XD14069
XD14069
    XINLUDA(信路达)
    DIP-14
    XD14069 六反相器采用 MOS P 沟道和 N 沟道增强型器件构建在单一单片结构中。这些反相器主要用于需要低功耗和/或高抗噪性的场合。六个反相器中的每一个都是单级结构,以尽量减少传播延迟
XD14069 数据手册
XD14069 DIP-14 The XD14069 hex inverter is constructed with MOS P−channel and N−channel enhancement mode devices in a single monolithic structure. These inverters find primary use where low power dissipation and/or high noise immunity is desired. Each of the six inverters is a single stage to minimize propagation delays. Features • Supply Voltage Range = 3.0 Vdc to 18 Vdc • Capable of Driving Two Low−Power TTL Loads or One • • • • • Low−Power Schottky TTL Load Over the Rated Temperature Range Triple Diode Protection on All Inputs Pin−for−Pin Replacement for CD4069UB Meets JEDEC UB Specifications NLV Prefix for Automotive and Other Applications Requiring Unique Site and Control Change Requirements; AEC−Q100 Qualified and PPAP Capable These Devices are Pb−Free and are RoHS Compliant IN 1 1 14 VDD OUT 1 2 13 IN 6 IN 2 3 12 OUT 6 OUT 2 4 11 IN 5 OUT 5 IN 3 5 10 OUT 3 6 9 IN 4 VSS 7 8 OUT 4 MAXIMUM RATINGS (Voltages Referenced to VSS) Symbol Value Unit −0.5 to +18.0 V −0.5 to VDD + 0.5 V Input or Output Current (DC or Transient) per Pin ±10 mA PD Power Dissipation, per Package (Note 1) 500 mW TA Ambient Temperature Range −55 to +125 °C Tstg Storage Temperature Range −65 to +150 °C TL Lead Temperature (8−Second Soldering) 260 °C VDD Vin, Vout Iin, Iout Parameter DC Supply Voltage Range Input or Output Voltage Range (DC or Transient) Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected. 1. Temperature Derating: “D/DW” Packages: –7.0 mW/_C From 65_C To 125_C This device contains protection circuitry to guard against damage due to high static voltages or electric fields. However, precautions must be taken to avoid applications of any voltage higher than maximum rated voltages to this high−impedance circuit. For proper operation, Vin and Vout should be constrained to the range VSS ≤ (Vin or Vout) ≤ VDD. Unused inputs must always be tied to an appropriate logic voltage level (e.g., either VSS or VDD). Unused outputs must be left open. 1 XD14069 DIP-14 1 2 VDD VDD = PIN 14 VSS = PIN 7 3 4 5 6 9 8 11 10 13 INPUT* OUTPUT VSS *Double diode protection on all inputs not shown 12 (1/6 of circuit shown) Figure 1. Logic Diagram PULSE GENERATOR Figure 2. Circuit Schematic VDD 20 ns 14 OUTPUT INPUT INPUT 7 VSS 20 ns VDD 90% 50% 10% tPHL CL tPLH 90% 50% 10% OUTPUT tTHL Figure 3. Switching Time Test Circuit and Waveforms 2 VSS VOH VOL tTLH XD14069 DIP-14 ELECTRICAL CHARACTERISTICS (Voltages Referenced to VSS) −55_C Characteristic Output Voltage Vin = VDD Symbol 25_C VDD Vdc Min Max Min Typ (Note 2) 125_C Max Min Max Unit “0” Level VOL 5.0 10 15 − − − 0.05 0.05 0.05 − − − 0 0 0 0.05 0.05 0.05 − − − 0.05 0.05 0.05 Vdc “1” Level VOH 5.0 10 15 4.95 9.95 14.95 − − − 4.95 9.95 14.95 5.0 10 15 − − − 4.95 9.95 14.95 − − − Vdc “0” Level VIL 5.0 10 15 − − − 1.0 2.0 2.5 − − − 2.25 4.50 6.75 1.0 2.0 2.5 − − − 1.0 2.0 2.5 5.0 10 15 4.0 8.0 12.5 − − − 4.0 8.0 12.5 2.75 5.50 8.25 − − − 4.0 8.0 12.5 − − − 5.0 5.0 10 15 –3.0 –0.64 –1.6 –4.2 − − − − –2.4 –0.51 –1.3 –3.4 –4.2 –0.88 –2.25 –8.8 − − − − –1.7 –0.36 –0.9 –2.4 − − − − IOL 5.0 10 15 0.64 1.6 4.2 − − − 0.51 1.3 3.4 0.88 2.25 8.8 − − − 0.36 0.9 2.4 − − − mAdc Input Current Iin 15 − ±0.1 − ±0.00001 ±0.1 − ±1.0 mAdc Input Capacitance (Vin = 0) Cin − − − − 5.0 7.5 − − pF Quiescent Current (Per Package) IDD 5.0 10 15 − − − 0.25 0.5 1.0 − − − 0.0005 0.0010 0.0015 0.25 0.5 1.0 − − − 7.5 15 30 mAdc Total Supply Current (Notes 3 and 4) (Dynamic plus Quiescent, Per Gate) (CL = 50 pF) IT 5.0 10 15 Output Rise and Fall Times (Note 3) (CL = 50 pF) tTLH, tTHL = (1.35 ns/pF) CL + 33 ns tTLH, tTHL = (0.60 ns/pF) CL + 20 ns tTLH, tTHL = (0.40 ns/pF) CL + 20 ns tTLH, tTHL Propagation Delay Times (Note 3) (CL = 50 pF) tPLH, tPHL = (0.90 ns/pF) CL + 20 ns tPLH, tPHL = (0.36 ns/pF) CL + 22 ns tPLH, tPHL = (0.26 ns/pF) CL + 17 ns tPLH, tPHL Vin = 0 Input Voltage (VO = 4.5 Vdc) (VO = 9.0 Vdc) (VO = 13.5 Vdc) “1” Level VIH (VO = 0.5 Vdc) (VO = 1.0 Vdc) (VO = 1.5 Vdc) Output Drive Current (VOH = 2.5 Vdc) (VOH = 4.6 Vdc) (VOH = 9.5 Vdc) (VOH = 13.5 Vdc) (VOL = 0.4 Vdc) (VOL = 0.5 Vdc) (VOL = 1.5 Vdc) Vdc Vdc IOH Source Sink mAdc IT = (0.3 mA/kHz) f + IDD/6 IT = (0.6 mA/kHz) f + IDD/6 IT = (0.9 mA/kHz) f + IDD/6 mAdc ns 5.0 10 15 − − − − − − − − − 100 50 40 200 100 80 − − − − − − ns 5.0 10 15 − − − − − − − − − 65 40 30 125 75 55 − − − − − − Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 2. Data labelled “Typ” is not to be used for design purposes but is intended as an indication of the IC’s potential performance. 3. The formulas given are for the typical characteristics only at 25_C. 4. To calculate total supply current at loads other than 50 pF: IT(CL) = IT(50 pF) + (CL – 50) Vfk where: IT is in mA (per package), CL in pF, V = (VDD – VSS) in volts, f in kHz is input frequency, and k = 0.002. 3 XD14069 DIP-14 34
