XL833
XL833
    XINLUDA(信路达)
    SOP-8
    xD/xL833 是一款高性能双运算放大器,适用于高品质音频和数据信号应用。该器件可在宽范围的单电源和双电源电压下工作,具有低噪声、高增益带宽和高转换速率的特点。其他特性包括低总谐波失真、出色的相位和...
XL833 数据手册
XD833 DIP-8 XL833 SOP-8 FEATURES DESCRIPTION • • • • The XDXL833 is a dual general purpose operational amplifier designed with particular emphasis on performance in audio systems. 1 2 • • • • • Wide Dynamic Range: >140dB Low Input Noise Voltage: 4.5nV/√Hz High Slew Rate: 7 V/μs (typ); 5V/μs (Min) High Gain Bandwidth: 15MHz (typ); 10MHz (Min) Wide Power Bandwidth: 120KHz Low Distortion: 0.002% Low Offset Voltage: 0.3mV Large Phase Margin: 60° Available in 8 Pin VSSOP Package This dual amplifier IC utilizes new circuit and processing techniques to deliver low noise, high speed and wide bandwidth without increasing external components or decreasing stability. The XDXL833 is internally compensated for all closed loop gains and is therefore optimized for all preamp and high level stages in PCM and HiFi systems. Schematic Diagram (1/2 XDXL833) 1 XD833 DIP-8 XL833 SOP-8 Connection Diagram Figure 1. See Package Number D0008A, P0008E or DGK0008A ABSOLUTE MAXIMUM RATINGS (1) (2) Supply Voltage VCC–VEE Differential Input Voltage 36V (3) VI ±30V Input Voltage Range (3) VIC ±15V Power Dissipation (4) PD 500 mW −40 ∼ 85°C Operating Temperature Range TOPR −60 ∼ 150°C Storage Temperature Range TSTG Soldering Information PDIP Package Soldering (10 seconds) 260°C Small Outline Package (SOIC and VSSOP) Vapor Phase (60 seconds) 215°C Infrared (15 seconds) ESD tolerance (1) (2) (3) (4) (5) 220°C 1600V Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is functional, but do not ensure specific performance limits. Electrical Characteristics state DC and AC electrical specifications under particular test conditions which ensure specific performance limits. This assumes that the device is within the Operating Ratings. Specifications are not ensured for parameters where no limit is given, however, the typical value is a good indication of device performance. If supply voltage is less than ±15V, it is equal to supply voltage. This is the permissible value at TA ≤ 85°C. Human body model, 1.5 kΩ in series with 100 pF. 2 XD833 DIP-8 XL833 SOP-8 DC ELECTRICAL CHARACTERISTICS (1) (2) (TA = 25°C, VS = ±15V) Symbol Parameter Conditions Min Typ Units VOS Input Offset Voltage 0.3 5 mV IOS Input Offset Current 10 200 nA IB Input Bias Current 500 1000 nA AV Voltage Gain VOM Output Voltage Swing VCM Input Common-Mode Range CMRR Common-Mode Rejection Ratio PSRR Power Supply Rejection Ratio IQ Supply Current VO = 0V, Both Amps (1) RS = 10Ω Max RL = 2 kΩ, VO = ±10V 90 110 dB RL = 10 kΩ ±12 ±13.5 V RL = 2 kΩ ±12 ±13.4 V ±12 ±14.0 V VIN = ±12V 80 100 dB VS = 15 ∼ 5V, −15 ∼ −5V 80 100 dB 5 8 mA Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. Operating Ratings indicate conditions for which the device is functional, but do not ensure specific performance limits. Electrical Characteristics state DC and AC electrical specifications under particular test conditions which ensure specific performance limits. This assumes that the device is within the Operating Ratings. Specifications are not ensured for parameters where no limit is given, however, the typical value is a good indication of device performance. All voltages are measured with respect to the ground pin, unless otherwise specified. (2) AC ELECTRICAL CHARACTERISTICS (TA = 25°C, VS = ±15V, RL = 2 kΩ) Symbol Parameter Conditions Min Typ Max Units SR Slew Rate RL = 2 kΩ 5 7 V/μs GBW Gain Bandwidth Product f = 100 kHz 10 15 MHz VNI Equivalent Input Noise Voltage (XDXL833) RIAA, RS = 2.2 kΩ (1) (1) μV 1.4 RIAA Noise Voltage Measurement Circuit DESIGN ELECTRICAL CHARACTERISTICS (TA = 25°C, VS = ±15V) The following parameters are not tested or ensured. Symbol ΔVOS/ΔT Parameter Conditions Average Temperature Coefficient Typ Units 2 μV/°C 0.002 % of Input Offset Voltage THD Distortion RL = 2 kΩ, f = 20∼20 kHz VOUT = 3 Vrms, AV = 1 en Input Referred Noise Voltage RS = 100Ω, f = 1 kHz 4.5 nV / √Hz in Input Referred Noise Current f = 1 kHz 0.7 pA / √Hz PBW Power Bandwidth VO = 27 Vpp, RL = 2 kΩ, THD ≤ 1% 120 kHz fU Unity Gain Frequency Open Loop 9 MHz φM Phase Margin Open Loop 60 deg Input Referred Cross Talk f = 20∼20 kHz −120 dB 3 XD833 DIP-8 XL833 SOP-8 TYPICAL PERFORMANCE CHARACTERISTICS Maximum Power Dissipation vs Ambient Temperature Input Bias Current vs Ambient Temperature Figure 2. Figure 3. Input Bias Current vs Supply Voltage Supply Current vs Supply Voltage Figure 4. Figure 5. DC Voltage Gain vs Ambient Temperature DC Voltage Gain vs Supply Voltage Figure 6. Figure 7. 4 XD833 DIP-8 XL833 SOP-8 TYPICAL PERFORMANCE CHARACTERISTICS (continued) Voltage Gain & Phase vs Frequency Gain Bandwidth Product vs Ambient Temperature Figure 8. Figure 9. Gain Bandwidth vs Supply Voltage Slew Rate vs Ambient Temperature Figure 10. Figure 11. Slew Rate vs Supply Voltage Power Bandwidth Figure 12. Figure 13. 5 XD833 DIP-8 XL833 SOP-8 TYPICAL PERFORMANCE CHARACTERISTICS (continued) CMR vs Frequency Distortion vs Frequency Figure 14. Figure 15. PSRR vs Frequency Maximum Output Voltage vs Supply Voltage Figure 16. Figure 17. Maximum Output Voltage vs Ambient Temperature Spot Noise Voltage vs Frequency 833 Figure 18. Figure 19. 6 XD833 DIP-8 XL833 SOP-8 TYPICAL PERFORMANCE CHARACTERISTICS (continued) Spot Noise Current vs Frequency Input Referred Noise Voltage vs Source Resistance 833 833 Figure 20. Figure 21. Noninverting Amp Noninverting Amp Figure 22. Figure 23. Inverting Amp Figure 24. 7 XD833 DIP-8 XL833 SOP-8 APPLICATION HINTS The XDXL833 is a high speed op amp with excellent phase margin and stability. Capacitive loads up to 50 pF will cause little change in the phase characteristics of the amplifiers and are therefore allowable. Capacitive loads greater than 50 pF must be isolated from the output. The most straightforward way to do this is to put a resistor in series with the output. This resistor will also prevent excess power dissipation if the output is accidentally shorted. Noise Measurement Circuit 833 Complete shielding is required to prevent induced pick up from external sources. Always check with oscilloscope for power line noise. Figure 25. Total Gain: 115 dB @f = 1 kHz Input Referred Noise Voltage: en = V0/560,000 (V) 8 XD833 DIP-8 XL833 SOP-8 RIAA Noise Voltage Measurement Circuit RIAA Preamp Voltage Gain, RIAA Deviation vs Frequency Flat Amp Voltage Gain vs Frequency Figure 26. Figure 27. 9 XD833 DIP-8 XL833 SOP-8 Typical Applications AV = 34.5 F = 1 kHz En = 0.38 μV A Weighted Figure 28. NAB Preamp Figure 29. NAB Preamp Voltage Gain vs Frequency VO = V1–V2 Figure 30. Balanced to Single Ended Converter 10 XD833 DIP-8 XL833 SOP-8 VO = V1 + V2 − V3 − V4 Figure 31. Adder/Subtracter Figure 32. Sine Wave Oscillator Illustration is f0 = 1 kHz Figure 33. Second Order High Pass Filter (Butterworth) 11 XD833 DIP-8 XL833 SOP-8 Illustration is f0 = 1 kHz Figure 34. Second Order Low Pass Filter (Butterworth) Illustration is f0 = 1 kHz, Q = 10, ABP = 1 Figure 35. State Variable Filter Figure 36. AC/DC Converter 12 XD833 DIP-8 XL833 SOP-8 Figure 37. 2 Channel Panning Circuit (Pan Pot) Figure 38. Line Driver 13 XD833 DIP-8 XL833 SOP-8 Illustration is: fL = 32 Hz, fLB = 320 Hz fH =11 kHz, fHB = 1.1 kHz Figure 39. Tone Control Av = 35 dB En = 0.33 μV S/N = 90 dB f = 1 kHz A Weighted A Weighted, VIN = 10 mV @f = 1 kHz Figure 40. RIAA Preamp 14 XD833 DIP-8 XL833 SOP-8 Illustration is: V0 = 101(V2 − V1) Figure 41. Balanced Input Mic Amp 15 XD833 DIP-8 XL833 SOP-8 833 Figure 42. 10 Band Graphic Equalizer fo (Hz) C1 C2 R1 R2 32 0.12μF 4.7μF 75kΩ 500Ω 64 0.056μF 3.3μF 68kΩ 510Ω 125 0.033μF 1.5μF 62kΩ 510Ω 250 0.015μF 0.82μF 68kΩ 470Ω 500 8200pF 0.39μF 62kΩ 470Ω 1k 3900pF 0.22μF 68kΩ 470Ω 2k 2000pF 0.1μF 68kΩ 470Ω 4k 1100pF 0.056μF 62kΩ 470Ω 8k 510pF 0.022μF 68kΩ 510Ω 16k 330pF 0.012μF 51kΩ 510Ω Note: At volume of change = ±12 dB Q = 1. LM833-N MDC MWC DUAL AUDIO OPERATIONAL AMPLIFIER Figure 43. Die Layout (A - Step) 16 XD833 DIP-8 XL833 SOP-8 DIP-8 17 XD833 DIP-8 XL833 SOP-8 SOP-8 18
XL833 价格&库存
很抱歉,暂时无法提供与“XL833”相匹配的价格&库存,您可以联系我们找货
