MKEV008GCB-SS510
MKEV008GCB-SS510
    MK(米客方德)
    FBGA-153(11.5x13)
    存储器类型:eMMC 存储器构架(格式):MLC 技术:BCH纠错算法 存储器容量:8Gb 时钟频率:HS200,HS400 存储器接口类型:eMMC5.1 8GByte eMMC5.1,MLC,1...
MKEV008GCB-SS510 数据手册
eMMC 8GB MKEV008GCB-SS510 Specification V1.0 Aug 13th, 2019 MKEV008GCB-SS510 Contents 1. Foreword ......................................................................................................... 6 2. Revision History ................................................................................................ 7 3. Statement of Scope ........................................................................................... 8 4. General Description ........................................................................................... 9 4.1. Product list ............................................................................................. 9 4.2. Feature .................................................................................................. 9 5. eMMC Function Block Diagram .......................................................................... 11 6. Pin Description ............................................................................................... 12 7. 8. 6.1. eMMC 153 Ball Pin Assignment ................................................................ 12 6.2. eMMC Pin Description ............................................................................. 13 Electrical Characteristics .................................................................................. 14 7.1. General operating conditions ................................................................... 14 7.2. Device Power Diagram............................................................................ 14 7.3. Power supply voltage ............................................................................. 15 7.4. Bus Signal Line Loading .......................................................................... 15 7.5. Bus Signal Level .................................................................................... 16 7.6. Bus Timing for eMMC in backward-compatible device and high speed mode ... 17 7.7. Bus Timing for eMMC in DDR Mode........................................................... 19 7.8. Bus Timing for eMMC in HS200 Mode........................................................ 21 7.9. Bus Timing for eMMC in HS400 Mode........................................................ 22 eMMC Register Description ............................................................................... 25 8.1. Operation Conditions Register (OCR) Register ............................................ 25 2 / 44 MKEV008GCB-SS510 9. 8.2. SD Card Identification Register (CID) ....................................................... 26 8.3. Driver Stage Register (DSR) .................................................................... 26 8.4. Relative Card Address Register (RCA) ....................................................... 26 8.5. Card Specific Data Register (CSD) ............................................................ 26 8.6. Extended CSD register ........................................................................... 28 Production Specifications.................................................................................. 39 9.1. Performance ......................................................................................... 39 9.2. Power Consumption ............................................................................... 39 9.3. Endurance Test...................................................................................... 40 9.3.1 Bit Test………………………………………………………………………………………………………..40 9.3.2 Junior Test……………………………………………………………………………………………………40 10. Package Dimension ......................................................................................... 41 11. MKEV008GCB-SS510 Compatibility List .............................................................. 42 12. MKEV008GCB-SS510 Partition Configuration………………………………………………………………..44 3 / 44 MKEV008GCB-SS510 List of Figures FIGURE 5-1 EMMC FUNCTION BLOCK DIAGRAM ......................................................... 11 FIGURE 6-1 EMMC 153 BALL PIN ASSIGNMENT (TOP VIEW) ........................................ 12 FIGURE 7-1 DEVICE POWER DIAGRAM ..................................................................... 14 FIGURE 7-2 BUS SIGNAL LEVEL .............................................................................. 16 FIGURE 7-3 TIMING DIAGRAM DATA INPUT/OUTPUT REFERENCED TO CLOCK (EMMC IN BACKWARD-COMPATIBLE DEVICE AND HIGH SPEED) ......................................... 17 FIGURE 7-4 TIMING DIAGRAM DATA INPUT/OUTPUT REFERENCED TO CLOCK (DDR MODE)…………………………………………….………………………………………………………….19 FIGURE 7-5 TIMING DIAGRAM DATA INPUT REFERENCED TO CLOCK (HS200 MODE) .... 21 FIGURE 7-6 TIMING DIAGRAM DATA OUTPUT REFERENCED TO CLOCK (HS200 MODE) . 21 FIGURE 7-7 TIMING DIAGRAM DATA INPUT REFERENCED TO CLOCK (HS400 MODE) .... 22 FIGURE 7-8 TIMING DIAGRAM DATA OUTPUT REFERENCED TO CLOCK (HS400 MODE) . 23 FIGURE 10-1 PACKAGE OUTLINE DIMENSION DRAWING............................................. 41 4 / 44 MKEV008GCB-SS510 List of Table TABLE 4-1 EMMC PRODUCT LIST ............................................................................... 9 TABLE 6-1 EMMC PIN DESCRIPTION ........................................................................ 13 TABLE 7-1 GENERAL OPERATING CONDITIONS ......................................................... 14 TABLE 7-2 POWER SUPPLY VOLTAGE ........................................................................ 15 TABLE 7-3 BUS SIGNAL LINE LOADING ................................................................... 15 TABLE 7-4 BUS SIGNAL LINE LOADING FOR HS400 .................................................. 16 TABLE 7-5 BUS SIGNAL LEVEL ................................................................................ 17 TABLE 7-6 BACKWARD-COMPATIBLE DEVICE MODE TIMING FOR EMMC....................... 18 TABLE 7-7 HIGH SPEED MODE TIMING FOR EMMC .................................................... 18 TABLE 7-8 DDR MODE TIMING FOR EMMC ................................................................ 20 TABLE 7-9 HS200 MODE TIMING FOR EMMC ............................................................ 22 TABLE 7-10 HS400 MODE TIMING FOR EMMC ........................................................... 23 TABLE 8-1 EMMC REGISTER TABLE .......................................................................... 25 TABLE 8-2 OCR TABLE ........................................................................................... 25 TABLE 8-3 CID TABLE ............................................................................................ 26 TABLE 8-4 CSD TABLE ........................................................................................... 27 TABLE 8-5 EXTEND CSD TABLE ............................................................................... 28 TABLE 9-1 MKEV008GCB-SS510 PERFORMANCE ....................................................... 39 TABLE 9-2 MKEV008GCB-SS510 OPERATING CURRENT.............................................. 39 TABLE 9-3 MKEV008GCB-SS510 STANDBY/SLEEP CURRENT ....................................... 39 TABLE 9-4 MKEV008GCB-SS510 BIT TEST ............................................................... 40 TABLE 9-5 MKEV008GCB-SS510 JUNIOR TEST .......................................................... 40 TABLE 11-1 MKEV008GCB-SS510 COMPATIBILITY LIST………………………………………………….……42 TABLE 12-1 MKEV008GCB-SS510 PARTITION CONFIGURARION TABLE……………………....…..47 5 / 44 MKEV008GCB-SS510 1. Foreword This document has been produced by MKEV008GCB-SS510, should the company modifies the contents of this specification, it will be re-released with an identifying change of release date and an increase in revision number as follows: Revision mn.xy, where:  mn the first two digit are incremented for major changes of substance, e.g., functional changes.  xy the second two digits are incremented when minor changes have been incorporated into the specification, i.e., enhancements, corrections, updates, etc. Top page 6 / 44 MKEV008GCB-SS510 2. Revision History Revision Date 1.0 2019/8/13 Modified By Ian Lin Description Initial release Top page 7 / 44 MKEV008GCB-SS510 3. Statement of Scope This Datasheet document is described the eMMC MKEV008GCB-SS510 of methods and abstractions of reliability. The contents include the concept and measurement methodologies. Top page 8 / 44 MKEV008GCB-SS510 4. General Description MKEV008GCB-SS510 is the eMMC Technology of product, which is an embedded non-volatile memory system package into BGA. It has high performance, low power consumption features and supports eMMC4.5, eMMC5.01 and eMMC5.1 specifications. 4.1 Product list Capacities Part Number Flash Type Package Size (mm) 8GB MKEV008GCB-SS510 64Gb MLCx1 11.5x13x1.0 Package Type 153FBGA Table 5.1 eMMC product list Top page 4.2 Feature HS200 Bus Speed Mode   The HS200 mode has the following features - SDR Data sampling method - CLK frequency up to 200 MHz Data rate – up to 200 MB/s - 4 or 8-bits bus width supported - Signaling levels of 1.8 V - Tuning concept for Read Operations Device type values (EXT_CSD Register : DEVICE_TYPE [196]) Bit Device Type Supportability 7 HS400 Dual Data Rate e•MMC @ 200 MHz - 1.2V I/O Not support 6 HS400 Dual Data Rate e•MMC @ 200 MHz - 1.8V I/O Not support 5 HS200 Single Data Rate e•MMC @ 200 MHz - 1.2V I/O Not support 4 HS200 Single Data Rate e•MMC @ 200 MHz - 1.8V I/O Support 3 High-Speed Dual Data Rate e•MMC @ 52MHz - 1.2V I/O 2 High-Speed Dual Data Rate e•MMC @ 52MHz - 1.8V or 3V I/O 9 / 44 Not support Support MKEV008GCB-SS510 1 High-Speed e•MMC @ 52MHz - at rated device voltage(s) Support 0 High-Speed e•MMC @ 26MHz - at rated device voltage(s) Support Note:It is being discussed in JEDEC and is not confirmed yet. It can be modified according to JEDEC standard in the future.  Extended CSD revisions (EXT_CSD Register : EXT_CSD_REV [192]) Value 255–9 Timing Interface EXT_CSD Register Value Reserved - 8 Revision 1.8 (for MMC v5.1) - 7 Revision 1.7 (for MMC V5.0) 0x07h 6 Revision 1.6 (for MMC V4.5, V4.51) - 5 Revision 1.5 (for MMC V4.41) - 4 Revision 1.4 (Obsolete) - 3 Revision 1.3 (for MMC V4.3) - 2 Revision 1.2 (for MMC V4.2) - 1 Revision 1.1 (for MMC V4.1) - 0 Revision 1.0 (for MMC V4.0) - Note:Current e•MMC standard defined by JEDEC supports up to 0x07 for EXT_CSD_REV value.  High Speed timing values (EXT_CSD Register: HS_TIMING [185]) Value Timing Interface Supportability 0x0 Selecting backwards compatibility interface timing Support 0x1 High Speed Support 0x2 HS200 Support 0x3 HS400 Not Support Top page 10 / 44 MKEV008GCB-SS510 6. Pin Description 6.1 eMMC 153 Ball Pin Assignment Figure 6-1 eMMC 153 ball pin assignment (Top view) Ball No. Name Ball No. Name Ball No. Name Ball No. Name A3 DAT0 C2 VDDi J5 VSS N4 VCCQ A4 DAT1 C4 VSSQ J10 VCC N5 VSSQ A5 DAT2 C6 VCCQ K5 RST_n P3 VCCQ A6 VSS E6 VCC K8 VSS P4 VSSQ B2 DAT3 E7 VSS K9 VCC P5 VCCQ B3 DAT4 F5 VCC M4 VCCQ P6 VSSQ B4 DAT5 G5 VSS M5 CMD -- -- B5 DAT6 H5 DS M6 CLK -- -- B6 DAT7 H10 VSS N2 VSSQ -- -- Note: NC: No Connect, can be connected to ground or left floating. 11 / 44 MKEV008GCB-SS510 RFU: Reserved for Future Use, should be left floating for future use. VSF: Vendor Specific Function, shall be left floating. 6.2 eMMC Pin Description Signal Ball No. CLOCK (CLK) M6 Description Each cycle of the clock directs a transfer on the command line and on the data lines. This signal is a bidirectional command channel used for device COMMAND (CMD) initialization and command transfer. M5 The CMD Signal has 2 operation modes: open drain for initialization, and push-pull for fast command transfer. DATA (DAT0-DAT7) A3~A5 These are bidirectional data channels. The DAT signals operate in B2~B6 push-pull mode. RST_n K5 Hardware Reset Input DS H5 Data Strobe: Return Clock signal used in HS400 mode Power supply for MMC interface and Controller, have two power VCCQ C6,M4,N4,P3,P5 mode: High power mode:2.7V~3.6V; Lower power mode:1.7V~1.95V VCC E6,F5,J10,K9 VDDi C2 VSS,VSSQ Power supply for NAND flash memory, its power voltage range is: 2.7V~3.6V VDDi is internal power mode. Connect 0.1uF or 2.2uF capacitor from VDDi to ground A6, E7, G5, H10, J5, J8,C4,N2,P4,P6 Ground lines Note:All other pins are not connected [NC] and can be connected to GND or left floating. Table 6-1 eMMC Pin Description Top page 12 / 44 MKEV008GCB-SS510 7. DC Electrical Characteristics 7.1 General operating conditions 8 Parameter Peak voltage on all lines Symbol Min Max Unit Remarks -- -0.5 VCCQ+0.5 V -- -- -100 100 uA -- -- -2 2 uA -- -- -100 100 uA -- -- -2 2 uA -- All Inputs Input Leakage Current (before initialization sequence and/or the internal pull up resistors connected) Input Leakage Current (after initialization sequence and the internal pull up resistors disconnected) All Outputs Output Leakage Current (before initialization sequence) Output Leakage Current (after initialization sequence) Note:Initialization sequence is defined in Power-Up chapter of JEDEC/MMCA Standard. Table 7-1 General Operating Conditions Top page 13 / 44 MKEV008GCB-SS510 7.2  Operating Current (RMS) Active Power Consumption during operation Capacity NAND Type 8 GB 64Gb x 1 Icc Iccq (Max) (Max) Read 50 150 mA Write 50 100 mA Operation Unit Note: - Power measurement conditions: Bus configuration =x8 @200MHz DDR - Max RMS current is the average RMS current consumption over a period of 100ms. - Temperature: 25℃ - VCC=3.3V, VCCQ=1.8V - Not 100% tested Figure 7-2 Operating Current Top page 7.3 Power supply voltage Parameter Supply voltage1 Symbol Test Conditions VCC -- VCCQ -- Min Max Unit 2.7 3.6 V 1.7 1.95 V 2.7 3.6 V (NAND/Core) Supply voltage 2 (CTRL/IO) Table 7-2 Power Supply Voltage Top page 14 / 44 MKEV008GCB-SS510 7.4  Standby Power Consumption Standby Power Consumption in auto power saving mode and standby state Capacity 8 GB NAND Type 64Gb x 1 State Icc Iccq Unit 25℃ 85℃ 25℃ 85℃ 50 150 150 600 uA 50 150 150 600 uA Standby Note: - Power measurement conditions: Bus configuration =x8, No CLK - VCC=3.3V, VCCQ=1.8V - Not 100% tested 7.5  Sleep Power Consumption Sleep Power Consumption in Sleep State Capacity 8 GB NAND Type 64Gb x 1 State Sleep Icc Iccq Unit 25℃ 85℃ 25℃ 85℃ 0 0 150 600 uA 0 0 150 600 uA Note: - Power measurement conditions: Bus configuration = x8, No CLK - Enter sleep state by CMD5, VCC power is switched off, VCCQ=1.8V - Not 100% tested 15 / 44 MKEV008GCB-SS510 7.6 Bus Signal Line Loading The total capacitance CL of each line of the e•MMC bus is the sum of the bus master capacitance CHOST, the bus capacitance CBUS itself and the capacitance CDEVICE of the e•MMC connected to this line: CL = CHOST + CBUS + CDEVICE The sum of the host and bus capacitances should be under 20pF.  Bus Signal Line Load Parameter Symb ol Min Typ. Max Unit Remark Pull-up resistance for CMD RCMD 4.7 -- 100 kΩ to prevent bus floating Pull-up resistance for DAT0–7 RDAT 10 -- 100 kΩ to prevent bus floating Rint 10 -- 150 kΩ Bus signal line capacitance CL -- -- 30 pF Single Device Single Device capacitance CDEVICE -- -- 12 pF Single Device capacitance -- -- -- 16 nH fPP ≤ 52 MHz Internal pull up resistance DAT1–DAT7 Maximum signal line inductance Table 7-6 Bus Signal Line Loading Top page 16 / 44 to prevent unconnected lines floating MKEV008GCB-SS510 8. eMMC Register Description Software designers should refer to the particular implementation to do the programming. This section introduces the registers in eMMC and the values that are used in MKEV008GCB-SS510. The following table is the register list of current specification. The detail functionality is not described here; please reference to latest eMMC specifications. Top page 8.1 Operation Conditions Register (OCR) Register The 32-bit operation conditions register (OCR) stores the VDD voltage profile of the Device and the access mode indication. In addition, this register includes a status information bit. This status bit is set if the Device power up procedure has been finished. The OCR register shall be implemented by all Devices. OCR bit VCCQ voltage window e•MMC [6:0] Reserved 000 0000b [7] 1.7–1.95 1b [14:8] 2.0–2.6 000 0000b [23:15] 2.7–3.6 1 1111 1111b [28:24] Reserved 000 0000b [30:29] Access Mode [31] 00b (byte mode) 10b (sector mode) Card power up status bit (busy)* Note*:This bit is set to LOW if the e•MMC has not finished the power up routine. The supported voltage range is coded as shown in table. Table 8-1 OCR Table Top page 17 / 44 MKEV008GCB-SS510 8.2 SD Card Identification Register (CID) The Device IDentification (CID) register is 128 bits wide. It contains the Device identification information used during the Device identification phase (e•MMC protocol). Every individual flash or I/O Device shall have a unique identification number. Every type of e•MMC Device shall have a unique identification number. Table 75 lists these identifiers. The structure of the CID register is defined in this section. Name Field Width CID-slice CID Value Manufacturer ID MID 8 [127:120] EAh Reserved - 6 [119:114] 0h Card/BGA CBX 2 [113:112] 01h OEM/Application ID OID 8 [111:104] 0Eh Product name PNM 48 [103:56] Product revision PRV 8 [55:48] 10h Product serial number PSN 32 [47:16] Serial number Manufacturing date MDT 8 [15:8] Manufacturing date CRC7 checksum CRC 7 [7:1] CRC7 Not used, always ‘1’ - 1 [0:0] 1h 53 50 65 4D 4D 43 (SPeMMC) Table 8-3 CID Table Top page 8.3 Driver Stage Register (DSR) The 16-bit driver stage register (DSR) is optionally used to improve the bus performance for extended operating conditions. The CSD register carries the information about the DSR register usage. The default value of the DSR register is 0x404. Top page 8.4 Relative Card Address Register (RCA) The writable 16-bit relative Device address (RCA) register carries the Device address assigned 18 / 44 MKEV008GCB-SS510 by the host during the Device identification. This address is used for the addressed host-Device communication after the Device identification procedure. The default value of the RCA register is 0x0001. The value 0x0000 is reserved to set all Devices into the Stand-by State with CMD7. Top page 8.5 Card Specific Data Register (CSD) The Card-Specific Data register provides information on how to access the e•MMC contents. The CSD defines the data format, error correction type, maximum data access time, data transfer speed, whether the DSR register can be used etc. The programmable part of the register (entries marked by W or E, see below) can be changed by CMD27. The type of the entries in the table below is coded as follows: 9 R: Read only 10 W: One time programmable and not readable. 11 R/W: One time programmable and readable. 12 W/E: Multiple writable with value kept after power failure, H/W reset assertion and any CMD0 reset and not readable. 13 R/W/E: Multiple writable with value kept after power failure, H/W reset assertion and any CMD0 reset and readable. 14 R/W/C_P: Writable after value cleared by power failure and HW/ rest assertion (the value not cleared by CMD0 reset) and readable. 15 R/W/E_P: Multiple writable with value reset after power failure, H/W reset assertion and any CMD0 reset and readable. 16 W/E/_P: Multiple writable with value reset after power failure, H/W reset assertion and any CMD0 reset and not readable. Name Field Width Cell CSD- Type slice Value CSD structure CSD_STRUCTURE 2 R [127:126] 3h System specification version SPEC_VERS 4 R [125:122] 4h Reserved - 2 R [121:120] 0h Data read access-time 1 TAAC 8 R [119:112] 7Fh NSAC 8 R [111:104] 8h Max. bus clock frequency TRAN_SPEED 8 R [103:96] 32h Card command classes CCC 12 R [95:84] 5F5h Data read access-time 2 in CLK cycles (NSAC*100) 19 / 44 MKEV008GCB-SS510 Max. read data block length READ_BL_LEN 4 R [83:80] 9h Partial blocks for read allowed READ_BL_PARTIAL 1 R [79:79] 0h Write block misalignment WRITE_BLK_MISALIGN 1 R [78:78] 0h Read block misalignment READ_BLK_MISALIGN 1 R [77:77] 0h DSR implemented DSR_IMP 1 R [76:76] 0h Reserved - 2 R [75:74] 0h Device size C_SIZE 12 R [73:62] FFFh Max. read current @ VDD min VDD_R_CURR_MIN 3 R [61:59] 6h Max. read current @ VDD max VDD_R_CURR_MAX 3 R [58:56] 6h Max. write current @ VDD min VDD_W_CURR_MIN 3 R [55:53] 6h Max. write current @ VDD max VDD_W_CURR_MAX 3 R [52:50] 6h Device size multiplier C_SIZE_MULT 3 R [49:47] 7h Erase group size ERASE_GRP_SIZE 5 R [46:42] 1Fh Erase group size multiplier ERASE_GRP_MULT 5 R [41:37] 1Fh Write protect group size WP_GRP_SIZE 5 R [36:32] Fh Write protect group enable WP_GRP_MULT 1 R [31:31] 1h Manufacturer default ECC DEFAULT_ECC 2 R [30:29] 0h Write speed factor R2W_FACTOR 3 R [28:26] 5h Max. write data block length WRITE_BL_LEN 4 R [25:22] 9h Partial blocks for write allowed WRITE_BL_PARTIAL 1 R [21:21] 0h Reserved - 4 R [20:17] 0h Content protection application CONTENT_PROT_APP 1 R [16:16] 0h File format group FILE_FORMAT_GRP 1 R/W [15:15] 0h Copy flag(OTP) COPY 1 R/W [14:14] 0h Permanent write protection PERM_WRITE_PROTECT 1 R/W [13:13] 0h Temporary write protection TMP_WRITE_PROTECT 1 R/W/E [12:12] 0h File format FILE_FORMAT 2 R/W [11:10] 0h CRC CRC 7 R/W/E [7:1] 0h Not used, always ‘1’ - 1 - [0:0] 1h Table 8-4 CSD Table Top page 20 / 44 MKEV008GCB-SS510 8.6Extended CSD register 17 The Extended CSD register defines the e•MMC properties and selected modes. It is 512 bytes long. 18 19 The most significant 320 bytes are the Properties segment, which defines the e•MMC capabilities and cannot be modified by the host. The lower 192 bytes are the Modes segment, which defines the configuration the e•MMC is working in. These modes can be changed by the host by means of the SWITCH command. 20 R: Read only 21 W: One time programmable and not readable. 22 R/W: One time programmable and readable. 23 W/E: Multiple writable with value kept after power failure, H/W reset assertion and any CMD0 reset and not readable. 24 R/W/E: Multiple writable with value kept after power failure, H/W reset assertion and any CMD0 reset and readable. 25 R/W/C_P: Writable after value cleared by power failure and HW/ rest assertion (the value not cleared by CMD0 reset) and readable. 26 R/W/E_P: Multiple writable with value reset after power failure, H/W reset assertion and any CMD0 reset and readable. 27 W/E/_P: Multiple writable with value reset after power failure, H/W reset assertion and any CMD0 reset and not readable. Size Name Field (Byte s) Cell CSD- Type slice Value Properties Segment Reserved [511:506 6 TBD EXT_SECURITY_ERR 1 R [505] 0h Supported Command Sets S_CMD_SET 1 R [504] 1h HPI features HPI_FEATURES 1 R [503] 1h Extended Security Commands Error - 21 / 44 ] 0h MKEV008GCB-SS510 Background operations support BKOPS_SUPPORT 1 R [502] 1h Max packed read commands MAX_PACKED_READS 1 R [501] Ah Max packed write commands MAX_PACKED_WRITES 1 R [500] Ah Data Tag Support DATA_TAG_SUPPORT 1 R [499] 1h Tag Unit Size TAG_UNIT_SIZE 1 R [498] 5h Tag Resources Size TAG_RES_SIZE 1 R [497] 1h CONTEXT_CAPABILITIES 1 R [496] 5h LARGE_UNIT_SIZE_M1 1 R [495] 7h EXT_SUPPORT 1 R [494] 3h Supported modes SUPPORTED_MODES 1 R [493] 1h FFU features FFU_FEATURES 1 R [492] 1h 1 R [491] 40h Context management capabilities Large Unit size Extended partitions attribute support OPERATION_CODE_TIME Operation codes timeout OUT FFU Argument FFU_ARG 4 R Barrier support BARRIER_SUPPORT 1 R 177 TBD Reserved - [490:487 ] [486] [485:309 ] 0h 0h All ”0” CMD Queuing Support CMDQ_SUPPORT 1 R [308] 1h CMD Queuing Depth CMDQ_DEPTH 1 R [307] 1Fh 1 TBD [306] 0h 32 R 1 R [269] All “0” 1 R [268] 0h Cell CSD- Type slice Reserved Vendor proprietary health VENDOR_PROPRIETARY_ report HEALTH_REPORT Device life time estimation type DEVICE_LIFE_TIME_EST B _TYP_B Device life time estimation type DEVICE_LIFE_TIME_EST A _TYP_A Size Name Field (Byte s) [301:270 ] 0h Value Pre EOL information PRE_EOL_INFO 1 R [267] 0h Optimal read size OPTIMAL_READ_SIZE 1 R [266] 0h Optimal write size OPTIMAL_WRITE_SIZE 1 R [265] 0h 22 / 44 MKEV008GCB-SS510 OPTIMAL_TRIM_UNIT_SI Optimal trim unit size ZE 1 R [264] [263:262 0h Device version DEVICE_VERSION 2 R Firmware version FIRMWARE_VERSION 8 R PWR_CL_DDR_200_360 1 R Cache size CACHE_SIZE 4 R Generic CMD6 timeout GENERIC_CMD6_TIME 1 R [248] 0h POWER_OFF_LONG_TIME 1 R [247] 10h Background operations status BKOPS_STATUS 1 R [246] 2h Number CORRECTLY_PRG_SECTO 4 R INI_TIMEOUT_AP 1 R [241] 0h CACHE_FLUSH_POLICY 1 R [240] 0h PWR_CL_DDR_52_360 1 R [239] 0h PWR_CL_DDR_52_195 1 R [238] 0h PWR_CL_200_195 1 R [237] 0h PWR_CL_200_130 1 R [236] 0h MIN_PERF_DDR_W_8_52 1 R [235] 0h MIN_PERF_DDR_R_8_52 1 R [234] 0h 2 TBD [233] 0h Power class for 200MHz, DDR at VCC= 3.6V Power off notification(long) timeout of correctly programmed sectors 1st initialization time RS_NUM after partitioning Cache Flushing Policy Power class for 52MHz, DDR at VCC = 3.6V Power class for 52MHz, DDR at VCC = 1.95V Power class for 200MHz at VCCQ =1.95V, VCC = 3.6V Power class for 200MHz, at VCCQ=1.3V, VCC = 3.6V Minimum Write Performance for 8bit at 52MHz in DDR mode Minimum Read Performance for 8bit at 52MHz in DDR mode Reserved ] [261:254 ] [253] [252:249 ] [245:242 ] 0h 0h 0h 0h 0h TRIM Multiplier TRIM_MULT 1 R [232] 10h Secure Feature support SEC_FEATURE_SUPPORT 1 R [231] 55h Secure Erase Multiplier SEC_ERASE_MULT 1 R [230] 1Bh 23 / 44 MKEV008GCB-SS510 Secure TRIM Multiplier SEC_TRIM_MULT 1 R [229] 11h Boot information BOOT_INFO 1 R [228] 7h 1 TBD [227] 0h Reserved Boot partition size BOOT_SIZE_MULT 1 R [226] 20h Access size ACC_SIZE 1 R [225] 6h High-capacity erase unit size HC_ERASE_GRP_SIZE 1 R [224] 1h High-capacity erase timeout ERASE_TIMEOUT_MULT 1 R [223] 10h Reliable write sector count REL_WR_SEC_C 1 R [222] 1h HC_WP_GRP_SIZE 1 R [221] 10h Sleep current [VCC] S_C_VCC 1 R [220] Dh Sleep current [VCCQ] S_C_VCCQ 1 R [219] Dh 1 R [218] 6h 1 R [217] 17h Cell CSD- Type slice 1 R [216] SEC_COUNT 4 R SECURE_WP_INFO 1 R [211] 0h MIN_PERF_W_8_52 1 R [210] 0h MIN_PERF_R_8_52 1 R [209] 0h 1 R [208] 0h MIN_PERF_R_8_26_4_52 1 R [207] 0h MIN_PERF_W_4_26 1 R [206] 0h MIN_PERF_R_4_26 1 R [205] 0h High-capacity write protect group size Production state awareness PRODUCTION_STATE_A timeout WARENESS_TIMEOUT Sleep/awake timeout S_A_TIMEOUT Size Name Field (Byte s) Sleep Notification Timout1 Sector Count Secure Write Protect Information Minimum Write Performance for 8bit at 52MHz Minimum Read Performance for 8bit at 52MHz SLEEP_NOTIFICATION_TI ME Minimum Write Performance for MIN_PERF_W_8_26_4_5 8bit at 26MHz, for 4bit at 52MHz 2 Minimum Read Performance for 8bit at 26MHz, for 4bit at 52MHz Minimum Write Performance for 4bit at 26MHz Minimum Read Performance for 24 / 44 [215:212 ] Value 0h E6A340h MKEV008GCB-SS510 4bit at 26MHz Reserved Power class for 26MHz at 3.6 V 1R Power class for 52MHz at 3.6 V 1R Power class for 26MHz at 1.95 V 1R Power class for 52MHz at 1.95 V 1R Partition switching timing Out-of-interrupt busy timing 1 TBD [204] 0h PWR_CL_26_360 1 R [203] 0h PWR_CL_52_360 1 R [202] 0h PWR_CL_26_195 1 R [201] 0h PWR_CL_52_195 1 R [200] 0h 1 R [199] FFh 1 R [198] 64h PARTITION_SWITCH_TIM E OUT_OF_INTERRUPT_TI ME I/O Driver Strength DRIVER_STRENGTH 1 R [197] 0h Device type DEVICE_TYPE 1 R [196] 17h 1 TBD [195] 0h 1 R [194] 2h 1 TBD [193] 0h EXT_CSD_REV 1 R [192] 7h CMD_SET 1 R/W/E_P [191] 0h 1 TBD [190] 0h R [189] 0h TBD [188] 0h R/W/E_P [187] 0h 1 TBD [186] 0h 1 R/W/E_P [185] 2h 1 TBD [184] 0h 1 W/E_P [183] 2h 1 TBD [182] 0h [181] 0h [180] 0h [179] 0h Reserved CSD Structure Version CSD_STRUCTURE Reserved Extended CSD Revision Modes Segment Command Set Reserved Command set revision CMD_SET_REV Reserved Power class 1 POWER_CLASS Reserved High Speed Interface Timing HS_TIMING Reserved Bus Width Mode BUS_WIDTH Reserved Erased memory range ERASE_MEM_CONT Reserved Partition Configuration 1 1 PARTITION_CONFIG 1 25 / 44 TBD R/W/E & R/W/E_P MKEV008GCB-SS510 R/W Boot Config protection BOOT_CONFIG_PROT 1 &R/W/C_ [178] 0h P Size Cell CSD- Type slice 1 R/W/E [177] 0h 1 TBD [176] 0h ERASE_GROUP_DEF 1 R/W/E [175] 0h BOOT_WP_STATUS 1 R [174] 0h [173] 0h [172] 0h [171] 0h Name Field (Byte s) Boot bus Conditions BOOT_BUS_CONDITIONS Reserved High-density erase group definition Boot write protection status registers Value R/W Boot area write protect register BOOT_WP 1 &R/W/C_ P Reserved 1 TBD R/W,R/W/ User area write protect register USER_WP 1 C_P &R/W/E_ P Reserved 1 TBD [170] 0h FW configuration FW_CONFIG 1 R/W [169] 0h RPMB Size RPMB_SIZE_MULT 1 R [168] 20h Write reliability setting register WR_REL_SET 1 R/W [167] 1Fh WR_REL_PARAM 1 R [166] 14h SANITIZE_START 1 W/E_P [165] 0h BKOPS_START 1 W/E_P [164] 0h BKOPS_EN 1 [163] 0h H/W reset function RST_n_FUNCTION 1 R/W [162] 0h HPI management HPI_MGMT 1 R/W/E_P [161] 0h Partitioning Support PARTITIONING_SUPPORT 1 R [160] 7h Max Enhanced Area Size MAX_ENH_SIZE_MULT 3 R [159:157 133h Write reliability parameter register Start Sanitize operation Manually start background operations Enable background operations handshake 26 / 44 R/W & R/W/E MKEV008GCB-SS510 ] Partitions attribute PARTITIONS_ATTRIBUTE PARTITION_SETTING_CO Partitioning Setting MPLETED 1 R/W [156] 0h 1 R/W [155] 0h 12 R/W [154:143 General Purpose Partition Size GP_SIZE_MULT Enhanced User Data Area Size ENH_SIZE_MULT 3 R/W ENH_START_ADDR 4 R/W 1 TBD [135] 0h 1 R/W [134] 0h 1 R/W/E [133] 0h TCASE_SUPPORT 1 W/E_P [132] 0h Periodic Wake-up PERIODIC_WAKEUP 1 R/W/E [131] 0h Program CID/CSD in DDR mode PROGRAM_CID_CSD_DD support R_SUPPORT 1 R [130] 0h 2 TBD Enhanced User Data Start Address Reserved Bad Block Management mode Production state awareness Package Case Temperature is controlled SEC_BAD_BLK_MGMNT PRODUCTION_STATE_A WARENESS Reserved Vendor Specific Fields NATIVE_SECTOR_SIZE 1 Native sector size NATIVE_SECTOR_SIZE 1 Sector size emulation USE_NATIVE_SECTOR Sector size 1st initialization after disabling sector size emulation Class 6 commands control Number of addressed group to be Released ] [139:136 ] [129:128 ] 0h 0h 0h 0h R [63] 0h 1 R/W [62] 0h DATA_SECTOR_SIZE 1 R [61] 0h INI_TIMEOUT_EMU 1 R [60] 0h CLASS_6_CTRL 1 R/W/E_P [59] 0h DYNCAP_NEEDED 1 R [58] 0h Cell CSD- Type slice R/W/E_P [57:56] Field (Byte s) Exception events control [142:140 0h [127:64] Size Name Value 0h MKEV008GCB-SS510 RL EXCEPTION_EVENTS_ST Exception events status Extended Partitions Attribute Context configuration turn the the R/W [53:52] 0h 15 R/W/E_P [51:37] 0h 1 R [36] 0h 1 R [35] 0h 1 R/W/E_P [34] 0h CACHE_CTRL 1 R/W/E_P [33] 0h FLUSH_CACHE 1 W/E_P [32] 0h BARRIER_CTRL 1 R/W [31] 0h MODE_CONFIG 1 R/W/E_P [30] 0h 1 W/E_P [29] 0h 2 TBD [28:27] 0h 1 R [26] 0h 4 R/W/E_P [25:22] 0h 4 R [21:18] 39A8D0h [17] 3h BUTE PACKED_FAILURE_INDEX ON Cache Flushing of the cache to 2 EXT_PARTITIONS_ATTRI POWER_OFF_NOTIFICATI ON/OFF Control 0h TUS Power Off Notification turn [55:54] PACKED_COMMAND_STA Packed command failure index to R CONTEXT_CONF Packed command status Control 2 ATUS Barrier ON/OFF Mode config Mode operation codes MODE_OPERATION_COD ES Reserved FFU status FFU_STATUS PRE_LOADING_DATA_SI Pre loading data size ZE Max pre loading data size Product state awareness MAX_PRE_LOADING_DAT A_SIZE PRODUCT_STATE_AWAR 1 R/W/E & enablement ENESS_ENABLEMENT Secure Removal Type SECURE_REMOVAL_TYPE 1 R/W & R [16] 1h Command Queue Mode Enable CMDQ_MODE_EN 1 R/W/E_P [15] 0h 15 TBD [14:0] 0h Reserved 28 Note:Reserved bits should be read as “0”. Table 8-5 Extend CSD Table Top page 28 / 44 R MKEV008GCB-SS510 9. Production Specifications 9.1 Performance Sustained Capacity Part Number Mode Sequential Read (MB/s) 8 GB P/N HS200 130 SLC Sequential Write (MB/s) 45 Sustained Sequential Write (MB/s) 22 Test Condition: Bus width x8, 200MHz SDR, 512KB data transfer, w/o file system overhead, measured on internal board. Table 9-1 MKEV008GCB-SS510 performance Top page 29 / 44 MKEV008GCB-SS510 9.2 Power Consumption Operating Current Capacity NAND Type 8 GB 64Gb x 1 Icc Iccq (Max) (Max) Read 50 150 mA Write 50 100 mA Operation Unit Note: - Power measurement conditions: Bus configuration =x8 @200MHz DDR - Max RMS current is the average RMS current consumption over a period of 100ms. - Temperature: 25℃ - VCC=3.3V, VCCQ=1.8V - Not 100% tested Standby Power Consumption Capacity 8 GB NAND Type 64Gb x 1 State Standby Icc Iccq Unit 25℃ 85℃ 25℃ 85℃ 50 150 150 600 uA 50 150 150 600 uA Note: - Power measurement conditions: Bus configuration =x8, No CLK - VCC=3.3V, VCCQ=1.8V - Not 100% tested Sleep Power Consumption Capacity 8 GB NAND Type 64Gb x 1 State Sleep Icc Iccq Unit 25℃ 85℃ 25℃ 85℃ 0 0 150 600 uA 0 0 150 600 uA Note: 30 / 44 MKEV008GCB-SS510 - Power measurement conditions: Bus configuration = x8, No CLK - Enter sleep state by CMD5, VCC power is switched off, VCCQ=1.8V - Not 100% tested Top page 31 / 44 MKEV008GCB-SS510 10. Package Dimension Figure 10-2 Package Outline Dimension Drawing Top page 32 / 44 MKEV008GCB-SS510 11. Partition Configuration 11.1 Partition Management The memory configuration initially consists (before any partitioning operation) of the User Data Area and RPMB Area Partitions and two Boot Area Partitions. The embedded device also offers the host the possibility to configure additional local memory partitions with independent address spaces, starting from logical address 0x00000000, for different usage models. Therefore, the memory block areas can be classified as follows: - Two Boot Area Partitions, whose size is multiple of 128 KB and where booting from e•MMC can be performed. - One RPMB Partition accessed through a trusted mechanism, whose size is defined as multiple of 128 KB. - Four General Purpose Area Partitions to store sensitive data or for other host usage models, whose sizes are a multiple of a Write Protect Group. Boot and RPMB Area Partitions' sizes and attributes are defined by the memory manufacturer (readonly), while General Purpose Area Partitions' sizes and attributes can be programmed by the host only once in the device life-cycle (one-time programmable). Moreover, the host is free to configure one segment in the User Data Area to be implemented as enhanced storage media, and to specify its starting location and size in terms of Write Protect Groups. The attributes of this Enhanced User Data Area can be programmed only once during the device life-cycle (one-time programmable). 33 / 44 MKEV008GCB-SS510 A possible final configuration can be the following: 11.2 User Density 34 / 44 MKEV008GCB-SS510   Boot and RPMB Size Capacity Boot1 Size Boot2 Size RPMB Size 8 GB 4096 KB 4096 KB 4096 KB User Density Size Capacity User Area Capacity 7,738,916,864 Bytes 8 GB  SEC_COUNT in Extended CSD 0xE6A340 (7.2 GB) Maximum Enhanced Partition Size Max. Capacity Enhanced MAX_ENH_SIZE_M HC_WP_GRP_SI HC_ERASE_GRP_S Partition ULT ZE IZE 0x133h 0x10h 0x1h Size 2,575,302, 8 GB 656 Bytes (2450 MB) Max Enhanced Area = MAX_ENH_SIZE_MULT x HC_WP_GRP_SIZE x HC_ERASE_GRP_SIZE x 512kBytes 35 / 44 MKEV008GCB-SS510 11.3 Boot Operation Mode In boot operation mode, the master can read boot data from the slave (device) by keeping CMD line low or sending CMD0 with argument + 0xFFFFFFFA, before issuing CMD1. The data can be read from either boot area or user area depending on register setting. State diagram (boot mode) Boot operation complete Clock = 400 kHz (Compatible with the description which ≤400kHz) State diagram (alternative boot mode) Top page 36 / 44
MKEV008GCB-SS510
物料型号:MKEV008GCB-SS510
器件简介:MKEV008GCB-SS510是一款采用eMMC技术的嵌入式非易失性存储系统,封装在BGA中。它具有高性能、低功耗的特点,并支持eMMC 4.5、eMMC 5.01和eMMC 5.1规范。
引脚分配:该器件共有153个引脚,包括数据传输引脚(DATO-DAT7)、时钟引脚(CLK)、命令引脚(CMD)、复位引脚(RST_n)等。每个引脚的具体功能在文档的"Pin Description"部分有详细说明。
参数特性:包括操作条件、电源电压、待机功耗、睡眠功耗等。例如,在操作状态下,读操作的电流(Icc)为50mA,写操作的电流(Icc)为50mA。
功能详解:文档详细介绍了eMMC的功能块图、引脚描述、电气特性、寄存器描述等。例如,电气特性部分详细列出了一般操作条件、电源电压、总线信号线负载等参数。
应用信息:文档提供了产品规格、性能测试条件、功耗测试条件等应用信息。例如,8GB容量的eMMC在HS200模式下,连续读取速度为130MB/s,SLC顺序写入速度为45MB/s。
封装信息:提供了153FBGA封装的尺寸信息,包括球径、封装体尺寸等。
MKEV008GCB-SS510 价格&库存
很抱歉,暂时无法提供与“MKEV008GCB-SS510”相匹配的价格&库存,您可以联系我们找货
