XD17324
XD17324
    XINLUDA(信路达)
    DIP-14
    仪表 运算 缓冲器放大器
XD17324 数据手册
XD17324 DIP-14 Description XD17324 series are quad operational amplifier that provide high gain and internal phase compensation, with single power supply. They can be widely used to control equipments. Features Wide range of supply voltage, and single power supply used Internal phase compensation Wide range of common mode voltage, and possible to operate with an input about 0 V Low electro-magnetic susceptibility level Measurement Condition Output Offset Voltage vs. Input Interference 5.0 Rf Vcc = +7.5 V Vee = −7.5 V Rs Rs − + Rf 0.01 µ Vin −10 dBm RF signal source (for quasi-RF noise) Vout V _ (= 100∗Vio) Output offset voltage (arb. unit) • • • • 4.0 XD17324 series 3.0 2.0 Improvement 1.0 XD17324 series 0 −1.0 100E+3 1 1E+6 10E+6 100E+6 1E+9 Input RF frequency (Hz) 10E+9 XD17324 DIP-14 Pin Arrangement Vout1 1 Vin(−)1 2 Vin(+)1 3 VCC 4 Vin(+)2 5 Vin(−)2 6 Vout2 7 14 Vout4 1 − + 4 + − 13 Vin(−)4 12 Vin(+)4 11 VEE + − 3 − + 2 10 Vin(+)3 9 Vin(−)3 8 Vout3 (Top view) Circuit Schematic (1/4) Q5 Vin(−) Q1 Q2 Q3 Q6 Q4 C Q7 R1 Vin(+) Vout Q11 Q10 Q8 Q13 Q12 Q9 Note: If Input/Output terminals voltage over the absolute maximum ratings, there is possibility of mis-operation, characteristics deterioration and destruction, because of the current’s flowing to parasitic diode in IC. The Input/Output terminals are recommended to be protected with the clamp circuit which using the diode with low forward voltage (like schottky barrier diode) when there is a possibility for the Input/Output terminals voltage exceeds the absolute maximum ratings. 2 XD17324 DIP-14 Absolute Maximum Ratings (Ta = 25°C) Item Power supply voltage Output sink current Common mode input voltage Differential input voltage Output voltage Allowable power dissipation Symbol DIP Operating temperature Storage temperature VCC Iosink VCM Vin(diff) Vout PT Ratings 32 50 −0.3 to +VCC ±VCC −0.3 to +VCC 625 *2 Unit V mA V V V mW Topr Tstg −40 to +85 −55 to +125 °C °C Notes: 1. XD17324: This is the allowable values up to Ta = 50°C. Derate by 8.3 mW/°C. 2. XD17324: When it is mounted on glass epoxy board of 40 mm × 40 mm × 1.6 mmt with 10% wiring density, value at Ta ≤ 25°C. If Ta > 25°C, derated by 6.25 mW/°C. When it is mounted on glass epoxy board of 40 mm × 40 mm × 1.6 mmt with 30% wiring density. If Ta > 32°C, derated by 6.70 mW/°C. 3. XD17324: These are the allowable values up to Ta = 25°C. Derate by 4 mW/°C above that temperature. Electrical Characteristics (VCC = +15 V, Ta = 25°C) Item Input offset voltage Input offset current Input bias current Power source rejection ratio Voltage gain Common mode rejection ratio Common mode input voltage range Maximum output voltage Symbol VIO IIO IIB PSRR AVD CMR VCM VOP-P Output source current Output sink current Supply current Slew rate 1 Channel separation * Output sink current Iosource Iosink ICC SR CS Iosink Output voltage VOH1 VOH2 VOL1 VOL2 Output voltage Note: Min     75  −0.3 Typ 2 5 30 93 90 80  Max 7 50 500    13.5 Unit mV nA nA dB dB dB V Test Conditions VCM = 7.5 V, RS = 50 Ω, Rf = 50 kΩ VCM = 7.5 V, IIO = | II (–) – II (+) | VCM = 7.5 V f = 100 Hz, RS = 1 kΩ, Rj = 100 kΩ RS = 1 kΩ, Rf = 100 kΩ, RL = ∞ RS = 50 Ω, Rf = 5 kΩ RS = 1 kΩ, Rf = 100 kΩ, f = 100 Hz  13.6  V 20 10    15 3 13.2 12.0   40 20 0.8 0.19 (120) 50 9 13.6 13.3 0.8 1.1   2       1.0 1.8 mA mA mA V/µs dB µA mA V V V V f = 100 Hz, RS = 1 kΩ, Rf = 100 kΩ, RL = 20 kΩ + – VIN = 1 V, VIN = 0 V, VOH = 10 V VIN = 0 V, VIN = 1 V, VOL = 2.5 V VIN = GND, RL = ∞ f = 1.5 kHz, VCM = 7.5 V, RL = ∞ f = 1 kHz + – VIN = 0 V, VIN = 1 V, VOL = 200 mV + – VIN = 0 V, VIN = 1 V, VOL = 1 V IOH = –1 mA IOH = –10 mA IOL = 1 mA IOL = 10 mA 1. Design spec. 3 XD17324 DIP-14 Input Bias Current vs. Ambient Temperature Output Source Current vs. Ambient Temperature 80 VCC = 15 V 70 VOH = 10 V 60 80 Input bias current IIB (nA) Output source current Iosource (mA) Characteristic Curves 50 40 30 20 10 0 −20 0 20 40 60 Ambeint temperature Ta (°C) VCC = 15 V VCM = 7.5 V 70 60 50 40 30 20 10 0 −20 80 Ta = 25°C Input bias current IIB (nA) Supply current ICC (mA) 80 3 2 1 0 8 16 24 32 Supply voltage VCC (V) 40 20 0 40 Maximum output voltage VOP-P (V) Voltage gain AVD (dB) 8 16 24 32 Supply voltage VCC (V) 40 Maxlmum Output Voltage vs. Frequency 160 Ta = 25°C RL = ∞ 120 80 40 8 16 24 32 Supply voltage VCC (V) Ta = 25°C 60 Voltage Gain vs. Supply Voltage 0 80 Input Bias Current vs. Supply Voltage Supply Current vs. Supply Voltage 4 0 20 40 60 Ambeint temperature Ta (°C) 40 4 20 VCC = 15 V Ta = 25°C RL = 20 kΩ 16 12 8 4 0 1k 3k 10 k 30 k 100 k 300 k Frequency f (Hz) 1M XD17324 DIP-14 Voltage Gain vs. Frequency 120 VCC = 15V Ta = 25°C RL = ∞ Voltage gain AVD (dB) 100 80 60 40 20 0 1 3 10 30 100 300 1k 3k Frequency f (Hz) 10 k 30 k 100 k 300 k 1M Common Mode Rejection Ratio vs. Frequency Common mode rejection ratio CMR (dB) 120 VCC = 15V Ta = 25°C RS = 50 Ω 100 80 60 40 20 0 100 300 1k 3 k 10 k 30 k 100 k 300 k Frequency f (Hz) 1M D 8 E 14 1 7 b3 A Z L A1 Reference Symbol e θ bp c e1 ( Ni/Pd/Au plating ) 5 e1 D E A A1 bp b3 c θ e Z L Dimension in Millimeters Min Nom Max 7.62 19.2 20.32 6.3 7.4 5.06 0.51 0.40 0.48 0.56 1.30 0.19 0.25 0.31 0° 15° 2.29 2.54 2.79 2.39 2.54
XD17324 价格&库存
很抱歉,暂时无法提供与“XD17324”相匹配的价格&库存,您可以联系我们找货
XD17324
  • 5+2.50355
  • 50+1.91031
  • 150+1.68642
库存:18
