XD74HC597 DIP16
XL74HC597 SOP16
FEATURES
GENERAL DESCRIPTION
• 8-bit parallel storage register inputs
The 74HC597 are high-speed Si-gate CMOS devices
and are pin compatible with low power Schottky TTL
(LSTTL). They are specified in compliance with JEDEC
standard no. 7A.
• Shift register has direct overriding load and clear
• Output capability: standard
• ICC category: MSI
The 74HC597 consist each of an 8-bit storage
register feeding a parallel-in, serial-out 8-bit shift register.
Both the storage register and the shift register have
positive edge-triggered clocks. The shift register also has
direct load (from storage) and clear inputs.
QUICK REFERENCE DATA
GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns
TYPICAL
SYMBOL
PARAMETER
CONDITIONS
UNIT
HC
tPHL/ tPLH
propagation delay
HCT
CL = 15 pF; VCC = 5 V
SHCP to Q
17
ns
STCP to Q
25
29
ns
PL to Q
21
26
ns
96
83
MHz
3.5
3.5
pF
29
32
pF
fmax
maximum clock frequency SHCP
CI
input capacitance
CPD
power dissipation capacitance per package
notes 1 and 2
Notes
1. CPD is used to determine the dynamic power dissipation (PD in µW):
PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where:
fi = input frequency in MHz
fo = output frequency in MHz
∑ (CL × VCC2 × fo) = sum of outputs
CL = output load capacitance in pF
VCC = supply voltage in V
2. For HC the condition is VI = GND to VCC
For HCT the condition is VI = GND to VCC − 1.5 V
1
XD74HC597 DIP16 / XL74HC597 SOP16
PIN DESCRIPTION
PIN NO.
SYMBOL
NAME AND FUNCTION
8
GND
ground (0 V)
9
Q
serial data output
10
MR
asynchronous reset input (active LOW)
11
SHCP
shift clock input (LOW-to-HIGH, edge-triggered)
12
STCP
storage clock input (LOW-to-HIGH, edge-triggered)
13
PL
parallel load input (active LOW)
14
DS
serial data input
15, 1, 2, 3, 4, 5, 6, 7
D0 to D7
parallel data inputs
16
VCC
positive supply voltage
Fig.1 Pin configuration.
Fig.2 Logic symbol.
2
Fig.3 IEC logic symbol.
Fig.4 Functional diagram.
FUNCTION TABLE
STCP
SHCP
PL
MR
FUNCTION
X
X
X
data loaded to input latches
X
L
H
data loaded from inputs to shift register
no clock edge
X
L
H
data transferred from input flip-flops to shift register
X
X
L
L
invalid logic, state of shift register indeterminate when signals removed
X
X
H
L
shift register cleared
X
H
H
shift register clocked Qn = Qn−1, Q0 = DS
Notes
1. H
L
X
= HIGH voltage level
= LOW voltage level
= don’t care
= LOW-to-HIGH CP transition
3
Fig.5 Logic diagram.
4
Fig.6 Timing diagram.
5
ICC category: MSI
AC CHARACTERISTICS FOR 74HC
GND = 0 V; tr = tf = 6 ns; CL = 50 pF
Tamb (°C)
TEST CONDITIONS
74HC597
SYMBOL
PARAMETER
−40 to +85
+25
−40 to +125
min. typ. max. min. max. min.
UNIT V
WAVEFORMS
CC
(V)
max.
tPHL/ tPLH
propagation delay
SHCP to Q
55
175
35
30
220
44
37
265
53
45
ns
2.0
4.5
6.0
Fig.7
tPHL
propagation delay
MR to Q
58
21
17
175
35
30
220
44
37
265
53
45
ns
2.0
4.5
6.0
Fig.8
tPHL/ tPLH
propagation delay
STCP to Q
80
29
23
250
50
43
315
63
54
375
75
64
ns
2.0
4.5
6.0
Fig.7
tPHL/ tPLH
propagation delay
PL to Q
69
25
43
37
270
54
46
325
65
55
ns
2.0
4.5
6.0
Fig.9
tTHL/ tTLH
output transition time
19
7
6
75
15
13
95
19
16
110
22
19
ns
2.0
4.5
6.0
Fig.9
tW
STCP pulse width
HIGH or LOW
80
16
14
11
4
3
100
120
24
ns
2.0
4.5
6.0
Fig.7
tW
SHCP pulse width
HIGH or LOW
80
16
14
14
5
4
100
120
24
ns
2.0
4.5
6.0
Fig.7
tW
MR pulse width
LOW
80
16
14
22
8
6
100
120
24
ns
2.0
4.5
6.0
Fig.8
tW
PL pulse width
LOW
80
16
14
22
8
6
100
120
24
ns
2.0
4.5
6.0
Fig.9
trem
removal time
MR to SHCP
60
12
10
−3
−1
−1
75
15
13
90
18
15
ns
2.0
4.5
6.0
Fig.10
tsu
set-up time
Dn to STCP
60
12
10
8
3
2
75
15
13
90
18
15
ns
2.0
4.5
6.0
Fig.11
6
Tamb (°C)
TEST CONDITIONS
74HC597
SYMBOL
PARAMETER
−40 to +85
+25
−40 to +125
UNIT V
WAVEFORMS
CC
(V)
max.
tsu
set-up time
DS to SHCP
60
12
10
11
4
3
75
15
13
90
18
15
ns
2.0
4.5
6.0
Fig.11
tsu
set-up time
PL to SHCP
60
12
10
11
4
3
75
15
13
90
18
15
ns
2.0
4.5
6.0
Fig.12
th
hold time
Dn to STCP
5
5
5
−3
−1
−1
5
5
5
5
5
5
ns
2.0
4.5
6.0
Fig.11
th
hold time
PL, DS to SHCP
5
5
5
−6
−2
−2
5
5
5
5
5
5
ns
2.0
4.5
6.0
Fig.11
fmax
maximum pulse frequency
SHCP
6.0
30
35
29
87
104
4.8
24
28
4.0
MHz
2.0
4.5
6.0
Fig.7
Note to HCT types
The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications.
To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below.
INPUT
UNIT LOAD COEFFICIENT
DS
Dn
PL, MR
STCP, SHCP
0.25
0.30
1.50
1.50
7
AC WAVEFORMS FOR 74HC597
Tamb (°C)
TEST CONDITIONS
74HC597
SYMBOL
PARAMETER
−40 to +85
+25
−40 to +125
UNIT V
CC
WAVEFORMS
(V)
max.
tPHL/ tPLH
propagation delay
SHCP to Q
23
40
50
60
ns
4.5
Fig.7
tPHL
propagation delay
MR to Q
28
49
61
74
ns
4.5
Fig.8
tPHL/ tPLH
propagation delay
STCP to Q
33
57
71
86
ns
4.5
Fig.7
tPHL/ tPLH
propagation delay
PL to Q
30
52
65
78
ns
4.5
Fig.9
tTHL/ tTLH
7
15
19
22
ns
4.5
Fig.9
tW
SHCP pulse width
HIGH or LOW
16
7
ns
4.5
Fig.7
tW
STCP pulse width
HIGH or LOW
16
6
ns
4.5
Fig.7
tW
MR pulse width
LOW
25
14
31
38
ns
4.5
Fig.8
tW
PL pulse width
LOW
25
30
ns
4.5
Fig.9
trem
removal time
MR to SHCP
12
−2
15
18
ns
4.5
Fig.10
tsu
set-up time
Dn to STCP
12
5
15
18
ns
4.5
Fig.11
tsu
set-up time
DS to SHCP
12
2
15
18
ns
4.5
Fig.11
tsu
set-up time
PL to SHCP
12
4
15
18
ns
4.5
Fig.12
th
hold time
Dn to STCP
5
−1
5
5
ns
4.5
Fig.11
th
hold time
PL, DS to SHCP
5
−2
5
5
ns
4.5
Fig.11
fmax
SHCP
30
75
24
MHz
4.5
Fig.7
8
AC WAVEFORMS
(1) HC : VM = 50%; VI = GND to VCC.
HCT : VM = 1.3 V; VI = GND to 3 V.
Fig.7
Fig.8
Waveforms showing the SHCP and STCP
inputs to Q output propagation delays, the
SHCP and STCP pulse widths and maximum
clock pulse frequency.
Waveforms showing the MR input to Q
output propagation delays and the MR
pulse width.
Fig.9
Fig.10 Waveforms showing the MR input to SHCP,
STCP removal times.
Waveforms showing the PL input to Q
output propagation delays, PL pulse width
and output transition times.
9
Fig.11 Waveforms showing hold and set-up times
for DS, Dn inputs to SHCP, STCP inputs.
Fig.12 Waveforms showing set-up times for PL
input to SHCP input.
10
11
10
12
10
很抱歉,暂时无法提供与“XL74HC597”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.58145
- 50+1.23714
- 150+1.08962
- 500+0.90548
- 2500+0.83484
- 5000+0.78560
