DB107S
DB107S
    SLKOR(萨科微)
    DBS-4P_8.5X6.35MM_SM
    DBS
DB107S 数据手册
DB101S-DB107S SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIERS REVERSE VOLTAGE - 50 to 1000Volts FORWARD CURRENT - 1.0Amperes .047(1.2) .037(0.95) .307(7.8) FEATURES - ●Rating to 1000V PRV ●Ideal for printed circuit board + .256(6.5) .244(6.2) ~ ~ ●Low forward voltage drop,high current capability .291(7.4) .406(10.3) .391(10.0) ●Reliable low cost construction utilizing molded plastic .140(0.35) .008(0.2) technique results in inexpensive product ●Lead tin Pb/Sn copper .346(8.8) .323(8.2) ●The plastic material has UL flammability .102(2.6) .087(2.2) classification 94V-0 MECHANICAL DATA .205(5.2) .197(5.0) ●Polarit:As marked on Body ●Weight:0.02 ounces,0.38 grams Dimensions in inches and (millimeters) ●Mounting position:Any Pakage:DBS MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating at 25℃ ambient temperature unless otherwise specified. Single phase, half wave ,60Hz, resistive or inductive load. For capacitive load, derate current by 20% CHARACTERISTICS SYMBOL DB101S DB102S DB103S DB104S DB105S DB106S DB107S Maximum Recurrent Peak Reverse Voltage VRRM 50 Maximum RMS Voltage VRMS Maximum DC Blocking Voltage VDC Maximum Average Forward Rectified Current @T A=40℃ 100 200 400 600 800 35 70 140 280 420 50 100 200 400 600 UNIT 1000 V 560 700 V 800 1000 V I(AV) 1.0 A IFSM 50 A VF 1.1 V Peak Forward Surage Current 8.3ms Single Half Sine-Wave Super Imposed on Rated Load (JEDEC Method) Maximum Forward Voltage at 1.0A DC Maximum DC Reverse Current @TJ=25℃ at Rated DC Bolcking Voltage @TJ=125℃ 10 IR 500 uA I2t Rating for Fusing (t
DB107S 价格&库存
很抱歉,暂时无法提供与“DB107S”相匹配的价格&库存,您可以联系我们找货
DB107S
    • 10+0.30286
