Ru.
DATA SHEET
SURFACE-MOUNT CERAMIC
EMI FILTER CAPACITORS
X2Y® Series
Product Specification – Nov. 10, 2008 V.13
6.3 V TO 100 V
Phycomp
Product specification
Surface-mount ceramic
EMI filter capacitors
X2Y® Series
DESCRIPTION
X2Y® series is a breakthrough in the design of ceramic multilayer products for decoupling and filtering in an IPD
(integrated passive device).
X2Y® products comprise two identical Y-capacitors and one X-capacitor, integrated into a 4 terminal device, which is
available in standard MLCC sizes. Thanks to the unique multilayer construction the device provides noise cancellation
within the device, reducing ESL from nanohenry to picohenry levels.
Using the unique balance between the Y-capacitors and the shielded multilayer structure the X2Y® products offer
superior decoupling and filtering.
The X2Y® device performs as a broadband filter enabling better EMC compliance for electrical equipment in a wide
range of applications.
FEATURES
BENEFITS
• Broadband Filtering and Decoupling: X2Y® is
effective up to 10 GHz and frequencies beyond
• Fewer Component in Filtering: One X2Y® can
replace multiple inductors and/or capacitors
• Ultra Low ESL: Noise cancellation within X2Y®
makes ESL reducing from nanohenry to picohenry
levels
• Superior Performance in Filtering: One X2Y® can
eliminate both differential and common mode noises
• Bypass: Unlike feedthrough capacitors, X2Y® is in
bypass, so no DC current limitations
• Fewer Component in Decoupling: Up to 1:7
replacement of MLCC in power delivering system
bypass networks
• Matched Y-caps: Two tightly matched line to ground
capacitors in one device
• Superior Performance in Decoupling: Large or
small, X2Y® components exhibit ultra low ESL
• Superior Balance: Temperature and voltage
variations balanced of two Y-caps
• Total Cost Savings: Assembly cost savings through
reduced component count and placement costs
• Aging Reliability: Aging effects are equal on two Ycaps
• Board Level Design Advantages: Dramatically
reduces via drills, which blocks routing
APPLICATIONS
• EMI filtering on DC motors
• Filtered connectors (airbag
connectors, RJ-45 connectors)
SCM049_V
• High speed data-line filtering
• Decoupling of supply-lines in high
speed digital circuits
• Broadband filtering.
• Amplifier decoupling and EMI
suppression.
• IC Decoupling, on-package, onPCB.
A
A
G1
A
G2
G2
G2
G1
B
B
B
Decoupling application
G1
EMI filtering application
• DC power line filtering.
Fig.1
• Data line filtering.
Circuit of typical applications
• EMI suppression for DC motors.
• Sensors
• Audio
2008 Nov. 10 V.13
2
www.yageo.com
Phycomp
X2Y® Series
QUICK REFERENCE DATA
DESCRIPTION
VALUE
Materials
NPO / X7R / X5R
Rated voltage
NPO
50 / 63 V
X7R
10 V, 16 V, 25 V, 50 / 63 V, 100 V (IEC)
X5R
6.3 V, 10V
Capacitance range (Y-capacitor)
NPO
0805 series
22 pF, 47 pF
X7R
0603 series
1.0 nF to 100 nF
0805 series
4.7 nF to 180 nF
1206 series
15 nF to 820 nF
1210 series
47 nF to 1 µF
1410 series
390 nF
0603 series
220 nF to 470 nF
X5R
Tolerance on capacitance
±20% (M)
Test voltage (DC) for 1 minute
2.5 × Ur
Sectional specifications
IEC 60384-10, second edition 1989-04; also based on
CECC 32 100
Detailed specification
based on IEC 60384-10-1
Climatic category (IEC 60068)
X7R: 55 / 125 / 56
2008 Nov. 10 V.13
3
www.yageo.com
Phycomp
X2Y® Series
GENERAL SELECTION CHART
C
(pF)
NPO
0805
X7R
0603
0805
1206
X5R
1210
1410
0603
10
22
47
50 V
100
220
330
1,000
1, 500
2, 200
100 V
4, 700
5, 600
10, 000
50 V / 63 V
15,000
18 ,000
25 V
22 ,000
180, 000
100 V
16 V
50 V / 63 V
16 V
56 ,000
100, 000
50 V / 63 V
25 V
39 ,000
47 ,000
100 V
10 V
10 V
25 V
220, 000
270, 000
50 V / 63 V
10 V
16 V
330, 000
390, 000
25 V
470, 000
50 V
6.3 V
10 V
560, 000
820, 000
16 V
1 000, 000
2008 Nov. 10 V.13
100 V
4
www.yageo.com
Phycomp
X2Y® Series
MECHANICAL DATA
L
SCM051
A
ground
W
equivalent circuit configuration
line
line
Cy
C
ground
Cx
Cy
T
line
line
Component type
Simplified type
For dimensions see Table 1.
Fig.2. Component outline & simplified outline
Physical dimensions
Table 1
Capacitor dimensions
CASE SIZE
L
W
T
A
MIN.
MAX.
MIN.
MAX.
C
Dimensions in millimetres
0603
1.6 ±0.15
0.85 ±0.15
0.55
0.75
0.25
0.55
0.40 ±0.20
0805
2.0 ±0.15
1.25 ±0.15
0.75
0.95
0.25
0.55
0.70 ±0.20
1206
3.2 ±0.20
1.65 ±0.20
1.10
1.40
0.25
0.65
1.20 ±0.30
1210
3.2 ±0.20
2.5 ±0.20
1.10
1.70
0.25
0.65
1.20 ±0.30
1410
3.56 ±0.20
2.5 ±0.20
1.10
1.50
0.25
0.65
1.20 ±0.30
Dimensions in inches
0603
0.063 ±0.006
0.032 ±0.006
0.022
0.030
0.010
0.022
0.016 ±0.008
0805
0.079 ±0.006
0.049 ±0.006
0.030
0.037
0.010
0.022
0.028 ±0.008
1206
0.126 ±0.008
0.065 ±0.008
0.043
0.055
0.010
0.026
0.047 ±0.012
1210
0.126 ±0.008
0.098 ±0.008
0.043
0.067
0.010
0.026
0.047 ±0.012
1410
0.140 ±0.008
0.098 ±0.008
0.043
0.059
0.010
0.026
0.047 ±0.012
2008 Nov. 10 V.13
5
www.yageo.com
Phycomp
X2Y® Series
ELECTRICAL CHARACTERISTICS FOR NPO
Class 1 capacitors; NPO dielectric; NiSn terminations
VALUE
DESCRIPTION
Rated voltage Ur (DC)
50 V
Capacitance range
22 pF, 47pF
Capacitance tolerance
±20%
Tanδ; note 1
≤ 10 x 10-4
Insulation resistance after 1 minute at Ur (DC)
Rins > 10 GΩ
Temperature Coefficient
(0 ± 30) x 10-6 / K
Note
1.
Measured at 20 °C, 1 V and 1 MHz, using a four-gauge method.
ELECTRICAL CHARACTERISTICS FOR X7R / X5R
Class 2 capacitors; X7R / X5R dielectric; NiSn terminations
Unless otherwise stated all electrical values apply at an ambient temperature of 20 ±1 °C, an atmospheric pressure of
86 to 106 kPa, and a relative humidity of 63 to 67%.
VALUE
DESCRIPTION
6.3 V, 10 V, 16 V, 25 V, 50 V/63 V and 100 V
Capacitance range
1.0 nF to 1 µF
Tolerance on capacitance after 1,000 hours
±20%
Dissipation factor (D.F.); note 1
6.3 V
7%
10 V
7%
16 V
7%
≥ 25 V
5%
Rins × C > 500 seconds or Rins > 10 GΩ, whichever
is less
Maximum capacitance change as a function of temperature
±15%
Operating temperature range:
X5R
–55 °C to +85 °C
X7R
–55 °C to +125 °C
Aging
Typical 1% per time decade
Note
1.
Measured at 20 °C, 1 V and 1 kHz, using a four-gauge method.
2008 Nov. 10 V.13
6
www.yageo.com
Phycomp
X2Y® Series
SELECTION CHART FOR X7R SIZES 0603, 0805, 1206, 1410 (1)
Y-CAPACITOR
X-CAPACITOR
THICKNESS
(mm)
CTC ORDERING CODE
200
0.60
CX 0603 MR X7R 0BB 102
0.75
200
0.60
CX 0603 MR X7R 0BB 152
100
1.1
200
0.60
CX 0603 MR X7R 0BB 222
4.7
100
2.4
200
0.60
CX 0603 MR X7R 0BB 472
5.6
50 / 63
2.8
100
0.60
CX 0603 MR X7R 9BB 562
10
50 / 63
5
100
0.60
CX 0603 MR X7R 9BB 103
22
25
11
50
0.60
CX 0603 MR X7R 8BB 223
47
16
24
25
0.60
CX 0603 MR X7R 7BB 473
56
16
28
25
0.60
CX 0603 MR X7R 7BB 563
100
10
50
16
0.60
CX 0603 MR X7R 6BB 104
4.7
100
2.4
200
0.85
CX 0805 MR X7R 0BB 472
10
100
5
200
0.85
CX 0805 MR X7R 0BB 103
15
50 / 63
8
100
0.85
CX 0805 MR X7R 9BB 153
18
50 / 63
9
100
0.85
CX 0805 MR X7R 9BB 183
22
25
11
50
0.85
CX 0805 MR X7R 8BB 223
39
25
0.85
CX 0805 MR X7R 8BB 393
47
16
24
25
0.85
CX 0805 MR X7R 7BB 473
100
16
50
25
0.85
CX 0805 MR X7R 7BB 104
180
10
90
16
0.85
CX 0805 MR X7R 6BB 184
22
100
11
200
1.20
CX 1206 MK X7R 0BB 223
47
50 / 63
24
100
1.20
CX 1206 MK X7R 9BB 473
100
50 / 63
50
100
1.20
CX 1206 MK X7R 9BB 104
180
25
90
50
1.20
CX 1206 MK X7R 8BB 184
220
16
110
25
1.20
CX 1206 MK X7R 7BB 224
390
16
195
25
1.20
CX 1206 MK X7R 7BB 394
470
10
235
CX 1206 MK X7R 6BB 474
820
10
410
CX 1206 MK X7R 6BB 824
47
100
24
200
1.20
CX 1210 MK X7R 0BB 473
100
50/63
50
100
1.20
CX 1210 MK X7R 9BB 104
220
50/63
110
100
1.60
CX 1210 MK X7R 9BB 224
470
25
235
50
1.60
CX 1210 MK X7R 8BB 474
560
25
280
50
1.60
CX 1210 MK X7R 8BB 564
820
16
410
25
1.60
CX 1210 MK X7R 7BB 824
1000
16
500
25
1.60
CX 1210 MK X7R 7BB 105
390
50
195
100
1.30
CX 1410 MK X7R 9BB 394
SIZE
CAP.
(nF)
VOLTAGE
RATING (V)
CAP.
(nF)
VOLTAGE
RATING (V)
0603
1.0
100
0.5
1.5
100
2.2
0805
1206
1210
1410
2008 Nov. 10 V.13
7
(2)
www.yageo.com
Phycomp
X2Y® Series
SELECTION CHART FOR X5R SIZES 0603 (1)
Y-CAPACITOR
X-CAPACITOR
SIZE
CAP.
(nF)
VOLTAGE
RATING
(V)
CAP.
(nF)
VOLTAGE
RATING
(V)
THICKNESS
(mm)
CTC ORDERING CODE
0603
220
10
110
CX 0603 MR X5R 6BB 224
330
10
165
CX 0603 MR X5R 6BB 334
470
6.3
235
12
0.60
CX 0603 MR X5R 5BB 474
(2)
Notes
1.
Other values are available on request.
2.
Ordering codes for preferred versions (20% tolerance, 180 mm reel). For other packing and tolerance see section
“Ordering Code Information”.
SELECTION CHART FOR NPO SIZES 0805 (1)
Y-CAPACITOR
X-CAPACITOR
SIZE
CAP.
(nF)
VOLTAGE
RATING
(V)
CAP.
(nF)
VOLTAGE
RATING
(V)
THICKNESS
(mm)
CTC ORDERING CODE
0805
0.022
50
0.011
100
0.85
CX 0805 MR NPO 9BB 220
0.047
50
0.023
100
0.85
CX 0805 MR NPO 9BB 470
(2)
Notes
1.
2.
THICKNESS CLASSIFICATION AND PACKING QUANTITIES FOR X7R
QUANTITY PER REEL
THICKNESS
CLASSIFICATION
(mm)
8 mm TAPE WIDTH
Ø180 mm; 7"
PAPER
BLISTER
0.6 ±0.1
4,000
0.85 ±0.1
4,000
1.2 ±0.15
2,500
1.6 ±0.15
2,500
1.9 ±0.2
2,500
2008 Nov. 10 V.13
8
www.yageo.com
Phycomp
X2Y® Series
ORDERING INFORMATION
Components may be ordered by using either a Yageo part number or Phycomp’s unique 12NC.
Ordering code: Yageo part number
Example: CX0805MRX7R8BB223
CX
0805
M
X7R
R
8
B
B
223
Code 1 - 2
Code 7
Code 9 - 11
Code 13
Code 15 - 17
Series name
Capacitance
tolerance
TC Material
Termination
Capacitance value
CX = X2Y® series
M = ±20%
X7R
X5R
NP0
B = Ni-Barrier
Code 3 - 6
Code 8
Code 12
Code 14
Size code
Packing style
Rated voltage
Process code
R = Paper tape reel ∅ 7 inch
K = Embossed plastic tape
reel ∅ 7 inch
5 = 6.3 V
6 = 10 V
7 = 16 V
8 = 25 V
9 = 50 V
0 = 100 V
B = BME
EIA
0603
0805
1206
1210
1410
1812
mm
(1608M)
(2012M)
(3216M)
(3225M)
(3625M)
(4632M)
2008 Nov. 10 V.13
(2 significant digits +
number of zeros; the
third digit signifies the
multiplying factor, and
letter R is decimal point)
0=x1
1 = x 10
2 = x 102
3 = x 103
4 = x 104
5 = x 105
6 = x 106
SCM045
9
www.yageo.com
Phycomp
Table 2
TC
X2Y® Series
Conversion table for Yageo part number
SIZE
CAP.
VALUE
CAP.
TOLERANCE
RATED VOLTAGE (V)
Y-CAP
Y-CAP
Y-CAP
CTC
ORDERING
CODE
QUANTITY
PER
REEL
X7R
0603
1.0 nF
±20%
100
4,000
X7R
0603
1.5 nF
±20%
100
4,000
X7R
0603
2.2 nF
±20%
100
4,000
X7R
0603
4.7 nF
±20%
100
4,000
X7R
0603
5.6 nF
±20%
50 / 63
4,000
X7R
0603
10 nF
±20%
50 / 63
4,000
X7R
0603
22 nF
±20%
25
4,000
X7R
0603
47 nF
±20%
16
4,000
X7R
0603
56 nF
±20%
16
4,000
X7R
0603
100 nF
±20%
10
4,000
X7R
0805
4.7 nF
±20%
100
4,000
X7R
0805
10 nF
±20%
100
4,000
X7R
0805
15 nF
±20%
50 / 63
4,000
X7R
0805
18 nF
±20%
50 / 63
4,000
X7R
0805
22 nF
±20%
25
4,000
X7R
0805
39 nF
±20%
25
4,000
X7R
0805
47 nF
±20%
16
4,000
X7R
0805
100 nF
±20%
16
4,000
X7R
0805
180 nF
±20%
10
4,000
X7R
1206
22 nF
±20%
100
2,500
X7R
1206
47 nF
±20%
50 / 63
2,500
X7R
1206
100 nF
±20%
50 / 63
2,500
X7R
1206
180 nF
±20%
25
2,500
X7R
1206
220 nF
±20%
16
2,500
X7R
1206
390 nF
±20%
16
2,500
X7R
1206
470 nF
±20%
10
2,500
X7R
1206
820 nF
±20%
10
2,500
X7R
1210
47 nF
±20%
100
2,500
X7R
1210
100 nF
±20%
50 / 63
2,500
X7R
1210
220 nF
±20%
50 / 63
2,500
X7R
1210
470 nF
±20%
25
2,500
X7R
1210
560 nF
±20%
25
2,500
X7R
1210
820 nF
±20%
16
2,500
X7R
1210
1 µF
±20%
16
2,500
X7R
1410
390 nF
±20%
50
CX 0603 MR X5R 9BB 394
2,500
2008 Nov. 10 V.13
10
www.yageo.com
Phycomp
Table 2
TC
X2Y® Series
SIZE
CAP.
VALUE
CAP.
TOLERANCE
RATED VOLTAGE (V)
Y-CAP
Y-CAP
Y-CAP
CTC
ORDERING
CODE
QUANTITY
PER
REEL
X5R
0603
220 nF
±20%
10
4,000
X5R
0603
330 nF
±20%
10
4,000
X5R
0603
470 nF
±20%
6.3
4,000
NPO
0805
22 pF
±20%
50
4,000
NPO
0805
47 pF
±20%
50
4,000
RECOMMENDED DIMENSIONS OF SOLDER LANDS
Table 3
Reflow soldering
Footprint dimensions
(mm)
A
B
C
D
E
Placement
Accuracy
(mm)
0603
2.30
0.76
0.64
0.51
1.52
±0.20
0805
3.05
1.27
0.89
0.56
2.03
±0.20
1206
4.06
1.65
1.00
1.02
3.05
±0.25
1210
4.57
2.55
1.00
1.14
4.06
±0.25
1410
4.57
2.55
1.00
1.14
4.06
±0.25
CASE SIZE
(EIA)
A
D
C
E
B
HBK085
Fig.3
2008 Nov. 10 V.13
Recommended dimensions of solder lands
11
www.yageo.com
Phycomp
X2Y® Series
MEASUREMENT SETUP
network analyzer
SCM048
19.2
A
0.8
B
1.6
0.8
G2
G1
B
A
SCM046
12.55
12.55
25.6
Via
Fig.4
X2Y® series through measurement
Ground plane
50 Ω microstrip line
with CPW design method
X2Y® are soldered on a printed circuit board
PCB: FR-4 substrate, with 50 Ω microstrip line
Network Analyzer: Agilent E5071b
Size 0603: A=0.5 mm, B=1.2 mm
Calibration: full 2-port calibration with 85033E kit
For other dimensions see Table 4
Fig.5
Table 4
2008 Nov. 10 V.13
12
Testing board for measurement
Recommended dimensions of measurement
CASE SIZE
A (mm)
B (mm)
0603
0.5 ±0.10
1.2 ±0.10
0805
0.8 ±0.10
1.6 ±0.10
1206
1.2 ±0.10
2.8 ±0.15
1210
2.1 ±0.15
2.8 ±0.15
1410
2.1 ±0.15
3.1 ±0.15
www.yageo.com
Phycomp
X2Y® Series
TESTS AND REQUIREMENTS
Table 5
Test procedures and requirements
TEST METHOD
IEC60384-21/22
TEST
PROCEDURE
REQUIREMENTS
4.3
mounting
The capacitors may be mounted on printedcircuit boards or ceramic substrates
no visible damage
4.4
visual inspection
and dimension
check
any applicable method using ×10
magnification
in accordance with
specification
4.5.1
capacitance
NP0:
within specified tolerance
f = 1 MHz for C ≤ 1 nF, measuring at
voltage 1 Vrms at 20 °C;
f = 1 KHz for C > 1 nF, measuring at voltage
1 Vrms at 20 °C
X5R/X7R/Y5V:
f = 1 KHz for C ≤ 10 µF, measuring at
4.5.2
Dissipation factor
(D.F.)
NP0:
in accordance with
specifications
1 Vrms at 20 °C
X5R/X7R/Y5V:
4.5.3
insulation
resistance
at Ur (DC) for 1 minute
in accordance with
specification
4.5.4.2
voltage proof
Test voltage (DC) applied for 1 minute
Ur ≤ 100 V: 2.5 × Ur applied to
NP0/X5R/X7R/Y5V series
100 V < Ur ≤ 200 V: 1.5 × Ur + 100 V
applied to NP0/X7R series
200 V < Ur ≤ 500 V: 1.3 × Ur + 100 V
Ur > 500 V: 1.3 × Ur applied to NP0/X7R
series
no breakdown or flashover
I: 7.5 mA
2008 Nov. 10 V.13
13
www.yageo.com
Phycomp
Table 5
X2Y® Series
Test procedures and requirements (continued)
TEST METHOD
IEC 60384-21/22
4.6
TEST
temperature
characteristic
PROCEDURE
Between minimum and maximum
temperature
REQUIREMENTS
NP0: ΔC/C: ±30 ppm/°C
X5R/X7R: ΔC/C: ±15%
Y5V: ΔC/C: +22% ~ −82%
4.15
adhesion
A force applied for 10 seconds to the line
joining the terminations and in a plane
parallel to the substrate
no visible damage
for size ≥ 0603: a force of 5 N applied
for size 0402: a force of 2.5 N applied
for size 0201: a force of 1 N applied
4.8
bond strength
of plating on
end face
Mounting in accordance with IEC 60384-22
paragraph 4.3
no visible damage
Conditions: bending 1 mm at a rate of 1
mm/s, radius jig 340 mm
NP0: lΔC/Cl: ≤ 1% or 0.5 pF
whichever is greater
X5R/X7R/Y5V: lΔC/Cl: ≤ 10%
4.9
Resistance to
soldering heat
Precondition: 150 +0/−10 °C for 1 hour,
then keep for 24 ±1 hours at room
temperature
Preheating: for size ≤ 1206: 120 to 150 °C
for 1 minute
Preheating: for size >1206: 100 to 120 °C
for 1 minute and 170 to 200 °C for 1 minute
X5R/X7R: lΔC/Cl: ≤ 10%
Y5V: lΔC/Cl: ≤ 20%
Recovery time: 24 ±2 hours
Unmounted chips completely immersed in
a solder bath at 235 ±5 °C
The termination shall be well
tinned
Dipping time: 10 ±0.5 seconds
Solderability
NP0: lΔC/Cl: ≤ 0.5% or 0.5
pF whichever is greater
D.F.: within initial specified
value
Rins: within initial specified
value
Solder bath temperature: 260 ±5 °C
4.10
tinned
Dipping time: 2 ±0.5 seconds
Depth of immersion: 10 mm
2008 Nov. 10 V.13
14
www.yageo.com
Phycomp
Table 5
X2Y® Series
TEST METHOD
IEC 60384-21/22
4.11
TEST
Rapid change
of temperature
PROCEDURE
Preconditioning;
No visual damage
150 +0/−10 °C for 1 hour, then keep for 24
±1 hours at room temperature
NP0: lΔC/Cl: ≤ 1% or 1 pF
5 cycles with following detail:
X5R/X7R: lΔC/Cl: ≤ 15%
30 minutes at lower category temperature;
Y5V: lΔC/Cl: ≤ 20%
30 minutes at upper category temperature
value
value
Recovery time 24 ±2 hours
4.13
Damp heat,
with Ur load
Initial measurements; after 150 +0/−10 °C for
1 hour, then keep for 24 ±1 hours at room
temperature
NP0: lΔC/Cl: ≤ 2% or 1 pF
Duration and conditions: 500 ±12 hours at
40 ±2 °C; 90 to 95% RH; Ur applied
Y5V: lΔC/Cl: ≤ 30%
Final measurement: perform a heat
treatment at 150 +0/−10 °C for 1 hour, final
measurements shall be carried out 24 ±1
hours after recovery at room temperature
without load
4.14
Endurance
Preconditioning;
temperature
Duration and conditions: 1,000 ±12 hours at
upper category temperature with 1.5 × Ur
voltage applied
without load
2008 Nov. 10 V.13
REQUIREMENTS
15
X5R/X7R: lΔC/Cl: ≤ 20%
NP0/X5R/X7R/Y5V: D.F.: 2
× initial value max.
NP0: Rins ≥ 2,500 MΩ or
Rins × Cr ≥ 25 seconds,
whichever is less
X5R/X7R/Y5V: Rins ≥ 500
MΩ or Rins × Cr ≥ 25
seconds, whichever is less
Y5V: lΔC/Cl: ≤ 30%
NP0: Rins ≥ 4,000 MΩ or
Rins × Cr ≥ 40 seconds,
whichever is less
X5R/X7R/Y5V: Rins ≥ 1,000
MΩ or Rins × Cr ≥ 50
www.yageo.com
Phycomp
X2Y® Series
REVISION HISTORY
Revision
Date
Change
Notification
Description
Rev.5
2001 Sep 25
- Published on web
Rev.6
2002 Jul 10
- Product range extended in all materials and sizes;
- Insertion loss measurements added.
Rev.7
2003 Apr 02
- Updated company logo
Rev.8
2003 Jul 23
- Cover page revised
Rev.9
2003 Sep 09
- Cover page corrected
Rev.10
2004 Apr 21
- Product range updated
- NP0, Y5V and size 1812 removed.
Rev.11
2006 Nov 21
- Size 1410 extended
- Product applications, features and benefits update
- Measurement setup added
- Updated tests and requirements
Rev.12
2006 Dec 22
- 12 NC revised
Rev.13
2008 Nov 10
- Product range extended in materials of NP0 and X5R
2008 Nov. 10 V.13
16
www.yageo.com
