SL6206 Series
300mA Low-Dropout Linear Regulator
Description
Features
The SL6206 series products are high performance and low
Input Voltage Range: 2.5 V to 5.5 V
dropout linear regulators. The SL6206 series products support
Output Voltage Options:
maximum 300 mA output current with low quiescent current and
Fixed Voltage: 1.2 V, 1.8 V, 2.5 V, 2.8 V, 3 V, 3.3 V
high PSRR. The SL6206 series products is stable with ceramic
Adjustable Voltage: 0.8 V to 5 V
output capacitor from 2.2 μF to 10 μF.
±2% Output Accuracy Through Operating Conditions
Maximum Output Current: 300 mA
The SL6206 series products have a high PSRR with 60 dB at 1
Low Dropout Voltage: 200 mV at 300 mA
KHz. This feature makes SL6206 series products very suitable
Low Quiescent Current and Shutdown Current
for power-sensitive applications with high noise from previous
Foldback Current Limit and Thermal Protection
stage power supply. As low as 50 μA quiescent current and
Stable with 2.2 μF Ceramic Capacitor
shutdown current makes the SL6206 series products ideal
Soft-start Limits Input Current Surge During Enable
choices for portable devices with battery power supply.
Thermal Shutdown Protection
Junction Temperature Range: −40°C to +125°C
Applications
Handheld Devices with Battery Power Supply
Video Surveillance
Wireless and IoT modules
Typical Application Schematic
Input
VIN
VOUT
CIN
Output
Input
COUT
VIN
Output
VOUT
CIN
R1
CBP
FB
Off On
EN
Off On
GND
Fixed Output Voltage
EN
GND
Adjustable Output Voltage
Product Family Table
Transport Media,
Part Number
Output Voltage
Package
SL6206-ADJMR
Adjustable (0.8 V ~ 5 V)
SOT23-5
Tape and Reel, 3,000
SL6206-12MR
Fixed 1.2 V
SOT23-5
SL6206-18MR
Fixed 1.8 V
SOT23-5
SL6206-25MR
Fixed 2.5 V
SOT23-5
SL6206-28MR
Fixed 2.8 V
SOT23-5
SL6206-30MR
Fixed 3.0 V
SOT23-5
SL6206-33MR
Fixed 3.3 V
SOT23-5
www.slkormicro.com
R2
Quantity
1
COUT
SL6206 Series
Pin Configuration and Functions
SOT23-5 Package
Top View
IN
1
GND
2
EN
3
5
OUT
4
NC/FB
Pin Functions
Name
Pin Number
I/O
Description
IN
1
I
Input voltage pin. Bypass IN to GND with a 1 μF or greater capacitor.
OUT
5
O
Regulated output voltage pin. Bypass OUT to GND with a 2.2 μF or greater capacitor.
EN
3
I
GND
2
Ground reference pin. Connect GND pin to PCB ground plane directly.
NC
4
No connection.
FB
4
I
Output feedback pin (Adjustable version only). Connect to a resistor divider to adjust the output voltage.
Regulator enable pin. Drive EN high to turn on the regulator; drive EN low to turn off the regulator. For automatic
startup, connect EN to IN directly.
Note: Thermal pad must be connected to PCB ground plane to maximum the thermal performance.
www.slkormicro.com
2
SL6206 Series
Specifications
Absolute Maximum Ratings
Parameters
Min
Max
Unit
VIN, VEN
Input Voltage
−0.3
6
V
VOUT
Output Voltage
−0.3
6
V
VFB
Feedback Voltage (Adjustable version only)
−0.3
6
V
TJ
−40
150
°C
TSTG
Storage Temperature Range
−65
150
°C
TL
Lead Temperature (Soldering 10 sec)
260
°C
(1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum
Rating condition for extended periods may affect device reliability and lifetime.
(2) All voltage values are with respect to GND.
ESD, Electrostatic Discharge Protection
Symbol
Parameter
Condition
Minimum Level
Unit
HBM
Human Body Model ESD
ANSI/ESDA/JEDEC JS-001
±8
kV
CDM
Charged Device Model ESD
ANSI/ESDA/JEDEC JS-002
±2
kV
Recommended Operating Conditions
Parameters
Min
Max
Unit
2.5
5.5
V
VIN
Input Voltage
VEN
Enable Voltage
VIN
V
VOUT
Output Voltage
V
VFB
VOUT
V
IOUT
Output Current
mA
TJ
−40
125
°C
www.slkormicro.com
3
SL6206 Series
Electrical Characteristics
All test condition: VIN = VOUT(NOM) + 0.5V or 2.5 V, whichever is greater; COUT = 2.2 µF, TA = +25°C, unless otherwise noted.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
5.5
V
Supply Input Voltage and Current
VIN
Input voltage range
2.5
IGND
Ground pin current
IOUT = 0 mA
50
µA
ISHDN
Shutdown current
EN = GND
1
µA
V
VIN under-voltage lock-out
VIN rising
2
UVLO
0.2
V
Hysteresis
Enable Input Voltage and Current
VIH(EN)
EN logic-input high level (enable)
1.2
VIN
V
VIL(EN)
EN logic-input low level (disable)
V
IEN
EN pin leakage current
EN = 5V
1
μA
Regulated Output Voltage and Current
VOUT
Output voltage accuracy
VFB
Feedback pin voltage
ΔVOUT
Line regulation
Load regulation
−2%
ADJ version only
4
= 1 mA
V
10
mV
IOUT = 1 mA to 300 mA
25
mV
VIN = 0.98 × VOUT(NOM), IOUT = 100 mA
80
mV
VIN = 0.98 × VOUT(NOM), IOUT = 300 mA
240
Dropout voltage
IOUT
Output current
VOUT in regulation
ICL
Output current limit
VOUT = 0.9 × VOUT(NOM)
PSRR
Power supply rejection ratio
tSTR(2)
0.8
VIN = VOUT(NOM) + 0.5 V or 2.5V to 5.5 V, IOUT
VDO (1)
VN
2%
300
mV
mA
350
1200
mA
IOUT = 100 mA, f = 1 kHz
60
dB
IOUT = 100 mA, f = 1 MHz
40
dB
IOUT = 100 mA, BW = 100Hz to 80 kHz
150
μVRMS
IOUT = 500 mA, COUT = 2.2 μF
150
μs
IOUT = 500 mA, COUT = 2.2 μF, CBP = 100 nF
15
ms
Thermal shutdown temperature
170
ºC
Thermal shutdown hysteresis
30
ºC
Output noise voltage
Start-up time
Temperature Range
TSD
(1) Dropout voltage is the minimum input to output voltage differential needed to maintain regulation at a specified output current. In dropout, the
output voltage will be equal to: VIN – VDROPOUT.
(2) Start-up time from EN assertion to 0.98 × VOUT(NOM).
www.slkormicro.com
4
SL6206 Series
Typical Performance Characteristics
100
600
–40°C
25°C
400
Ground Current (µA)
Ground Current (µA)
500
85°C
300
200
100
80
60
40
–40°C
25°C
85°C
100
150
200
250
3
300
3.5
Load Current (mA)
4.5
5
5.5
Figure 2 Quiescent Current vs Supply Voltage
3.4
4.0
3.35
3.0
Output Voltage (V)
Output Voltage (V)
Figure 1 Quiescent Current vs Output Current
3.3
3.25
3.2
2.0
1.0
0.0
-40
-15
10
35
60
85
Ambient Temperature (°C)
2
3
4
5
6
Figure 4 Output Voltage vs Supply Voltage
3.40
3.35
3.35
Output Voltage (V)
3.40
3.30
–40°C
3.25
1
Supply Voltage (V)
Figure 3 Output Accuracy vs Ambient Temperature
Output Voltage (V)
4
Supply Voltage (V)
25°C
3.30
–40°C
3.25
25°C
85°C
85°C
3.20
3.20
3
4
5
6
Supply Voltage (V)
Figure 5. Line Regulation
www.slkormicro.com
100
200
Load Current (mA)
Figure 6. Load Regulation
5
300
SL6206 Series
Functional Block Diagram
IN
OUT
UVLO
Ban dgap
Regula tor
Control
VBG
GND
Thermal
Shu tdo wn
EN
Curren t
Limit
SL6206 Series Fixed Output Version
IN
OUT
UVLO
Ban dgap
Regula tor
Control
FB
VBG
Thermal
Shu tdo wn
EN
Curren t
Limit
SL6206 Series Adjustable Output Version
www.slkormicro.com
6
GND
SL6206 Series
Package Outline Dimensions
SOT23-5
www.slkormicro.com
7
很抱歉,暂时无法提供与“SL6206-33MR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.885771+0.11513
- 10+0.4588910+0.05965
- 25+0.4025525+0.05232
- 100+0.33531100+0.04359
- 250+0.30394250+0.03951
- 500+0.28488500+0.03703
- 1000+0.269171000+0.03499
- 国内价格
- 5+0.57413
- 50+0.46008
- 150+0.40306
- 500+0.36029
- 3000+0.32606
- 6000+0.30888
- 国内价格
- 10+0.52628
- 100+0.42174
- 600+0.33026
- 1200+0.32531
- 3000+0.29888
- 国内价格 香港价格
- 3000+0.249693000+0.03246
- 6000+0.240196000+0.03122
- 9000+0.235429000+0.03060
- 15000+0.2301415000+0.02992
- 21000+0.2270621000+0.02952
- 30000+0.2240930000+0.02913
