WPE1291WP6
WPE1291WP6
    WPMTEK(维攀微)
    DFN-2_1610(METRIC)
    ESD抑制器/TVS二极管 单向 25V 75A
WPE1291WP6 数据手册
WPEXX91WP6 1-Line Uni-directional TVS Diode Integrated in OVP&OCP products provider Description Mechanical Characteristics The WPEXX91WP6 is an uni-directional TVS diode, n Package: DFN1610-2 utilizing leading monolithic silicon technology to provide n Lead Finish: Matte Tin fast re-sponse time and low ESD clamping voltage, n Case Material: “Green” Molding Compound. making this device an ideal solution for protecting n Moisture Sensitivity: Level 3 per J-STD-020 voltage The n Terminal Connections: See Diagram Below WPEXX91WP6 complies with the IEC 61000-4-2 (ESD) n Marking Information: See Below sensitive data and power line. standard with ±30kV air and ±30kV contact discharge. It is assembled into an ultra-small 1.6x1.0x0.5mm lead-free DFN package. The small size and high ESD Applications surge protection make WPEXX91WP6 an ideal choice to protect cell phone, digital cameras, audio play-ers and many other portable applications. Features n Small package: 1.6x1.0x0.5mm n Protects one data or power line n Working Voltage: 3.3V, 5V, 7V, 12V, 15V, 18V, 24V, n Mobile Phones and Accessories n Battery Protection n USB VBus n Power Line Protection n Hand Held Portable Applications Marking Information 36V n High peak pulse current capability n 2-pin leadless package n Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Bar denotes cathode Air discharge: ±30kV Details marking code reference customer approval list Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 20A - 90A (8/20μs) n Ordering Information RoHS Compliant Part Number WPE3391WP6 WPE0591WP6 WPE0791WP6 WPE0991WP6 WPE1291WP6 WPE1591WP6 WPE1891WP6 WPE2491WP6 WPE3691WP6 Dimensions & Symbol(Unit: mm Max) Rev.A_July,2018 -1- Packaging 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel Reel Size 7 inch 7 inch 7 inch 7 inch 7 inch 7 inch 7 inch 7 inch 7 inch www.wpmtek.com WPEXX91WP6 1-Line Uni-directional TVS Diode Integrated in OVP&OCP products provider Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Ppk 1875 W Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) WPE3391WP6 Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 3.3 V 3.5 Test Condition V IT = 1mA 1.0 μA VRWM = 3.3V 1.2 V IF = 10mA Reverse Leakage Current IR Forward Voltage VF Peak Pulse Current IPP 90 A tp = 8/20µs Clamping Voltage VC 5.5 V IPP = 10A (8 x 20µs pulse) Clamping Voltage VC 12.5 V IPP = 150A (8 x 20µs pulse) Junction Capacitance CJ 750 pF VR = 0V, f = 1MHz Max Unit 5 V 1.0 WPE0591WP6 Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 6 Test Condition V IT = 1mA 1.0 μA VRWM = 5V 1.2 V IF = 10mA Reverse Leakage Current IR Forward Voltage VF Peak Pulse Current IPP 125 A tp = 8/20µs Clamping Voltage VC 9 V IPP = 10A (8 x 20µs pulse) Clamping Voltage VC 15 V IPP = 125A (8 x 20µs pulse) Junction Capacitance CJ 650 pF VR = 0V, f = 1MHz Rev.A_July,2018 1.0 -2- www.wpmtek.com WPEXX91WP6 1-Line Uni-directional TVS Diode Integrated in OVP&OCP products provider WPE0791WP6 Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 7 V 7.5 Test Condition V IT = 1mA 0.5 μA VRWM = 7V 1.2 V IF = 10mA Reverse Leakage Current IR Forward Voltage VF Peak Pulse Current IPP 115 A tp = 8/20µs Clamping Voltage VC 12 V IPP = 10A (8 x 20µs pulse) Clamping Voltage VC 16.5 V IPP = 115A (8 x 20µs pulse) Junction Capacitance CJ 550 pF VR = 0V, f = 1MHz Max Unit Test Condition 9 V 1.0 WPE0991WP6 Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 10 V IT = 1mA 0.5 μA VRWM = 9V 1.2 V IF = 10mA Reverse Leakage Current IR Forward Voltage VF Peak Pulse Current IPP 90 A tp = 8/20µs Clamping Voltage VC 15 V IPP = 10A (8 x 20µs pulse) Clamping Voltage VC 23 V IPP = 90A (8 x 20µs pulse) Junction Capacitance CJ 525 pF VR = 0V, f = 1MHz Max Unit 12 V 1.0 WPE1291WP6 Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 12.6 Test Condition V IT = 1mA Reverse Leakage Current IR 0.1 μA VRWM = 12V Forward Voltage VF 1.2 V IF = 10mA Peak Pulse Current IPP 75 A tp = 8/20µs Clamping Voltage VC 18 V IPP = 10A (8 x 20µs pulse) Clamping Voltage VC 25 V IPP = 75A (8 x 20µs pulse) Junction Capacitance CJ 500 pF VR = 0V, f = 1MHz Rev.A_July,2018 -3- www.wpmtek.com WPEXX91WP6 1-Line Uni-directional TVS Diode Integrated in OVP&OCP products provider WPE1591WP6 Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 15 V 16.5 Test Condition V IT = 1mA Reverse Leakage Current IR 0.1 μA VRWM = 15V Forward Voltage VF 1.2 V IF = 10mA Peak Pulse Current IPP 60 A tp = 8/20µs Clamping Voltage VC 22 V IPP = 10A (8 x 20µs pulse) Clamping Voltage VC 31.25 V IPP = 60A (8 x 20µs pulse) Junction Capacitance CJ 450 pF VR = 0V, f = 1MHz Max Unit Test Condition 18 V WPE1891WP6 Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 19.6 V IT = 1mA 0.1 μA VRWM = 18V 1.2 V IF = 10mA Reverse Leakage Current IR Forward Voltage VF Peak Pulse Current IPP 50 A tp = 8/20µs Clamping Voltage VC 26 V IPP = 10A (8 x 20µs pulse) Clamping Voltage VC 37.5 V IPP = 50A (8 x 20µs pulse) Junction Capacitance CJ 350 pF VR = 0V, f = 1MHz Max Unit 24 V 1.0 WPE2491WP6 Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 26.7 Test Condition V IT = 1mA Reverse Leakage Current IR 0.1 μA VRWM = 24V Forward Voltage VF 1.2 V IF = 10mA Peak Pulse Current IPP 35 A tp = 8/20µs Clamping Voltage VC 42 V IPP = 10A (8 x 20µs pulse) Clamping Voltage VC 53.5 V IPP = 35A (8 x 20µs pulse) Junction Capacitance CJ 200 pF VR = 0V, f = 1MHz Rev.A_July,2018 -4- www.wpmtek.com WPEXX91WP6 1-Line Uni-directional TVS Diode Integrated in OVP&OCP products provider WPE3691WP6 Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 36 V 37 Test Condition V IT = 1mA Reverse Leakage Current IR 0.1 μA VRWM = 36V Forward Voltage VF 1.2 V IF = 10mA Peak Pulse Current IPP 25 A tp = 8/20µs Clamping Voltage VC 60 V IPP = 10A (8 x 20µs pulse) Clamping Voltage VC 75 V IPP = 25A (8 x 20µs pulse) Junction Capacitance CJ 150 pF VR = 0V, f = 1MHz Typical Performance Characteristics (TA=25°C unless otherwise Specified) Rev.A_July,2018 -5- www.wpmtek.com WPEXX91WP6 1-Line Uni-directional TVS Diode Integrated in OVP&OCP products provider Soldering Parameters Reflow Condition Pre Heat Pb-Free assembly -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_July,2018 -6- www.wpmtek.com WPEXX91WP6 1-Line Uni-directional TVS Diode Integrated in OVP&OCP products provider Package Mechanical Data Suggested Land Pattern Contact information WPMTEK Incorporated Limited Room 207,2nd Floor,Block 3,Minxing lndustry Park,Minzhi Longhua New District,Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_July,2018 -7- www.wpmtek.com
WPE1291WP6 价格&库存
很抱歉,暂时无法提供与“WPE1291WP6”相匹配的价格&库存,您可以联系我们找货
WPE1291WP6
  • 1+0.25500
  • 100+0.23800
  • 300+0.22100
  • 500+0.20400
  • 2000+0.19550
  • 5000+0.19040
