RoHS & Halogen Free & REACH Compliance.
SPECIFICATION FOR APPROVAL
Customer:
Customer P/N:
Drawing No:
Quantity:
Pcs.
Date :
CPY160808T-SERIES-NP
Chilisin P/N:
SPECIFICATION
ACCEPTED BY:
COMPONENT
ENGINEER
ELECTRICAL
ENGINEER
MECHANICAL
ENGINEER
APPROVED
REJECTED
奇力新電子股份有限公司
Chilisin Electronic sCorp
No. 29, Alley 301, Tehhsin Rd.,
Hukou,Hsinchu 303, Taiwan
TEL +886-3- 599-2646
FAX +886-3- 599-9176
E-mail sales@chilisin.com.tw
http //www.chilisin.com.tw
奇力新電子(
奇力新電子(河南)
河南)有限公司
Chilisin Electronics (Henan) Co., Ltd.
XiuWu Xian, industry gathering area
JiaoZuo, Henan China
Postal Code:454350
TEL:+86-391-717-0682
FAX:+86-391-717-0666
Drawn by
張瑞滿 rammi
東莞奇力新電子有限公司
Chilisin Electronics (Dongguan) Co., Ltd.
No. 78, Puxing Rd., Yuliangwei Administration
Area, Qingxi Town, Dongguan City,
Guangdong,China
TEL +86-769-8773-0251~3
FAX +86-769-8773-0232
E-mail cect@chilisin.com.tw
奇力新電子(
奇力新電子(蘇州)
蘇州)有限公司
Chilisin Electronics (Suzhou) Co., Ltd.
No.143,Song Shan Rd., Suzhou New District,
Suzhou,China
Postal Code:215129
TEL:+86-512-6841-2350
FAX:+86-512-6841-2356
E-mail suzhou@chilisin.com.tw
Checked by
邱明傑 Joseph.Chiu
Approved by
JACKY jacky.chung
鍾
CPY160808T Series Specification
1 Scope: This specification applies to Multilayer Ferrite chip inductors
2 Part Numbering:
3 Rating:
Operating Temperature: -40℃~105℃(Including self - temperature rise)
Storage Temperature: -40℃~85℃(after PCB)
-5℃~40℃,Humidity 40%~70%(before PCB)
4 Marking:
5 Standard Testing Condition
Temperature
Humidity
Unless otherwise specified
Ordinary Temperature(15 to 35 )
Ordinary Humidity(25 to 85% RH)
In case of doubt
20±2
60 to 70 % RH
6 Configuration and Dimensions:
7 Electrical Characteristics:
Inductance
(uH)
Test Freq.
RDC
(Ω)Max.
Rated
Current
(mA)Max.
Tolerance
CPY160808T-1R0□-NP
1
1 MHz,200 mV
0.12
1500
20,30
CPY160808T-2R2□-NP
2.2
1 MHz,200 mV
0.2
1000
20,30
CPY160808T-4R7□-NP
4.7
1 MHz,200 mV
0.25
800
20,30
CPY160808T-100□-NP
10
1 MHz,200 mV
0.9
90
20,30
Part No.
NOTE: □-tolerance M=±20% / T=±30%
1.Operating temperature range
2.Rate Current : Applied the current to coils, the temperature rise shall not be more than 30
"-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER)
8 CPY160808T Series
8.1 Construction:
8.2 Material List:
9 Reliability Of Ferrite Multilayer Chip Inductor
1-1.Mechanical Performance
No
Item
1-1-1 Flexure Strength
Test Method
Specification
The forces applied on the right Test device shall be soldered on the substrate
conditions must not damage Substrate Dimension: 100x40x1.6mm
the terminal electrode and the Deflection: 2.0mm
ferrite
Keeping Time: 30sec
*For 100505, substrate dimension is 100x40x0.8mm
1-1-2 Vibration
Oscillation Frequency: 10 to 55 to 10Hz for 1min
Amplitude: 1.5mm
Time: 2hrs for each axis (X, Y & Z), total 6hrs
1-1-3 Resistance to Soldering Heat Appearance: No damage
Pre-heating: 150 , 1min
More than 75% of the terminal.Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free)
electrode should be covered Solder Temperature: 260±5
with solder.
Immersion Time: 10±1sec
Inductance: within ±20% of
initial value
1-1-4 Solder ability
The electrodes shall be at
least 95% covered with new
solder coating
1-2.Environmental Performance
No
Item
1-2-1 Temperature Cycle
1-2-2 Humidity Resistance
1-2-3 High
Temperature Resistance
1-2-4 Low
Specification
Inductance:within±20% of
initial value
Solder Temperature: 245±5 (Pb-Free)
Immersion Time: 4±1sec
Test Method
One cycle:
Time (min)
Step
Temperature ( )
1
-40±3
30
2
25±2
3
3
105±3
30
4
25±2
3
Total: 100cycles
Measured after exposure in the room condition for 24hrs
Temperature: 40±2
Relative Humidity: 90 ~ 95% / Time: 1000hrs
Temperature: 85±3
Relative Humidity: 20%
Applied Current: Rated Current / Time: 1000hrs
Temperature: -40±3
Relative Humidity: 0% / Time: 1000hrs
11 Packaging:
11.1 Packaging -Cover Tape
The force for tearing off cover tape is 10 to 100 grams in the arrow direction.
11.2 Packaging Quantity
11.3 Reel Dimensions
11 Packaging:
11.4 Tape Dimensions in mm
12 Recommended Land Pattern:
13 Note:
1. Please make sure that your product has been evaluated and confirmed against your specifications
when our product is mounted to your product.
2. Do not knock nor drop.
3. All the items and parameters in this product specification have been prescribed on the premise that
our product is used for the purpose,under the condition and in the environment agreed upon between
you and us. You are requested not to use our product deviating from such agreement.
4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950)
很抱歉,暂时无法提供与“CPY160808T-4R7M-NP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.55990
- 200+0.18700
- 2000+0.11660
- 4000+0.09240
- 国内价格
- 100+0.07245
- 500+0.06795
- 1000+0.06120
- 5000+0.05220
- 10000+0.04680
- 国内价格
- 100+0.18700
- 200+0.13200
- 300+0.12100
- 400+0.11000
