XL78L05A
XL78L05A
    XINLUDA(信路达)
    SOP-8
    5V 100MA 20V
XL78L05A 数据手册
XL78L05A SOP8 / XT78L05 TO92 5 Pin Configuration and Functions YPB Package 8-Pin DSBGA Top View A 3 2 D Package 8-Pin SOIC Top View B VOUT C NC VOUT 1 8 VIN GND 2 7 GND GND 3 6 GND NC 4 5 NC GND VOUT GND Not to scale 1 VIN VIN NC Not to scale LP Package 3-Pin TO-92 Bottom View 3 VIN 2 GND 1 VOUT Not to scale Pin Functions PIN TO-92 I/O DESCRIPTION NAME DSBGA SOIC GND C2, C3 2, 3, 6, 7 2 — Ground NC B3, C1 4, 5 — — No connection VIN A1, B1 8 3 I Input supply voltage pin VOUT A2, A3 1 1 O Output voltage pin 2 XL78L05A SOP8 / XT78L05 TO92 6 Specifications 6.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) (2) MIN MAX UNIT 35 V Input voltage Power dissipation Internally limited Operating junction temperature, TJ XT78L05 (TO-92) 0 125 XL78L05A (SOP8) 0 125 XL78L05A (SOP8) –40 125 XL78L05A (SOP8) –40 85 –65 150 Storage temperature, Tstg (1) °C °C Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 6.2 ESD Ratings V(ESD) (1) Electrostatic discharge Human-body model (HBM), VALUE UNIT ±1000 V (1) Human body model, 1.5 kΩ in series with 100 pF. 6.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) MIN NOM Input voltage Continuous output current TJ Junction temperature XT78L05 (TO-92) XL78L05A XL78L05A XL78L05A MAX UNIT 30 V 100 mA 0 125 (SOP8) 0 125 (SOP8) –40 125 (SOP8) –40 85 °C 6.4 Thermal Information XL78L05A/XT78L05 THERMAL METRIC (1) D (SOIC) LP (TO-92) YPB (DSBGA) 8 PINS 3 PINS 8 PINS UNIT 128.8 158.7 108.4 °C/W RθJA Junction-to-ambient thermal resistance RθJC(top) Junction-to-case (top) thermal resistance 76 75.2 1.3 °C/W RθJB Junction-to-board thermal resistance 69.3 n/a 31.4 °C/W ψJT Junction-to-top characterization parameter 26.3 30.2 4.5 °C/W ψJB Junction-to-board characterization parameter 68.8 138.2 31.4 °C/W RθJC(bot) Junction-to-case (bottom) thermal resistance — — — °C/W (1) For more information about traditional and new thermal metrics, see the Semiconductor and IC Package Thermal Metrics application report. 3 XL78L05A SOP8 / XT78L05 TO92 6.5 Electrical Characteristics —XL78L05A Typical values apply for TJ = 25°C, Minimum and Maximum limits apply for the entire operating temperature range of the package (1) (2), IO = 40 mA, CI = 0.33 µF, CO = 0.1 µF, VIN = 10 V (unless otherwise noted). PARAMETER TEST CONDITIONS TJ = 25°C VO Output voltage Line regulation ΔVO Load regulation IQ Quiescent current ΔIQ Quiescent current change Vn Output noise voltage ΔVIN/ΔVO Ripple rejection MIN TYP MAX 4.8 5 5.2 VIN = 7 V to 20 V, IO = 1 mA to 40 mA (3) 4.75 5.25 IO = 1 mA to 70 mA (3) 4.75 5.25 VIN = 7 V to 20 V, TJ = 25°C 18 75 VIN = 8 V to 20 V, TJ = 25°C 10 54 IO = 1 mA to 100 mA, TJ = 25°C 20 60 IO = 1 mA to 40 mA, TJ = 25°C 5 30 TJ = 25°C 3 5 VIN = 8 V to 20 V 1 IO = 1 mA to 40 mA 0.1 f = 10 Hz to 100 kHz (4) f = 120 Hz, VIN = 8 V to 16 V, TJ = 25°C 40 47 mV mA mA µV 62 dB mA Peak output current ΔVO/ΔT Average output voltage temperature coefficient IO = 5 mA –0.65 VIN(MIN) Minimum value of input voltage required to maintain line regulation TJ = 25°C 6.7 For the operating ranges of each package, see Absolute Maximum Ratings. Limits are ensured by production testing or correlation techniques using standard Statistical Quality Control (SQC) methods. Power dissipation ≤ 0.75 W. Recommended minimum load capacitance of 0.01 µF to limit high-frequency noise. 4 V 140 IPK (1) (2) (3) (4) UNIT mV/°C 7 V XL78L05A SOP8 / XT78L05 TO92 6.10 Typical Characteristics LP Package Figure 1. Maximum Average Power Dissipation Figure 2. Peak Output Current Figure 3. Dropout Voltage Figure 4. Ripple Rejection Figure 5. Output Impedance Figure 6. Quiescent Current 5 XL78L05A SOP8 / XT78L05 TO92 Typical Characteristics (continued) Figure 7. Quiescent Current 6 XL78L05A SOP8 / XT78L05 TO92 7 Detailed Description 7.1 Overview The XL78L05A series ofpositive regulators is available in thefollowing fixedoutput voltages: 5V, 6.2V, 8.2V, 9 V, 12 V, and 15 V. The regulator can be configured to an adjustable output by connecting the GND pin to the center of a resistive voltage divider as shown in Figure 10. In this configuration, the fixed output voltage acts as the reference voltage across R1 allowing the output to be adjusted by changing the resistor. 7.2 Functional Block Diagram 7 XL78L05A SOP8 / XT78L05 TO92 78 XL78L05A SOP8 / XT78L05 TO92 89 XL78L05A SOP8 / XT78L05 TO92 710
XL78L05A 价格&库存
很抱歉,暂时无法提供与“XL78L05A”相匹配的价格&库存,您可以联系我们找货
