MF0207FTE52-1K
MF0207FTE52-1K
    YAGEO(国巨)
    插件,D2.4xL6.3mm
    金属膜电阻 AXIAL_D2.4X6.3MM_TM 1KΩ ±1% 3/5W
MF0207FTE52-1K 数据手册
Through-hole resistors Professional Type Metal Film Resistors Miniature Style [ MF0 Series ] FEATURES Power Rating 0.4W, 0.6W Resistance Tolerance ±0.5%, ±1%, ±2%, ±5%, T.C.R. ±50ppm/°C, ±100ppm/°C DERATING CURVE For resistors operated in ambient temperatures above 70°C, power rating must be derated in accordance with the curve below. INTRODUCTION The MF0 Series Metal Film Professional Resistors are manufactured using a vacuum sputtering system to deposit multiple layers of mixed metal alloys and passivative materials onto a carefully treated high grade ceramic substrate. After a helical groove has been cut in the resistive layer, tinned connecting leads of electrolytic copper are welded to the end-caps. The resistors are coated with layers of blue color lacquer. 70 Rated Load (%) 155 °C 100 80 60 40 20 20 40 60 80 Ambient Temperature (°C) 100 120 140 160 DIMENSIONS Unit: mm ød H L øD STYLE DIMENSION Miniature L øD H ød MF0204 3.4±0.3 1.9±0.2 28±2.0 0.45±0.05 MF0207 6.3±0.5 2.4±0.2 28±2.0 0.55±0.05 9 Note: ELECTRICAL CHARACTERISTICS STYLE MF0204 MF0207 Power Rating at 70°C 0.4W 0.6W Maximum Working Voltage 250V 350V Maximum Overload Voltage 500V 700V Voltage Proof on Insulation 300V 500V Resistance Range 1Ω - 4M7Ω & 0Ω for E24 & E96 series value Operating Temp. Range -55°C to +155°C Temperature Coefficient ±50ppm/°C , ±100ppm/°C Note: Special value is available on request ENVIRONMENTAL CHARACTERISTICS PERFORMANCE TEST TEST METHOD APPRAISE Short Time Overload IEC 60115-1 4.13 2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage) ±0.25%+0.05Ω Voltage Proof on Insulation IEC 60115-1 4.7 In V-Block for 60 sec., test voltage as above table No Breakdown Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By type Insulation Resistance IEC 60115-1 4.6 in V-block for 60 Sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of Marking IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings and markings Robustness of Terminations IEC 60115-1 4.16 Direct load for 10 Sec. in the direction of the terminal leads ≥2.5kg (24.5N) Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off) ±1.0%+0.05Ω Damp Heat Steady State IEC 60115-1 4.24 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV ±1.5%+0.05Ω Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±1.5%+0.05Ω Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C  Room Temp. (5 cycles) ±0.75%+0.05Ω Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body ±0.25%+0.05Ω Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less. Revision: 2020
MF0207FTE52-1K 价格&库存
很抱歉,暂时无法提供与“MF0207FTE52-1K”相匹配的价格&库存,您可以联系我们找货
MF0207FTE52-1K
  • 1+0.886841+0.11375
  • 10+0.4594510+0.05893
  • 25+0.3816725+0.04896
  • 50+0.3357250+0.04306
  • 100+0.29512100+0.03786
  • 250+0.25131250+0.03224
  • 500+0.22338500+0.02865
  • 1000+0.199791000+0.02563
库存:53442
MF0207FTE52-1K
  • 50+0.17510
  • 500+0.14590
  • 1500+0.11670
  • 5000+0.09730
MF0207FTE52-1K
  • 50+0.09846
  • 1000+0.07956
  • 2000+0.06903
  • 5000+0.06021
库存:5000
MF0207FTE52-1K
  • 100+0.25830100+0.03320
  • 1300+0.254701300+0.03280
  • 2500+0.248702500+0.03200
库存:9700
