 25°C IIB MAX 10 25°C IIO XL2902 TYP (3) 15 120 –30 120 –60 –20 –30 dB –60 Source –10 mA 20 10 12 20 Sink 5 μA VID = –1 V, VO = 200 mV 25°C 30 VCC at 5 V, VO = 0, GND at –5 V 25°C ±40 ±60 ±40 40 ±60 VO = 2.5 V, No load Full range 0.7 1.2 0.7 1.2 VCC = MAX, VO = 0.5 VCC, No load Full range 1.4 3 1.4 3 mA mA All characteristics are measured under open-loop conditions, with zero common-mode input voltage, unless otherwise specified. MAX VCC for testing purposes is 26 V for XD2902 and 32 V for XL2902. Full range is –40°C to 125°C for XD2902. All typical values are at TA = 25°C. 5 XD124/XD224/XD324/XD2902N DIP14 XL124/XL224/XL324/XL2902 SOP14 Electrical Characteristics at specified free-air temperature, VCC = 5 V (unless otherwise noted) PARAMETER TEST CONDITIONS (1) VIO Input offset voltage VCC = 5 V to 30 V, VIC = VICRmin, VO = 1.4 V IIO Input offset current VO = 1.4 V IIB Input bias current VO = 1.4 V VICR Common-mode input voltage range 3 MIN UNIT TYP (3) MAX 2 3 5 15 2 25°C –50 Full range –100 30 –15 30 75 –80 –15 –100 –100 0 to VCC – 1.5 0 to VCC – 1.5 0 to VCC − 2 0 to VCC – 2 0 to VCC – 2 VCC – 1.5 VCC – 1.5 26 RL≥10kΩ Full range 27 27 Common-mode rejection ratio VIC = VICRmin kSVR Supply-voltage rejection ratio (ΔVCC /ΔVIO) VO1/ VO2 Crosstalk attenuation Full range f = 1 kHz to 20 kHz –200 0 to VCC − 1.5 26 CMRR (1) (2) (3) 2 2 VCC − 1.5 VCC = 15 V, VO = 1 V to 11 V, RL ≥ 2 kΩ Supply current (four amplifiers) 30 25°C Large-signal differential voltage amplification ICC 10 MAX mV Full range AVD Short-circuit output current 25°C Full range XD324, XL324 TYP (3) 4 RL=2kΩ RL ≤ 10 kΩ IOS 4 Full range Low-level output voltage Output current Full range MIN nA VOL IO XD224 MAX 2 VCC = 30 V VCC = 15 V, VID = 1 V, VO = 0 TYP (3) 25°C 25°C VCC = 30 V XD124 MIN nA RL = 2 kΩ High-level output voltage VOH TA (2) 20 100 26 28 5 50 V 27 20 100 V 28 5 25 20 25°C 50 100 Full range 25 25 25°C 70 70 80 65 80 dB 25°C 65 65 100 65 100 dB 120 dB V/mV 25°C 120 15 120 25°C –20 –20 Full range –10 –10 25°C 10 10 Full range 5 5 VID = −1 V, VO = 200 mV 25°C 12 VCC at 5 V, GND at –5 V, VO = 0 25°C ±40 ±60 ±40 ±60 ±40 ±60 VO = 2.5 V, No load Full range 0.7 1.2 0.7 1.2 0.7 1.2 VCC = 30 V, VO = 15 V, No load Full range 1.4 3. 1.4 3 1.4 3 VCC = 15 V, VID = –1 V, VO = 15 V mV –30 –60 –20 –30 –60 Source –10 mA 20 1 20 Sink 12 5 30 12 μA 30 mA mA All characteristics are measured under open-loop conditions, with zero common-mode input voltage, unless otherwise specified. Full range is –55°C to 125°C for XD124A, –25°C to 85°C for XD224, and 0°C to 70°C for XD324. All typical values are at TA = 25°C. 6 XD124/XD224/XD324/XD2902N DIP14 XL124/XL224/XL324/XL2902 SOP14 Operating Conditions VCC = ±15 V, TA = 25°C PARAMETER TEST CONDITIONS TYP UNIT SR Slew rate at unity gain RL = 1 MΩ, CL = 30 pF, VI = ±10 V (see Figure 1) 0.5 V/μs B1 Unity-gain bandwidth RL = 1 MΩ, CL = 20 pF (see Figure 1) 1.2 MHz Vn Equivalent input noise voltage RS = 100 Ω, VI = 0 V, f = 1 kHz (see Figure 2) 35 nV/√Hz 900 Ω VCC+ VCC+ − VI 100 Ω VO + − VI = 0 V RS VCC− CL RL VO + VCC− Figure 1. Unity-Gain Amplifier Figure 2. Noise-Test Circuit 7 XD124/XD224/XD324/XD2902N DIP14 XL124/XL224/XL324/XL2902 SOP14 78 XD124/XD224/XD324/XD2902N DIP14 XL124/XL224/XL324/XL2902 SOP14 79
XL2902 价格&库存
很抱歉,暂时无法提供与“XL2902”相匹配的价格&库存,您可以联系我们找货
XL2902
  • 5+0.61128
  • 50+0.47996
  • 150+0.41429
  • 500+0.36504
库存:833
