S9014
S9014
    SLKOR(萨科微)
    SOT-23
    通用三极管 NPN 45V 100mA SOT-23
S9014 数据手册
S9014 NPN Silicon Epitaxial Planar Transistor FEATURES z Complementary To S9015. z Excellent HFE Linearity. z Power dissipation.(PC=0.2W) APPLICATIONS z Per-Amplifier low level & low noise. SOT-23 MAXIMUM RATING @ Ta=25℃ unless otherwise specified Symbol Parameter Value Units VCBO Collector-Base Voltage 50 V VCEO Collector-Emitter Voltage 45 V VEBO Emitter-Base Voltage 5 V IC Collector Current -Continuous 100 mA PC Collector Dissipation 200 mW Tj,Tstg Junction and Storage Temperature -55~150 ℃ www.slkormicro.com 1 S9014 ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified Parameter Symbol Test conditions MIN Collector-base breakdown voltage V(BR)CBO IC=100μA,IE=0 50 V Collector-emitter breakdown voltage V(BR)CEO IC=0.1mA,IB=0 45 V Emitter-base breakdown voltage V(BR)EBO IE=-100μA,IC=0 5 V Collector cut-off current ICBO VCB=50V,IE=0 0.1 μA Collector cut-off current ICEO VCE=35V,IB=0 0.1 μA Emitter cut-off current IEBO VEB=3V,IC=0 0.1 μA DC current gain hFE VCE=5V,IC=1mA Collector-emitter saturation voltage VCE(sat) IC=100mA, IB= 5mA 0.3 V Base-emitter saturation voltage VBE(sat) IC=100mA, IB= 5mA 1 V Transition frequency fT VCE=6V, IC= 20mA f=30MHz CLASSIFICATION Rank Range www.slkormicro.com OF B TYP B 200 UNIT 1000 B B 150 hFE(1) L H 200-450 450-1000 2 MAX MHz S9014 TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified www.slkormicro.com 3 S9014 SOT-23 Package Information SOT-23 A E K B Dim Min Max A 2.85 2.95 B 1.25 1.35 C J D G H D 0.37 0.43 E 0.35 0.48 G 1.85 1.95 H 0.02 0.1 J C 1.0Typical K 0.1Typical 2.35 2.45 All Dimensions in mm www.slkormicro.com 4
S9014 价格&库存
很抱歉,暂时无法提供与“S9014”相匹配的价格&库存,您可以联系我们找货
S9014
    • 50+0.04524
    • 600+0.03613
    • 1200+0.03559
    • 3000+0.02822
    库存:10314
    S9014
    • 100+0.04480
    • 1000+0.03520
    • 3000+0.02710
    • 9000+0.02410
    • 51000+0.02130
    • 99000+0.01990
    库存:53340
    S9014
    • 1+0.02420
    • 3000+0.01930
    库存:10306
    S9014
    • 100+0.04936
    • 1000+0.03942
    • 3000+0.03078
    • 9000+0.02754
    • 51000+0.02463
    • 99000+0.02312
    库存:16375
    S9014
    • 1+0.06550
    • 100+0.06290
    库存:50
    S9014
    • 3000+0.083913000+0.01089
    • 6000+0.073406000+0.00953
    • 9000+0.068049000+0.00883
    • 15000+0.0619815000+0.00805
    • 21000+0.0583821000+0.00758
    • 30000+0.0548830000+0.00712
    库存:9007
    S9014
    • 1+0.883691+0.11466
    • 10+0.2725610+0.03537
    • 100+0.16908100+0.02194
    • 500+0.12063500+0.01566
    • 1000+0.104511000+0.01356
    库存:9007
