HC1812CG331J102
HC1812CG331J102
    MERITEK
    贴片电容(MLCC) 1812 330pF ±5% 1KV C0G(NP0)
HC1812CG331J102 数据手册
Multilayer Ceramic Chip Capacitors High Voltage Type ≥1KV HC Series FEATURE  High voltage rating in a given case size.  High reliability and thermal stability.  Application: DC to DC converter, High Voltage Coupling/DC blocking, Back-lighting inverters, LAN/WLAN interface, Power supplies, Snubbers in HF power convertors. PART NUMBERING SYSTEM HC 1812 XR 822 K 102 (1) (2) (3) (4) (5) (6) No Item (1) Meritek Series (2) Size (3) Dielectric Digit Description HC 1812 XR (4) Capacitance (5) Tolerance (6) Rated Voltage RoHS Reference High-Voltage Ceramic Chip Capacitor High voltage application with ≧ 1KVdc 1812 inch (4532 mm) 0805,1206,1210,1808, 1825,2211,2220,2225 X7R CG: C0G(NP0), XR: X7R, XF: X5R, YV: Y5V 822: 82x10 pF = 8200pF 103: 10x103pF, 4R7: 4.7pF (K): ±10% F: ±1%,G: ±2%,J: ±5%,K: ±10%,M: ±20% Working Voltage: 1000VDC 152: 1.5KVDC, 202: 2.0KVDC, 3KVDC, 4KVDC 2 822 K 102 DIMENSIONS Thickness Size Inch (mm) L (mm) W (mm) 0603 (1608) 1.60±0.20 0.80±0.15 0.40±0.15 0805 (2012) 2.10±0.20 1.25±0.20 0.50±0.20 1206 (3216) 3.30±0.30 1.60+0.30/-0.10 1210 (3225) 3.30±0.40 2.50±0.30 1808 (4520) 4.60±0.50 2.00±0.20 1812 (4532) 4.60±0.50 3.20±0.30 1825 (4563) 4.60±0.50 6.30±0.40 2220 (5750) 5.70±0.50 5.00±0.40 0.85±0.35 2225 (5763) 5.70±0.50 6.30±0.40 0.85±0.35 T (mm) code See Thickness Specification Reference Table below MB min (mm) 0.60±0.20 0.75±0.35 0.75±0.35 0.75±0.35 0.75±0.35 THICKNESS SPECIFICATION REFERENCE Code A B C D E F G H Thickness (mm) 0.60 ± 0.10 0.8 + 0.15/-0.10 1.25 ± 0.10 1.40 ± 0.15 1.60 ± 0.20 2.00 ± 0.20 2.50 ± 0.30 2.80 ± 0.30 Code I J K L M N O P Thickness (mm) 1.25 ± 0.20 1.15 ± 0.15 0.50 ± 0.20 0.30 ± 0.03 0.95 ± 0.10 0.50 ± 0.05 3.50 ± 0.20 1.60 +0.3/-0.10 Code Q R S T U V X Z Thickness (mm) 0.50 + 0.02/-0.05 3.10 ± 0.30 0.80 ± 0.07 0.85 ± 0.10 0.50 ± 0.10 0.20 ± 0.02 0.80 ± 0.10 0.25 ± 0.03 Rev. 7d Multilayer Ceramic Chip Capacitors High Voltage Type ≥1KV HC Series ELECTRICAL CHARACTERISTICS Properties Characteristics Dielectric C0G(NP0) X7R Size 0805, 1206, 1210, 1808, 1812, 1825, 2220, 2225 0603, 0805, 1206, 1210,1808, 1812, 1825, 2220, 2225 Rated Voltage 1KV, 1.5KV, 2KV, 3KV,4KV 1KV, 1.5KV, 2KV, 3KV,4KV Capacitance Range 0.5pF ~ 12nF 100pF ~ 330nF Capacitance Tolerance See Capacitance Tolerance ReferenceTable Below Cap. Range Cap < 30pF Cap ≥ 30pF Dissipation Factor Q Spec. Q ≥ 400+20C Q ≥ 1000 ≤2.5% Measured at the condition of 30~70% related humidity.  Preconditioning : Preform a heat treatment at 150±10⁰C for an hour, then leave in ambient condition for 24±2 hours before measurement For 25⁰C at ambient temperature Cap. & D.F. Test Condition (30~70% Relative Humidity) Cap. Range Cap≤1000pF Cap>1000pF Test Condition 1.0±0.2Vrms, 1.0MHz±10% 1.0±0.2Vrms, 1.0KHz±10% 1.0±0.2Vrms, 1.0KHz±10%, at 25⁰C ambient temperature ≥100GΩ or RC≥5000Ω-F Whichever is smaller Insulation Resistance Operation Temperature ≥10GΩ or RC≥100Ω-F Whichever is smaller -55°C ~ +125°C Temperature Coefficient ±15% ±30ppm/⁰C Termination Cu (or Ag)/Ni/Sn (lead-free) CAPACITANCE TOLERANCE REFERENCE Code Description Code Description Code Description Code Description A ±0.05 pF F ±1 % J ±5 % N -5%~10% B ±0.10 pF G ±2 % K ±10 % P ±0.02 pF C ±0.25 pF H ±3 % L 0%~10% Q ±0.03 pF D ±0.50 pF I -10%~0% M ±20 % Z -20%~80% Rev. 7d Multilayer Ceramic Chip Capacitors High Voltage Type ≥1KV HC Series RELIABILITY TEST CONDITIONS AND REQUIREMENTS Item Visual and Dimensions Test Condition Requirements  No remarkable defect.  Dimensions to confirm to individual specification sheet. ---  Shall not exceed the limits given in the detailed spec. Capacitance Q/ D.F. (Dissipation Factor) Temperature Coefficient Class I: C0G(NP0) Cap≤1000pF, 1.0±0.2Vrms, 1MHz±10% Cap>1000pF, 1.0±0.2Vrms, 1KHz±10% Class II: (X7R) 1.0±0.2Vrms, 1kHz±10%  With no electrical load. T.C. C0G(NP0) X7R Dielectric Operation Temp. -55~125°C at 25°C -55~125°C at 25°C  To apply voltage at 500VDC for 60 sec. Insulation Resistance Solderability Dielectric Strength  Solder temperature: 235±5°C for (1206~1210)  Solder temperature: 245±5°C for (1808~2225)  Dipping time: 2±0.5 sec. Resistance to Soldering Heat Temperature Cycle  Conduct the five cycles according to the temperatures and time. Step Temp. (°C) Time (min.) 1 Min. operating temp. +0/-3 30±3 2 Room temp. 2~3 3 Max. Operating temp. +3/-0 30±3 4 Room temp. 2~3  Before initial measurement (Class II only): Perform 150+0/-10°C for 1 hr and then set for 48±4 hrs at room temp.  Measurement to be made after keeping at room temp. for 24±2 hrs (Class I) or 48±4 hrs (Class II). Vibration Resistance  Vibration frequency: 10~55 Hz/min.  Total amplitude: 1.5mm  Test time: 6 hrs. (Two hrs. each in three mutually perpendicular directions.) Class I(NP0) All Class II(X7R) ≥ 100 Q/D.F. Remark Q≥1000 Q≥400+20C D.F. < 2.5% D.F. < 3.0% Cap≥30pF Cap
HC1812CG331J102 AI解析
物料型号:MERITEK HC系列,为高压型多层陶瓷片式电容器,电压等级≥1KV。
器件简介:该系列电容器具有在给定的封装尺寸下高电压等级、高可靠性和热稳定性。适用于DC-DC转换器、高压耦合/直流阻断、背光逆变器、LAN/WLAN接口、电源、高频功率转换器中的缓冲器等。
引脚分配:未在文档中明确说明引脚分配,但通常这类电容器为无引脚的表面贴装元件。
参数特性: - 尺寸范围:从0603(1608)到2225(5763)不等。 - 介质类型:X7R。 - 电容值范围:从100pF到330nF。 - 电容公差:根据代码不同,有±10%、±5%、±2%、±1%等。 - 额定电压:提供1KV、1.5KV、2KV、3KV、4KV等不同工作电压。
功能详解:电容器能够在直流或交流电路中储存能量,用于滤波、耦合、去耦、能量存储等。
应用信息:适用于高电压应用场合,如电源转换、通信设备、医疗设备等。
封装信息:提供了详细的尺寸信息,包括英寸和毫米两种单位,以及不同尺寸的电容器的厚度规格。
电气特性:包括电容范围、介质损耗因数、绝缘电阻、操作温度范围、温度系数、端头材料等。
可靠性测试条件和要求:包括视觉和尺寸检查、电容测试、介质损耗因数(D.F.)测试、温度系数测试、绝缘电阻测试、焊接性测试、耐电压测试、耐焊接热测试、温度循环测试、耐弯折性测试等。
电容值范围:提供了X7R介质和C0G介质的电容值范围表,展示了不同尺寸和电压等级下的电容值选项。
包装尺寸:提供了7英寸和13英寸卷装的尺寸和数量信息。
应用注意事项:包括存储条件、处理注意事项、预热、焊接、冷却和清洁等。
*介绍内容由AI识别生成
HC1812CG331J102 价格&库存
很抱歉,暂时无法提供与“HC1812CG331J102”相匹配的价格&库存,您可以联系我们找货
