XD74LS166 DIP-16
The inputs are buffered to lower the drive requirements to one series 74 or 74LS standard load, respectively. Input
clamping diodes minimize switching transients and simplify system design. This parallel in or serial-in, serial-out shift
register has a complexity of 77 equivalent gates on a monolithic chip. This device features gated clock inputs and an
overriding clear input.
The parallel-in or serial-in modes are established by the shift / load input.
When high, this input enables the serial data input and couples the eight flip-flops for serial shifting with each clock
pulse. When low, the parallel (broadside) data inputs are enabled and synchronous loading occurs on the next clock
pulse, during parallel loading, serial data flow is inhibited.
This, of course, allows the system clock to be free running and the register can be stopped on command with the other
clock input. The clock-inhibit input should be changed to the high level only while the clock input is high. A buffered,
direct clear input overrides all other inputs, including the clock, and sets all flip-flops to zero.
Pin Arrangement
Serial
Input
1
16
VCC
A
2
15
B
3
14
Shift/
Load
Parallel
Input H
C
4
13
Output QH
D
5
12
G
Clock
Inhibit
6
11
F
Clock
7
10
E
GND
8
9
Clear
Parallel
Inputs
(Top view)
1
Parallel
Inputs
XD74LS166 DIP-16
Function Table
Inputs
Clear
Shift
Load
Clock
Inhibit
Clock
Serial
L
H
H
H
H
H
X
X
L
H
H
X
X
L
L
L
L
H
X
L
X
X
X
H
L
X
Parallel
A…H
X
X
a…h
X
X
X
Internal outputs
QA
L
QA0
a
H
L
QA0
QB
L
QB0
b
QAn
QAn
QB0
Output
QH
L
QH0
h
QGn
QGn
QH0
Notes: 1. H; high level, L; low level, X; irrelevant
2. ↑; transition from low to high level
3. a to h; the level of steady-state input at inputs A to H respectively
4. QA0 to QH0; the level of QA to QH, respectively, before the indicated steady-state input conditions were
established.
5. QAn to QGn; the level of QA to QG, respectively, before the most recent ↑ transition of the clock.
2
XD74LS166 DIP-16
Block Diagram
Clear
Serial Input
Shift/Load
A
R CK S
QA
B
R CK S
QB
C
R CK S
QC
D
R CK S
QD
E
R CK S
QE
F
R CK S
QF
G
R CK S
QG
H
Clock
R CK S
Clock Inhibit
QH
Absolute Maximum Ratings
Item
Symbol
Ratings
Unit
Supply voltage
VCC
7
V
Input voltage
VIN
7
V
Power dissipation
PT
400
mW
Tstg
–65 to +150
°C
Storage temperature
Note: Voltage value, unless otherwise noted, are with respect to network ground terminal.
3
XD74LS166 DIP-16
Recommended Operating Conditions
Item
Symbol
Min
Typ
Max
Unit
VCC
4.75
5.00
5.25
V
IOH
–400
µA
IOL
8
mA
Operating temperature
Topr
–20
25
75
°C
Clock frequency
ƒclock
MHz
Clock and clear pulse width
tw
ns
Mode control setup time
tsu
30
ns
Data setup time
tsu
ns
Hold time
th
ns
Supply voltage
Output current
Electrical Characteristics
(Ta = –20 to +75 °C)
Item
Input voltage
Symbol
VIH
VIL
min.
2.0
typ.*
max.
0.8
Unit
V
V
VOH
2.7
V
IIH
IIL
II
0.4
0.5
–0.4
0.1
µA
mA
mA
VCC = 5.25 V, VI = 2.7 V
VCC = 5.25 V, VI = 0.4 V
VCC = 5.25 V, VI = 7 V
IOS
–20
–100
mA
VCC = 5.25 V
ICC
VIK
–1.5
mA
V
VCC = 5.25 V
VCC = 4.75 V, IIN = –18 mA
Output voltage
VOL
Input current
Short-circuit output
current
Supply current**
Input clamp voltage
V
Condition
VCC = 4.75 V, VIH = 2 V, VIL = 0.8 V,
IOH = –400 µA
IOL = 4 mA
VIL = 0.8 V
IOL = 8 mA
Notes: * VCC = 5 V, Ta = 25°C
** With the outputs open, 4.5 V applied to the serial input and all other inputs except the clock grounded, ICC is
measured after a momentary ground, then 4.5 V, is applied to clock.
Switching Characteristics
(VCC = 5 V, Ta = 25°C)
Item
Maximum clock frequency
Propagation delay time
Symbol
ƒmax
tPHL
tPHL
tPLH
Inputs
Clear
Clock
min.
25
7
5
4
typ.
35
19
14
11
max.
30
25
Unit
MHz
ns
ns
ns
Condition
CL = 15 pF, RL = 2 kΩ
XD74LS166 DIP-16
Testing Method
Test Circuit
VCC
4.5V
P.G.
Zout = 50Ω
Notes:
See Testing Table
Input
Clear
Serial Input
Shift/Load
A
QH
B
C
D
E
F
G
H
Clock
Clock
Inhibit
RL
Output
CL
1. CL includes probe and jig capacitance.
2. All diodes are 1S2074(H).
Testing table
Data inputs
Data H
Serial-in
Shift / Load
0V
4.5 V
Output
QH
QH
5
Bit time
tn + 1
tn + 8
XD74LS166 DIP-16
Waveform
tw (Clear)
3V
Clear
Input
1.3V
1.3V
0V
tn
tn + 1
tn + 1
tn
3V
Clock
Input
1.3V
1.3V
1.3V
1.3V
0V
tsu
tw (Clock)
th
tsu
th
3V
Data
Input
1.3V
1.3V
1.3V
1.3V
0V
tPHL
tPLH
tPHL
VOH
Output QH
1.3V
1.3V
1.3V
VOL
Notes:
1. Input pulse; ≤ 15 ns, tTHL ≤ 6 ns, PRR = 1 MHz, duty cycle 50%
Clock input; tw ≥ 20 ns
Clear inpu; tw ≥ 20 ns, th = 10 ns, when testing ƒmax, vary the clock PRR.
2. Propagation delay time (tPLH and tPHL) are measured at tn + 1. Proper shifting of data is verified
at tn + 8 with a functional test.
3. tn; bit time before clocking transition.
tn + 1; bit time after one clocking transition.
tn + 8; bit time after eight clocking transition.
Typical Clear, Shift, Load, Inhibit, and Shift Sequences
Clock
Clock Inhibit
Clear
Serial Input
Shift / Load
A
H
L
B
C
Parallel
Inputs
H
L
D
E
H
L
F
G
H
H
H
Output QH
H
Clear
Serial Shift
Load Inhibit
6
H
L
H
L
H
L
Serial Shift
H
L
XD74LS166 DIP-16
Package Dimensions
JEITA Package Code
P-DIP16-6.3x19.2-2.54
RENESAS Code
PRDP0016AE-B
Previous Code
DP-16FV
MASS[Typ.]
1.05g
D
9
E
16
1
8
b3
0.89
A1
A
Z
L
Reference
Symbol
e
θ
bp
c
e1
( Ni/Pd/Au plating )
7
e1
D
E
A
A1
bp
b3
c
θ
e
Z
L
Dimension in Millimeters
Min
Nom Max
7.62
19.2 20.32
6.3 7.4
5.06
0.51
0.40 0.48 0.56
1.30
0.19 0.25 0.31
0°
15°
2.29 2.54 2.79
1.12
2.54
很抱歉,暂时无法提供与“XD74LS166”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.78146
- 50+1.35238
- 150+1.19384
