SLSOT Series
Dual Transient Voltage Suppressors Array for ESD Protection
General Description
Features
The SLSOT Series is a dual monolithic voltage
z
2 Unidirectional Transil functions
suppressor designed to protect components which
z
Low leakage current: IR max< 20 μA at VRM
are connected to data and transmission lines
z
300W peak pulse power(8/20μs)
against ESD. It clamps the voltage just above the
z
Transient protection for data lines as per
logic level supply for positive transients and to a
diode drop below ground for negative transients. It
can also work as bidirectional suppressor by
Complies with the following standards
connecting only pin1 and 2.
IEC61000-4-2
Level 4
Applications
z
z
z
15 kV (air discharge)
8 kV(contact discharge)
Computers
Printers
Communication systems
MIL STD 883E - Method 3015-7 Class 3
25 kV HBM (Human Body Model)
Functional diagram
SOT-23
Absolute Ratings (Tamb=25°C )
Symbol
Parameter
Value
Units
PPP
Peak Pulse Power (tp = 8/20μs)
350
W
TL
Maximum lead temperature for soldering during 10s
260
°C
Tstg
Storage Temperature Range
-55 to +155
°C
Top
Operating Temperature Range
-40 to +125
°C
Tj
Maximum junction temperature
150
°C
IEC61000-4-2 air discharge
15
kV
IEC61000-4-2 contact discharge
8
Electrostatic discharge
VPP
www.slkormicro.com
1
SLSOT Series
Electrical Parameter
Symbol
IPP
VC
VRWM
IR
IT
VBR
Parameter
Reverse Peak
Maximum
Current
Clamping Voltage @ IPP
Pulse
Working Peak Reverse Voltage
Maximum Reverse Leakage Current
@ VRWM
Test Current
Breakdown Voltage @ IT
Electrical Characteristics
VBR
C
IT
VRWM
IR
Typ. 0v
Min.
Typ.
Max.
V
V
V
mA
V
µA
pF
SLSOT04C
5.0
5.6
6.2
1
4.0
1
30
SLSOT05C
6.0
6.7
7.4
1
5.0
1
30
SLSOT12C
13.3
14.0
14.7
1
12.0
1
25
SLSOT15C
16.7
17.4
18.1
1
15.0
1
25
SLSOT24C
26.7
28.2
29.6
1
24.0
1
Part Numbers
bias
1).8/20 waveform used. (see fig2.)
Typical Characteristics
Fig1. Peak Pulse Power VS Pulse Time
www.slkormicro.com
2
SLSOT Series
Fig2. Pulse Waveform
Fig3.Power Derating Curve
Application Note
Electrostatic discharge (ESD) is a major cause of failure in electronic systems. Transient Voltage
Suppressors (TVS) are an ideal choice for ESD protection. They are capable of clamping the incoming
transient to a low enough level such that damage to the protected semiconductor is prevented.
Surface mount TVS arrays offer the best choice for minimal lead inductance. They serve as parallel
protection elements, connected between the signal line to ground. As the transient rises above the operating
voltage of the device, the TVS array becomes a low impedance path diverting the transient current to ground.
The tiny SOT-23 package allows design flexibility in the design of high density boards where the space
saving is at a premium. This enables to shorten the routing and contributes to hardening against ESD.
www.slkormicro.com
3
SLSOT Series
SOT-23 mechanical data
Dim
www.slkormicro.com
4
Millimeters
Min
TYP
Max
A
1.00
1.20
1.40
A1
0.10
A2
1.00
1.15
1.30
b
0.35
0.40
0.50
c
0.10
0.15
0.20
D
2.70
2.90
3.10
E
2.40
2.60
2.80
E1
1.40
1.50
1.60
e
0.85
1.00
1.15
e1
1.80
1.90
2.00
L1
0.40
q
0°
5°
10°
S
0.45
0.50
0.55
很抱歉,暂时无法提供与“SLSOT05C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28739
- 100+0.23426
- 300+0.20758
- 3000+0.16805
- 6000+0.15207
- 9000+0.14408
- 国内价格
- 20+0.26344
- 300+0.19028
- 1200+0.18743
- 3000+0.15404
