S8550
PNP General Purpose Transistors
TO-92
1. E MIT T E R
2. B A SE
3. COL L E CTOR
1
2
3
ABSOLUTE MAXIMUM RATINGS (Ta=25 C)
Symbol
V CE O
V CB O
VE B O
IC
Rating
Collector-E m itter Voltage
Collector-B as e Voltage
E m itter-B as e VOltage
Collector Current
Total Device Dis s ipation TA=2 5 C
PD
J unction Tem perature
Tj
S torage, Tem perature
Ts tg
Unit
Vdc
Vdc
Vdc
m Adc
Value
-2 5
-4 0
-5 . 0
-5 0 0
0.625
W
150
C
C
-5 5 to +1 5 0
ELECTRICAL CHARACTERISTICS
Characteristics
Symbol
Min
Max
Unit
Collector-E m itter B reakdown Voltage (I C = -0 . 1 mAdc, I B =0 )
V (B R )CE O
-2 5
Vdc
Collector-B as e B reakdown Voltage (I C = -1 0 0 µAdc, I E =0 )
V (B R )CB O
-4 0
Vdc
E m itter-B as e B reakdown Voltage (I E = -1 0 0 µAdc, I C =0 )
V (B R )E B O
-5 . 0
Vdc
Collector Cutoff Current (V CE = -2 0 Vdc, I B =0 )
I CE 0
-0 . 2
uAdc
Collector Cutoff Current (V CB = -4 0 Vdc, I E =0 )
I CB O
-0 . 1
uAdc
E m itter Cutoff Current (V E B = -3 . 0 V d c, I C =0 )
IE B O
-0 . 1
uAdc
www.slkormicro.com
1
S8550
ELECTRICAL CHARACTERISTICS (TA=25 C unless otherwise noted) (Countinued)
Symbol
Min
TYP
Max
Unit
DC Current Gain
(IC=- 50 mAdc, VCE=-1.0 Vdc)
hFE (1)
85
300
DC Current Gain
(IC= -500 mAdc, VCE= 1.0 Vdc)
hFE (2)
50
Collector-Emitter Saturation Voltage
(IC= -500 mAdc, IB= -50 mAdc)
VCE(sat)
-0.6
Vdc
Base-Emitter Saturation Voltage
VBE(sat)
-1.2
Vdc
fT
150
MHz
Characteristics
ON CHARACTERISTICS
Current-Gain-Bandwidth Product
(IC= -20 mAdc, VCE=-6.0 Vdc, f=30MHz)
Classification of hFE(1)
Rank
B
C
Range
85-160
120-200
www.slkormicro.com
2
D
160-300
S8550
www.slkormicro.com
3
S8550
TO-92 Outline Dimensions
unit:mm
E
H
Dim
A
B
C
D
E
G
H
J
K
L
L
C
J
K
D
A
B
G
www.slkormicro.com
4
TO-92
Min
Max
3.70
3.30
1.40
1.10
0.55
0.38
0.51
0.36
4.70
4.40
3.43
4.70
4.30
1.270TYP
2.44
2.64
14.10
14.50
很抱歉,暂时无法提供与“S8550 TO-92”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.05549
- 100+0.05179
- 300+0.04809
- 500+0.04440
- 2000+0.04255
- 5000+0.04144
