XD7650-14
XD7650-14
    XINLUDA(信路达)
    DIP-14
    2MHz超斩波稳定运算放大器
XD7650-14 数据手册
XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier 1. DESCRIPTION The XL7650-8, XD7650-8 and XD7650-14 are Super Chopper-Stabilized Amplifier offers exceptionally low input offset voltage and are extremely stable with respect to time and temperature. It is a direct replacement for the industry-standard XL7650 offering improved input offset voltage, lower input offset voltage temperature coefficient, reduced input bias current, and wider common mode voltage range. All improvements are highlighted in bold italics in the Electrical Characteristics section. Critical parameters are guaranteed over the entire commercial temperature range. The chopper amplifier achieves its low offset by comparing the inverting and non-inverting input voltages in a nulling amplifier, nulled by alternate clock phases. Two external capacitors are required to store the correcting potentials on the two amplifier nulling inputs; these are the only external components necessary. The clock oscillator and all the other control circuitry is entirely self-contained. However the 14 lead version includes a provision for the use of an external clock, if required for a particular application. In addition, the XL7650-8, XD7650-8 and XD7650-14 are internally compensated for unity-gain operation. 2. FEATURES  Guaranteed Max Input Offset Voltage for All Temperature Ranges  Low Long-Term and Temperature Drifts of Input Offset Voltage  Guaranteed Max Input Bias Current......................... 10pA  Extremely Wide Common Mode Voltage Range............................................ +3.5V to -5V  Reduced Supply Current........................................... 2mA  Guaranteed Minimum Output Source/Sink Current  Extremely High Gain.............................................. 150dB  Extremely High CMRR and PSRR........................... 140dB  High Slew Rate..................................................... 2.5V/μs  Wide Bandwidth....................................................... 2MHz  Unity-Gain Compensated  Clamp Circuit to Avoid Overload Recovery Problems and Allow Comparator Use  Extremely Low Chopping Spikes at Input and Output  Package option: XL7650-8 (SOP8), XD7650-8 (DIP8),XD7650-14(DIP16) www.xinluda.com 1 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier 3. TYPICAL APPLICATION AMPLIFIER The functional diagram shows the major elements of the XL7650. There are two amplifiers, the main amplifier, and the nulling amplifier. Both have offset-null capability. The main amplifier is connected continuously from the input to the output, while the nulling amplifier, under the control of the chopping oscillator and clock circuit, alternately nulls itself and the main amplifier. The nulling connections, which are MOSFET gates, are inherently high impedance, and two external capacitors provide the required storage of the nulling potentials and the necessary nulling-loop time constants. The nulling arrangement operates over the full common-mode and power-supply ranges, and is also independent of the output level, thus giving exceptionally high CMRR, PSRR, and AVOL. Careful balancing of the input switches, and the inherent balance of the input circuit, minimizes chopper frequency charge injection at the input terminals, and also the feed forward-type injection into the compensation capacitor, which is the main cause of output spikes in this type of circuit. INTERMODULATION Previous chopper-stabilized amplifiers have suffered from intermodulation effects between the chopper frequency and input signals. These arise because the finite AC gain of the amplifier necessitates a small AC signal at the input. This is seen by the zeroing circuit as an error signal, which is chopped and fed back, thus injecting sum and difference frequencies and causing disturbances to the gain and phase vs frequency characteristics near the chopping frequency. These effects are substantially reduced in the XL7650 by feeding the nulling circuit with a dynamic current, corresponding to the compensation capacitor current, in such a way as to cancel that portion of the input signal due to finite AC gain. Since that is the major error contribution to the XL7650, the intermodulation and gain/phase disturbances are held to very low values, and can generally be ignored. CAPACITOR CONNECTION The OUTPUT CLAMP pin allows reduction of the overload recovery time inherent with chopperstabilized amplifiers. When tied to the inverting input pin, or summing junction, a current path between this point and the OUTPUT pin occurs just before the device output saturates. Thus uncontrolled input differentials are avoided, together with the consequent charge buildup on the correction-storage capacitors. The output swing is slightly reduced. www.xinluda.com 2 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier CLOCK The XL7650 has an internal oscillator, giving a chopping frequency of 200Hz, available at the CLOCK OUT pin on the 14 pin devices. Provision has also been made for the use of an external clock in these parts.The INT/EXT pin has an internal pull-up and may be left open for normal operation, but to utilize an external clock this pin must be tied to V- to disable the internal clock. The external clock signal may then be applied to the EXT CLOCK IN pin. An internal divide-by-two provides the desired 50% input switching duty cycle. Since the capacitors are charged only when EXT CLOCK IN is high, a 50% to 80% positive duty cycle is recommended, especially for higher frequencies. The external clock can swing between V+ and V-. The logic threshold will be at about 2.5V below V+. Note also that a signal of about 400 Hz, with a 70% duty cycle, will be present at the EXT CLOCK IN pin with INT/EXT high or open. This is the internal clock signal before being fed to the divider. In those applications where a strobe signal is available, an alternate approach to avoid capacitor misbalancing during overload can be used. If a strobe signal is connected to EXT CLK IN so that it is low during the time that the overload signal is applied to the amplifier, neither capacitor will be charged. Since the leakage at the capacitor pins is quite low at room temperature, the typical amplifier will drift less than 10V/s, and relatively long measurements can be made with little change in offset. COMPONENT SELECTION The two required capacitors, CEXTA and CEXTB, have optimum values depending on the clock or chopping frequency. For the preset internal clock, the correct value is 0.1F, and to maintain the same relationship between the chopping frequency and the nulling time constant this value should be scaled approximately in proportion if an external clock is used. A high quality film type capacitor such as mylar is preferred, although a ceramic or other lower-grade capacitor may prove suitable in many applications. For quickest settling on initial turn-on, low dielectric absorption capacitors (such as polypropylene) should be used. With ceramic capacitors, several seconds may be required to settle to 1V. STATIC PROTECTION All device pins are static-protected by the use of input diodes. However, strong static fields and discharges should be avoided, as they can cause degraded diode junction characteristics, which may result in increased input-leakage currents. LATCHUP AVOIDANCE Junction-isolated CMOS circuits inherently include a parasitic 4-layer (PNPN) structure which has characteristics similar to an SCR. Under certain circumstances this junction may be triggered into a low-impedance state, resulting in excessive supply current. To avoid this condition, no voltage greater than 0.3V beyond the supply rails should be applied to any pin. In general, the amplifier supplies must be established either at the same time or before any input signals are applied. If this is not possible, the drive circuits must limit input current flow to under 1mA to avoid latchup, even under fault conditions. www.xinluda.com 3 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier OUTPUT STAGE/LOAD DRIVING The output circuit is a high-impedance type (approximately 18k), and therefore with loads less than this value, the chopper amplifier behaves in some ways like a transconductance amplifier whose open-loop gain is proportional to load resistance. For example, the open-loop gain will be 17dB lower with a 1k load than with a 10k load. If the amplifier is used strictly for DC, this lower gain is of little consequence, since the DC gain is typically greater than 120dB even with a 1k load. However, for wideband applications, the best frequency response will be achieved with a load resistor of 10k or higher. This will result in a smooth 6dB/octave response from 0.1Hz to 2MHz, with phase shifts of less than 10° in the transition region where the main amplifier takes over from the null amplifier. THERMO-ELECTRIC EFFECTS The ultimate limitations to ultra-high precision DC amplifiers are the thermo-electric or Peltier effects arising in thermocouple junctions of dissimilar metals, alloys, silicon, etc. Unless all junctions are at the same temperature, thermoelectric voltages typically around 0.1 V/°C, but up to tens of mV/°C for some materials, will be generated. In order to realize the extremely low offset voltages that the chopper amplifier can provide, it is essential to take special precautions to avoid temperature gradients. All components should be enclosed to eliminate air movement, especially that caused by power-dissipating elements in the system. Low thermoelectric-efficient connections should be used where possible and power supply voltages and power dissipation should be kept to a minimum. High-impedance loads are preferable, and good separation from surrounding heatdissipating elements is advisable. GUARDING Extra care must be taken in the assembly of printed circuit boards to take full advantage of the low input currents of the XL7650. Boards must be thoroughly cleaned with TCE or alcohol and blown dry with compressed air. After cleaning, the boards should be coated with epoxy or silicone rubber to prevent contamination. Even with properly cleaned and coated boards, leakage currents may cause trouble, particularly since the input pins are adjacent to pins that are at supply potentials. This leakage can be significantly reduced by using guarding to lower the voltage difference between the inputs and adjacent metal runs. The guard, which is a conductive ring surrounding the inputs, is connected to a low impedance point that is at approximately the same voltage as the inputs. Leakage currents from high-voltage pins are then absorbed by the guard. www.xinluda.com 4 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier FIGURE 1A. INVERTING AMPLIFIER FIGURE 1B. FOLLOWER FIGURE 1C. NON-INVERTING AMPLIFIER FIGURE 1. CONNECTION OF INPUT GUARDS Clearly the applications of the XL7650 will mirror those of other op amps. Anywhere that the performance of a circuit can be significantly improved by a reduction of input-offset voltage and bias current, the XL7650 is the logical choice. Basic non-inverting and inverting amplifier circuits are shown in Figures 2 and 3. Both circuits can use the output clamping circuit to enhance the overload recovery performance. The only limitations on the replacement of other op amps by the XL7650 are the supply voltage (8V Max) and the output drive capability (10k load for full swing). Even these limitations can be overcome using a simple booster circuit, as shown in Figure 4, to enable the full output capabilities of the LM741 (or any other standard device) to be combined with the input capabilities of the XL7650. The pair form a composite device, so loop gain stability, when the feedback network is added, should be watched carefully. NOTE: R1||R2 indicates the parallel combination of R1 and R2. FIGURE 2. NON INVERTING AMPLIFIER WITH OPTIONAL www.xinluda.com 5 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier Figure 5 shows the use of the clamp circuit to advantage in a zero-offset comparator. The usual problems in using a chopper stabilized amplifier in this application are avoided, since the clamp circuit forces the inverting input to follow the input signal. The threshold input must tolerate the output clamp current VlN/R without disturbing other portions of the system. The pin configuration of the 14 pin dual in-line package is designed to facilitate guarding, since the pins adjacent to the inputs are not used (this is different from the standard 741 and 101A pin configuration, but corresponds to that of the LM108). NOTE: R1||R2 indicates the parallel combination of R1 and R2. FIGURE 3. INVERTING AMPLIFIER WITH (OPTIONAL) CLAMP FIGURE 4. USING 741 TO BOOST OUTPUT DRIVE CAPACITY FIGURE 1A. INVERTING AMPLIFIER FIGURE 6. 8048 OFFSET NULLED BY 7650 www.xinluda.com 6 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier 4. PIN CONFIGURATIONS AND FUNCTIONS 5. FUNCTIONAL DIAGRAM www.xinluda.com 7 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier 6. ABSOLUTE MAXIUM RATINGS Supply Voltage (V+ to V-).............................................................................. V Input Voltage............................................................. (V+ +0.3) to (V- -0.3) Voltage on Oscillator Control Pins.................................................... V+ to VDuration of Output Short Circuit.................................................... Indefinite Current to Any Pin................................................................................ 10mA While Operating (Note 1)................................................................ 100A 7. OPERATING CONDITIONS Temperature Range XL7650................................................................................ 0°C to +70°C 8. THERMAL INFORMATION Thermal Resistance (Typical, Note 2) θJA (°C/W) θJC (°C/W) Maximum Junction Temperature (Plastic Package)............... +150°C Maximum Storage Temperature Range.................. -55°C to +150°C Pb-free reflow profile............................................... see link below *Pb-free PDIPs can be used for through hole wave solder processing only. They are not intended for use in Reflow solder processing applications. CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTES: 1. Limiting input current to 100μA is recommended to avoid latchup problems. Typically 1mA is safe, however this is not guaranteed. 2. θJA is measured with the component mounted on an evaluation PC board in free air. www.xinluda.com 8 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier 9. ELECTRICAL SPECIFICATIONS PARAMETER SYMBOL (VSUPPLY = 5V. See Test Circuit, Unless Otherwise Specified) TEST CONDITIONS TEMP. (°C) MIN TYP MAX UNITS +25 - 0.7 5 V InputOffsetVoltage(Note3) VOS 0 to +70 - 1 8 V AverageTemperatureCoefficient of InputOffsetVoltage(Note3) VOS/T 0 to +70 - 0.02 - V/°C Change in Input Offset with Time VOS/T +25 - 100 - nV/month InputBias Current|I(+)|, |I(-)| IBIAS +25 - 4 10 pA 0 to +70 - 5 20 pA InputOffsetCurrent|I(-), |I(+)| IOS +25 - 8 20 pA 0 to +70 - 10 40 pA +25 -  +25 135 1012 150 - dB Input Resistance RIN LargeSignalVoltage Gain (Note3) AVOL RL = 10k, VO = 4V 0 to +70 130 - - dB OutputVoltage Swing(Note4) VOUT RL = 10k +25 4.7 4.85 - V RL = 100k +25 - 4.95 - V +25 -5 -5.2 to +4 3.5 V CommonModeVoltage Range (Note3) CMVR 0 to +70 -5 - 3.5 V +25 120 140 - dB 0 to +70 120 - - dB VS = 3V to 8V +25 120 140 - dB RS = 100, f = DC to 10Hz +25 - 2 - VP-P f = 10Hz +25 - 0.01 - pA/Hz GBWP +25 - 2 - MHz SlewRate SR +25 - 2.5 - V/s RiseTime tR +25 - 0.2 - s Common ModeRejection Ratio (Note3) CMRR CMVR = -5V to +3.5V PowerSupplyRejection Ratio PSRR InputNoiseVoltage eN InputNoiseCurrent iN GainBandwidth Product CL = 50pF, RL = 10k Overshoot OS +25 - 20 - % OperatingSupplyRange V+ to V- +25 4.5 - 16 V SupplyCurrent ISUPP +25 - 2 3 mA 0 to +70 - - 3.2 mA www.xinluda.com No Load 9 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier PARAMETER Output Source Current Output Sink Current Internal Chopping Frequency Clamp ON Current (Note 5) Clamp OFF Current (Note 5) SYMBOL TEST CONDITIONS IO SOURCE IO SINK fCH TEMP. (°C) MIN TYP MAX UNITS +25 2.9 4.5 - mA 0 to +70 2.3 - - mA +25 25 30 - mA 0 to +70 20 - - mA Pins 13 and 14 Open +25 120 250 375 Hz RL = 100k +25 25 70 - A -4V  VOUT  +4V +25 - 0.001 5 nA 0 to +70 - - 10 nA NOTES: 3. These parameters are guaranteed by design and characterization, but not tested at temperature extremes because thermocouple effects prevent precise measurement of these voltages in automatic test equipment. 4. OUTPUT CLAMP not connected. See typical characteristic curves for output swing vs clamp current characteristics. 5. See OUTPUT CLAMP under detailed description. 6. All significant improvements over the industry-standard ICL7650 are highlighted in bold italics. 10. TEST CIRCUIT www.xinluda.com 10 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier 11. TYPICAL PERFORMANCE CURVES FIGURE 7. SUPPLY CURRENT vs SUPPLY VOLTAGE FIGURE 8. SUPPLY CURRENT vs AMBIENT TEMPERATURE FIGURE 10. COMMON MODE INPUT VOLTAGE RANGE vs SUPPLY VOLTAGE FIGURE 9. MAXIMUM OUTPUT CURRENT vs SUPPLY VOLTAGE FIGURE 11. CLOCK RIPPLE REFERRED TO THE INPUT vs TEMPERATURE www.xinluda.com 11 / 16 FIGURE 12. 10Hz NOISE VOLTAGE vs CHOPPING FREQUENCY Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier FIGURE 14. INPUT OFFSET VOLTAGE vs CHOPPING FREQUENCY FIGURE 13. INPUT OFFSET VOLTAGE CHANGE vs SUPPLY VOLTAGE FIGURE 16. OPEN LOOP GAIN AND PHASE SHIFT vs FREQUENCY FIGURE 15. OUTPUT WITH ZERO INPUT; GAIN = 1000; BALANCED SOURCE IMPEDANCE = 10k www.xinluda.com 12 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier NOTE: The two different responses correspond to the two phases of the clock. FIGURE 17. OPEN LOOP GAIN AND PHASE SHIFT vs FREQUENCY FIGURE 7. SUPPLY CURRENT vs SUPPLY VOLTAGE FIGURE 19. VOLTAGE FOLLOWER LARGE SIGNAL PULSE RESPONSE (NOTE) FIGURE 20. N-CHANNEL CLAMP CURRENT vs OUTPUT VOLTAGE FIGURE 21. P-CHANNEL CLAMP CURRENT vs OUTPUT VOLTAGE www.xinluda.com 13 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier 12. ORDERING INFORMATION Ordering Information Part Number Device Marking Package Type Body size (mm) Temperature (°C) MSL Transport Media Package Quantity XL7650-8 XL7650-8 SOP8 4.90  3.90 0 to +70 MSL3 T&R 2500 XD7650-8 XD7650-8 DIP8 9.25  6.38 0 to +70 MSL3 Tube 50 2000 XD7650-14 XD7650-14 DIP14 19.05  6.35 0 to +70 MSL3 Tube 25 1000 13. DIMENSIONAL DRAWINGS SOP8 PIN1 UNIT:mm A1 A2 e D E E1 L www.xinluda.com 14 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier DIP8 PIN1 UNIT:mm A1 A2 e D E E1 L www.xinluda.com 15 / 16 Rev 2.25.8 XL7650-8, XD7650-8,XD7650-14 2MHz, Super Chopper-Stabilized Operational Amplifier DIP14 [ if you need helpcontact us.Xinluda reserves the right tochangethe above information withoutpriornotice ] 16 / 16 www.xinluda.com Rev 2.25.8
