RGC0805FTD402R
RGC0805FTD402R
    SEI
    贴片电阻 0805 402Ω ±1% 1/8W ±100ppm/℃
RGC0805FTD402R 数据手册
RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • • Precision performance Highly stable performance over time Tolerances of 0.1% may be available - contact Stackpole for details Temperature coefficient of resistance as low as ± 50 ppm/ºC RoHS compliant and halogen free REACH compliant 0402 and 0603 package sizes are qualified to AEC-Q200 Electrical Specifications Type / Code Power Rating (W) @ 70ºC Maximum Working Voltage (V) (1) Maximum Overload Voltage (V) TCR (ppm/ºC) 0.1% 0.5% 1% RGC0201 0.05 25 50 ± 200 - 10 - 10M - RGC0402 0.063 50 100 ± 50 ± 100 - 10 - 1M ± 200 - 1.02M - 10M ± 50 10 - 1M ± 100 ± 200 - ± 50 10 - 1M RGC0603 RGC0805 RGC1206 0.1 0.125 0.25 0.25 RGC1210 RGC2010 0.33 0.75 75 150 150 300 200 400 200 200 200 RGC2512 1 - ± 50 10 - 1M - 100 - 1M 1 - 1M - 10 - 10M 10 - 1M 1.02M - 10M 1 - 10M - 10 - 10M 10 - 1M 1.02M - 10M 1 - 10M 10 - 10M 10 - 1M 1.02M - 10M ± 100 10 - 1M 400 ± 50 ± 100 ± 200 - ± 50 ± 100 10 - 1M ± 200 - 1.02M - 10M - ± 100 ± 50 10 - 1M - 1 - 9.76 500 1 - 9.76 10 - 10M 10 - 1M 10 - 10M 1.02M - 10M 1 - 10M 10 - 10M 10 - 1M - - 10 - 10M 10 - 1M ± 100 ± 200 - 1 - 10M 400 400 250 ± 100 ± 200 ± 100 ± 200 400 200 Ohmic Range (Ω) and Tolerance 10 - 10M 1.02M - 10M - Note: (1) Lesser of √ P*R or maximum working voltage Mechanical Specifications Type / Code Weight (g) (1000 pc.) RGC0201 0.150 L Body Length 0.024 ± 0.001 0.60 ± 0.03 W Body Width 0.012 ± 0.001 0.30 ± 0.03 Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 1 H Body Height 0.009 ± 0.001 0.23 ± 0.03 a Top Termination 0.006 ± 0.002 0.15 ± 0.05 b Bottom Termination 0.006 ± 0.002 0.15 ± 0.05 Unit inches mm www.seielect.com marketing@seielect.com RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Mechanical Specifications (cont.) Type / Code Weight (g) (1000 pc.) RGC0402 0.620 RGC0603 2.042 RGC0805 4.368 RGC1206 8.947 RGC1210 15.959 RGC2010 24.241 RGC2512 39.448 L Body Length 0.039 ± 0.004 1.00 ± 0.10 0.063 ± 0.004 1.60 ± 0.10 0.079 ± 0.004 2.00 ± 0.10 0.122 ± 0.006 3.10 ± 0.15 0.126 ± 0.010 3.20 ± 0.25 0.197 ± 0.008 5.00 ± 0.20 0.250 ± 0.008 6.35 ± 0.20 W Body Width 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.004 0.80 ± 0.10 0.049 ± 0.004 1.25 ± 0.10 0.061 ± 0.004 1.55 ± 0.10 0.102 ± 0.006 2.60 ± 0.15 0.098 ± 0.006 2.50 ± 0.15 0.124 ± 0.008 3.15 ± 0.20 H Body Height 0.012 ± 0.004 0.30 ± 0.10 0.018 ± 0.004 0.45 ± 0.10 0.020 ± 0.004 0.50 ± 0.10 0.024 ± 0.006 0.60 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.004 0.55 ± 0.10 a Top Termination 0.008 ± 0.004 0.20 ± 0.10 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.010 0.40 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.020 ± 0.010 0.50 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 b Bottom Termination 0.010 ± 0.006 0.25 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.008 0.50 ± 0.20 0.024 ± 0.012 0.60 ± 0.30 0.024 ± 0.012 0.60 ± 0.30 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm Performance Characteristics Test Test Specification ± 1% and below Temperature Coefficient of Resistance As specified. Short Time Overload ±(1% + 0.05Ω) Insulation resistance ≥ 10G Endurance ±(1% + 0.1Ω) Damp Heat with Load ±(1% + 0.1Ω) Dry Heat ±(1% + 0.05Ω) Bending Strength ±(1% + 0.05Ω) Solderability 95% minimum coverage Resistance to Soldering Heat ±(0.5% + 0.05Ω) Voltage Proof No breakdown or flashover Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 2 Test Method JIS-C-5201-1 4.8 IEC-60115-1 4.8 -55°C +125°C, 25°C is the reference temperature JIS-C-5201-1 4.13 IEC-60115-1 4.13 RCWV*2.5 or max. overload voltage whichever is lower for 5 seconds; 2 seconds for high power series JIS-C-5201-1 4.6 IEC-60115-1 4.6 Max. overload voltage for 1 minute JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 70 ± 2°C, RCWV for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" JIS-C-5201-1 4.24 IEC-60115-1 4.24 40 ± 2°C, 90 ~ 95% R.H., RCWV for 1000 hours with 1.5 hour "ON" and 0.5 hour "OFF" JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 at +125 / +155°C for 1000 hours JIS-C-5201-1 4.33 IEC-60115-1 4.33 Bending once for 5 seconds 2010, 2512 sizes: 2 mm; other sizes: 3 mm JIS-C-5201-1 4.17 IEC-60115-1 4.17 245 ± 5°C for 3 seconds JIS-C-5201-1 4.18 IEC-60115-1 4.18 260 ± 5°C for 10 seconds JIS-C-5201-1 4.7 IEC-60115-1 4.7 1.42 times max. operating voltage for 1 minute www.seielect.com marketing@seielect.com RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Performance Characteristics (cont.) Test Specification ± 1% and below Individual leaching area ≤ 5% Total leaching area ≤ 10% Test Test Method JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 260 ± 5°C for 30 seconds JIS-C-5201-1 4.19 Rapid Change of Temperature ±(0.5% + 0.05Ω) IEC-60115-1 4.19 -55°C to +125 / +155°C, 5 cycles RCWV (Rated Continuous Working Voltage) = √ P*R or max. operating voltage whichever is lower Storage temperature: 25 ± 3ºC; humidity < 80% RH Operating temperature range for 0201 is -55°C to +125°C Operating temperature range for 0402 - 2512 is -55°C to 155°C Leaching Power Derating Chart: Percent Rated Power (%) 100 -55ºC 70ºC 80 60 0402 - 2512 40 20 0 -60 0201 0 20 40 60 80 125ºC 100 120 140 155ºC 160 180 Ambient Temperature (ºC) Recommended Pad Layout Type / Code RGC0201 RGC0402 RGC0603 RGC0805 RGC1206 a b c Unit 0.012 0.30 0.020 0.50 0.035 0.90 0.047 1.20 0.079 2.00 0.010 0.25 0.018 0.45 0.024 0.60 0.028 0.70 0.035 0.90 0.012 0.30 0.024 0.60 0.035 0.90 0.051 1.30 0.063 1.60 inches mm inches mm inches mm inches mm inches mm Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Recommended Pad Layout (cont.) Type / Code RGC1210 RGC2010 RGC2512 a b c Unit 0.079 2.00 0.150 3.80 0.193 4.90 0.035 0.90 0.035 0.90 0.063 1.60 0.110 2.80 0.110 2.80 0.138 3.50 inches mm inches mm inches mm Soldering Profiles (1) Time of IR reflow soldering at maximum temperature point 260ºC : 10 seconds (2) Time of wave soldering at maximum temperature point 260ºC : 10 seconds (3) Time of soldering iron at maximum temperature point 410ºC : 5 seconds Packaging Specifications Type / Code RGC0201 RGC0402 RGC0603 RGC0805 RGC1206 RGC1210 RGC2010 RGC2512 Packaging Description Tape Width Reel Diameter A B C W T Unit Paper 8mm 7 inches 7.028 ± 0.059 178.50 ± 1.50 2.362 ± 0.039 60.00 ± 1.00 0.512 ± 0.008 13.00 ± 0.20 0.354 ± 0.020 9.00 ± 0.50 0.492 ± 0.020 12.50 ± 0.50 inches mm Embossed 12mm 7 inches 7.028 ± 0.059 178.50 ± 1.50 2.362 ± 0.039 60.00 ± 1.00 0.512 ± 0.020 13.00 ± 0.50 0.512 ± 0.020 13.00 ± 0.50 0.610 ± 0.020 15.50 ± 0.50 inches mm Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Paper Tape Specifications Type / Code RGC0201 RGC0402 RGC0603 RGC0805 RGC1206 RGC2010 Type / Code RGC0201 RGC0402 RGC0603 RGC0805 RGC1206 RGC2010 A ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 P0 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.015 0.38 0.026 0.65 0.043 1.10 0.063 1.60 0.075 1.90 0.114 2.90 W ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P2 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 B ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.008 ± 0.20 ± 0.008 ± 0.20 ± 0.008 ± 0.20 P1 0.079 ± 0.002 2.00 ± 0.05 0.079 ± 0.002 2.00 ± 0.05 0.157 ± 0.002 4.00 ± 0.05 0.157 ± 0.002 4.00 ± 0.05 0.157 ± 0.002 4.00 ± 0.05 0.157 ± 0.002 4.00 ± 0.05 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.027 0.68 0.045 1.15 0.075 1.90 0.094 2.40 0.138 3.50 0.138 3.50 E 0.069 ± 1.75 ± 0.069 ± 1.75 ± 0.069 ± 1.75 ± 0.069 ± 1.75 ± 0.069 ± 1.75 ± 0.069 ± 1.75 ± D0 0.059 ± 1.50 ± 0.059 ± 1.50 ± 0.059 ± 1.50 ± 0.059 ± 1.50 ± 0.059 ± 1.50 ± 0.059 ± 1.50 ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.017 0.42 0.018 0.45 0.028 0.70 0.033 0.85 0.033 0.85 0.033 0.85 F ± ± ± ± ± ± ± ± ± ± ± ± T ± ± ± ± ± ± ± ± ± ± ± ± 0.217 5.50 0.217 5.50 F ± ± ± ± 0.008 0.20 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Unit inches mm inches mm inches mm inches mm inches mm inches mm Unit inches mm inches mm inches mm inches mm inches mm inches mm 0.002 0.05 0.002 0.05 Unit inches mm inches mm 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 Embossed Tape Specifications Type / Code RGC2010 RGC2512 0.110 2.80 0.138 3.50 A ± ± ± ± 0.004 0.10 0.004 0.10 0.217 5.50 0.264 6.70 B ± ± ± ± W 0.472 ± 0.012 12.00 ± 0.30 0.472 ± 0.012 12.00 ± 0.30 0.004 0.10 0.004 0.10 Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 E 0.069 ± 1.75 ± 0.069 ± 1.75 ± 0.004 0.10 0.004 0.10 www.seielect.com marketing@seielect.com RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions Embossed Tape Specifications (cont.) Type / Code RGC2010 RGC2512 0.157 4.00 0.157 4.00 P0 ± 0.004 ± 0.10 ± 0.004 ± 0.10 0.157 4.00 0.157 4.00 P1 ± 0.004 ± 0.10 ± 0.004 ± 0.10 0.079 2.00 0.079 2.00 P2 ± 0.002 ± 0.05 ± 0.002 ± 0.05 D0 0.059 ± 1.50 ± 0.059 ± 1.50 ± 0.004 0.10 0.004 0.10 0.047 1.20 0.047 1.20 T ± ± ± ± 0.000 0.00 0.000 0.00 Unit inches mm inches mm RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type Semi-Precision Thick Film SMD Surface Mount Resistor Note (1): RoHS Compliant by means of exemption 7c-I. RGC Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn over Ni Jul-04 04/27 “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com RGC Series Stackpole Electronics, Inc. Semi-Precision Thick Film Chip Resistor Resistive Product Solutions How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 R G C 0 6 0 3 F T C 4 K 7 0 Product Series Semi-Precision RGC Thick Film Size Size W 0201 0.05 0402 0.063 0603 0.1 0805 0.125 1206 0.25 1210 0.25 1210 0.33 2010 0.75 2512 1 Tolerance Code Tol Value B 0.1% D 0.5% E24, E96 F 1% Rev Date: 04/22/2020 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. Packaging Description Size Quantity 0201, 0402 10000 7" Reel 0603, 0805 Paper Tape 5000 T 1206, 1210 7" Reel 2010(*) 4000 Plastic Tape 2512 (*) RGC2010F 1Ω to 9.76Ω MOQ is 12000 Code 7 TCR Code ppm C 50 D 100 L 200 Resistance Value Four characters with the multiplier used as the decimal holder. 100 ohm = 100R 10.5 Kohm = 10K5 1 Mohm = 1M00 www.seielect.com marketing@seielect.com
RGC0805FTD402R
物料型号:RGC Series Semi-Precision Thick Film Chip Resistor
器件简介: - 由Stackpole Electronics, Inc.生产 - 特点包括精密性能、高稳定性、低温度系数、RoHS合规、无卤素、REACH合规 - 0402和0603封装尺寸符合AEC-Q200标准
引脚分配:文档中未明确提供引脚分配信息,但通常这类电阻器是表面贴装设备(SMD),具有底部和顶部端子。
参数特性: - 功率额定值、最大工作电压、最大过载电压、温度系数、欧姆范围和公差等电气规格 - 例如,RGC0402型号在70°C时的功率额定值为0.063W,最大工作电压为50V
功能详解: - 提供了详细的性能特性测试,包括电阻温度系数、绝缘电阻、耐久性、湿热负载、干热、弯曲强度、焊接性和耐焊接热等测试规格和方法。
应用信息: - 适用于需要精密和稳定电阻性能的应用场合 - 0402至2512不同封装尺寸,适应不同空间需求
封装信息: - 提供了详细的机械规格,包括身体长度、宽度、高度和单位重量 - 例如,RGC0402封装的身体长度为0.039英寸,宽度为0.020英寸,高度为0.012英寸
订购信息: - 提供了如何根据产品系列、尺寸、电阻值、公差和包装来订购产品的指南
环保合规性: - 符合RoHS指令,无铅终端由100%的Matte Sn覆盖Ni - 遵守REACH指令,所有被动组件均不含高度关注物质(SVHC) - 承诺不使用来自刚果民主共和国东部冲突地区的金属
RGC0805FTD402R 价格&库存
很抱歉,暂时无法提供与“RGC0805FTD402R”相匹配的价格&库存,您可以联系我们找货
