XD74LS157 DIP-16
XL74LS157 SOP-16
XDXL74LS157 is a high speed Quad 2-Input Multiplexer.
Four bits of data from two sources can be selected using the common Select
and Enable inputs. The four buffered outputs present the selected data in the
true (non-inverted) form. The 74LS157 can also be used to generate any four
of the 16 different functions of two variables. The 74LS157 is fabricated with the
Schottky barrier diode process for high speed.
Schottky Process for High Speed
Multifunction Capability
Non-Inverting Outputs
Input Clamp Diodes Limit High Speed Termination Effects
Special Circuitry Ensures Glitch Free Multiplexing
ESD > 3500 Volts
LOGIC SYMBOL
NOTE:
The Flatpak version has
the same pinouts
(Connection Diagram) as
the Dual In-Line Package.
PIN NAMES
LOADING (Note a)
HIGH
Common Select Input
Enable (Active LOW) Input
Data Inputs from Source 0
Data Inputs from Source 1
Multiplexer Outputs (Note b)
S
E
I0a – I0d
I1a – I1d
Za – Zd
LOW
1.0 U.L.
1.0 U.L.
0.5 U.L.
0.5 U.L.
10 U.L.
0.5 U.L.
0.5 U.L.
0.25 U.L.
0.25 U.L.
5 (2.5) U.L.
NOTES:
a) 1 TTL Unit Load (U.L.) = 40 µA HIGH/1.6 mA LOW.
b) The Output LOW drive factor is 2.5 U.L. for Military (54) and 5 U.L. for Commercial (74)
Temperature Ranges.
LOGIC DIAGRAM
CONNECTION DIAGRAM DIP (TOP VIEW)
1
XD74LS157 DIP-16
XL74LS157 SOP-16
FUNCTIONAL DESCRIPTION
The 74S157 is a Quad 2-Input Multiplexer fabricated with the
Schottky barrier diode process for high speed. It selects four
bits of data from two sources under the control of a common
Select Input (S). The Enable Input (E) is active LOW. When E
is HIGH, all of the outputs (Z) are forced LOW regardless of all
other inputs.
The 74S157 is the logic implementation of a 4-pole,
2-position switch where the position of the switch is determined by the logic levels supplied to the Select Input. The logic
equations for the outputs are:
Za = E ⋅ (I1a ⋅ S + I0a ⋅ S)
Zc = E ⋅ (I1c ⋅ S + I0c ⋅ S)
Zb = E ⋅ (I1b ⋅ S + I0b ⋅ S)
Zd = E ⋅ (I1d ⋅ S + I0d ⋅ S)
A common use of the 74S157 is the moving of data from two
groups of registers to four common output busses. The particular register from which the data comes is determined by the
state of the Select Input. A less obvious use is as a function
generator. The 74S157 can generate any four of the 16 dif ferent
functions of two variables with one variable common. This is
useful for implementing highly irregular logic.
TRUTH TABLE
ENABLE
SELECT
INPUT
E
S
I0
I1
Z
H
L
L
L
L
X
H
H
L
L
X
X
X
L
H
X
L
H
X
X
L
L
H
L
H
INPUTS
OUTPUT
H = HIGH Voltage Level
L = LOW Voltage Level
X = Don’t Care
GUARANTEED OPERATING RANGES
Symbol
Parameter
Min
Typ
Max
Unit
VCC
Supply Voltage
54
74
4.5
4.75
5.0
5.0
5.5
5.25
V
TA
Operating Ambient Temperature Range
54
74
– 55
25
125
70
°C
IOH
Output Current — High
54, 74
– 0.4
mA
IOL
Output Current — Low
54
74
4.0
8.0
mA
2
XD74LS157 DIP-16
XL74LS157 SOP-16
DC CHARACTERISTICS OVER OPERATING TEMPERATURE RANGE (unless otherwise specified)
Limits
Symbol
Parameter
VIH
Input HIGH Voltage
VIL
Input LOW Voltage
VIK
Input Clamp Diode Voltage
VOH
Output HIGH Voltage
VOL
Output LOW Voltage
IIH
Min
Typ
Max
2.0
54
0.7
74
0.8
– 0.65
– 1.5
Short Circuit Current (Note 1)
ICC
Power Supply Current
V
Guaranteed Input LOW Voltage for
All Inputs
V
VCC = MIN, IIN = – 18 mA
2.5
3.5
V
2.7
3.5
V
VCC = MIN, IOH = MAX, VIN = VIH
or VIL per Truth Table
VCC = VCC MIN,
VIN = VIL or VIH
per Truth Table
54, 74
0.25
0.4
V
IOL = 4.0 mA
74
0.35
0.5
V
IOL = 8.0 mA
µA
VCC = MAX, VIN = 2.7 V
mA
VCC = MAX, VIN = 7.0 V
– 0.4
– 0.8
mA
VCC = MAX, VIN = 0.4 V
– 100
mA
VCC = MAX
16
mA
VCC = MAX
0.1
0.2
IOS
V
74
I0, I1
E, S
Input LOW Current
I0, I1
E, S
Test Conditions
Guaranteed Input HIGH Voltage for
All Inputs
54
Input HIGH Current
I0, I1
E, S
IIL
Unit
– 20
Note 1: Not more than one output should be shorted at a time, nor for more than 1 second.
AC CHARACTERISTICS (TA = 25°C)
Limits
Symbol
Parameter
Min
Typ
Max
Unit
Test Conditions
tPLH
tPHL
Propagation Delay
Data to Output
9.0
9.0
14
14
ns
Figure 2
tPLH
tPHL
Propagation Delay
Enable to Output
13
14
ns
Figure 1
tPLH
tPHL
Propagation Delay
Select to Output
15
18
23
27
ns
Figure 2
VCC = 5.0 V
CL = 15 pF
AC WAVEFORMS
Figure 1
Figure 2
3
XD74LS157 DIP-16
XL74LS157 SOP-16
SOP-16
-A-
16
9
P
-B1
8
R X 45°
G
C
-T-
D
M
K
F
J
DIP-16
-A16
9
1
8
B
F
L
C
S
-TK
H
G
J
M
D
4
很抱歉,暂时无法提供与“XD74LS157”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.01320
- 10+2.38680
- 25+2.01960
- 100+1.68480
