XD4069
XD4069
    XINLUDA(信路达)
    DIP-14
    逻辑 - 栅极和逆变器 反相器 IC 6 通道
XD4069 数据手册
XD4069 DIP-14 1. General description The XD4069 is a general purpose hex unbuffered inverter. Each inverter has a single stage. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits      Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C and 40 C to +125 C Complies with JEDEC standard JESD 13-B 3. Applications  Oscillator 4. Functional diagram $ $ $ $ $ $             < < < < 9'' < $ < < 966 Fig 1. Functional diagram Fig 2. 1 Schematic diagram (one inverter) XD4069 DIP-14 5. Pinning information 5.1 Pinning Fig 3. $   9'' <   $ $   < <  $  <   $ 966   < XD4069  $  < Pin configuration 5.2 Pin description Table 1. Pin description Symbol Pin Description 1A to 6A 1, 3, 5, 9, 11, 13 input 1Y to 6Y 2, 4, 6, 8, 10, 12 output VSS 7 ground (0 V) VDD 14 supply voltage 6. Limiting values Table 2. Limiting values In accordance with the Absolute Maximum Rating System . Symbol Parameter Conditions Min Max Unit 0.5 +18 V - 10 mA 0.5 VDD + 0.5 - 10 mA - 10 mA 50 mA VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current IDD supply current Tstg storage temperature 65 +150 C Tamb ambient temperature 40 +125 C Ptot total power dissipation - 500 mW - 100 mW VI < 0.5 V or VI > VDD + 0.5 V VO < 0.5 V or VO > VDD + 0.5 V - Tamb = 40 C to +125 C [1] DIP-14 P power dissipation V per output [1] DIP-14 packages: above Tamb = 70 C, Ptot derates linearly with 8 mW/K. 2 XD4069 DIP-14 7. Recommended operating conditions Table 3. Recommended operating conditions Symbol Parameter VDD Conditions Min Typ Max supply voltage 3 - 15 V VI input voltage 0 - VDD V Tamb ambient temperature 40 - +125 C in free air Unit 8. Static characteristics Table 4. Static characteristics VSS = 0 V; VI = VSS or VDD; unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL Tamb = 40 C Tamb = +25 C Tamb = +85 C Tamb = +125 C Unit Conditions VDD Min Max Min Max Min Max Min Max IO < 1 A 5V 4 - 4 - 4 - 4 - V 10 V 8 - 8 - 8 - 8 - V 15 V 12.5 - 12.5 - 12.5 - 12.5 - V 5V - 1 - 1 - 1 - 1 V 10 V - 2 - 2 - 2 - 2 V 15 V - 2.5 - 2.5 - 2.5 - 2.5 V HIGH-level IO < 1 A output voltage 5V 4.95 - 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - 14.95 - V LOW-level IO < 1 A output voltage 5V - 0.05 - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 - 0.05 V 5V - 1.7 - 1.4 - 1.1 - 1.1 mA 5V - 0.64 - 0.5 - 0.36 - 0.36 mA VO = 9.5 V 10 V - 1.6 - 1.3 - 0.9 - 0.9 mA VO = 13.5 V 15 V - 4.2 - 3.4 - 2.4 - 2.4 mA 5V 0.64 - 0.5 - 0.36 - 0.36 - mA 10 V 1.6 - 1.3 - 0.9 - 0.9 - mA 15 V 4.2 - 3.4 - 2.4 - 2.4 - mA HIGH-level input voltage LOW-level input voltage IO < 1 A HIGH-level VO = 2.5 V output current V = 4.6 V O LOW-level VO = 0.4 V output current V = 0.5 V O VO = 1.5 V II input leakage current 15 V - 0.1 - 0.1 - 1.0 - 1.0 A IDD supply current all valid input 5 V combinations; 10 V IO = 0 A 15 V - 0.25 - 0.25 - 7.5 - 7.5 A - 0.5 - 0.5 - 15.0 - 15.0 A - 1.0 - 1.0 - 30.0 - 30.0 A - - - 7.5 - - - - pF CI input capacitance digital inputs 3 XD4069 DIP-14 9. Dynamic characteristics Table 5. Dynamic characteristics Tamb = 25 C; for waveforms see Figure 4; for test circuit see Figure 5. Symbol Parameter tPHL tPLH tTHL tTLH [1] HIGH to LOW propagation delay Conditions VDD Extrapolation formula[1] nA to nY; 5V LOW to HIGH propagation delay nA to nY HIGH to LOW output transition time output nY LOW to HIGH output transition time output nY Min Typ Max Unit 18 ns + (0.55 ns/pF)CL - 45 90 ns 10 V 9 ns + (0.23 ns/pF)CL - 20 40 ns 15 V 7 ns + (0.16 ns/pF)CL - 15 25 ns 5V 13 ns + (0.55 ns/pF)CL - 40 80 ns 10 V 9 ns + (0.23 ns/pF)CL - 20 40 ns 15 V 7 ns + (0.16 ns/pF)CL - 15 30 ns 5V 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 5V 10 ns + (1.00 ns/pF)CL - 60 120 ns 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns The typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF). Table 6. Dynamic power dissipation VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol Parameter PD dynamic power dissipation VDD Typical formula Where 5V PD = 600  fi + (fo  CL)  VDD (W) 2 10 V PD = 4000  fi + (fo  CL)  VDD2 (W) fi = input frequency in MHz; fo = output frequency in MHz; 15 V PD = 22000  fi + (fo  CL)  VDD (W) CL = output load capacitance in pF; (fo  CL) = sum of the outputs; 2 VDD = supply voltage in V. 4 XD4069 DIP-14 10. Waveforms WU 9,  90 LQSXW 9 WI  W3+/ 92+ W3/+  90 RXWSXW  92/ W7+/ W7/+ Measurement points: VM = 0.5VDD. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 4. Propagation delay and transition times 9'' * 9, 92 '87 &/ 57 Definitions for test circuit: CL = load capacitance including jig and probe capacitance; RT = termination resistance should be equal to the output impedance Zo of the pulse generator; For test data refer to Table 7. Fig 5. Test circuit for measuring switching times Table 7. Test data Supply voltage Input VDD VI tr, tf Load CL 5 V to 15 V VSS or VDD  20 ns 50 pF 5 XD4069 DIP-14 10.1 Transfer characteristics   92 9 ,' —$ 92 9      ,' P$                   9, 9 b. VDD = 10 V; IO = 0 A   92 9 ,' P$             9, 9 c. VDD = 15 V; IO = 0 A (1) VO = output voltage. (2) ID = drain current. Fig 6.  9, 9 a. VDD = 5 V; IO = 0 A     Typical transfer characteristics 6 XD4069 DIP-14 11. Application information Some examples of applications for the XD4069. Figure 7 shows an astable relaxation oscillator using two HEF4069UB inverters and 2 BAW62 diodes. The oscillation frequency is mainly determined by R1  C1, provided R1
XD4069 价格&库存
很抱歉,暂时无法提供与“XD4069”相匹配的价格&库存,您可以联系我们找货
XD4069
  • 5+1.10020
  • 50+0.85536
  • 150+0.75255
  • 500+0.62435
库存:495
