RK1210A-800
RK1210A-800
    RICKY(浩瑞佳)
    TO-220A
    12A 800V 三象限双向 IGT3:<10mA
RK1210A-800 数据手册
Shenzhen RICKY Electronic Technology Co.,Ltd RK12xx Series 12A TRIACs High current density due to double mesa technology, SIPOS and Glass Passivation. RK12xx series triacs is suitable for or for phase contol operation, light dimmers,motor speed ON/OFF function in applications such as static relays, general purpose AC switching,They can be used as an heating regulation,induction motor stating circuits...controllers. RK12xx-600/800 - are 3 quadrants triacs,They are specially recommended for use on inductive loads. RK12xxA are isolated in internally.they provide a 2500V RMS isolation voltage from all three terminals to extemal heat sink. NO:SKW-ZSJ14P-12A11 Tel: +86-0755-89519740 www.sika-wen.com RK12xx Series Shenzhen RICKY Electronic Technology Co.,Ltd IGT Class 5 10 35 50 NO:SKW-ZSJ14P-12A11 Tel: +86-0755-89519740 www.sika-wen.com RK12xx Series Shenzhen RICKY Electronic Technology Co.,Ltd R K 12 xx E __ xxx SIKA CO.,LIMITED E:D2PAK A:TO-220A B:TO-220B RK1235A-600 NO:SKW-ZSJ14P-12A11 Tel: +86-0755-89519740 www.sika-wen.com RK12xx Series Shenzhen RICKY Electronic Technology Co.,Ltd NO:SKW-ZSJ14P-12A11 Tel: +86-0755-89519740 www.sika-wen.com RK12xx Series Shenzhen RICKY Electronic Technology Co.,Ltd RK12xxE/B RK12xxA NO:SKW-ZSJ14P-12A11 Tel: +86-0755-89519740 www.sika-wen.com
RK1210A-800
物料型号包括: - RK1235A-600 - RK12xxA - RK12xxE/B
器件简介中提到这些三端双向可控硅因双沟技术、SIPoS和玻璃钝化而具有高电流密度,适合于多种应用,包括静态继电器、通用交流开关、相位控制操作、调光器、电机速度控制、加热调节和感应电机启动电路。
引脚分配信息包括: - E: D2PAK - A: TO-220A - B: TO-220B
参数特性功能详解部分文档中没有提供详细信息。
应用信息包括:适用于静态继电器、通用交流开关、相位控制操作、调光器、电机速度控制、加热调节和感应电机启动电路。
封装信息为: - D2PAK - TO-220A - TO-220B
RK1210A-800 价格&库存
很抱歉,暂时无法提供与“RK1210A-800”相匹配的价格&库存,您可以联系我们找货
