XD74LS154
XD74LS154
    XINLUDA(信路达)
    DIP24
    逻辑 - 信号开关,解码器/多路分解器 1 x 4:16
XD74LS154 数据手册
XD74LS154 DIP-24 1. General description The XD74LS154 is a 4-to-16 line deco der/demultiplexer. It decodes four binary weighted address inputs (A0 to A3) to sixteen mutually exclusive outputs (Y0 to Y15). The device features two input enable (E0 and E1) inputs. A HIGH on either of the input enables forces the outputs HIGH. The device can be used as a 1-to-16 demultiplexer by using one of the enable inputs as the multiplexed data input. When the other enable input is LOW the addressed output will follow the state of the applied data. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits     16-line demultiplexing capability Decodes 4 binary-coded inputs into 16 mutually-exclusive outputs Complies with JEDEC standard no. 7A Input levels:  For XD74LS154: CMOS level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C 1 XD74LS154 DIP-24 3. Functional diagram   $ $  $  $ (   '(&2'(5 (
XD74LS154 价格&库存
很抱歉,暂时无法提供与“XD74LS154”相匹配的价格&库存,您可以联系我们找货
XD74LS154
  • 1+12.52800
  • 10+10.65960
  • 30+9.12600
  • 105+7.92720
库存:118
