XD4136 DIP-14
D
D
D
D
D
D
D
D
D
Continuous Short-Circuit Protection
Wide Common-Mode and Differential
Voltage Ranges
No Frequency Compensation Required
Low Power Consumption
No Latch-Up
Unity-Gain Bandwidth . . . 3 MHz Typ
Gain and Phase Match Between Amplifiers
Designed To Be Interchangeable With
Raytheon XD4136
Low Noise . . . 8 nV√Hz Typ at 1 kHz
(TOP VIEW)
description
XD4136 are quad
general-purpose operational amplifiers, with each
amplifier electrically similar to the XD741, except
that offset null capability is not provided.
The high common-mode input voltage range and
the absence of latch-up make these amplifiers
ideal for voltage-follower applications. The
devices are short-circuit protected and the
internal frequency compensation ensures stability
without external components.
The XD4136 is characterized for operation from
0°C to 70°C,
1
1IN–
1IN+
1OUT
2OUT
2IN+
2IN–
VCC–
1
14
2
13
3
12
4
11
5
10
6
9
7
8
4IN–
4IN+
4OUT
VCC+
3OUT
3IN+
3IN–
schematic (each amplifier)
VCC+
IN+
IN–
OUT
VCC–
absolute maximum ratings over operating free-air temperature range (unless otherwise noted)†
Supply voltage (see Note 1): VCC+, XD4136 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 V
VCC–, XD4136 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –18 V
Differential input voltage, VID (see Note 2) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±30 V
Input voltage, VI (any input) (see Notes 1 and 3) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±15 V
Duration of output short circuit to ground, one amplifier at a time (see Note 4) . . . . . . . . . . . . . . . . . Unlimited
Continuous total dissipation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . See Dissipation Rating Table
Package thermal impedance, θJA (see Note 5): N package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 80°C/W
Case temperature for 60 seconds: FK package . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 260°C
Lead temperature 1,6 mm (1/16 inch) from case for 10 seconds: D or N package . . . . . . . . . . . . . . . . 260°C
Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C
† Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and
functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not
implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
NOTES: 1. All voltage values, unless otherwise noted, are with respect to the midpoint between VCC+ and VCC–.
2. Differential voltages are at IN+ with respect to IN–.
3. The magnitude of the input voltage must never exceed the magnitude of the supply voltage or 15 V, whichever is less.
4. Temperature and/or supply voltages must be limited to ensure that the dissipation rating is not exceeded.
5. The package thermal impedance is calculated in accordance with JESD 51-7.
2
VCC+
VCC–
MIN
MAX
Supply voltage
5
15
V
Supply voltage
–5
–15
V
electrical characteristics at specified free-air temperature, VCC+ = 15 V, VCC– = –15 V
PARAMETER
TEST CONDITIONS†
XD4136
MIN
25°C
VIL
Input offset
voltage
VO = 0
IIO
Input offset
current
VO = 0
IIB
Input bias current
VO = 0
Vi
Input voltage
range
VOM
Maximum peak
out
ut voltage
output
swing
MAX
0.5
6
Full
range
7.5
25°C
5
Full
range
140
Full
range
±12
±14
RL = 10 kΩ
RL = 2 kΩ
25°C
±12
±14
25°C
±10
±13
RL ≥ 2 kΩ
Full
range
±10
25°C
Full
range
15
AVD
Large-signal
g
g
differential voltage
amplification
B1
Unity-gain
bandwidth
25°C
ri
Input resistance
25°C
RS = 50 Ω
25°C
VO = ±10 V,
V
RL ≥ 2 kΩ
VO = 0,
V
MHz
0.3*
5
MΩ
70
90
dB
25°C
30
Vn
Equivalent input
noise voltage
(closed loop)
AVD = 100,
BW = 1 Hz,
f = 1 kHz,
RS = 100 Ω
25°C
8
ICC
Supply current
(all four amplifiers)
am lifiers)
VO = 0,
Total power
ower
dissipation
VO = 0,
Crosstalk
attenuation
(VO1/VO2)
AVD = 100,,
f = 10 kHz,
RS = 1 kΩ
3
V
3
VCC = ±9 V to ±15 V,
V
VO = 0
No load
nA
V/mV
Supply-voltage
y
g
sensitivity
(∆VIO/∆VCC)
PD
nA
300
kSVS
No load
mV
500
800
25°C
UNIT
200
300
25°C
Common-mode
CMRR
rejection ratio
TYP
150
µV/V
µ
nV√Hz
25°C
5
11.3
MIN TA
6
13.7
MAX TA
4.5
10
25°C
150
340
MIN TA
180
400
MAX TA
135
300
25°C
105
mA
mW
dB
UNIT
4
很抱歉,暂时无法提供与“XD4136”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.99941
- 50+1.56276
- 150+1.37506
- 500+1.14070
