ULN2003
HIGH VOLTAGE AND HIGH CURRENT
DARLINGTON TRANSISTOR ARRAY
DESCRIPTION
The ULN2003 is a monolithic high voltage and high current
Darlington transistor arrays. It consists of seven NPN darlington pairs
that features high-voltage outputs with common-cathode clamp
diode for switching inductive loads. The collector-current rating of a
single darlington pair is 500mA. The darlington pairs may be
ULN2003AE DIP- 16
parrlleled for higher current capability. Applications include relay
drivers,hammer
drivers,
lampdrivers,display
drivers(LED
gas
discharge),line drivers, and logic buffers.
The ULN2003 has a 2.7kΩ series base resistor for each
darlington pair for operation directly with TTL or 5V CMOS devices.
FEATURES
ULN2003AU SOP- 16
* 500mA rated collector current(Single output)
* High-voltage outputs: 50V
* Inputs compatibale with various types of logic.
* Relay driver application
LOGIC DIAGRAM
PAIR)
SCHEMATIC(EACH DARLINGTON
1B
1
16
1C
2B
2
15
2C
3B
3
14
3C
COM
2.7kO
4B
4
13
4C
5B
5
12
5C
6B
6
11
6C
7B
7
10
7C
E
8
9
COM
OUPUT C
INPUT B
7.2kO
www.slkormicro.com
3kO
E
1
ULN2003
ABSOLUTE MAXIMUM RATINGS(Ta=25°C)
Characteristic
Symbol
Value
Unit
VCE
50
V
VI
30
V
Peak Collector Current
Io
500
mA
Total Emitter-terminal
IOK
500
mA
Power Dissipation
Pd
950 Tamb=25°C
mW
495 Tamb
很抱歉,暂时无法提供与“ULN2003AU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.29676
- 50+1.06251
- 150+0.96207
- 500+0.79495
- 2500+0.73309
- 5000+0.70128
- 国内价格
- 5+1.17669
- 50+0.96412
- 500+0.72134
- 1000+0.71052
- 2500+0.66520
