MT-2018
MT-2018
    PRO'SKIT(宝工)
    保护功能模拟万用表
MT-2018 数据手册
MT-2018 Protective Function Analog Multimeter User’s Manual 2st Edition, 2018 © 2018 Copyright by Prokit’s Industries Co., Ltd. INTRODUCTION This Multi-meter is an accurate, safe, battery operated, rear tilt-stand, easy to operate handheld instrument with robust protective holster alongside and the adjustable back tilt device with hook-up design. It can offer accurate, reliable measurement of DC/AC Voltage, DC Current, Resistance and Diode, LED, Transistor, Decibels, and Capacitance with very high sensitive quality movement, and good-designed circuit, as well as mirrored Aluminum dial plate etc. It has the perfect full overload & miss-used protection via Fuses, Oxide Varactor & Diodes. It is an ideal instrument for indoor use in the laboratory, school, workshop, hobby and home applications. SPECIFICATIONS Safety Category: IEC61010-1, CAT II 1000V, CAT III 500V and Pollution Degree 2. Common Environment: 23C5C, less than 75% RH. Temperature Ranges: 0C to 40C, 32 F to 104 F for Operating condition. -10 C to 50C, 14 F to 122F for Storage condition. Humidity Scope: Operating condition less than 90% RH. Storage condition: less than 80% RH. Size: 160(W) x 105(D)x 40(H) MM Weight: 390g approx. (including batteries 3pcs) Accessories: One set of Test Leads; One Spare Fuse: 0.5A/250V, 1 Test Functions Range Accuracy DC V 0-0.1-0.5-2.5-10-50 -250 V -1000V  3% FSD.  4% FSD. For 1000V AC V 0-10-50-250V -1000V  4% FSD.  5% FSD. For 1000V 0-0.05-2.5-25250 mA,  3% FSD. DC mA Ω X1: 0.2 ~ 2KΩ midscale at 20Ω X10: 2~20KΩ Midscale at 200Ω X100:20~200KΩ Midscale at 2000Ω X1K: 200~ 2MΩ Midscale at 20KΩ X10K: 2K ~ 20MΩ Midscale at 200KΩ Capacitan ce (uF) 2000uF BATT Check 0 ~ 1.5V: GOOD - ? – BAD 0 ~ 9V: GOOD - ? – BAD Remarks Input Impendence: 20KΩ/V Overload Protection: Max. 1000V AC/DC BUT 0.1V/0.5V/ 2.5V/10V/50V /250V Max. Input Impendence: 9KΩ/V Overload Protection: Max. 1000V AC/DC But 10V/50V only 250V Max. Band width: 40 ~10K Hz Drop Voltage: 250mV Overload protected by Fuses 0.5A/250V, and Oxide Varactor.
MT-2018 价格&库存
很抱歉,暂时无法提供与“MT-2018”相匹配的价格&库存,您可以联系我们找货
