MKM04EL04TD2-TN
MKM04EL04TD2-TN
    MK(米客方德)
    BGA162_11.5X13MM
    NAND MCP 4+4; 4Gb(512Mb x8) NAND Flash + 4Gb(128Mb x32) LPDDR2 BGA162_13X11.5MM
MKM04EL04TD2-TN 数据手册
MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) MKM04EL04TD2-TN NAND Flash and Mobile Memory 162-Ball MCP Specification 4Gb(512Mb x8) NAND Flash with 4Gb(128Mb x32) LPDDR2 Revision 1.0 1 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) 4Gb(512Mb x8) NAND Flash Featues • Organization Memory cell array Register Page size Block size x8 4352 x 128K x 8 4352 x 8 4352 bytes (256K + 16K) bytes • Modes Read, Reset, Auto Page Program, Auto Block Erase, Status Read, Page Copy, Multi Page Program, Multi Block Erase, Multi Page Copy, Multi Page Read • Mode control Serial input/output Command control • Number of valid blocks Min 2008 blocks Max 2048 blocks • Power supply VCC = 1.8V (1.7 V ~ 1.95V) • Access time Cell array to register Serial Read Cycle 25 µs max 25 ns min (CL=30pF) Program/Erase time Auto Page Program Auto Block Erase 300 µs/page typ. 3.5 ms/block typ. Operating current Read (50 ns cycle) Program (avg.) Erase (avg.) Standby 30 mA max. 30 mA max 30 mA max 50 µA max • • • 8-bits ECC for 512Btyes is required Revision 1.0 2 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) 4Gb(128Mb x32) LPDDR2 Feature  Double-data rate architecture; two data transfer per clock cycle  Bidirectional, data strobe (DQS, /DQS) is transmitted/received with data, to be used in capturing data at the receiver  Eight internal banks for concurrent operation  Data mask (DM) for write data  Programmable Burst Lengths: 4 ,8 or 16  Burst type: Sequential or interleave  Programmable RL (Read latency) & WL (Write latency)  Clock Stop capability during idle period  Auto Precharge for each burst access  Configurable Drive Strength (DS)  Auto Refresh and Self Refresh Modes  Differential clock inputs (CK and /CK)  Differential data strobe (DQS and /DQS)  Commands & addresses entered on both positive & negative CK edge; data and data mask referenced to both edges of DQS  Optional Partial Array Self Refresh (PASR) and Temperature Compensated Self Refresh (TCSR)  Deep Power Down Mode (DPD)  HSUL_12 compatible inputs (High Speed Un-terminated Logic 1.2V)  VDD2/VDDCA/VDDQ= 1.14~1.30V; VDD1=1.70~1.95  Speed:  8-Banks / 14bits rows / 10bits columns  Every Bank is organized as 16384 rows by 1024 columns by 32bits. Revision 1.0 667MHz / 800MHz / 1066MHz 3 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) MCP Signal Assignments Revision 1.0 4 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) MCP Ball Descriptions NAND Flash Symbol Type Function DATA INPUTS/OUTPUTS I/O0 ~ I/O7 (X8) I/O0 ~ I/O15 (X16) Input/output The I/O pins are used to input command, address and data, and to output data during read operations. The I/O pins float to high-z when the chip is deselected or when the outputs are disabled. COMMAND LATCH ENABLE CLE Input The CLE input controls the activating path for commands sent to the internal command registers. Commands are latched into the command register through the I/O ports on the rising edge of the WE# signal with CLE high. ADDRESS LATCH ENABLE ALE Input The ALE input controls the activating path for addresses sent to the internal address registers. Addresses are latched into the address register through the I/O ports on the rising edge of WE# with ALE high. CHIP ENABLE CE# Input The CE# input is the device selection control. When the device is in the Busy state, CE# high is ignored, and the device does not return to standby mode in program or erase operation. Regarding CE# control during read operation, refer to ’Page read’ section of Device operation. READ ENABLE RE# Input The RE# input is the serial data-out control, and when it is active low, it drives the data onto the I/O bus. Data is valid tREA after the falling edge of RE# which also increments the internal column address counter by one. WRITE ENABLE WE# Input The WE# input controls writes to the I/O ports. Commands, address and data are latched on the rising edge of the WE# pulse. WRITE PROTECT WP# Input The WP# pin provides inadvertent write/erase protection during power transitions. The internal high voltage generator is reset when the WP# pin is active low. READY/BUSY OUTPUT The R/B# output indicates the status of the device operation. When low, it indicates that a R/B# Input program, erase or random read operation is in progress and returns to high state upon completion. It is an open drain output and does not float to high-z condition when the chip is deselected or when outputs are disabled. VCC Revision 1.0 Supply POWER VCC is the power supply for device. 5 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) VSS Supply N.C. - GROUND NO CONNECTION Lead is not internally connected. LPDDR2 Symbol Type Function Clock: CK and CK# are differential clock inputs. All Double Data Rate (DDR) CA input signals are CK, CK# Input sampled on both positive and negative edge of CK. CS_n and CKE inputs are sampled at the positive edge of CK. AC timings are referenced to clock. Clock Enable: CKE high activates, and CKE low deactivates internal clock signals, and device input CKE Input buffers and output drivers. Power saving modes are entered and exited through CKE transitions. CKE is considered part of the command code. CKE is sampled at the positive Clock edge. CS_n Input Chip Select: CS_n is considered part of the command code. CS_n is sampled at the positive Clock edge. Command/Address Inputs: Uni-directional command/address bus inputs. Provide the command CA0 – CA9 Input and address inputs according to the command truth table. CA is considered part of the command code. Input Data Mask: DM is an input mask signal for write data. Input data is masked when DM is sampled HIGH coincident with that input data during a Write access. DM is sampled on both DM0-DM3 Input edges of DQS. Although DM pins are input-only, the DM loading matched the DQ and DQS (or /DQS). DM0 corresponds to the data on DQ0-DQ7, DM1 corresponds to the data on DQ8-DQ15, DM2 corresponds to the data on DQ16-DQ23, and DM3 corresponds to the data on DQ24-DQ31. DQ0-DQ31 Input/output Data Bus: Bi-directional Input / Output data bus. Data Strobe (Bi-directional, Differential): The data strobe is bi-directional (used for read and write data) and Differential (DQS and DQS#). It is output with read data and input with write DQS, DQS# DQS0-3,DQS0#-3# data. DQS is edge-aligned to read data, and centered with write data. Input/output DQS0 & DQS0# corresponds to the data on DQ0-DQ7, DQS1 & DQS1# corresponds to the data on DQ8-DQ15, DQS2 & DQS2# corresponds to the data on DQ16-DQ23, DQS3 & DQS3# corresponds to the data on DQ24-DQ31. Reference Pin for Output Drive Strength Calibration. External impedance (240-ohm): this signal is ZQ Input VREFDQ, VREFCA Supply Revision 1.0 used to calibrate the device output impedance. Reference Voltage: VREFDQ is reference for DQ input buffers. VREFCA is reference for Command 6 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) / Address input buffers. NO CONNECTION NC - VDDQ Supply DQ Power Supply: Isolated on the die for improved noise immunity. VSSQ Supply DQ Ground: Isolated on the die for improved noise immunity. VDDCA Supply Command / Address Power Supply. VSSCA Supply Command / Address Ground: Isolated on the die for improved noise immunity. VDD1 Supply Core power supply 1. VDD2 Supply Core power supply2. Vss Supply Common Ground. Revision 1.0 Lead is not internally connected. 7 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) MCP Functional Overview Block Diagram Revision 1.0 8 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) MCP Package Dimensions Revision 1.0 9 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) 4Gbit NAND Flash(512M x 8bit) Descriptions The Device is a single 1.8V 4 Gbit (4,563,402,752 bits) NAND Electrically Erasable and Programmable Read-Only Memory (NAND E2PROM) organized as (4096 + 256) bytes × 64 pages × 2048blocks. The Device is a serial-type memory device which utilizes the I/O pins for both address and data input/output as well as for command inputs. The Erase and Program operations are automatically executed making the device most suitable for applications such as solid-state file storage, voice recording, image file memory for still cameras and other systems which require high-density non-volatile memory data storage. The device has two 4352-bytes static registers which allow program and read data to be transferred between the register and the memory cell array in 4352-byte increments. The Erase operation is implemented in a single block unit (256Kbytes + 16Kbytes: 4352bytes × 64pages). Revision 1.0 10 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Block Diagram Functional Block Diagram Revision 1.0 11 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Schematic Cell Layout and Address Assignment A page consists of 4352bytes in which 4096 bytes are used for main memory storage and 256bytes are for redundancy or for other uses. 1 page = 4352 bytes 1 block = 4352 bytes X 64 pages = ( 256K + 16K) bytes Capacity = 4352 bytes X 64 pages X 2048 blocks = 570,425,344 bytes = 4,563,402,752 bits IO7 IO6 IO5 IO4 IO3 IO2 IO1 IO0 CA7 CA6 CA5 CA4 CA3 CA2 CA1 CA0 L L L CA12 CA11 CA10 CA9 CA8 Third cycle PA7 PA6 PA5 PA4 PA3 PA2 PA1 PA0 Fourth cycle PA15 PA14 PA13 PA12 PA11 PA10 PA9 PA8 L L L L L L L PA16 First cycle Second cycle Fifth cycle CA0 to CA12 : Column address PA0 to PA16 : Page address PA0 to PA5 : NAND address in block PA6 to PA16 : Block address Revision 1.0 12 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Operation Mode: Logic and Command Tables Logic Tables CLE ALE CE# Command Input H L Data Input L Address Input RE# WP# L H X L L H H L H L H X Serial Data Output L L L H During Program (Busy) X X X X X H During Erase (Busy) X X X X X H X X H X X X X X L H H X Program / Erase Inhibit X X X X X L Standby X X H X X 0V / VCC During Read (Busy) WE# X Command Tables First Cycle Second Cycle Serial Data Input 80 - Read 00 30 Column Address Change in Serial Data Output 05 E0 Read with Data Cache 31 - Read Start for Last Page in Read Cycle with Data Cache 3F - Auto Page Program 80 10 Column Address Change in Serial Data Input 85 - Auto Program with Data Cache 80 15 80 11 81 15 81 10 Read for Page Copy (2) with Data Out 00 3A Auto Program with Data Cache during Page Copy (2) 8C 15 Auto Program for last page during Page Copy (2) 8C 10 Auto Block Erase 60 D0 ID Read 90 - Status Read 70 - ○ Status Read for Multi-Page Program or Multi Block Erase 71 - ○ Reset FF - ○ Multi Page Program Revision 1.0 13 Acceptable while Busy APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Power On/Off Sequence The timing sequence shown in the figure below is necessary for the power-on/off sequence. The device internal initialization starts after the power supply reaches an appropriate level in the power on sequence. During the initialization the device Ready/Busy signal indicates the Busy state as shown in the figure below. In this time period, the acceptable commands are FFh or 70h. The WP signal is useful for protecting against data corruption at power-on/off. Device Operation Read Read mode is set when the 00h and 30h commands are issued to the Command register. Between the two commands, a start address for the Read mode needs to be issued. After initial power on sequence, Revision 1.0 14 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) 00h command is latched into the internal command register. Therefore read operation after power on sequence is executed by the setting of only five address cycles and 30h command. Refer to the figures below for the sequence and the block diagram. A data transfer operation from the cell array to the Data Cache via Page Buffer starts on the rising edge of WE in the 30h command input cycle (after the address information has been latched). The device will be in the Busy state during this transfer period. After the transfer period, the device returns to Ready state. Serial data can be output synchronously with the RE clock from the start address designated in the address input cycle. Random Column Address Change in Read Cycle During the serial data output from the Data Cache, the column address can be changed by inputting a new column address using the 05h and E0h commands. The data is read out in serial starting at the new Revision 1.0 15 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) column address. Random Column Address Change operation can be done multiple times within the same page. Read Operation with Read Cache The device has a Read operation with Data Cache that enables the high speed read operation shown below. When the block address changes, this sequence has to be started from the beginning. If the 31h command is issued to the device, the data content of the next page is transferred to the Page Buffer during serial data out from the Data Cache, and therefore the tR (Data transfer from memory cell to data register) will be reduced. 1. Normal read. Data is transferred from Page N to Data Cache through Page Buffer. During this time period, the device outputs Busy state for tR max. 2. After the Ready/Busy returns to Ready, 31h command is issued and data is transferred to Data Cache from Page Buffer again. This data transfer takes tDCBSYR1 max and the completion of this time period can be detected by Ready/Busy signal. 3. Data of Page N + 1 is transferred to Page Buffer from cell while the data of Page N in Data cache can be read out by /RE clock simultaneously. 4. The 31h command makes data of Page N + 1 transfer to Data Cache from Page Buffer after the completion of the transfer from cell to Page Buffer. The device outputs Busy state for tDCBSYR1 max. This Busy period depends on the combination of the internal data transfer time from cell to Page buffer and the serial data out time. 5. Data of Page N + 2 is transferred to Page Buffer from cell while the data of Page N + 1 in Data cache can be read out by /RE clock simultaneously 6. The 3Fh command makes the data of Page N + 2 transfer to the Data Cache from the Page Buffer after the completion of the transfer from cell to Page Buffer. The device outputs Busy state for tDCBSYR1 max.. This Busy period depends on the combination of the internal data transfer time from cell to Page buffer and the serial data out time. 7. Data of Page N + 2 in Data Cache can be read out, but since the 3Fh command does not transfer the data from the memory cell to Page Buffer, the device can accept new command input immediately after the completion of serial data out. Revision 1.0 16 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Multi Page Read Operation (1) Multi Page Read without Data Cache The sequence of command and address input is shown below. Same page address (PA0 to PA5) within each district has to be selected. Revision 1.0 17 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) The data transfer operation from the cell array to the Data Cache via Page Buffer starts on the rising edge of WE in the 30h command input cycle (after the 2 Districts address information has been latched). The device will be in the Busy state during this transfer period. After the transfer period, the device returns to Ready state. Serial data can be output synchronously with the RE clock from the start address designated in the address input cycle. (2) Multi Page Read with Data Cache When the block address changes (increments) this sequenced has to be started from the beginning. The sequence of command and address input is shown below. Same page address (PA0 to PA5) within each district has to be selected. Revision 1.0 18 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Internal addressing in relation with the Districts: to use Multi Page Read operation, the internal addressing should be considered in relation with the District. • The device consists from 2 Districts. • Each District consists from 1024 erase blocks. • The allocation rule is follows. District 0: Block 0, Block 2, Block 4, Block 6,···, Block 2046 District 1: Block 1, Block 3, Block 5, Block 7,···, Block 2047 Address input restriction for the Multi Page Read operation: There are following restrictions in using Revision 1.0 19 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Multi Page Read, maximum one block should be selected from each District. Same page address (PA0 to PA5) within two districts has to be selected. For example, (60) [District 0, Page Address 0x00000] (60) [District 1, Page Address 0x00040] (30) (60) [District 0, Page Address 0x00001] (60) [District 1, Page Address 0x00041] (30) (Acceptance)There is no order limitation of the District for the address input. For example, following operation is accepted, (60) [District 0] (60) [District 1] (30) (60) [District 1] (60) [District 0] (30) Auto Page Program Operation The device carries out an Automatic Page Program operation when it receives a 10h Program command after the address and data have been input. The sequence of command, address and data input is shown below. The data is transferred (programmed) from the Data Cache via the Page Buffer to the selected page on the rising edge of WE following input of the 10h command. After programming, the programmed data is transferred back to the Page Buffer to be automatically verified by the device. If the programming does not Revision 1.0 20 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) succeed, the Program/Verify operation is repeated by the device until success is achieved or until the maximum loop number set in the device is reached. Random Column Address Change in Auto Page Program Operation The column address can be changed by the 85h command during the data input sequence of the Auto Page Program operation. Two address input cycles after the 85h command are recognized as a new column address for the data input. After the new data is input to the new column address, the 10h command initiates the actual data program into the selected page automatically. The Random Column Address Change operation can be repeated multiple times within the same page. Multi Page Program The device has a Multi Page Program, which enables even higher speed program operation compared to Auto Page Program. The sequence of command, address and data input is shown below. Although two planes are programmed simultaneously, pass/fail is not available for each page by 70h command when the program operation completes. Status bit of I/O 1 is set to 1 when any of the pages fails. Limitation in addressing with Multi Page Program is shown below. Revision 1.0 21 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Auto Page Program Operation with Data Cache The device has an Auto Page Program with Data Cache operation enabling the high speed program operation shown below. When the block address changes this sequenced has to be started from the beginning. Issuing the 15h command to the device after serial data input initiates the program operation with Data Cache. 1. Data for Page N is input to Data Cache. 2. Data is transferred to the Page Buffer by the 15h command. During the transfer the Ready/Busy outputs Busy State (tDCBSYW2). 3. Data is programmed to the selected page while the data for page N + 1 is input to the Data Cache. 4. By the 15h command, the data in the Data Cache is transferred to the Page Buffer after the programming of page N is completed. The device output busy state from the 15h command until the Data Cache becomes empty. The duration of this period depends on timing between the internal programming of page N and serial data input for Page N + 1 (tDCBSYW2). 5. Data for Page N + P is input to the Data Cache while the data of the Page N + P − 1 is being programmed. 6. The programming with Data Cache is terminated by the 10h command. When the device becomes Ready, it shows that the internal programming of the Page N + P is completed. Pass/fail status for each page programmed by the Auto Page Programming with Data Cache operation can be detected by the Status Read operation. I/O1 : Pass/fail of the current page program operation. I/O2 : Pass/fail of the previous page program operation. The Pass/Fail status on I/O1 and I/O2 are valid under the following conditions. Status on I/O1: Page Buffer Ready/Busy is Ready State. The Page Buffer Ready/Busy is output on I/O6 by Status Read operation or RY / BY pin after the 10h command. Status on I/O2: Data Cache Read/Busy is Ready State. The Data Cache Ready/Busy is output on I/O7 by Status Read operation or RY / BY pin after the 15h command. Revision 1.0 22 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Multi Page Program with Data Cache The device has a Multi-Page Program with Data Cache operation, which enables even higher speed program operation compared to Auto Page Program with Data Cache as shown below. When the block address changes (increments) this sequenced has to be started from the beginning. The data is transferred (programmed) from the page buffer to the selected page on the rising edge of WE# following input of the 15h or 10h command. After programming, the programmed data is transferred back to the register to be automatically verified by the device. If the programming does not succeed, the Program/Verify operation is repeated by the device until success is achieved or until the maximum loop number set in the device is reached. Revision 1.0 23 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Starting the above operation from 1st page of the selected erase blocks, and then repeating the operation total 64 times with incrementing the page address in the blocks, and then input the last page data of the blocks, 10h command executes final programming. Make sure to terminate with 81h-10hcommand sequence. After the 15h or 10h command, the results of the above operation is shown through the 71h Status Read command. The 71h command Status description is as below. Status Revision 1.0 Output 24 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Fail: 1 IO0 Chip Status1 : Pass/Fail Pass: 0 IO1 District 0 Chip Status1 : Pass/Fail Pass: 0 Fail: 1 IO2 District 1 Chip Status1 : Pass/Fail Pass: 0 Fail: 1 IO3 District 0 Chip Status2 : Pass/Fail Pass: 0 Fail: 1 IO4 District 1 Chip Status2 : Pass/Fail Pass: 0 Fail: 1 IO5 Ready/Busy Ready:1 Busy: 0 IO6 Data Cache Ready/Busy Ready:1 Busy: 0 IO7 Write Protect Protect: 0 Not Protect: 1 Page Copy (2) By using Page Copy (2), data in a page can be copied to another page after the data has been read out. When the block address changes (increments) this sequenced has to be started from the beginning. Page Copy (2) operation is as following. 1. Data for Page N is transferred to the Data Cache. 2. Data for Page N is read out. 3. Copy Page address M is input and if the data needs to be changed, changed data is input. 4. Data Cache for Page M is transferred to the Page Buffer. 5. After the Ready state, Data for Page N + P1 is output from the Data Cache while the data of Page M is being programmed. 6. Copy Page address (M + R1) is input and if the data needs to be changed, changed data is input. 7. After programming of page M is completed, Data Cache for Page M + R1 is transferred to the Page Buffer. 8. By the 15h command, the data in the Page Buffer is programmed to Page M + R1. Data for Page N + P2 is transferred to the Data cache. 9. The data in the Page Buffer is programmed to Page M + Rn − 1. Data for Page N + Pn is transferred to the Data Cache. 10. Copy Page address (M + Rn) is input and if the data needs to be changed, changed data is input. 11. By issuing the 10h command, the data in the Page Buffer is programmed to Page M + Rn. Revision 1.0 25 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Revision 1.0 26 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Multi Page Copy (2) By using Multi Page Copy (2), data in two pages can be copied to other pages after the data has been read out. When each block address changes (increments) this sequence has to be started from the beginning. Same page address (PA0 to PA5) within two districts has to be selected. Revision 1.0 27 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Auto Block Erase The Auto Block Erase operation starts on the rising edge of WE after the Erase Start command D0h which follows the Erase Setup command 60h. This two-cycle process for Erase operations acts as an extra layer of protection from accidental erasure of data due to external noise. The device automatically executes the Erase and Verify operations. Multi Block Erase The Multi Block Erase operation starts by selecting two block addresses before D0h command as in below diagram. The device automatically executes the Erase and Verify operations and the result can be monitored by checking the status by 71h status read command. ID Read The device contains ID codes which can be used to identify the device type, the manufacturer, and features of the device. The ID codes can be read out under the following timing conditions: Revision 1.0 28 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Code Table Description IO7 IO6 IO5 IO4 IO3 IO2 IO1 IO0 Hex Data 1st Data Maker Code 1 0 0 1 1 0 0 0 98h 2nd Data Device Code 1 0 1 0 1 1 0 0 ACh 3rd Data Chip Number, Cell Type 1 0 0 1 0 0 0 0 90h 4th Data Page Size, Block Size, I/O Width 0 0 1 0 0 1 1 0 26h 5th Data Plane Number 0 1 1 1 0 1 1 0 76h 3rd Table Description IO7 IO6 IO5 IO4 IO3 IO2 IO1 IO0 Internal Chip Number Cell Type 1 2 4 8 0 0 1 1 2 level cell 0 0 4 level cell 0 1 8 level cell 1 0 16 level cell 1 1 Reserved 1 0 0 0 1 0 1 1 4th Table Description IO7 IO6 IO5 IO4 IO3 IO2 IO1 IO0 Page Size (without redundant area) Block Size (without redundant area) I/O Width 1KB 2KB 4KB 8KB 0 0 1 1 64KB 0 0 128KB 0 1 256KB 1 0 512KB 1 1 x8 0 x16 1 Reserved Revision 1.0 0 29 0 0 1 0 1 1 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) 5th Table Description IO7 IO6 IO5 IO4 IO3 IO2 IO1 IO0 Plane Number 1Plane 0 0 2Plane 4Plane 8Plane 0 1 1 1 0 1 Reserved 0 1 1 1 1 0 Status Read The device automatically implements the execution and verification of the Program and Erase operations. The Status Read function is used to monitor the Ready/Busy status of the device, determine the result of a Program or Erase operation, and determine whether the device is in Protect mode. The device status is output via the I/O port using RE after a 70h command input. The Status Read can also be used during a Read operation to find out the Ready/Busy status. Definition Page Program Block Erase Cache Program Read Cache Read IO0 Chip Status1 Pass: 0 Fail: 1 Pass/Fail Pass/Fail Invalid IO1 Chip Status 2 Pass: 0 Fail: 1 Invalid Pass/Fail Invalid IO2 Not Used 0 0 0 IO3 Not Used 0 0 0 IO4 Not Used 0 0 0 IO5 Page Buffer Ready/Busy Ready: 1 Busy: 0 Ready/Busy Ready/Busy Ready/Busy IO6 Data Cache Ready/Busy Ready: 1 Busy: 0 Ready/Busy Ready/Busy Ready/Busy IO7 Write Protect Not Protected :1 Protected: 0 Write Protect Write Protect Write Protect Revision 1.0 30 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Reset The Reset mode stops all operations. For example, in case of a Program or Erase operation, the internally generated voltage is discharged to 0 volt and the device enters the Wait state. Reset during a Cache Program/Page Copy may not just stop the most recent page program but it may also stop the previous program to a page depending on when the FF reset is input. The response to a FFh Reset command input during the various device operations is as follows: When a Reset (FFh) command is input during programming Revision 1.0 31 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) When a Reset (FFh) command is input during erasing When a Reset (FFh) command is input during Read Operation When a Reset (FFh) command is input during Ready When a Status Read command (70h) is input after a Reset When two or more Reset commands are input in succession Revision 1.0 32 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Absolute Maximum Ratings Parameter Symbol Rating Vcc -0.6 to +2.5 VIN -0.6 to +2.5 VI/O -0.6 to Vcc+0.3( tCK Revision 1.0 66 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Notes: Burst read, RL=3, BL=8, tDQSCK < tCK tDQSCKDL Timing Notes: 1. tDQSCKDL=tDQSCKn – tDQSCKm 2. tDQSCKDLmax is defined as the maximum of ABS(tDQSCKn – tDQSCKm) for any {tDQSCKn - tDQSCKm} pair within any 32ms rolling windows. Revision 1.0 67 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) tDQSCKDM Timing Notes: 1. tDQSCKDM = tDQSCKn - tDQSCKm 2. tDQSCKDMmax is defined as the maximum of ABS(tDQSCKn – tDQSCKm) for any {tDQSCKn - tDQSCKm} pair within any 1.6us rolling windows. tDQSCKDS Timing Notes: 1. tDQSCKDS = tDQSCKn - tDQSCKm 2. tDQSCKDSmax is defined as the maximum of ABS(tDQSCKn – tDQSCKm) for any {tDQSCKn - tDQSCKm} pair for reads within a consecutive burst within any 160s rolling window. Revision 1.0 68 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) The minimum time from the burst READ command to the burst WRITE command is defined by the read latency (RL) and the burst length (BL). Minimum READ-to-WRITE latency is RL + RU(tDQSCK(MAX)/tCK) + BL/2 + 1 - WL clock cycles. Note that if a READ burst is truncated with a burst TERMINATE (BST) command, the effective burst length of the truncated READ burst should be used as BL to calculate the minimum READ-to-WRITE delay. Notes: Burst read followed by burst write, RL=3, WL=1, BL=4 Notes: Seamless burst read: RL=3, BL=4, tCCD=2 The minimum time from the burst READ command to the burst WRITE command is defined by the read latency (RL) and the burst length (BL). Minimum READ-to-WRITE latency is RL + RU(tDQSCK(MAX)/tCK) + BL/2 + 1 - WL clock cycles. Note that if a READ burst is truncated with a burst TERMINATE (BST) command, the effective burst length of the truncated READ burst should be used as BL to calculate the minimum READ-to-WRITE delay. The seamless burst READ operation is supported by enabling a READ command at every other clock cycle for BL = 4 operation, every fourth clock cycle for BL = 8 operation, and every eighth clock cycle for BL=16 operation. This operation is supported as long as the banks are activated, whether the accesses read the same or different banks. Revision 1.0 69 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Reads interrupted by a read For LPDDR2-S4 devices, burst read can be interrupted by another read on even clock cycles after the Read command, provided that tCCD is met. For LPDDR2-S2 devices, burst reads may be interrupted by other reads on any subsequent clock, provided that tCCD is met. Notes: Read can only be interrupted by other reads or the BST command. Burst Write The burst WRITE command is initiated with /CS LOW, CA0 HIGH, CA1 LOW, and CA2 LOW at the rising edge of the clock. The command address bus inputs, CA5r–CA6r and CA1f–CA9f, determine the starting column address for the burst. Write latency (WL) is defined from the rising edge of the clock on which the WRITE command is issued to the rising edge of the clock from which the tDQSS delay is measured. The first valid data must be driven WL × tCK + tDQSS from the rising edge of the clock from which the WRITE command is issued. The data strobe signal (DQS) must be driven LOW tWPRE prior to data input. The burst cycle data bits must be applied to the DQ pins tDS prior to the associated edge of the DQS and held valid until tDH after that edge. Burst data is sampled on successive edges of the DQS until the 4-, 8-, or 16-bit burst length is completed. After a burst WRITE operation, tWR must be satisfied before a PRECHARGE command to the same bank can be issued. Pin input timings are measured relative to the cross-point of DQS and its complement, /DQS. Revision 1.0 70 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Notes: 1. The minimum number of clock cycles from the burst write command to the burst read command for any bank is [WL + 1 + BL/2 + RU (tWTR / tCK) ]. 2. tWTR starts at the rising edge of the clock after the last valid input datum. 3. If a write burst is truncated with a Burst Terminate (BST) command, the effective burst length of the truncated write burst should be used as “BL” to calculate the minimum write to read delay. Revision 1.0 71 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Notes: The seamless burst write operation is supported by enabling a write command every other clock for BL=4 operation, every four clocks for BL=8 operation, or every eight clocks for BL=16 operation. This operation is allowed regardless of same or different banks as long as the banks are activated. Writes interrupted by a write For LPDDR2-S4 devices, burst write can only be interrupted by another write on even clock cycles after the Write command, provided that tCCD(min) is met. For LPDDR2-S2 devices, burst writes may be interrupted on any subsequent clock, provided that tCCD(min) is met. Notes: 1. WRITEs can only be interrupted by other WRITEs or the BST command. 2. The effective burst length of the first WRITE equals two times the number of clock cycles between the first WRITE and the interrupting WRITE. Revision 1.0 72 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Burst Terminate (BST) The BST command is initiated with /CS LOW, CA0 HIGH, CA1 HIGH, CA2 LOW, and CA3 LOW at the rising edge of the clock. A BST command can only be issued to terminate an active READ or WRITE burst. Therefore, a BST command can only be issued up to and including BL/2 - 1 clock cycles after a READ or WRITE command. The effective burst length of a READ or WRITE command truncated by a BST command is as follows: 1. Effective burst length = 2 × (number of clock cycles from the READ or WRITE command to the BST command). 2. If a READ or WRITE burst is truncated with a BST command, to calculate the minimum READ-to-WRITE or WRITE-to-READ delay, the effective burst length of the truncated burst should be used as the value for BL. 3. The BST command only affects the most recent READ or WRITE command. The BST command truncates an ongoing READ burst RL × tCK + tDQSCK + tDQSQ after the rising edge of the clock where the BST command is issued. The BST command truncates an on-going write burst WL × tCK + tDQSS after the rising edge of the clock where the BST command is issued. 4. For LPDDR2-S4 devices, the 4-bit prefetch architecture enables BST command assertion on even clock cycles following a WRITE or READ command. The effective burst length of a READ or WRITE command truncated by a BST command is thus an integer multiple of 4. 5. For LPDDR2-S2 devices, the 2-bit prefetch architecture enables BST command assertion in any cycle after a WRITE or READ command. Notes: 1. The BST command truncates an ongoing write burst WL * tCK + tDQSS after the rising edge of the clock where the Burst Terminate command is issued. 2. For LPDDR2-S4 devices, BST can only be issued an even number of clock cycles after the Write command. 3. Additional BST commands are not allowed after T4, and may not be issued until after the next Read or Write command. Revision 1.0 73 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Notes: 1. The BST command truncates an ongoing read burst RL * tCK + tDQSCK + tDQSQ after the rising edge of the clock where the Burst Terminate command is issued. 2. For LPDDR2-S4 devices, BST can only be issued an even number of clock cycles after the Read command. 3. Additional BST commands are not allowed after T4, and may not be issued until after the next Read or Write command. Write Data Mask One write data mask (DM) pin for each data byte (DQ) will be supported on LPDDR2 devices, consistent with the implementation on LPDDR SDRAMs. Each data mask (DM) may mask its respective data byte (DQ) for any given cycle of the burst. Data mask has identical timings on write operations as the data bits, though used as input only, is internally loaded identically to data bits to insure matched system timing. Revision 1.0 74 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Precharge The Precharge command is used to precharge or close a bank that has been activated. The Precharge command is initiated by having CS_n LOW, CA0 HIGH, CA1 HIGH, CA2 LOW, and CA3 HIGH at the rising edge of the clock. The Precharge Command can be used to precharge each bank independently or all banks simultaneously. For 4-bank devices, the AB flag, and the bank address bits, BA0 and BA1, are used to determine which bank(s) to precharge. For 8-bank devices, the AB flag, and the bank address bits, BA0, BA1, and BA2, are used to determine which bank(s) to precharge. The bank(s) will be available for a subsequent row access tRPab after an All-Bank Precharge command is issued and tRPpb after a Single-Bank Precharge command is issued. In order to ensure that 8-bank devices do not exceed the instantaneous current supplying capability of 4-bank devices, the Row Precharge time (tRP) for an All-Bank Precharge for 8-bank devices (tRPab) will be longer than the Row Precharge time for a Single-Bank Precharge (tRPpb). For 4-bank devices, the Row Precharge time (tRP) for an All-Bank Precharge (tRPab) is equal to the Row Precharge time for a Single-Bank Precharge (tRPpb). Revision 1.0 75 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) AB (CA4R) BA2(CA9R) BA1(CA8R) BA0(CA7R) Precharged Bank(s) 8-bank 0 0 0 0 Bank 0 only 0 0 0 1 Bank 1 only 0 0 1 0 Bank 2 only 0 0 1 1 Bank 3 only 0 1 0 0 Bank 4 only 0 1 0 1 Bank 5 only 0 1 1 0 Bank 6 only 0 1 1 1 Bank 7 only 1 don't care don't care don't care All Banks Burst Read operation followed by Precharge For the earliest possible precharge, the precharge command may be issued BL/2 clock cycles after a Read command. A new bank active (command) may be issued to the same bank after the Row Precharge time (tRP). A precharge command can not be issued until after tRAS is satisfied. For LPDDR2-S4 devices, the minimum Read to Precharge spacing has also to satisfy a minimum analog time from the rising cloak edge that initiates the last 4-bit precharge of a Read command. For LPDDR2-S2 devices, the minimum Read to Precharge spacing has also to satisfy a minimum analog time from the rising clock edge that initiates the last 2-bit prefetch of a Read command. This time is called tRTP (Read to Precharge). For LPDDR2-S2 devices, tRTP begins BL/2 – 1 clock after the Read command. For LPDDR2-S4 devices, tRTP begins BL/2 – 2 clock cycles after the Read command. If the burst is truncated by a BST command, the effective “BL” ahsll be used to calculate when tRTP begins. Revision 1.0 76 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Burst Write operation followed by Precharge For write cycles, a delay must be satisfied from the time of the last valid burst input data until the Precharge command may be issued. This delay is known as the write recovery time (tWR) referenced from the completion of the burst write to the Precharge command. No Precharge command to the same bank should be issued prior to the tWR delay. LPDDR2-S2 devices write data to the array in prefetch pairs (prefetch = 2) and LPDDR2-S4 devices write data to the array in prefetch quadruples (prefetch = 4). The beginning of an internal write operation may only begin after a prefetch group has been completely. Therefore, the write recovery time (tWR) starts different boundaries for LPDDR2-S2 and LPDDR2-S4 devices. For LPDDR2-S2 devices, minimum Write to Precharge command spacing to the same bank is WL + RU(BL/2) + 1 + RU(tWR/tCK) clock cycles. For LPDDR2-S4 devices, minimum Write to Precharge command spacing to the same bank is WL + BL/2 + 1+ RU (tWR/tCK) clock cycles. For an untruncated burst, BL is the value from the Mode Register. For a truncated burst, BL is the effective burst length. Revision 1.0 77 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Auto Precharge Before a new row in an active bank can be opened, the active bank must be precharged using either the Precharge command or the auto-precharge function. When a Read or a Write command is given to the LPDDR2 SDRAM, the AP bit (CA0f) may be set to allow the active bank to automatically begin precharge at the earliest possible moment during the burst read or write cycle. If AP is LOW when the Read or Write command is issued, the normal Read or Write burst operation is executed and the bank remains active at the completion of the burst. If AP is HIGH when the Read or Write command is issued, then the auto-precharge function is engaged. This feature allows the precharge operation to be partially or completely hidden during burst read cycles (dependent upon Read or Write latency) thus improving system performance for random data access. Burst Read with Auto-Precharge If AP (CA0f) is HIGH when a Read Command is issued, the Read with Auto-Precharge function is engaged. LPDDR2-S2 devices start an Auto-Precharge operation on the rising edge of the clock BL/2 – 1 + RU(tRTP/tCK) clock cycles later than the Read with AP command. LPDDR2-S4 devices start an Auto-Precharge operation on the rising edge of the clock BL/2 or BL/2 – 2 + RU(tRTP/tCK) clock cycles later than the Read with AP command, whichever is greater. A new bank Activate command may be issued to the same bank if both of the following two conditions are satisfied simultaneously: 1. The RAS precharge time (tRP) has been satisfied from the clock at which the auto-precharge begins. 2. The RAS cycle time (tRC) from the previous bank activation has been satisfied. Burst Write with Auto-Precharge If AP (CA0f) is HIGH when a Write Command is issued, the Write with Auto-Precharge function is engaged. The LPDDR2 SDRAM starts an Auto-precharge operation on the rising edge which is tWR cycles after the completion of the burst write. A new bank Activate command may be issued to the same bank if both of the following two conditions are satisfied: 1. The RAS precharge time (tRP) has been satisfied from the clock at which the auto-precharge begins. Revision 1.0 78 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) 2. The RAS cycle time (tRC) from the previous bank activation has been satisfied. Precharge & Auto Precharge clarification From Command Read BST (for Reads) Read w/AP Write BST (for Writes) To Command Minimum Delay between "From Command" to "To Command" Precharge (to same Bank as Read) BL/2 + max(2, RU(tRTP/tCK)) - 2 clks 1 Precharge All BL/2 + max(2, RU(tRTP/tCK)) - 2 clks 1 Precharge (to same Bank as Read) 1 clks 1 Precharge All 1 clks 1 Precharge (to same Bank as Read w/AP) BL/2 + max(2, RU(tRTP/tCK)) - 2 clks 1,2 Precharge All BL/2 + max(2, RU(tRTP/tCK)) - 2 clks 1 Activate (to same Bank as Read w/AP) BL/2 + max(2, RU( RTP/ CK)) - 2 + RU(tRPpb/tCK) clks 1 Write or Write w/AP (same bank) illegal clks 3 Write or Write w/AP (different bank) RL + BL/2 + RU(tDQSCKmax/tCK) - WL + 1 clks 3 Read or Read w/AP (same bank) illegal clks 3 Read or Read w/AP (different bank) BL/2 clks 3 Precharge (to same Bank as Write) WL + BL/2 + RU(tWR/tCK) + 1 clks 1 Precharge All WL + BL/2 + RU(tWR/tCK) + 1 clks 1 Precharge (to same Bank as Write) WL + RU(tWR/tCK) + 1 clks 1 Precharge All WL + RU(tWR/tCK) + 1 clks 1 Precharge (to same Bank as Write w/AP) WL + BL/2 + RU(tWR/tCK) + 1 clks 1 Precharge All WL + BL/2 + RU(tWR/tCK) + 1 clks 1 Activate (to same Bank as Write w/AP) WL + BL/2 + RU(tWR/tCK) + 1 + RU(tRP /tCK) clks 1 Write w/AP Precharge Precharge All Unit Notes pb Write or Write w/AP (same bank) illegal clks 3 Write or Write w/AP (different bank) BL/2 clks 3 Read or Read w/AP (same bank) illegal clks 3 Read or Read w/AP (different bank) WL + BL/2 + RU(tWTR/tCK) + 1 clks 3 Precharge (to same Bank as Precharge) 1 clks 1 Precharge All 1 clks 1 Precharge Precharge All 1 1 clks clks 1 1 Notes: 1. For a given bank, the precharge period should be counted from the latest precharge command, either one bank precharge or precharge all, issued to that bank. The precharge period is satisfied after tRP depending on the latest precharge command Revision 1.0 79 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) issued to that bank. 2. Any command issued during the minimum delay time as specified above table is illegal. 3. After read with AP, seamless read operations to different banks are supported. After write with AP, seamless write operations to different banks are supported. Read w/AP and Write a/AP may not be interrupted or truncated. Refresh Command The Refresh Command is initiated by having CS_n LOW, CA0 LOW, CA1 LOW, and CA2 HIGH at the rising edge of clock. Per Bank Refresh is initiated by having CA3 LOW at the rising edge of the clock and All Bank Refresh is initiated by having CA3 HIGH at the rising edge of clock. Per Bank Refresh is only allowed in devices with 8 banks. A Per Bank Refresh Command, REFpb performs a refresh operation to the bank which is scheduled by the bank counter in the memory device. The bank sequence of Per Bank Refresh is fixed to be a sequential round-robin: “0-1-2-3-4-5-6-7-0-1-…”. The bank count is synchronized between the controller and the SDRAM upon issuing a RESET command or at every exit from self refresh, by resetting bank count to zero. The bank addressing for the Per Bank Refresh count is the same as established in the single-bank Precharge command. A bank must be idle before it can be refreshed. It is the responsibility of the controller to track the bank being refreshed by the Per Bank Refresh command. The REFpb command may not be issued to the memory until the following conditions are met: 1. tRFCab has been satisfied after the prior REFab command. 2. tRFCpb has been satisfied after the prior REFpb command. 3. tRP has been satisfied after the prior Precharge command to that given bank. tRRD has been satisfied after the prior ACTIVATE command (if applicable, for example after activating a row in a different bank than affected by the REFpb command. The target bank is inaccessible during the Per Bank Refresh cycle (tRFCpb), however other banks within the device are accessible and may be addressed during the Per Bank Refresh cycle. During the REFpb operation, any of the banks other than the one being refreshed can be maintained in active state or accessed by a read or a write command. When the Per Bank Refresh cycle has completed, the affected bank will be in the idle state. As shown in the table, after issuing REFpb: 1. tRFCpb must be satisfied before issuing a REFab command. 2. tRFCpb must be satisfied before issuing an ACTIVE command to a same bank. 3. tRRD must be satisfied before issuing an ACTIVE command to a different bank. 4. tRFCpb must be satisfied before issuing another REFpb command. An all Bank Refresh command, REFab performs a refresh operation to all banks. All banks have to be in idle state when REFab is issued (for instance, by Precharge All Bank command). REFab also synchronizes the bank count between the controller and the SDRAM to zero. As shown in the table, the REFab command Revision 1.0 80 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) may not be issued to the memory until the following conditions have been met: 1. tRFCab has been satisfied after the prior REFab command. 2. tRFCpb has been satisfied after the prior REFpb command. 3. tRP has been satisfied after the prior Precharge commands. When the All Bank Refresh cycle has completed, all banks will be in the idle state. As shown in the table, after issuing REFab: 1. the tRFCab latency must be satisfied before issuing an ACTIVATE command. 2. the tRFCab latency must be satisfied before issuing a REFab or REFpb command. Symbol minimum delay from tRFCab REFab tRFCab REFpb REFpb tRRD Activate to REFab Activate cmd to any bank . REFpb REFab Activate cmd to same bank as REFpb REFpb Activate cmd to different bank than REFpb REFpb affecting an idle bank (different bank than Activate) Activate cmd to different bank than prior Activate Notes 1 Notes: 1. A bank must be in the idle state before it is refreshed. Therefore, after Activate, REFab is not allowed and REFpb is allowed only if it affects a bank which is in the idle state. Refresh Requirements 1. Minimum number of Refresh commands: LPDDR2 requires a minimum number, R, of REFRESH (REFab) commands within any rolling refresh window (tREFW = 32 ms @ MR4[2:0] = 011 or TC ≤ 85°C). For actual values per density, and the resulting average refresh interval (tREFI). For devices supporting per-bank REFRESH, a REFab command can be replaced by a full cycle of eight REFpb commands. 2. Burst Refresh limitation: To limit maximum current consumption, a maximum of REFab commands may be issued in any rolling tREFBW (tREFBW = 4 x 8 x tRFCab). This condition does not apply if REFpb commands are used. 3. Refresh Requirements and Self-Refresh: If any time within a refresh window is spent in Self-Refresh Mode, the number of required Refresh commands in this particular window is reduced to: R* = R - RU{tSRF / tREFI} = R - RU{R * tSRF / tREFW}; where RU stands for the round-up function 4. Minimum number of Refresh commands: LPDDR2 requires a minimum number, R, of REFRESH (REFab) Revision 1.0 81 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Notes: 1. Time in self refresh mode is fully enclosed in the refresh window (tREF). 2. At self-refresh entry. 3. At self-refresh exit. 4. Several intervals in self refresh during one tREFW interval. In this example, tSRF = tSRF1 + tSRF2. Notes: All bank refresh operation Revision 1.0 82 APR 2017 MKM04EL04TD2-TN NAND 4G(x8) / LPDDR2 4G(x32) Notes: 1. In the beginning of this example, the REFpb bank is pointing to Bank0. 2. Operations to other banks than the bank being refreshed are allowed during the tREFpb period. LPDDR2-S4 devices allow significant flexibility in scheduling REFRESH commands, as long as the boundary conditions above are met. In the most straight forward case a REFRESH command should be scheduled every tREFI. In this case Self-Refresh may be entered at any time. The users may choose to deviate from this regular refresh pattern e.g., to enable a period where no refreshes are required. In the extreme the user may choose to issue a refresh burst of 4096 REFRESH commands with the maximum allowable rate (limited by tREFBW) followed by a long time without any REFRESH commands, until the refresh window is complete, then repeating this sequence. The achieveable time without REFRESH commands is given by tREFW - (R / 8) * tREFBW = tREFW - R * 4 * tRFCab. Tj
MKM04EL04TD2-TN 价格&库存
很抱歉,暂时无法提供与“MKM04EL04TD2-TN”相匹配的价格&库存,您可以联系我们找货
