Shenzhen RICKY Electronic Technology Co.,Ltd
K08 Series
1A SCRs
DESCRIPTION:
Thanks to highly sensitive triggering levels, the
K08 SCR series is suitable for all applications
where the available gate current is limited, such as
ground fault circuit interruptors, overvoltage
crowbar protection in low power supplies,
capacitive ignition circuits, ...
MAIN FEATURES
Symbol
Value
Unit
IT(RMS)
1.0
A
VDRM VRRM
600
V
IGT
200
µA
ABSOLUTE MAXIMUM RATINGS
Parameter
Symbol
Value
Unit
Storage junction temperature range
Tstg
-40 ~150
Operating junction temperature range
Tj
-40~125
Repetitive peak off-state voltage (T =25℃)
VDRM
600
V
Repetitive peak reverse voltage (T =25℃)
VRRM
600
V
RMS on-state current
IT(RMS)
1.0
A
Non repetitive surge peak on-state current
(180° conduction angle, F=50Hz)
ITSM
12
A
Average on-state current (180° conduction angle)
IT(AV)
0.6
A
I t value for fusing (tp=10ms)
2
It
0.72
A2S
Critical rate of rise of on-state current
(I =2×IGT, tr ≤ 100 ns)
dI/dt
50
A/μS
Peak gate current
IGM
1.0
A
Average gate power dissipation
PG(AV)
0.1
W
2
NO:JL-HRJK08-01A06
TEL:+86-0755-89519740
-1/-4
www.sika-wen.com
K08 Series
ELECTRICAL CHARACTERISTICS (T=25℃unless oth
Symbol
Test Condition
IGT
V =12V R =140Ω
VGT
Value
Unit
MAX.
200
µA
MAX.
1.0
V
VGD
VD=VDRM Tj=125℃ RGK=1KΩ
MIN.
0.2
V
IL
IG=1.2IGT
MAX.
6
mA
IH
IT=50mA
MAX.
5
mA
dV/dt
VD=2/3VDRM Gate Open RGK=1KΩ
Tj=110℃
MIN.
200
V/μs
Value(MAX.)
Unit
STATIC CHARACTERISTICS
Symbol
Parameter
VTM
ITM =2.0A tp=380μs
Tj =25℃
1.75
V
IDRM
VD=VDRM VR=VRRM
Tj =25℃
5
μA
Tj =125℃
0.5
mA
IRRM
Thermal Resistances
Symbol
Parameter
Value(MAX.)
Rth(j-a)
junction to ambient
150
Unit
℃/W
Rth(j-t)
Junction to tab (DC)
40
NO:JL-HRJK08-01A06
-2/-4
www.sika-wen.com
K08 Series
SOT-23-3L Package Mechanical Data
NO:JL-HRJK08-01A06
-3/-4
www.sika-wen.com
K08 Series
FIG.1 Maximum power dissipation
versus Average on-state current
FIG.2: Average on-state current versus
case temperature
FIG.3: Surge peak on-state current
versus number of cycles
FIG.4: On-state characteristics
(maximum values)
FIG.5: Non-repetitive surge peak on-state
currentfor a sinusoidal pulse with width
tp
很抱歉,暂时无法提供与“K08”相匹配的价格&库存,您可以联系我们找货
